I had the same issues and decided to purchase a new indoor antenna from SureCall thinking that surely the coax had been compromised from the extreme bend. Unfortunately that did not help. Being that the phone needs to be in such close proximity to the antenna to gain any improvement maybe the indoor antenna can be relocated to a place more easily accessible to the phone like closer to the table top or night stand.
My experience has been that the improvement of signal quality / strength has been minimal with the cell booster and any improvement dissipated quickly as the phone was moved away from the indoor antenna; I only saw improvement of signal strength when the phone was within a few inches of the indoor antenna. In testing I saw a difference of 11 db, 1 bar or so when using the booster and that required the phone to be within a few inches of the antenna. Maybe a better external antenna would help but still the signal radiated from the indoor antenna had very little effective range within the trailer. In my opinion it might help to sustain or place a call but barely.
Looking at the thermostat temperature data during the over-night period after stabilization when there is likely very little activity i.e., door/window opening, movement etc., the control looks pretty good. It looks like single-cycle variance of the thermostatic control algorithm is approximately 2 degrees with a cycle period of approximately 30 minutes per cycle consistently throughout the over-night; pretty good. The average temperature over the entire over-night control period is very consistent with negligible wanderation suggesting good control. I doubt that my house control is that good. It’s hard to say what factors influenced the data prior to and after the over-night periods, possibly activities within the trailer; hard to say. I’m not sure what would cause the temperatures to be what they are inside the equipment bays, it might be interesting to see what the skin temperature of the furnace itself is as it may be radiating heat towards the water pump area.
Same story, the waste hose shredded on a cold day last January returning from Oliver. Luckily the Oliver supplied waste hose came in two section and we could utilize the second section. We then replaced the hose with a Rhino and that's been working fine. We have a composting toilet and are very happy with that decision.
Battery compartment won't unlock
Tom and Doreen replied to Tom and Doreen's topic in General Discussion
Thanks John! I noticed quite a few sap blobs on the roof, I'll get a plastic scraper and get at it. -
Thanks folks! ....Problem solved! We've been camping in pine forests for a couple of weeks with varied temperatures and at times downpours; It turns out that quite a lot of pine sap found it's way into the door gasket and glued the door shut. Pouring warm water around the door seal and tugging very hard freed it up! -
Hi Bill, I tried pulling on the door but I don't think that I pushed on it, I'll try that tonight. I suspect that it won't make much difference as the door is tightly closed and the latch just spins freely around as if not connected to anything. I hate the thought of drilling through the latch. I'll likely be heading down to Oliver in January anyway so I may just wait until then for repair ( and hope that I don't need to access that area until then ). -
While camping last week and showing the trailer to one of the many interested people who stopped by I found that the battery compartment door would not unlock / open; the latch would unlock and turn (freely....too freely) but the door would not open. It seems that the lock handle may no longer be connected internally to the lock / unlock mechanism. I don't suppose there is an easy fix for this? Aside from this I've learned an important lesson: Always allow extra time when packing up a campsite because the Oliver draws a lot of interest and people will be stopping by.
Did you find that the x-chocks were causing problems?
No 120 vac from outlets in Elite II.
Tom and Doreen replied to docron's topic in Mechanical & Technical Tips
Shooting in the dark here but if your microwave is working your inverter is working. Possibly your GFCI outlet is at fault, hard to say. Oliver service will definitely help you, they're some of the best in the industry, try them again. -
Greasing Dexter EZ flex suspension.
Tom and Doreen replied to Ken_Judy's topic in Mechanical & Technical Tips
I have the "simple one" at $10.99 and I was able to connect to the difficult zerks. -
Truma CP Plus Control Panel error code
Tom and Doreen replied to Mike Griffin's topic in Getting Started
Make sure your Truma water heater main switch is set to the 'on' position. This switch is located on the water heater itself and can be set to either the up or down position. The center position is off. -
DC Fuse Panel Voltage
Tom and Doreen replied to Half Fast Hugo's topic in Mechanical & Technical Tips
The LED is wired across the fuse and will light when the fuse is blown AND a load is attached to complete the circuit. There must be a load applied and the fuse must be blown for the LED to light. As far as reading a voltage with your meter on the load side of the fuse ( when no actual load exists ) this may cause your meter to falsely read a voltage because your digital meter is completing the circuit between the LED and ground. Because your digital meter has high impedance inputs the LED may not actually light but it is completing the circuit between the LED and ground, thereby drawing a small current, and as such will indicate a voltage. You can think of your meter as a very high value resistor in this application. -
Oliver looking to partnership with RV dealerships.
