Patriot Posted October 16, 2024 Author Posted October 16, 2024 (edited) @rideandfly Bill, Can you have the Anker power pack plugged in and charging and still run your Mini while it’s plugged in for pass through use while still charging the Anker? Edited October 16, 2024 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
rideandfly Posted October 16, 2024 Posted October 16, 2024 (edited) 12 hours ago, Patriot said: @rideandfly Bill, Can you have the Anker power pack plugged in and charging and still run your Mini while it’s plugged in for pass through use while still charging the Anker? David, Tested the Anker power pack while at 100% charge, the power pack output USB-C1 port is 0 Vdc output when charging on the Anker charging dock, but the Anker charging dock also has three output ports and there is 19.9 to 20Vdc output from the USB-C1 port rated for 100W when testing with the 6' cord plug that connects to the Mini, this should be enough power to run the Mini, will test with the Mini later today. The Anker 100W charging dock also has an AC input of 100 to 240V 50-60Hz. Here is another thread where Snackchaser successfully powered the Mini with a 12V to 24Vdc Victron converter. I'm learning a lot from folks here. Edited October 16, 2024 by rideandfly 1 Bill 2015 LE2 #75 2024 F350 6.8L
Patriot Posted October 17, 2024 Author Posted October 17, 2024 (edited) Starlink Mini power cord storage solution. On our recent long trip I decided I needed to come with a solution to store our Starlink Mini power cord when we are traveling. After a deep dive, I ordered this reel and it will hold the entire 50’ SL mini power cord nice and neat. Winding up the power cord by hand each time was time consuming and usually it ended up looking like a rat nest. This musicians cord reel should be easier for deployment of the power cord as well as retracting when packing up our SL mini. Everything SL mini packs up nicely in our HF 3800 hard side storage case. I ordered a second reel for our spare SL mini power cord. Happy Camping from Hull #634 XPLOR https://www.amazon.com/gp/product/B07WYCR42L/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 Edited October 23, 2024 by Patriot 7 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted October 17, 2024 Posted October 17, 2024 just noticed this wording in the other thread cited here, "the router is built into the dish." Are all the Starlink Minis built this way? When I installed our Pepwave system, January of this year, they were asking $2,500 for Starlink HW and to my knowledge no mini was available. I want to add Starlink soon, but I do not want another router. The Pepwave has a WAN RJ45 input port, and it has the smarts to choose between the WAN source and cellular. I also want to install ours on our tow vehicle like I did the cellular antenna. Maybe I need another Starlink product vs. the Mini? Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted October 17, 2024 Author Posted October 17, 2024 (edited) 1 hour ago, jd1923 said: just noticed this wording in the other thread cited here, "the router is built into the dish." Are all the Starlink Minis built this way? When I installed our Pepwave system, January of this year, they were asking $2,500 for Starlink HW and to my knowledge no mini was available. I want to add Starlink soon, but I do not want another router. The Pepwave has a WAN RJ45 input port, and it has the smarts to choose between the WAN source and cellular. I also want to install ours on our tow vehicle like I did the cellular antenna. Maybe I need another Starlink product vs. the Mini? Starlink Mini Dish Open Source info - This compact, portable kit includes a built-in router that supports 2.4 and 5GHz bands, 802.11ax, and 3x3 MIMO. It also has an Ethernet port for connecting wired devices. Based on our experience we see no other reason to mod our Oliver with any other comm now having used our SL mini on a 48 day trip through 14 states. We won’t leave home without it. At the extraordinary rocket powered pace that Elon and SpaceX are deploying more satellites, SL will rule the day in comm. We are considering a SL home dish based how much we liked our mini on this last trip. Just plug it in to a power source with no obstructions and your on line. Edited October 17, 2024 by Patriot 1 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
