rideandfly Posted July 22, 2024 Posted July 22, 2024 (edited) John, Yes If you are going to order, I know you will check the specs & cost with Dexter first and what is or is not included. I cannot speak to bearings, new or old style, the Dexter distributor can answer this. Dexter 3" U bolts are 1/2" and off the shelf 5 leaf springs are 1 3/4" wide. Not current on Alcan spring replacement specs. Springs, mounting hardware, EZ flex, handling & shipping are extra. I looked up the Dexter distributor for my zip code on the Dexter website and called them, Redneck Trailer Lincolnton, NC to get the information I posted above. Also posted the build sheet for one of my axles earlier in this thread. Edited July 23, 2024 by rideandfly 1 1 2015 LE2 #75 / 2024 F-150/5.0L
MAX Burner Posted July 23, 2024 Posted July 23, 2024 19 hours ago, rideandfly said: it would be a special order with lead time of 3 to 3 1/2 weeks for $795 retail. FYI: This is exactly what we learned from Dexter and OTT last May when we switched ours out. Turned out that OTT had the correctly sized D52s in stock for our model year (luckily) so we didn't have to wait 3 - 4 weeks for the special order from Dexter. The price was $825/ea from OTT but that included the Dexter 4-pack 1,750# which we didn't need. Just as an interrogative comment: Since installing the Alcans in March, we've logged 6,750 miles on them and since upgrading from the D35s to D52s in May, we've logged 3,729 miles on the axles. We've experience zero issues and frankly, cannot "feel" or observe any differences while under tow. I "base-lined photographed" each of the aluminum angle cross members prior to installing the springs and have checked them several times since and haven't noted any cracked welds or other damage. At the 5,000-mile point, we last checked the 3" x 9/16" U-bolt torque - all good. Granted, we didn't wonder off on any long unimproved roads except for a few short jaunts into BLM and USFS campgrounds.... FWIW: We'll continue to keep a weather-eye on the running gear (as we would anyway), but our peace of mind and overall confidence in Casablanca is significantly better than before making these improvements. Cheers, ALL! 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
rideandfly Posted July 23, 2024 Posted July 23, 2024 4 hours ago, MAX Burner said: FYI: This is exactly what we learned from Dexter and OTT last May when we switched ours out. Turned out that OTT had the correctly sized D52s in stock for our model year (luckily) so we didn't have to wait 3 - 4 weeks for the special order from Dexter. The price was $825/ea from OTT but that included the Dexter 4-pack 1,750# which we didn't need. Art, Do you recall if the axles you removed were SC 50.0" or 50.5"? Thanks, 2015 LE2 #75 / 2024 F-150/5.0L
jd1923 Posted July 23, 2024 Posted July 23, 2024 1 minute ago, rideandfly said: Art, Do you recall if the axles you removed were SC 50.0" or 50.5"? Thanks, If not, the length of the new D52s would do @MAX Burner. Did they change from 50" to 50.5" by 2017 on hull 226? 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
rideandfly Posted July 23, 2024 Posted July 23, 2024 (edited) 16 minutes ago, jd1923 said: If not, the length of the new D52s would do @MAX Burner. Did they change from 50" to 50.5" by 2017 on hull 226? Another thing I wondering about, if the axle SC spec did not change from 2015/2016 to 2017, there could have been enough fabrication tolerance (Oliver welded axle mount) to allow the 50.5" to fit, just a thought for now. Edited July 23, 2024 by rideandfly 1 2015 LE2 #75 / 2024 F-150/5.0L
MAX Burner Posted July 23, 2024 Posted July 23, 2024 2 hours ago, rideandfly said: Do you recall if the axles you removed were SC 50.0" or 50.5"? The original D35s were Spring Center = 50.5" 1 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
rideandfly Posted July 23, 2024 Posted July 23, 2024 1 hour ago, MAX Burner said: The original D35s were Spring Center = 50.5" Thanks, Looks like some of the 2015 & 2016 LE2s have 3500lb & 5200lb axles with spring centers of 50.0". 1 2015 LE2 #75 / 2024 F-150/5.0L
mountainoliver Posted July 23, 2024 Posted July 23, 2024 If you’re keeping track. My 2017 hull 208 has a 50.50 in. 3500 lb. axle. 2 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
rideandfly Posted July 24, 2024 Posted July 24, 2024 (edited) LE2 (Dexter axle spring center) SC & weight capacity specifications, from information gathered, looks like only 2015 & 2016 LE2's axles have SC of 50” (so far) It was not my intention to start a list, but this will keep info organized. 2010 LE2 #45 SC 50.5" 5200lbs 2015 LE2 #75 SC 50” 5200lb 2016 LE2 #110 SC 50” 3500lb (Gathered from info Chris posted) 2016 LE2 # 113 SC 50 “ 3500lb 2017 LE2 # 208 SC 50.5" 3500lb 2017 LE2 # 226 SC 50.5” 5200lb 2021 LE2 # 898 SC 50.5" 3500lb Please correct me if I have your LE2 info wrong Edited July 24, 2024 by rideandfly 2015 LE2 #75 / 2024 F-150/5.0L
CRM Posted July 24, 2024 Posted July 24, 2024 27 minutes ago, rideandfly said: Please correct me if I have your LE2 info wrong 2010 LE2 #45 has 5200lb axles with SC 50.5 1 2010 Elite II, Hull #45. 2014 Toyota Sequoia Platinum 4WD 5.7 with tow package.
