Hi everyone, I just joined the forum and wanted to introduce myself. I’ve been interested in travel trailers and RV systems for a while and recently started learning more about the technical side of things, especially electrical setups, batteries, and solar systems. I don’t own an Oliver yet, but I’ve been researching different trailer options and the Oliver models caught my attention because of their fiberglass construction and overall build quality. I’m also really interested in how people are setting up lithium batteries, solar charging, and energy management for off-grid camping. There seems to be a lot of great knowledge in this community, so I’m looking forward to learning from everyone here. Thanks for having me and I’m excited to be part of the forum.
molin joined the community
Inspectable Item: Propane Area
Ollie-Haus replied to Wayfinder's topic in Mechanical & Technical Tips
The female side is 1/4 tapered. This allows reusing the straight adapter that was originally on the regulator. These adapter fittings have a check valve built in which needs to be included in the assembly. 👍 -
You could try Gorilla Clear Grip. It’s a clear, flexible, fast drying adhesive, nothing like original Gorilla Glue, or RTV silicone. It works like a contact cement. You put a thin layer on both surfaces, let dry for a few minutes, then stick it on. No need to clamp or hold it for more than a few seconds. I buy it at Home Depot, use it around the house for special projects. .https://gorillatough.com/product/gorilla-clear-grip
John Dorrer replied to Wayfinder's topic in Mechanical & Technical Tips
I think it was placed inside the bumper to keep it out of harms way. My hoses aren't in the way. I know of at least 2-3 owners that caught road debris and ripped the front quick connect off. One person had their propane on and emptied their tank. Oliver could place a round port and mount it inside the propane housing. - Yesterday
Each shade weighs about 3 oz. and there is over 3 square inches of total contact area, 1/2" around the perimeter, 4 1/2" diameter. I was hoping for something I could apply and press on without a support stand and there is no way to use a clamp. Rubber cement can drip and get messy and would need to be held in place for some time to get tacky. But thanks for helping! VHB tape would be overkill and wasteful to trim around the circular shades. Where are all you guys who glue on mounting boards for your electronics? There must be a good product for this!
Nice mod. A question about the elbows: You indicate they are 'street', are these 1/4" female NPT or 1/4" inverted flare on the input (pigtail) side? Thanks Tim
When I replaced my factory D35 axles with D52's last year, the brake wiring was an option. Based on other OTTO experience’s repairing the brake wiring inside the axles, I chose pigtails for each hub and used hose clamps to attach PVC conduit to the axle and ran the wiring through the conduit. Was that the right thing to do? Time will tell! Mossey
With lithium batteries and adequate solar, you should be able to last essentially for years.
Darlene and MichaelB joined the community
Jolli Olli is hiding in the coastal fog at Galveston Island SP. 4'+/- Male Western Diamondback along the boardwalk to the beach. A bit too close for comfort.
Unfortunately the awnings you describe are found on large trailers, Class A Motor Coaches and 5th Wheels. Those have large exposed frames and arms and wouldn't work on an Oliver. So with that said the awning for small trailers aren't designed to be out in winds or rain. They are designed for providing shade. You would be better off getting a stand alone canopy with option for sides, or something like the picture. I think it would be a big mistake to remove your Girard awning. The Girard is a top of the line awning, and resale value would be lost
Chris, spot on with your response. We don't regret getting the regular toilet, but your comments may have given us a different perspective 😊
We enjoyed our stay at Clear Spring, but we like to stay clear of I-30 and I-40. We usually head to Texas down through TN, MS, LA, into Texas, spending some time on the Natchez Trace Parkway.
You might want to take a look here too. I have seen some really good deals on preowned late model Olivers that could save you a substantial amount of money. This link may or may not work depending on whether or not you have a FB account. https://www.facebook.com/groups/OliverforSale
The standard plastic & aluminum mounts that came with it. They attach with a 3M VHB disc. Seem very secure, but not very attractive. I bought the optional aluminum mounts with 3M VHB, but haven’t used them yet.