MAX Burner Posted October 18, 2024 Posted October 18, 2024 14 hours ago, Patriot said: At the extraordinary rocket powered pace that Elon and SpaceX are deploying more satellites, SL will rule the day in comm. We are considering a SL home dish based how much we liked our mini on this last trip. Just plug it in to a power source with no obstructions and your on line. Concur, 100%, brother! 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Zodd Posted October 21, 2024 Posted October 21, 2024 (edited) On 10/17/2024 at 1:53 PM, jd1923 said: just noticed this wording in the other thread cited here, "the router is built into the dish." Are all the Starlink Minis built this way? Yes. This creates some pros and cons for the dish. It is small and compact and very easy to deploy. However, the further away you have to deploy it, the weaker your single and, in turn, your speed gest. So far, I have not found this to be a problem. The power cord is only so long and it can only get so far away. We just got back from our fall trip and had to put the SL mini as far away as we could to try and clear obstructions. Speed was still fine ( >80 mbps). The issue was still obstructions. As you can see we were pretty clear but had one section on the horizon that caused us to go between 97% ping success to 87%. At 87% zoom conference calls become an issue. Because of this I don't plan on mounting the mini to anything permanent on the TV or Ollie. I am looking for a stand to get it up higher but also mobile. This gives me the most flexibility to avoid obstructions. Also in case anyone is wondering. Here is what the power draw jump looks like when the mini needs to kick on its heater. Edited October 21, 2024 by Zodd spelling 4 Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
Patriot Posted October 23, 2024 Author Posted October 23, 2024 An interesting video on using Anker Prime portable battery packs to run the SL Mini. Naturally the larger Anker Prime battery provides a little more run time. This is all subject to how one intends to use the mini. Nonetheless kinda cool data. 1 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
rideandfly Posted October 27, 2024 Posted October 27, 2024 (edited) Just returned from our first camping trip using the Mini. Our campsite was covered with many trees, but managed to find a small opening in the following photo. Since it was a Rally, we spent a little more time in Ollie than normal. It was windy with tree limbs & leaves moving/falling, believe that affected the Mini's reception, too. Did not document obstructions like Zodd's previous post (I will next time). Used 11GB of data with three days of use streaming mostly with the ROKU device set at 720p resolution. Very pleased with the Mini's performance! 👍 View to NE (030) Edited October 27, 2024 by rideandfly 2 1 Bill 2015 LE2 #75 2024 F350 6.8L
Moderators SeaDawg Posted October 27, 2024 Moderators Posted October 27, 2024 Is it possible to start and stop the mini? To save on fees when not in use? 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Patriot Posted October 27, 2024 Author Posted October 27, 2024 (edited) 5 hours ago, SeaDawg said: Is it possible to start and stop the mini? To save on fees when not in use? No. SL does not offer a prorated plan at least for now. Once you start the new monthly subscription, you can pause it and still use the days left on the plan. After that when you unpause, you pay for another month of use. So for example ours runs out on Nov 2, I paused it upon our return from our western trip. If we want to unpause and use our mini after Nov 2, we pay for another month. edit and update - mid-billing cycle, you will only be charged for the remaining days in that cycle, especially when using the "Roam - 50GB" plan associated with the Mini; this applies to both pausing and unpausing your service. Edited October 28, 2024 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Patriot Posted October 27, 2024 Author Posted October 27, 2024 21 minutes ago, rideandfly said: Used 11GB of data with three days of use streaming mostly with the ROKU device set at 720p resolution. It will eat up GBs quickly which is why we opted for the unlimited plan on our recent 48 day trip. 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Zodd Posted October 28, 2024 Posted October 28, 2024 It does pro-rate based on start date. Our billing cycle is on the 11th of each month. In September we started on the 15th of the month and only paid $45. But it is only pro-rated based on start as regardless of when you pause you get it through the end of the billing cycle. 4 Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
