I thought that when I reviewed the catalog link Rob provided. I'm the oddball here re taste in windows (and certainly other things 🤣). I'm happy we have the sliders and very happy ours are in excellent condition after replacing the white rubber seals with new black rubber. I like the one-hand operation whether standing, sitting, or laying in bed. I open/close the one by my bed every night and morning. Every time I pressure wash the Oliver, I hit the windows dead on and a little dirt and a lot of water comes out of every weep hole while staying dry inside. No similar tracks or weep holes in the awning windows, so likely a benefit of being low maintenance. I know some of you have leaks in your original windows and many of you want awning windows for better air flow and other reasons. I hope for you that these windows fit into the roughout openings of your hull with an easy installation! 😂
Main battery switching, a different approach
Are they still mounting them under the streetside bed? - Today
😁 not a problem for us.
Windows in our LE2 have this ID tag inside of the window frame. Believe our rear window in our 2015 LE2 is different size compared to current LE2 rear windows. Please let me know if I have this wrong. In the following video at the 3:05 mark he shows how to identify the existing window to be replaced using the above ID tag when contacting Lippert, Oliver told me my windows were Lippert 8800 windows. Really like the Awning style glass windows that open 90 degrees.
You know, I've been worried about RV battery SOC ever since our first in 2018. But the Class A and then the Class C both had generators. I was adamant from day 1 with the Oliver that we would not run a generator. Battery and inverter/charger technology is here! You even got me thinking in a new way that an EV truck can be a proper TV! 😎 (Though no way we could afford one, and the old Dodge now with upgrades including exhaust brake is a joy!) I pulled out lead acid and a 2KW Xantrex, 2 years ago, and upgraded to the 3KW inverter/charger and 600 Ah LiFePO4. It took me a while to know what I can run and how long the SOC will last. Then last Black Friday we up'd to 900 Ah. In all our winter travels, I finally stopped worrying and I learned to use 3KW and 900 Ah to the fullest. Chris still worries some. After a week of travel, I remembered seeing 67% SOC and Chris asked could she use the Emeril (replaced the microwave with an air fryer). My reply was 67% of 900 Ah is equal to 100% of 600 Ah! Sure bake all afternoon of you need to! Love it. Our Chill Cube runs on ridiculous low power, consuming <30% of what the old Dometic pulled, and I estimate <50% of the power requirements of the Truma, Tosot, or any ON/OFF compressor model! This is amazing and sure helps the worry factor. We had 450 Ah in LA and that means 225 usable which would be our current battery bank at 25% SOC. I don't worry anymore! 😎 (When under 20% SOC, Victron and Epoch apps will warn us.) I believe that many of you with 600 - 640 Ah and 3KW inverter should think to worry less. Run your A/C and that Induction cooker, at least one burner! 🤣 -
DanielBoondock replied to Snackchaser's topic in Ollie Modifications
This mod is awesome but I’d go KISS with a simple switch too. It’s very useful for troubleshooting, in fact on my maiden voyage I ran into trouble with my Xantrex and Oliver support wanted me to isolate the battery by taking the leads off. I wasn’t too happy about that - they’re torqued and I didn’t have the proper wrench with me, and maybe not the right sized sockets anyhow. Pretty crude just pulling those leads … fortunately I quickly realized that these Lithionics I got have the built in power switches. So easy, but not everybody has a built in cutoff. The ‘26’s already have two master rotary cutoffs, one for solar and the other for the inverter. Odd they didn’t do one for the battery -
DanielBoondock replied to Lamar's topic in Mechanical & Technical Tips
I know - I’m an EV guy so my brain thinks in kWh. I do continue it here since the truck is the main power source off park, so for example “if I’m at 79 SOC (State of Charge) of 220 kWh, then taking 8kWh for the trailer leaves me 169 kWh or 75% of the battery, which is at 1.3 mi/kWh 219 miles which is fine to get back to civilization … Yeah your right it’s 640 Ah I was misremembering, 7ish or 9ish kWh or something … -
What I mean is as follows... We run our appliances on battery/inverter just as we would on shore power. I don't even like to hookup when hookups are available, not pulling out cables and hoses unless truly needed. I'll charge batteries, fill fresh water and dump tanks when leaving a campsite, given we are boondocking next. Often, I do not charge at all since as we drive away we average +40 Ah per hour towing with the Victron Orion 50A DC-DC charger! 