Made in USA leaf springs
I recall they are: D35 Axles have 10 X 2.5" shoes. D52 Axles have 12" X 2" shoe. Both magnets sets pull a nominal 3 amps each. Wiring per above is the same (Run thru the axle) GJ -
I will second the compost toilet choice. Never wait in line at a dump station, never waist a single gallon of fresh water flushing the toilet. With only 32 gallons of fresh water you can extend your dry camping significantly by economizing your fresh water. In the same line of thinking, getting the big lithium package empowers you to dry camp in complete silence for extended periods, and even use your AC for short periods before bedtime and replenish the batteries with the solar if you have good sun exposure. At the annual rally every year, there’s always a few people that ask the question, “ how hard/expensive is it to upgrade from AGM to the Lithium package”, and every year Jason has to explain it’s much more expensive then ordering it up front and quite involved. The entire electrical system, excluding the house wiring, has to be changed out. It can be done, and it can be DIY’d later for less, but the integrated system from the factory functions very well, and the components are premium quality. Second awning? I don’t think it’s worth the price for what it’ll get used for. Good luck with your decision, I think you’ll be very happy own an Oliver for your traveling future. Take the factory tour for sure!👍
We arrived in Hohenwald this evening for our appointment to get our battery box fixed. We’re the only ones here in the campground, so I hope that means our trailer will get their full attention tomorrow! We stayed at Clear Springs COE campground on Wright Patman Lake just outside of Texarkana on the Texas side last night. We’ve stayed there many times, it’s about a days drive from San Antonio, a good stop over when heading east. Here we are at the Oliver campground. We have it all to ourselves.
- Last week
Either get the factory rearview camera or plan on installing one soon after purchase. The second shore power inlet and second propane outlet can be very useful if you plan on doing a bunch of cooking outside, camping at places that have electric hookups and/or plan on a generator. There is an old saying - "always give the man a chance to say no". In the case of the Oliver, that would mean that you should negotiate your best price and then ask for a little help (discount) off that price. In any case I would not expect anything more than 1 or 2 grand discount. Or, perhaps you could ask for them to sweeten the deal with something that caught your eye on the sales floor - camping rug, grill, chairs, fire pit, etc.. Perhaps Oliver has a floor model that comes close to what you are looking for and they might be interested in making you a "deal" on that one. It never hurts to ask. Good luck! Bill
I've had my pre-owned Elite II (2016) since 2021. And I interact with many other Oliver owners at rallies, such as Oliver rallies as well as general "egg" rallies, fiberglass rallies. Those are the best! I don't have much in the ways of upgraded electronics, but here is what I "think" I know. Maybe someone else will agree or not. From what I've heard, hardly anyone stays with the heavy, low-powered AGM batteries. Which I do have even today. I would recommend at least going up the 390AH lithium batteries, which will include the 3000 Watt Inverter. I would think, but not sure, it would make for an easier upgrade path in the future to larger lithiums if needed. I also do not have a compost toilet, but would like one by default, but also not worth my time and money to convert what I have. If NOT storing the camper inside or under cover, consider not having the "bulb seals" installed under the awning housing. They trap too much tree junk and makes it much more difficult to clean the roof. They can always be added later if you don't like a little rain dribble coming down the sides of the camper. If you think you'll do a good bit of desert camping, I would get the extra awning, otherwise, save the weight & money and any other hassles that may come with more electronic equipment. These is only my opinions. Like ears, we all have them. LOL Good luck. P.S. No matter what you order, it will be the best trailer you can purchase. Just remember, it's still an earthquake on four wheels with all standard RV parts & components. Things will break, but you'll seldom ever need to worry about the frame or body falling apart or leaking. Also this site will be your best bet for quick answers and how-tos.
Thanks guys. I sort of suspected as much. But was wishing the other way. GJ -
We like our composting toilet. It is not maintenance free but certainly prefer it over the limitations of the small black tank. We do have the upgraded batteries and can go a good week or more with batteries and solar (but no ac). We do not have the second awning and for the locations where we camp, we are glad we didn't pay extra for it. In fact, we use our curbside awning only about half the time and only fully extended in the middle of the summer. Personally, I liked buying directly from the factory and staying overnight in their campsites to learn and check out. I wish we had spent a second night there because there were issues we later discovered that could have been corrected right then and there at the factory.
Dexter pre-wires the brake wires inside the axel. Oliver only connects their wiring to the Dexter wiring. -
So for those ordering straight from the factory, there are no negotiations and everyone pays the exact same price? I'm planning on the LE2 Platinum twin configuration. I'm considering the composting toilet. I think the only other options would be the second awning and upgraded batteries, both of which I'm not planning to add. Anything else I should know before purchasing?
Which connection anchors did you use..for the side of the trailer mount? CS
I wonder why no one is talking about the new board available ... that fix this issue