Patriot Posted January 9, 2025 Author Posted January 9, 2025 Starlink monthly billing works as follows: Payment due date The first month's service fee is automatically charged on the payment due date, which is the earlier of the date you activate your Starlink Kit or 30 days after it ships. Recurring billing The service fee for each subsequent month is due on the monthly anniversary of the payment due date. Billing cycle The day you activate your Starlink becomes the recurring date for your statement. For example, if your billing cycle is June 28th–July 27th, you'll be billed on June 28th. Pricing Pricing may vary based on your location and selected equipment. Additional charges You may be charged additional automatic charges for Priority or Mobile Priority data if you opt-in to purchasing it after hitting your data limit. Payment methods Starlink accepts most credit cards, debit cards, and ApplePay. Alternative payment methods are supported in various regions. Pausing and reactivating If you pause your service, the month you pause is not pro-rated. If you restart your service, the month you restart is pro-rated. 1 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted February 17, 2025 Posted February 17, 2025 Ever since @Patriot started this thread, I've had the Starlink Mini on my list, TY. Chris made me aware of a new Starlink Beta working with T-Mobile (gotta love Elon)! I'm not sure I understand it fully, so we just signed up for the beta. We have a T-Mobile business account for our cell phones and Pepwave router. Want to add the Starlink Mini wired to the WAN port on the router, but if this new technology comes to fruition will we need the dish? Looks like Starlink may become a satellite based cell tower for T-Mobile. Motorla was working on this with the Iridium Project in the 90s which never came to be. We went with T-Mobile since recently their 5G network is more capable than the competitors and they actually have 5G in Prescott and nobody else does. Verizon and AT&T could be in trouble when this launches! Check out this link FYI: T-Mobile Starlink Satellite Phone Service: A New Era in Connectivity 2 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Tideline77 Posted February 18, 2025 Posted February 18, 2025 I’m ready for that ! plus a starlink smartphone and a starlink tablet chunk this Apple phone in the rubbish 4 Robert E 2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
Snackchaser Posted February 18, 2025 Posted February 18, 2025 6 hours ago, jd1923 said: will we need the dish? Yes, definitely sign up for the T-Mobile Beta program! It’s a rapidly growing technology that is the future of cellular service. T-Mobile is actively seeking new subscribers by offering the free Beta plan to get a jump on other major carriers, such as AT&T, who have similar satellite-based plans in the works. So the more people that sign up, the quicker the industry will respond. Currently, the T-Mobil/Starlink Beta plan only offers basic SMS text messaging with very limited bandwidth. . . which would be good for emergencies. No calling or data. This will likely increase as more Satellites are launched, but who knows how long that will be. So still consider a Dishy, I think they are on sale right now. Cheers! Geoff 3
Boudicca908 Posted March 20, 2025 Posted March 20, 2025 Starlink is great for being on the road. I was looking at the Starlink website today, and they have a special -- Standard kit for $149 (less than half normal price) offered until 3/31/25 "in select areas". Just FYI. 2 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Ronbrink Posted March 21, 2025 Posted March 21, 2025 15 hours ago, Boudicca908 said: Starlink is great for being on the road. I was looking at the Starlink website today, and they have a special -- Standard kit for $149 (less than half normal price) offered until 3/31/25 "in select areas". Just FYI. I checked on this and found the special pricing to be for the Standard kit for Residential plans. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted March 21, 2025 Author Posted March 21, 2025 (edited) 16 hours ago, Boudicca908 said: Starlink is great for being on the road. I was looking at the Starlink website today, and they have a special -- Standard kit for $149 (less than half normal price) offered until 3/31/25 "in select areas". Just FYI. We have been thinking about the standard SL for our home…so thanks for this news. As for travel we really are happy with the Mini for so many reasons especially small size and portability. Edited March 21, 2025 by Patriot 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
