Popular Post MAX Burner Posted March 24, 2023 Popular Post Posted March 24, 2023 After replacing the protective strip around the “dog house” LPG tank cover, I realized I ordered enough for the spare tire cover. So after removing the cover when accessing the tire, I can place it flat on any surface without dinging the edge on sharp rocks or debris. It may seal the compartment a bit better now also. 15 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Patriot Posted March 24, 2023 Posted March 24, 2023 4 hours ago, MAX Burner said: After replacing the protective strip around the “dog house” LPG tank cover, I realized I ordered enough for the spare tire cover. So after removing the cover when accessing the tire, I can place it flat on any surface without dinging the edge on sharp rocks or debris. It may seal the compartment a bit better now also. Nice job! Here is a where you can ordered the edging off Amazon. 😊I used this on the edge of the dog house aka propane tank hood as well. And decided to use it on the fiberglass edges of the twin beds. 4 5 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️Recent Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Stevon Posted March 24, 2023 Posted March 24, 2023 Did you use any adhesive with this or just a friction fit? 2021 Oliver Legacy Elite II Hull #845
Patriot Posted March 24, 2023 Posted March 24, 2023 Here are a few pics of the mod mentioned above - Dog house Edge of bed rails. 1 8 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️Recent Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
John E Davies Posted March 24, 2023 Posted March 24, 2023 MAX Burner - Nice job, neat and tidy. I guess Oliver has to skip small visual detail improvements due to cost and the extra labor involved. I protected my cover edges by wrapping the entire unit in stretch wrap, and storing it permanently on a garage shelf 😉 I love your shop floor. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Patriot Posted March 24, 2023 Posted March 24, 2023 9 minutes ago, Stevon said: Did you use any adhesive with this or just a friction fit? You won’t need adhesive, this trim grips extremely well. No issues with it coming loose at all. 5 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️Recent Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
John E Davies Posted March 24, 2023 Posted March 24, 2023 8 minutes ago, Stevon said: Did you use any adhesive with this or just a friction fit? This type of edging has a spiral steel spring inside, no glue needed unless the material being edged is too thin. John Davies Spokane WA 3 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
John and Debbie Posted March 24, 2023 Posted March 24, 2023 2 hours ago, Patriot said: You won’t need adhesive, this trim grips extremely well. No issues with it coming loose at all. How many linear feet did you use for the beds, dog house and spare tire cover? I am guessing something like 30 feet. Thanks. John John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Patriot Posted March 24, 2023 Posted March 24, 2023 2 hours ago, John Welte said: How many linear feet did you use for the beds, dog house and spare tire cover? I am guessing something like 30 feet. Thanks. John Hi John, It’s been awhile since I did this mod, I think I ordered 20 or 25’. I did not put this edging on the rear spare tire cover only the bed rail edges and dog house. It would seem that 30’ would get the job done. Partriot🇺🇸 2 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️Recent Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Cameron Posted March 25, 2023 Posted March 25, 2023 Immediately got on Amazon and ordered it. I love this forum. In addition to helping me fix problems I have, it teaches me about problems I didn't even know I have. Yea! 5 1 2021 Elite II #841, 2020 GMC Sierra 1500 AT4, 3.0 diesel
MAX Burner Posted March 28, 2023 Author Posted March 28, 2023 Yeah, this plastic edging treatment is very useful. Now that I've read Patriot's post, I wish I got more - I will anyway this stuff is cheap from Amazon. Totally a friction fit, FYI. Ollie On! 4 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
MAX Burner Posted March 28, 2023 Author Posted March 28, 2023 On 3/24/2023 at 5:21 PM, Patriot said: Here are a few pics of the mod mentioned above - Dog house Edge of bed rails. Patriot - just curious, what material are you using for the mattress vapor barrier? We are looking for something that really works well, haven't been successful yet. 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Galway Girl Posted March 29, 2023 Posted March 29, 2023 The product Oliver sells as an option is called Hypervent. We've had it for 3 years and it's keep our mattresses dry from any condensation. It's sold directly from HyperVent but you might be able to get it through Oliver Service. Not cheap - you'll need 14' to do 2 twin beds... ($189.00) https://www.hyperventonline.com Hypervent is only sold by phone. Call 206-783-1696 to Order. Genuine Hypervent is $13.50 per linear foot. 2 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Geronimo John Posted March 29, 2023 Posted March 29, 2023 13 hours ago, MAX Burner said: Yeah, this plastic edging treatment is very useful. Now that I've read Patriot's post, I wish I got more - I will anyway this stuff is cheap from Amazon. Totally a friction fit, FYI. Please do confirm the number of feet to do them all. Thanks GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Katjo Posted March 29, 2023 Posted March 29, 2023 I really like this mod! Thank you for sharing. 3 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Katjo Posted March 29, 2023 Posted March 29, 2023 I’ve been looking for something similar to this to put around the upper interior cabinets, I’ve gouged my fingers so many times on the fiberglass edge taking things in and out of the cabinets. I think this would be too thick for the doors to close??….. but I’m going to definitely grab some for around the bed rails, dog house and spare tire cover. 6 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