😎 Our system can handle running our Chill Cube A/C, plus the induction cooktop at the #10 setting, while watching TV with soundbar, and if I wanted to push the system I could boil water with our 1100W tea kettle! Although running ALL of these appliances does add up to 3,000W! The Victron Multiplus II can handle it at default settings. It's rated at 3KVA and can run that in continuous mode. One time, I had our hot water heater running on AC, TV and normal stuff running and forgetting the HWH was heating I turned on the old dog Dometic P2 A/C (TG that beast is gone)! In a few minutes after the Easy Start got done with it's lame on-n-off routine, full power to the compressor, the Victron sounded an alarm! When I checked the app it was providing over 280A (3400W). But it didn't shut down, it just warned us, and it ran at that level for a few minutes. Looking at the amperage numbers, I remembered I had the HWH on electric (vs. propane). I hit the breaker to turn off the HWH and the Victron alarm stopped sounding. We did not lose our TV streaming, not even a hiccup in Internet connection of any other electrical need. Sorry, the Xantrex product will not do this. You can search for keyword 'Xantrex' on this forum to find dozens of posts re Xantrex inverters failing, or at least shutting down, error codes present. Yes, perhaps the default low voltage cutoff is set too high, but that's not all of it. The Victron MP2 also has the PowerAssist mode where if connected to 15A source, it will use that and add inverted battery power to carry higher loads like an inefficient A/C unit. So consider this. When connected to 30A shore power (3600W) the Victron can pass through that power and add another 3000W for 6600W total. Of course nobody would need that or do that, but you could run 3 of the worse A/C systems, like the Dometic P2 on that power. We run our Victron inverter 24x7x360! We run 5 Victron devices in the Oliver (MPPT SC, DC-DC, Shunts, etc.) and two more in the truck which can read from the VictronConnect app. BTW, most of us state battery capacity in Ah units vs KWH. Your batteries are 9KWH (750 Ah)? I thought the max OTT Lithionics installation is 640 Ah. It is standard to use Watts for appliance specs, like the 1800W (150A DC) induction cooktop. I'm always translating into 12VDC Amps since the Victron and Epoch apps show +/- Amps. - Yesterday
xdr started following Winterizing without RV Antifreeze
Based on various conversations I believe that the new windows are Lippert 3000 FV, 48"x18". I have not been able to confirm that the dimensions of the hull rough opening have not changed. Tim
Geoff adds some new thinking here and a clever solid approach! Using relays/solenoids for high amp connections is a good approach! We keep our our Oliver outdoors, never winterized, parked often but never "in storage." She's been parked a few weeks now and our batteries with rooftop solar are currently at 99% SOC. Needles to say, parasitic draw is not a concern of ours. I believe that adding a cut-off switch to the main 4/0 cabling, adds a point of resistance and possible point of failure. Geoff's solution does not interfere with the main power connection. Just 4/0 hardwired straight to the inverter is a good thing! Yet our friend GJ garages his Oliver for 8-9 months on the mainland while he enjoys Aloha-land! Extra precautions must be made if you're out-of-sight of your Oliver for this duration. Both solutions fit the differing needs of 2 Oliver owners! 😂 I'm old-school in that when servicing any vehicle, the first step in the service manual is "disconnect the ground." This is more trusting than any switched solution! I installed the 4/0 wire with the main ground connection closest to the opening. I can disconnect it in just a minute with only a 1/2" wrench, without rolling out a tray (ours was deleted) or removing the locking cover plate I installed (not shown in picture). Very safe too, since there is really no way to touch the positive lead which is 6" further into the bay. I disconnect rarely, haven't done so since I added the 3rd battery last year. The main ground is right there when needed! Call this the #1 most basic option, no switch required! 😎 -
Ollie-Haus replied to Lamar's topic in Mechanical & Technical Tips
Interesting thread indeed, and it will definitely be interesting to know how Oliver resolves the issue with @Lamar’s cooktop/inverter. It definitely appears that unique design considerations were required with the LE and its more limited power capabilities compared to the LE2 and it’s larger inverter and battery capacity. Depending on the outcome, this experience may initiate design changes for future LE builds. Regarding comments by @jd1923 and @DanielBoondock about induction appliances in their Oliver travels, after more than two seasons in our LE2 we definitely prefer induction for all cooking needs. Whether cooking outside or inside, the quickest, cleanest, simplest and in my opinion safest cooking option in an LE2 with large lithium system and 3k inverter is induction. And for us that includes both with utility connections and boondocking disconnected. Like any electrical system it requires a mind for managing capacity and demand. We actually have two of the induction cooktops @jd1923 mentioned above, and use them simultaneously when needed. The beauty of two separate units is they can be positioned side by side and used like a two burner and not be limited by the settings on the opposite unit. We even have a nice non-stick griddle we place on the dual burner arrangement, with separate controls for each half just like you can on a double burner single unit. For outside cooking, if we have utilities at the site, one gets plugged into the curbside outlet and the other run off the pedestal via a short 12ga extension cord. My eventual plans are to run a separate circuit from an added breaker in the 120v panel to a plug above the galley to facilitate using both induction units simultaneously without overloading a single circuit, keeping in mind the inverter capacity. Simultaneous use of one hot plate and the hot induction kettle would also become an option. As mentioned by @DanielBoondock we always must take into consideration any other appliances such as AC, microwave, induction kettle, and the notorious hairdryer!