Tom and Doreen replied to Katjo's topic in General Discussion
I can certainly understand Oliver's take on this. It’s incredibly difficult to troubleshoot owners problems over the phone / text / email without actually getting your own eyes and hands on the issue, this takes considerable time all of which is uncompensated. In addition customers may be pressed for time, unable to make repairs, or unable to make the trek in some cases thousands of miles to get service at the factory. Oliver is trying to address both of these issues. The issue that I have is that there aren’t any dealerships in my area that I would trust to work on our Olly so if something major happens I’ll make the trip, if possible, to the factory. This would be a good opportunity for some young entrepreneurs with skills and a van to form a close relationship with Oliver, get trained, vetted, and certified, and head out on the road. -
Looking for full-time couples opinions 🫂🤮😱🤗
Tom and Doreen replied to Bikerabbi's topic in General Discussion
Two enthusiastic thumbs up for Earth Roamer👍👍 and also it's little cousin Truckhouse. -
I think that we have the same dog! We've had the same experience in that people with other dogs assume that it's ok to let their dog approach without asking. It's funny that you mention the "find it" game; We have a ritual whereby while she's eating her dinner we hide her after-dinner snack somewhere in the house. When she's finished we shout "FIND IT" and off she goes. She quickly tracks it down and upon doing so we throw up our arms and exclaim "she saw it with her dog nose!!" 😁 while she proudly does a victory lap around the house.
Exceptional work!!
That sounds exactly like our dog, a rescue as well; Very good with people but does not like other dogs. Luckily so far she's been very well behaved when camping for some reason even when we've stayed at a Harvest Host farm with lots of animals. We do use a remote controlled training collar with her which we can set to make a noise, vibration, or tingle at the press of a button if need be. So far we've only had to use the noise and a couple of times a vibration to change her behavior. We are careful not to let other dogs get to close to her though, just in case. Some dogs she's ok with, others not; it's hard to know.
Toyota Tundra enough truck for an Elite II?
Tom and Doreen replied to Beaver Pilot's topic in Welcome to the Oliver Forums
On the 2023 Tundra, and likely the 2022, the right side gauges are configurable. The transmission temperature is one of the items that is selectable. I believe that there are actually two transmission temperature sensors but I believe that only one of them is readable even with my ScanGuage. -
Xantrex Inverter Issues? Try a Hard Reboot
Tom and Doreen replied to Rivernerd's topic in Mechanical & Technical Tips
This is what I measured back in April. "Panel indicated" is as stated, measurements recorded from the panel. "At terminals" were values recorded with a Fluke 8062A multimeter (calibrated) with respect to the common (-) buss bar except in the case of the actual battery voltage which was measured directly across the battery terminals at the battery ( for simplicity which does not include any drop across the shunt ). I haven't measured the drop across each segment of the high current DC line but the segment from the (+) terminal of the DC input to the Xantrex to the input of the circuit breaker accounts for approximately .27V with the remaining .24V being dropped across the segments preceding the circuit breaker. I don't know the specs for the shunt but it's probably not unreasonable to expect a .1V drop here given the load. I did speak with an engineer at Optifuse concerning the DCR ( DC resistance under load ) of the circuit breaker since their spec sheet did not disclose this information and he stated that he would expect those values to be in the "low milliOhms if not microOhms" region which would be insignificant. So I believe that it all comes down to the basics; is the cable quality, length, and gauge appropriately rated for the max load; is the surface area and quality of the crimps and terminals adequate, have the number of connections / crimps in the system been minimized ? Could be a 'bad circuit breaker' but given the fact that others are having the same problem, probably not. -
This should be considered a "work-around" rather than a "fix" and Oliver should come up with a permanent solution, which I'm sure they will. In my particular case, running a 1.5kW load, the voltage indicated by the Xantrex display was .5V lower than what was measured at that battery. This doesn't seem like much but it does cause a premature and unnecessary shutdown of the Xantrex, as many have experienced, since the Xantrex interprets the battery voltage being much lower than it actually is. Changing the LBCO to a lower value to compensate works however it doesn't change the fact that there is still a .5V drop across the wiring and associated circuit breaker. That doesn't sound like a big deal but what it equates to, in my case, is that running a 1.5kW load results in 60W ( conservatively ) being dissipated by the wiring on the DC input side of the Xantrex. That's power that's not being applied to the load and results in unnecessary heating of the wiring (although small). Ideally there would be no voltage drop between the battery and the Xantrex, in reality there will be some, nothings perfect, but .5V is excessive. Having said all that the "work-around" will work, as I've been using that method for a while with good results, and my heavy electrical loads are usually temporary. -
“Mouse” has gone away with a happy new owner.
Tom and Doreen replied to John E Davies's topic in General Discussion
Best wishes, John, enjoy your future adventures!! Thank you for all you've done for this forum and we look forward to hearing from you again! -
@MAX BurnerNice setup! Do you have the automatic bed step on your Tundra and if so do the Rock Tamers interfere with it? Any issues with the sensors?