tallmandan Posted March 22, 2025 Posted March 22, 2025 Starlink just announced a new $10 for 10GB monthly plan for those that only need it for sporadic use. Data over 10GB at $2 per GB. Only good for an existing user so a new activation would have to be on the $50 plan and then switch to the $10 plan on month two. This is what I plan to do as camping season is about to start here in CO. https://www.rvmobileinternet.com/starlink-adds-cheapest-roam-plan-to-date-10gb-for-10/ 3 2 2020 Elite II #627, 2021 Silverado 1500 3.0L Duramax, Colorado
jd1923 Posted March 22, 2025 Posted March 22, 2025 2 hours ago, tallmandan said: Starlink just announced a new $10 for 10GB monthly plan for those that only need it for sporadic use. Data over 10GB at $2 per GB. Only good for an existing user so a new activation would have to be on the $50 plan and then switch to the $10 plan on month two. I'm thinking I may have this wrong, the "too good to be true" kind-a-thing. To me the $50 for 50 GB plan is good enough with $1/GB when over 50Gb. Then I read where you can pause the 50GB plan, use it for a few days or weeks, pause your access and then use it later. Can any current Starlink Roam plan user confirm if this is indeed true? I likely have this wrong. But if so, there would be no reason to buy 10 MB plus $2/MB when you can pay for 50GB and use it only when needed. If it cannot be paused, I would buy 10GB to get the Starlink installed, configured to our router, test access and then buy the $10 plan for a few days on the road, or pay $50 for a longer camp! 🤣 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted March 22, 2025 Posted March 22, 2025 (edited) We love Elon Musk in our family and before this year, I was never interested in an EV or even wanting a Starlink connection. TOTAL respect of this great American! His products are the most forward-thinking products of the 21st Century (Tesla, SpaceX, AI, his work in healthcare, etc.) OMG! Besides, who else do you know, on planet Earth or Mars, who measures 99.999% right-of-bell-curve in intelligence, with engineering and business sense? He's also good person, soft-spoken and humble. He who just rescued two NASA astronauts, left stranded by .gov! Those who protest, speak to the contrary, are very wrong. He's respectful of others at all levels and wanting the American dream he achieved for all Americans. Edited March 22, 2025 by jd1923 2 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators bugeyedriver Posted March 22, 2025 Moderators Posted March 22, 2025 (edited) After reading all of the positive comments about using the SL Mini, Bosker insisted we up our game. We now have one, with a waterproof case, the Anker Prime Power Bank, an extra 50' power cord for the mini for when the Bison chomps the old one, and a USBC to DC5521 adapter cord. Bosker and I are ready to rock-n-roll, with continual connectivity this summer, on our trip from Texas to Yellowknife, NWT, Canada!! (according to SL, Yellowknife has connectivity all way up there at 62.4N) Thanks, everyone, for blazing this trail and informing the Ollie family about this great accessory. Edited March 22, 2025 by bugeyedriver 5 2 Pete & "Bosker". TV - '18 F150 Super-cab Fx4; RV - "The Wonder Egg"; '08 Elite, Hull Number 014. Travel blog of 1st 10 years' wanderings - http://www.peteandthewonderegg.blogspot.com
jd1923 Posted March 22, 2025 Posted March 22, 2025 2 hours ago, bugeyedriver said: We now have one, with a... I believe I will be next. I've read the $100 sale may end for awhile after Mar 31st. I found out that Home Depot is a reseller for Starlink and I have a 10% coupon also ending 3/31. These Mini's should get cheap at some point, but net $450 may be the best price for 2025, at least until Black Friday sales late in the year. I'm thinking the Trio Mini Speedmount with magnet mounts for doing a fixed installation on the roof of our tow vehicle, integrated to the Pepwave router. And for the case where we need to get out from under trees, etc. I will get a battery setup and not use a power cord. This way, we would use the Starlink vs. the Pepwave Wi-Fi. I found several $20 kits that use the 20V DeWalt tool batteries. We always bring 3-4 DeWalt batteries with us, for a flashlight, an impact tool, a vacuum and leaf blower, and we have an extra charger permanently in the attic. https://www.amazon.com/dp/B0DM1T6VX2/?th=1 2 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