😉 But once you understand the capabilities of the LE2 and its electrical capacities, induction appliances really open up a lot of options. We love the propane system for unlimited and instant hot water and it’s excellent heating capabilities with the furnace, but for us, the convenience of instant and precise cooking with induction is something we’ve learned to love at home, and now very happy to have while traveling. -
Geronimo John started following Main battery switching, a different approach
Geronimo John replied to Snackchaser's topic in Ollie Modifications
Good write up. But I'll stay with my 350 amp BlueSeas Master DC cut off switch. Why? Less complicated and less maintenance than a Master Switch. When a Master Switch if off, there are no power draws during the 8 months my OTT is lonely. Smart owners always do a brake check when starting a tow. Doing so also hints at DC power to the CO and Propane detectors and referigerator. GJ -
I used the stainless steel version of these when I added LED strip lights under my awning a few years ago. Love them.. https://olivertraveltrailers.com/forums/topic/9314-curbside-led-strip-lighting/?_rid=6801
Great minds think alike - I have this one for cooking outside https://www.amazon.com/dp/B07G9YKPQC Stainless is nice but most is I like that its fine if it rains, don’t ask me how I know. Also it’s got .5 increments so is finer grained control than the interior stove Hm? Not sure what you mean either … I’m just saying that the cooktops have a specified input power they can spend however they want. For the home Bosch the electrician used the wire gauge and breaker size required for installation and obviously same here. So the induction is sized to that, but they can use that power however it wants. The Bosch has a boost mode which is super crazy fast for boiling water, less than a minute for a full pot. I forget how much it is, 6-9kW I think? Anyhow that can only be used with the other burners at a much lower power, so it basically hogs the input. The Oliver induction is much the same. I can use the main burner on 10, and the secondary on 1 or 2 IIRC. Or I can use the secondary on 8 (max), and the main on 3. So clearly, 11 is the maximum level (the engineer must have seen Spinal Tap), and the onboard PLC lets you spread that across two burners in this way. Now the burner could be sized bigger, say 2.5 kW, and (without doing the math) say that allows both burners on full. OK fine, but now that would only sell to RV’s with 3k inverters which isn’t as common as 2k. Even on shore power we only have a 30A input which still limits. Don’t know what this means, everybody is limited to 30A on shore, and on battery are limited by the inverter and battery. With my stock dual Lithionics 9kWh batteries and the Xantrex 3k I always have to be mindful of power while cooking. On battery I can do two things at once usually, but no AC. On shore I can do AC and cook, one or two things but still have to be careful. From the factory they incorrectly set the low voltage cutoff of the Xantrex at 11.3 IIRC. By accident I found that out, it’s supposed to be 12.1. At the previous value I could easily run two things at once on battery. At the correct 12.1 I have to be much more careful and run more like 1.5 appliances simultaneously. Making it more interesting I’ve got 10 kW off my truck if you can believe that. 7kW off the bed power sockets, and I have a ~3kW dongle which goes off the charge port in a ‘reverse power’ configuration. I think it’s using the onboard Level II AC inverter backwards for that. Anyhow this dongle has a TT-30 socket - they must have done it for the campers, so I can plug the trailer into mobile ‘shore power’. But it’s limited to 25A not 30A, so have to be a bit more careful. Buuuuuuut, if it really mattered, I could also go off the bed power (using an adapter for 240V), or just run the outdoor induction off one of the 120V, or whatever. tl/dr … -
Be careful! Pretty soon you two just might run out of things to talk about!😇
The price for your dimmer switches at about $20 is sure a BUNCH cheaper than what I paid for my single dimmer switch some 10 years ago. And, the finished product looks great too. Bill
Dimmer switch to replace OEM rocker
Dean and Mary replied to Steve and MA's topic in Ollie Modifications
I’ve been looking for a quality dimming option for the three lights you mentioned, and I appreciate you sharing your results. -
I installed Obeaming touch lights and been very pleased, they are dimmable to your desired level of eye comfort and ambiance. I posted the install on this forum. Here’s a few pics:
- 1 reply
- 2
Hey Mike and Carol, one more question: Are the valves under the bed in the same position no matter if you put the solution in the boon dock port or the two side ports? I know I am a pain, but want to do this right. Thanks again.