MAX Burner Posted March 29, 2023 Author Posted March 29, 2023 3 hours ago, Geronimo John said: Please do confirm the number of feet to do them all. Thanks GJ I ordered an initial 20 feet for the spare tire cover and only needed 13 feet for the job. The "dog house" LPG cover edging was in good repair, so I actually had enough for that if it was necessary. The bed edges (which is a brilliant idea on Patriot's part, IMHO) will take 12 feet to cover - I've ordered 10 more feet from Amazon. Hope that helps... 2 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
MAX Burner Posted March 29, 2023 Author Posted March 29, 2023 1 hour ago, Katjo said: I’ve been looking for something similar to this to put around the upper interior cabinets, I’ve gouged my fingers so many times on the fiberglass edge taking things in and out of the cabinets. I think this would be too thick for the doors to close??….. but I’m going to definitely grab some for around the bed rails, dog house and spare tire cover. Good idea, Katjo! I'm on travel now, when I get home this weekend, I'll check the cabinets to see if it might work there and let you know... 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Ollie-Haus Posted March 29, 2023 Posted March 29, 2023 8 hours ago, Katjo said: I’ve been looking for something similar to this to put around the upper interior cabinets, I’ve gouged my fingers so many times on the fiberglass edge taking things in and out of the cabinets. I think this would be too thick for the doors to close??….. but I’m going to definitely grab some for around the bed rails, dog house and spare tire cover. I don't know the exact type of tape that they use, but on fiberglass boats I've seen a cloth tape applied to the raw edges of fiberglass openings. It would need to have a substantial adhesive backing. I'm thinking possibly a fiberglass cloth tape. To find the right thing may be a trial and error process. Quick search found this. It's not cloth but is designed to hold up to moisture exposure and permanent use. https://www.amazon.com/Adhesive-Decorative-Sealant-Bathroom-Protection/dp/B0BC4NL2XJ/ref=sr_1_70_sspa?crid=3QUZHKFMEOTNV&keywords=edge%2Btape&qid=1680097392&s=industrial&sprefix=edge%2Btape%2Cindustrial%2C96&sr=1-70-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExQUEwQzNZWDdBVkFQJmVuY3J5cHRlZElkPUEwNTU4NTIyM04xMjFYVFI4Qkw5TiZlbmNyeXB0ZWRBZElkPUEwODgyMTg5MlkzV0lZS0UzNEpXOCZ3aWRnZXROYW1lPXNwX2J0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1 4 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23
Katjo Posted March 30, 2023 Posted March 30, 2023 On 3/29/2023 at 2:28 AM, MAX Burner said: Good idea, Katjo! I'm on travel now, when I get home this weekend, I'll check the cabinets to see if it might work there and let you know... That will be great, thank you! 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Katjo Posted March 30, 2023 Posted March 30, 2023 On 3/29/2023 at 9:47 AM, Ollie-Haus said: I don't know the exact type of tape that they use, but on fiberglass boats I've seen a cloth tape applied to the raw edges of fiberglass openings. It would need to have a substantial adhesive backing. I'm thinking possibly a fiberglass cloth tape. To find the right thing may be a trial and error process. Quick search found this. It's not cloth but is designed to hold up to moisture exposure and permanent use. https://www.amazon.com/Adhesive-Decorative-Sealant-Bathroom-Protection/dp/B0BC4NL2XJ/ref=sr_1_70_sspa?crid=3QUZHKFMEOTNV&keywords=edge%2Btape&qid=1680097392&s=industrial&sprefix=edge%2Btape%2Cindustrial%2C96&sr=1-70-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExQUEwQzNZWDdBVkFQJmVuY3J5cHRlZElkPUEwNTU4NTIyM04xMjFYVFI4Qkw5TiZlbmNyeXB0ZWRBZElkPUEwODgyMTg5MlkzV0lZS0UzNEpXOCZ3aWRnZXROYW1lPXNwX2J0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1 That’s a good idea. It does have to be thin like this so it might work. Thank you 2 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
MAX Burner Posted April 5, 2023 Author Posted April 5, 2023 On 3/29/2023 at 12:28 AM, MAX Burner said: Good idea, Katjo! I'm on travel now, when I get home this weekend, I'll check the cabinets to see if it might work there and let you know... KATJO: See pic below. The edge guard would totally work for your application. The cabinet door closes without obstruction. You may need to heat up the edge guard material with a heathen to make it easier to go around the corners. Good luck - post pix of your upgrade! Cheers, Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
CnC Posted April 5, 2023 Posted April 5, 2023 The protective tape Oliver uses around the pantry edges would be a good choice - haven't looked for it but I bet it's available on Amazon. Charlie. 4 Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4