Moderators mossemi Posted July 24, 2024 Moderators Posted July 24, 2024 30 minutes ago, rideandfly said: LE2 (Dexter axle spring center) SC & weight capacity specifications, from information gathered, looks like only 2015 & 2016 LE2's axles have SC of 55.0" (so far) The value of 55.0" is a typo, correct? Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
rideandfly Posted July 24, 2024 Posted July 24, 2024 (edited) 36 minutes ago, mossemi said: The value of 55.0" is a typo, correct? Mossey I will change it to 50” Thanks, Edited July 24, 2024 by rideandfly 2015 LE2 #75 / 2024 F-150/5.0L
rideandfly Posted July 24, 2024 Posted July 24, 2024 29 minutes ago, CRM said: 2010 LE2 #45 has 5200lb axles with SC 50.5 Updated 2015 LE2 #75 / 2024 F-150/5.0L
jd1923 Posted July 24, 2024 Posted July 24, 2024 53 minutes ago, CRM said: 2010 LE2 #45 has 5200lb axles with SC 50.5 This is an outlier. It appears every other hull 2016 and older has the 50” axle. If this is true and Dexter can build either when ordered, why would OTT start with 50.5” then use 50” and then back to 50.5. It’s not what Henry Ford would have done! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
MAX Burner Posted July 24, 2024 Posted July 24, 2024 11 hours ago, rideandfly said: Please correct me if I have your LE2 info wrong Not to make the list more complicated or confusing, but would it be of value to anyone by indicating OEM "original" axle capacity and "upgraded" axle capacity for those that have gone from D35s to D52s? Just a thought... 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
rideandfly Posted July 24, 2024 Posted July 24, 2024 (edited) 1 hour ago, MAX Burner said: Not to make the list more complicated or confusing, but would it be of value to anyone by indicating OEM "original" axle capacity and "upgraded" axle capacity for those that have gone from D35s to D52s? Just a thought... OK, good idea. 2010 LE2 #45 SC 50.5" D52 Original axle capacity 2015 LE2 #75 SC 50” D52 Original axle capacity 2016 LE2 #110 SC 50” D35 Original axle capacity (Gathered from info Chris posted) 2016 LE2 # 113 SC 50 “ D35 Original axle capacity 2017 LE2 # 208 SC 50.5" D35 Original axle capacity 2017 LE2 # 226 SC 50.5” D52 Upgraded axle capacity 2021 LE2 # 898 SC 50.5" D35 Original axle capacity Again, please correct me if I have something wrong and I can add additional units, too. Edited July 24, 2024 by rideandfly 2015 LE2 #75 / 2024 F-150/5.0L
Moderators SeaDawg Posted July 24, 2024 Moderators Posted July 24, 2024 (edited) 17 hours ago, jd1923 said: This is an outlier. It appears every other hull 2016 and older has the 50” axle. If this is true and Dexter can build either when ordered, why would OTT start with 50.5” then use 50” and then back to 50.5. It’s not what Henry Ford would have done! When #45 was built, Oliver's main production was the Elite I, with the 5200# axle we have. It's what they had in stock, imo. Edited July 24, 2024 by SeaDawg 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
CRM Posted July 24, 2024 Posted July 24, 2024 25 minutes ago, SeaDawg said: When #45 was built, Oliver's main production was the Elite I, with the 5200# axle we have. It's what they had in stock, imo. That's what I was thinking, which means the early E1's were probably all 50.5 SC too. 2010 Elite II, Hull #45. 2014 Toyota Sequoia Platinum 4WD 5.7 with tow package.