@mossemi And thank you Sir for your help. Bill
I'd like to install a Mini Split A/C at home. Looking for my technical friends here who have researched models or installed one in your home. Our home, built in 1980, is still on the original HVAC system (with a few repairs I've made). It's a combined unit up on stilts, attached to one end of our long 4100 SF home. The other end of the home doesn't get much airflow and neither do the bedrooms. I'd like to install a dual-head mini split, one head in our bedroom and the other in my office where I train via Zoom in the afternoons. Both rooms get hot in the summer and it's a waste cooling the entire home low enough to cool these two small rooms (only 180 SF each). It would be OK if cool air flowed out in the hallway too to give the old system some help. Likely the smallest dual unit at 9,000 + 9,000 BTU is enough, or maybe 12 + 12. I see brands that are familiar like Tosot, Turbro and Pioneer, since they make RV units. I also see Senville, Cooper & Hunter, Daiken, Della and others. Any brand preference? I see Senville has good reviews with a 5/10 yr warranty. I'd like to buy from an HVAC distributor vs. Amazon, but each time I find a link the $2K dual unit on Amazon goes for over $3K elsewhere! Definitely need a dual head unit and the 2 rooms are side-by-side on one exterior wall which should make for a tidy installation. Time to drill into our home instead of the Oliver! 🤣 115V would be a close run. I could tap into a bedroom outlet which only has a nightstand lamp on the circuit. For 230V I can add a breaker and run wire from the garage along the soffit. Thinking 230V is more efficient, but not sure. Is R32 the best refrigerant or another kind? Lots of Qs! Any installation or use experience out there? Thanks
Steph and Dud, This works great for us. We are coming to the end our initial voyage . We needed to keep reminding each other where/when in the days ahead. We tend to not think about calendars so much when traveling and sometimes we don’t even know where we will stay the next night. I put up a similar white board using command strips on the closet door of our 2026 LE1. Hull #1687. Good use of that space and we quit asking each other what’s next. Lamar😁
mossemi started following Updated: Marine hatch in the bathroom
@Townesw The hatch looks very nice and you will love the easy access. Thank you for the step by step procedure. It will help someone else in the future! Mossey
The recent posts about adding lights to the rear and tongue reminded me to share this. There had also been a few previous posts about the bright exterior lights, and some mentioned adding dimmers. We've added these dimmers to ours. From what I've read, Oliver has changed the way the exterior lights are switched over the years so this modification may not work for everyone. On our 2022 LE2, the four Porch lights on both sides of the trailer are on a single switch, as are the lower Courtesy lights. The Porch lights are quite bright, which can be very annoying, especially to neighbors on the streetside. Though we can just use the awning light if we need to keep the streetside dark, sometimes we like less intense lighting. These dimmers replace the rockers in the original control panel. It's an easy modification, but requires enlarging the rocker hole slightly. We also added a dimmer to the Main Cabin lights. (Note: the blue light ring in the picture doesn't indicate whether the light is on/off, it's always on or off depending on a separate setting.) Steve
Regardless of usage, there is a wattage spec listed on electrical appliances sold in the USA. Pretty sure it's code, so that electricians know how to size wiring and fuses/breakers. Also, part of RV solar planning is to add up the wattage of each appliance and to estimate how many hours per day of usage, and so forth. We use the induction cooktop that @Ollie-Haus made us aware of in an older post. My wife likes it so much that after she was using at home too often, I purchased a 2nd one for the Oliver only (I like our Oliver always ready to go, fully equipped). It's rated at 1800W which is listed on the Amazon title and on the product label underneath. Wattage spec should also be listed in product literature and user manuals. https://www.amazon.com/dp/B07KSNTSVR/?th=1 I do not get this statement either, "the stove itself." How can an appliance possibly know what it's wired to, or know whether you're on inverter or shore power? We run our induction cooktop often at the full #10 setting, for example to boil water for pasta. Everything always on our Victron Multiplus II, no problem. 😎
