  1. Today
  2. You'll likely not be able to get it fixed in the shop. As soon as the middle shackle flips up, the other end will flip down. You can go back and forth like this for hours if you're enjoying the frustration. Just leave it alone until you're ready to travel in November. I won't hurt it to sit that way. Pull it over a 6 inch curb, listen for the bang and move on.
  3. Looks like a battery-operated Leaf Blower. I have a Dewalt model along with us on every trip! Blow the dirt of the vehicles after washboard roads, get the dirt, the pine needles and dog hair off the camping mat... Gotta have one! 🤣
  4. I'm looking forward to a test drive, sometime next year. We've loved our 2008 Dodge Ram. But, It's getting a bit long in the tooth, approaching 300k miles. The simplicity of the new hybrid design is indeed intriguing.
  5. What is the tool you are using in the last picture?
  6. Yesterday
  7. My stove one is acting exactly like your sink one. My sink one was acting up, but it seems to be fine now. I don't use the other touch lights very much. Thanks for the link. Those seem to be the very thing I was looking for.
  8. See my longer post - you WON’T need a new hole for the switch! BTW - I don’t really like the light switch in the bathroom. I find it pops loose out of the hole easily.
  9. I replaced all of my lights this year. Got them on amazon, they are 5 inch with a switch along the bezel they are dimmable also.. not to tech savey no pics look them up.. they dont sit flush , but it’s pretty close. Ok for for my taste…. I had two touch lights replaced under warrenty.. didnt last to long.. Im very happy with the lights i installed.. Good luck.. OTT finally got rid of those lights .. went with the ones with a switch..
  10. We had an issue with the touch light over the sink. It started acting intermittent last season, and then pretty much stopped working. Then for some reason, it “sorta” worked, sometimes coming on when touched, other times not. Oddly, when it was “off”, it stayed on dimly all the time. It got to the point I’d have to shut off the lighting master. I just didn’t want a light kinda working, and perhaps doing something bad - like starting a fire. I ordered these lights from Amazon - thinking they were touch lights just as were already installed. https://a.co/d/cg5xSAf When I finally got around to doing the replacement a couple of weeks ago, I found they are NOT touch lights, having a physical switch in the same location in the center of the light as the factory installed lights do. They look pretty much the same, and the mounting holes are close enough that no new holes need to be drilled. You’ll need to drill out the three pop rivets holding the old light in place, and get a light duty pop rivet gun and the smallest rivers (1/16” I think) to install the new light. You’ll also have to pull out the rubbed rubber mat and thin plastic floor plate in the cabinet to access the wires. I used crimp-on butt splices to make the new connection. Though I intended to replace the defective light with another touch light, I think I’m happier with a real switch as it more likely cuts the power off completely when off - where a touch light has to always be energized to sense your touch. PS - I probably could have used the included sheet metal screws - or a bit longer ones - instead of pop rivets, as I don’t really like them that much.
  11. That's a feature, not a bug. Built in sauna/clothes dryer.
  12. Am I the only one having problems with the touch lights?
  13. Actually Gree, not Cree:
  14. We are happy to hear that you were all OK. We were staying a bit away from there in Bandera, in a park bordering the Medina River which also rose quite a bit, but to nowhere near a level that would have threatened us despite the campers in the lower section of the park being relocated to the upper section. It was and remains a very tragic event.
  15. That’s been one of my only complaints on our trailer. Why would they use black material top and bottom!? It’s like an oven underneath! Even having a reflective top would be a huge benefit.
  16. These 90+ degree days are brutally hot beneath the black fabric on the Girard awning. Googling/chatgpt reveals some options for different fabric colors. Has anyone tried a lighter color?? The main concern for me is the invitation to mildew/mold issues. I have no problems now...I think the temps on the black fabric has some effect. Any help is much appreciated. I plan to call Carefree of Colorado tomorrow and see what they have to say. Thanks, John
  17. Last week
  18. The unimaginable has once again, tragically, become a reality. A large number of those lost were children. I cannot imagine the grief of their surviving families. Here's how you can help, at least monetarily. Click on any one of the links. They all need your support. The needs are immediate, but I can tell you from experience, the needs will be long, for many organizations. If you feel you can afford it, click on a monthly donation. Or, just remember to contribute from time to time. My first is always Salvation Army. They were first on site, according to my mom, when our home was destroyed by a tornado when I was a few years old. And, they do so much good, in so many ways, in every community they serve. If you're still working, some generous companies do matching funds. Sometimes, for retirees, too. You can help, outside of Texas, by giving blood, as well. May God wrap his arms around the survivors, and give them solace, and peace.. Here's where you can donate to help Central Texas flood recovery - CBS Texas https://share.google/mLDD7AfFVtWQ5fajI
  19. In 3 cargo trailers I’ve owned, the breakaway had its own small independent battery and the Black wire was used to power interior lights when hitched.
  20. Yes it seems your right, the charging is desired, but it's not explicitly defined in the regs. Years ago when I used to tow a sizable boat into Canada, I was almost denied entry one year because they had just outlawed Surge brakes. I had to replace the trailers surge coupler head with an Electric pump/hydraulic unit including a breakaway switch, battery, TV charging, and an electric brake controller. It was a unique setup because you don't want to dip all electric brakes into water when launching a boat. That expierience was burned permanently into my pocketbook and memory! Cheers! Geoff
  21. Let it be said, let it be written, let it be etched in stone! 😂
  22. When I had metal valve stems put on my trailer, Discount Tire used the jack points and commented it was the first trailer they ever saw with a designated spot to lift. Further comment was they wished all trailers had them, made their job much more easy.
  23. I agree that the back and forth on the merits/drawbacks of the ALCANS has run its course so lets just let that horse head out to pasture. There may be owners who still have genuine questions and to serve them best I think we should keep this open. Mike
  24. Thank You my port side rear is flipped and starboard side front is also flipped
  25. Hi Tideline77....the first and only time it happened to me I didn't know what to do so I called and talked to Hannah in service. She said run the nose jack all the way down. I did and nothing happened. So she said to run the nose jack all the way up and be prepared for a loud pop. And sure enough the shackle popped back into place. Of course raise the rear jacks when you raise the nose so no binding. Good luck, John
  26. 😔 I don’t know where to start to correct my flipped shackles, the trailer is tucked in its storage spot and I won’t be pulling it out until November. i can access both sides using the jacks or I can snag the combination jack/ jack stand at HFreight