rich.dev Posted July 24, 2024 Posted July 24, 2024 8 hours ago, rideandfly said: 2010 LE2 #45 SC 50.5" D52 Original axle capacity 2015 LE2 #75 SC 50” D52 Original axle capacity 2016 LE2 #110 SC 50” D35 Original axle capacity (Gathered from info Chris posted) 2016 LE2 # 113 SC 50 “ D35 Original axle capacity 2017 LE2 # 208 SC 50.5" D35 Original axle capacity 2017 LE2 # 226 SC 50.5” D52 Upgraded axle capacity 2021 LE2 # 898 SC 50.5" D35 Original axle capacity 2023 LE2# 1386 SC 50.5” D52 original axle capacity Added hull# 1386, my stock springs are 1750lbs capacity 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
rideandfly Posted July 24, 2024 Posted July 24, 2024 (edited) 2 hours ago, rich.dev said: Added hull# 1386, my stock springs are 1750lbs capacity Can you take a photo of the Dexter label on one of your axles & post or let me know if the SC is 50 or 50.5 and if axle is 3500lb or 5200lb capacity. What year is your Ollie? Check out the Dexter label photo in Mountainman198's first post in this thread. Thanks, Edited July 24, 2024 by rideandfly 2015 LE2 #75 / 2024 F-150/5.0L
rich.dev Posted July 25, 2024 Posted July 25, 2024 3 hours ago, rideandfly said: Can you take a photo of the Dexter label on one of your axles & post or let me know if the SC is 50 or 50.5 and if axle is 3500lb or 5200lb capacity. What year is your Ollie? Check out the Dexter label photo in Mountainman198's first post in this thread. year is 2023, and here’s a pic of the label on my axle and build sheet from Dexter. 1 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
rideandfly Posted July 25, 2024 Posted July 25, 2024 (edited) 4 hours ago, rich.dev said: year is 2023, and here’s a pic of the label on my axle and build sheet from Dexter. Thanks, 2010 LE2 #45 SC 50.5" D52 Original axle capacity 2015 LE2 #75 SC 50” D52 Original axle capacity 2016 LE2 #110 SC 50” D35 Original axle capacity (Gathered from info Chris posted) 2016 LE2 # 113 SC 50 “ D35 Original axle capacity 2017 LE2 # 208 SC 50.5" D35 Original axle capacity 2017 LE2 # 226 SC 50.5” D52 Upgraded axle capacity 2021 LE2 # 898 SC 50.5" D52 Upgraded axle capacity (Mountainman198's earlier axle label photo 12/22 date) 2023 LE2 # 1386 SC 50.5" D52 Original axle capacity Again, please correct me if I have something wrong and I can add additional campers, too. Edited July 25, 2024 by rideandfly 2015 LE2 #75 / 2024 F-150/5.0L
Ronbrink Posted July 25, 2024 Posted July 25, 2024 For the list, my 2020 OLEll, 579 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator.
rideandfly Posted July 25, 2024 Posted July 25, 2024 (edited) 7 hours ago, Ronbrink said: For the list, my 2020 OLEll, 579 Thanks, 2010 LE2 #45 SC 50.5" D52 Original axle capacity 2015 LE2 #75 SC 50” D52 Original axle capacity 2016 LE2 #110 SC 50” D35 Original axle capacity (Gathered from Wayfinder's posts) 2016 LE2 #113 SC 50 “ D35 Original axle capacity 2017 LE2 #208 SC 50.5" D35 Original axle capacity 2017 LE2 #226 SC 50.5” D52 Upgraded axle capacity 2020 LE2 #579 SC 50.5" D35 Original axle capacity 2021 LE2 #898 SC 50.5" D35 Original axle capacity 2023 LE2 #1386 SC 50.5" D52 Original axle capacity Again, please correct me if I have something wrong and I can add additional campers, too. Edited July 25, 2024 by rideandfly 1 2015 LE2 #75 / 2024 F-150/5.0L
MAX Burner Posted July 27, 2024 Posted July 27, 2024 @rideandfly - Steve and Talii's Hull #50 has SC 50.5" D52's w/disc brakes and upgraded Alcan springs --- FYI. 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
