Made in USA leaf springs
Tom and Doreen replied to Mountainman198's topic in Mechanical & Technical Tips
That's a smart move, John, I'm glad that you're replacing them! I was assured by the Oliver guys at the last rally that I didn't have to worry about my springs, 2023 build with D52 axles, because there were no problems with newer trailers with D52 axles. Well..... I have a broken spring set, passenger rear, with the remaining sets flattening. Needless to say I'm not a 'happy camper' regarding this. I have replacements from Alcan but haven't had time or decent weather to do the repair as yet. -
Cracked bushings on Monroe Struts
Tom and Doreen replied to Roger's topic in Mechanical & Technical Tips
It's likely those shocks are shot. -
Water Pump suddenly stopped. What to do?
Tom and Doreen replied to DonnaDuane's topic in General Discussion
If pulling on wires / switches and things temporarily work don’t discount the possibility that fiberglass dust may have gotten into a connection or switch. I’ve had this happen at times. Look for loose or contaminated connections as a possibility. -
If your batteries are very low your Xantrex is likely attempting to apply full power to charge your batteries thereby exceeding the power available from your shore power source. It may have worked just fine previously if your batteries had a better state of charge, requiring less demand on your source, but with really low state of charge more demand is required of the source. Decrease or turn off your Zantrex’s max charge current setting or plug into a higher power source. In addition, as others have said, make sure your source is wired correctly and test for faults.
Great episode, Steve!
Additionally you may want to consider replacing your valve stems to the metal variety as opposed to rubber. Rubber ones can fail when sensors are attached.
If you’re referring to the little device that relays the sensor signals I installed mine in the front jack housing, there is power in there and room for the module. I repurposed the switch that controls the jack light so that I can turn the module power on and off.
Another issue with a Truma heater.
Tom and Doreen replied to Buddhabelly's topic in Mechanical & Technical Tips
My ‘23 Tundra is on the recall list but I’m one of the lucky ones ( so far ) with 60k miles, 30k of which pulling our Oliver and no failure as yet. I’ve heard that they’re starting to address the ‘23s in my area soon. I have done frequent oil changes right from the start, hard to know if that made a difference.
The museum is awesome. You can boondock there for free, the area is nice. If you want an electric hook-up they charge $40 which includes water but when we were there the hydrants were labeled “non potable”. There is also a dump site there. The Truma service center is close by if you need anything from them.
Inverter freedoms 2000 is not turning on
Tom and Doreen replied to Skipster's topic in Welcome to the Oliver Forums
Like @jd1923 said, take measurements around this circuit breaker, input vs output . These have been known to fail. As John said you should measure 12V on each side with respect to ground. -
Someone had recommended this one, High Sierra.
A Convenient Location for the TST TPMS Repeater
Tom and Doreen replied to Tom and Doreen's topic in General Discussion
Yes, mine did. It worked pretty well (without the repeater) but there were times when I would loose contact with one tire sensor for a period of time. Once I installed the repeater I’ve had no sensor drop-outs. -
If you're looking for a convenient place to hook up your TST repeater there is ample space within the front jack head. +12V power is available and you can utilize the existing power switch currently used for the lamp or add an additional switch if you choose to.
Tom and Doreen replied to John and Jodi's topic in General Discussion
Yes, I have a GearWrench torque wrench, 250 ft//lb that we travel with. We were VERY lucky because we had been on the highway heading out to Yellowstone and had just pulled off to get groceries when the tire stem blew out most likely from the "waggle" affect of the TST sensor. We changed the tire in the parking lot then found a Discount Tire location near where we were and had the stems replaced on all tires including the spare. -
1) Using the stabilizer jack is very helpful 2) Change valve stems to the metal type especially if you have TST sensors 3) Invest in an electric impact wrench 4) A locking bottle type jack comes in handy 5) Tire plugs and a compressor can come in handy in a pinch. -
We've had two RVLocks fail, on the first one a circuit board failed, the second one had a mechanical failure which we were advised (by the manufacturer) to loosen the internal screws that held a metal plate in place; I don't have a lot of confidence in the second fix but it seems to be working for now. Lot's of people seem to have this lock and are happy with it though.
That is some fine work, John, excellent job!! You'll not only have the confidence in your equipment going forward but you'll also have the knowledge (and tools) to tackle any situation that comes along should something go wrong. Regarding having the parts and tools required at hand I still struggle with that as it seems like no matter how simple the job I find myself running back and forth to the garage several times to retrieve nearly all of the tools I own!! -
Unique Camping + Marine RV wastewater treatment
Tom and Doreen replied to routlaw's topic in Mechanical & Technical Tips
That guy seems to know his ........( stuff ) 😜 I will disagree with him on one point though and that is with his suggestion to leave the grey tank valve open while connected to the sewer. Unless you create a trap with the sewer hose you risk getting sewer gasses ( and possibly bugs ) from the campground sewer rising up into your grey tank. The problem becomes worse when some other trailer on the same branch dumps their tanks and displaces the gasses in the line. We have a composting toilet so we're only concerned about the grey tank. While at the rally I asked the tank clean guys what to use to keep the tank clean and they handed me a recipe which I've been using. They also said that this recipe helps to lubricate the gate valve. We also are very careful to not get too many food particles in the tank. -
Hello friends from hull #1452.
Tom and Doreen replied to Against The Wind's topic in Introduce Yourself
Congratulations and welcome to the community! Tom & Doreen #1321 -
Accurately measure propane level for under $10
Tom and Doreen replied to Snackchaser's topic in Mechanical & Technical Tips
I’ve had problems with the under the tank ultrasonic sensors so I purchased the Truma hand held sensor. It’s expensive but it works well. I’ve also used the (free) method by which you pour hot water down the tank and then feel for the temperature change. The Truma is as accurate as the hot water method (which is very accurate).
