I’ve been looking for some time to have a security camera above the entry door.  Most wireless cameras are not wireless  they still need a power wire. I also didn’t want to drill holes and fish wiring though the hull.  Roaming around Walmart I spotted this back up camera by Whistler.
  The camera is totally wireless and once fully charged via USB it has built in solar to keep the battery maintained. The monitor is 4in and plugs into a 12v outlet. With a suction cup mount. Looking at the picture on the box it looked like it would be a perfect fit above the entry door. The purchase price was $100,00  I rolled the dice if it didn’t fit perfectly it was going back.  I did a Amazon check it appears this model is only sold at Walmart.  The reviews on the whistler models were mixed good and bad.  Once the camera was charged I turned on the monitor within seconds the picture appeared. Very nice color image it has inferred for night time haven’t try it yet. Very few features it is not a continuous on you can choose  20 sec to 120 sec on then auto off plenty of time to see who is outside your door. Also no audio or recording capability.  Simple setup no frills.
Mounting the camera I used Scotch outdoor heavy duty Velcro very secure. Very happy on the looks of the camera  attached to the hull above the door  it looks like a factory installed  option.  The Big question?? Will it last, does anything these days? It’s the $100.00 question. We shall see I'll give a review in 6 month’s the warranty is good for one year.  attached are the photos of the install.
  • Like 10
Wow, that is pretty cool. Can the camera itself be adjusted vertically?
Never mind, found a pic:
Wow - this camera has a transmission of over 300 feet (unobstructed).
Looks like you have both the clear glass AND a camera.  Nice setup.
I also see in the manual that that supports 2 cameras so you could put one on the other side as well.
  1. This system can support 2 cameras, select the camera you
    would like to pair. Camera 1 is the rear camera, Camera 2
    is the front camera.
Wow. just wow.
Hello, in order to attach the camera flat into the Ollie, did you removed the plate that goes to attach it if it would have been used on the license plate?
R2W
  • 7 months later...
@Landrover, I  was reminded of your camera install by a recent thread. How has it worked out for you? Do you leave it installed, or remove it from the velcro mount before getting underway?
The camera system has been working great the industrial Velcro maybe over kill I have to use a plastic wedge to get the Velcro to separate a little then it separates easy. Last trip was to Jacksonville for Foy’s get together.  No problems staying put on the road. The trailer is parked inside. Almost 3 months battery down to half charge. Simple usb charge to full within an hour. Still not sure if the solar on it charges the battery being inside most of the time.  I’d replace it with another if it fails. When or if they stop making them.  Every thing goes back to normal no holes to fix. 👍🏼👍🏼
  • 3 weeks later...
I received the Whistler WBU-800 yesterday. It seems to be working well. Still need to attach the camera where Landrover attached his, but I DID purchases it for much less-- $38.19--on ebay. Figured at that price I could take the chance. The only drawback I see now is that the monitor needs to be plugged into one of my Ollie's automobile auxiliary power outlets. I would like to be able to mount the monitor near the door, but it looks like my options will be limited to near where Landrover shows he has mounted his or on or near the dinette table.
Onward through the Fog!
EarthPicks of Cochise County
  I have my monitor mounted away from the door.  Part of long ago training you don’t want to be standing in a doorway if the bad guys are on the other side of the door. You want to be away from the doorway, there are more advantages this way. No I’m not paranoid  safety first 🤪🥸
31 minutes ago, Landrover said:
Wow great price. Send the link from eBay I’ll buy another one.
Looked for it, but couldn't find the same deal. Perhaps it was a unique offer. You should find some better prices than at Walmart by Googling the product name an ebay. I found this one with free shipping:
https://www.ebay.com/itm/294769160738?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D20200818141841%26meid%3D57f99accd4ae422f95ee9bbb0622968f%26pid%3D101111%26rk%3D3%26rkt%3D12%26sd%3D194789229617%26itm%3D294769160738%26pmt%3D1%26noa%3D0%26pg%3D2563228%26algv%3DThematicAlgo%26brand%3DWhistler&_trksid=p2563228.c101111.m2109&amdata=cksum%3A29476916073857f99accd4ae422f95ee9bbb0622968f|enc%3AAQAGAAAB8GZDTETOCfMqa6dzTjv6DKdLphDOsKxYbqvvZVtkhPOsNOEG8jon0%2F23nQGKxJ5xbV%2FgEUwuWC5erCt%2FcCuWDuUSiDxP8CF2je%2FthC2zJ5MUkf3VxYsQyp7MsaXvivyGR0H%2Fb5SvjHbo9EX%2Fm%2FsEk6Pil4YJ5GTRBXpxecoofzyre6o8k4sLTQdIMG8c03Ms4lv3pQk2MbjtoVa2hTjVIuIfWefROGcdQ5qS2O7bKeef0htAkwm6TVoiG5JT%2FzZak8yb%2F7b6JEazxxXj%2F3n7bU5cRXjBTkA1%2FhEDWysbBRjqBthbo8UgWBrvJVVDdr5Qut0TmuzVhFTxc1em%2BvPvrP3FDuZdvRk1T8HRmL%2FtjTov%2FV3HWJVdKrQ%2B2U22uA0wcByesbWEu5n7jWD%2BQuY4AXMQvLQNGcLBzr3JEEauLWQOQO%2FEhvYuWEL9JmjxyfIt4ghykn4vuM0HaX9i7MEwkI1dpFmKeIMQFC5iiKW8P5Hg51DdD5m4%2FDoDp%2FIDMn1%2BuCYzdubOM62fIf%2BjVPTb7PBfrGPgEffhzExt9SpYvPupg1aIVzJMzNgkPNFypi%2BSCF%2BAkvshAuYiHkBRIvBSkTHcJsFwIIALgj4NPK9rVPCn5rAyNjX9gfX4%2Fj0a3HDVxzb94kZNNTLUOIMBPCgSdXI%3D|ampid%3APL_CLK|clp%3A2563228&epid=26037447570
I understand this. Thanks. I DO have a question for you though: Do you think the adhesive on the back of the Scotch product you used to attach the camera above the entrance will harm the gel coating if and when the product is removed? I tried to find the product you displayed on Amazon. I found this, which looks similar but not exact, and I wonder if I will be damaging the gel coating with it:
 https://www.amazon.com/Scotch-Brand-RF6731-051131642546-California/dp/B001LTTNOI/ref=pd_ybh_a_1/142-3314510-9135725?pd_rd_w=RFqFE&pf_rd_p=45643f1d-9a87-41c0-924d-e7e382d48035&pf_rd_r=3BQVYSE5Q60P7BZSXA11&pd_rd_r=6f36f76d-1c98-4f88-9d0b-5a167fb8e43c&pd_rd_wg=ny85z&pd_rd_i=B001LTTNOI&th=1
What do you think?
What do you think?
Spike  I really can’t  answer that question I don’t know.  Maybe a call to Oliver can help. I’m sure if its left on for months/years maybe time will tell.  The Velcro I have is clear not that noticeable. A full strip of this Velcro is over kill. i plan on removing the strip off the Ollie and just attaching two small squares which should be more than enough to hold.  It’s only been a few months I don’t expect any damage to the gel coat .
  • 3 weeks later...
Landrover, did you remove the metal frame and flat mount it to the velcro or just metal frame to velcro?
I'm leaning toward removing the frame, but thought I'd check.
Remove the frame.
