Kraig Posted October 12, 2024 Posted October 12, 2024 2021 F350 SRW Diesel 2022 Oliver Legacy Elite II - Hull #1014 While traveling through Montana, rolling up to a stop light I decided to check my trailer brakes so I reached down and grabbed the controller and gently squeezed. To my surprise, nothing happened then I received a dash notification stating "trailer disconnected"! That will make you look behind you for sure. All good, trailer was still there. I tried it numerous on the rest of our trip, I would get the same notification. So, Wednesday I began looking into the issue. I heard there was some software issues with Ford and the brake controller but that was 2020 models. I saw somewhat of a wiring diagram in someone's post so I reached out to Oliver for a diagram. Mike said he didn't have one. So, to keep my man card I reached out to a Chris Scarff. I knew he had a similar problem. Unfortunately, our trailers wiring was different so that meant I had to do it the hard way and follow the trail of 12 volts. Without a diagram. With junction boxes below the bathroom sink. With wiring harnesses between the hulls. 😓 Although I am enjoying telling this story, I will cut to the chase. Someone at Oliver had used a solder connector, or at least one side of it, to connect 4 wires. The blue brake wire to the two blue wires that go outside the trailer and a red wire that I am assuming is the power for the emergency disconnect. So, if you are having a braking issue, check under the drivers side bed for a connector problem. I reported this to Mike and hopefully this is a one off, but you never know. I must admit the idea is kinda genius in a lazy couch potato kind of way. But not recommended! On a positive note, the trailer didn't push my truck at all, even in the mountains I didn't notice it. Another positive for bigger trucks than needed...until you do. Had I not pushed the brake controller I would have never known. 4 2 2021 Ford F350 6.7 Diesel, SRW, 4WD. 2022 Oliver LEII, Hull #1014.
Steph and Dud B Posted October 12, 2024 Posted October 12, 2024 Sloppy work by OTT for sure. Like you said, good thing you have the big truck. (I always check my brakes as I pull out of a location after hitching up.) 1 4 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Steve Morris Posted October 12, 2024 Posted October 12, 2024 Oddly, my brakes stopped working on our 2023 this past week. Brake light works, but no brakes. That’s on my list of things to do before it gets cold and before heading to Florida in January. 3 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Patriot Posted October 12, 2024 Posted October 12, 2024 (edited) 7 hours ago, Kraig said: Another positive for bigger trucks than needed...until you do. Had I not pushed the brake controller I would have never known. @Kraig My wife and I just completed one of our bucket list 7400 mile, 48 day trips out west camping and touring through CO, UT, ID, WY, MT, NB. I can say without any hesitation we were so glad to have the comfort, safety and cargo capacity of our 1 ton diesel F350. Ford nailed it with their diesel engine brake on the 10 speed 6.7 liter power plant. It sure came in handy on steep mountain passes like Wolf Creek and Teton Pass just to name a few. Good on you for checking your brake controller and identifying the issue. Thanks for passing this info forward. Safe Travels! Edited October 12, 2024 by Patriot 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators Mike and Carol Posted October 12, 2024 Moderators Posted October 12, 2024 There have been other posts on trailer brakes disconnecting. What happened to me, and others, is that the brake wires in the axle frayed and shorted out against the metal axle, a Dexter issue. We pulled the wires and rerouted new wires on the outside of the axle, problem solved. Oliver service is aware of this issue, they looked at my solution last time I was there. Ours also failed in Colorado, so I was also happy to have a big truck with a big diesel engine. Mike 1 6 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Rivernerd Posted October 12, 2024 Posted October 12, 2024 (edited) How did you resolve the issue? Was it just a failed connector which was replaced, or should the two blue and one red wires be separated? If so, what should they be connected to? Where, exactly, under the bed on the driver's side in a 2022 Elite II should I look? Had you been involved in a catastrophic accident where functioning trailer brakes would have made a difference, the photo of the shrink-wrap solder connector you attached should have made Oliver a defendant in the case, and ultimately liable for a large percentage of any awarded damages. Such revelations demonstrating Oliver's obvious lack of production quality control, even in 2022, are disturbing to me. Whoever was responsible to verify the integrity of electrical connections was obviously asleep on the job. We have Hull #1291, one of the last built in the 2022 model year. Your post makes me glad I verified, and adjusted, trailer brake function on the road leading away from the Oliver Service Department facility right after we accepted delivery of the trailer. I recommend that anyone taking delivery of a new Oliver do the same. Particularly if their tow vehicle is not a 1-ton like yours! Edited October 12, 2024 by Rivernerd typo 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Rivernerd Posted October 12, 2024 Posted October 12, 2024 (edited) 14 hours ago, Kraig said: I must admit the idea is kinda genius in a lazy couch potato kind of way. But not recommended! You are very kind. As a retired attorney whose litigation practice included defense of auto claims involving life-altering catastrophic injuries, I am not so generous. Cutting corners with a critical safety system, like legally-mandated trailer brakes, is not "genius;" it is remarkably stupid and grossly negligent. Given this discovery of such sloppy work, Oliver would be well advised to verify the efficacy of trailer brakes on each Elite II before they allow it to leave the factory. Edited October 12, 2024 by Rivernerd 4 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
jd1923 Posted October 13, 2024 Posted October 13, 2024 If our trailer brakes did not test working positive when leaving a campsite, I would certainly fix the issue prior to any highway travel. Hope you were not in western Montana! Yes, the big F350 can stop itself and a 7K LB trailer, but not the issue. If the road gets slippery or some gravel, or an odd angle on a downhill slope, the trailer can easily jackknife w/o brakes. Then there are legal issues in you knowingly driving on US highways with faulty equipment required by law. Trailer brakes are required by law for 7K+ trailers. 3 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted October 13, 2024 Posted October 13, 2024 On 10/11/2024 at 7:01 PM, Kraig said: While traveling through Montana, rolling up to a stop light I decided to check my trailer brakes so I reached down and grabbed the controller and gently squeezed. To my surprise, nothing happened then I received a dash notification stating "trailer disconnected"! Our 7-Pin connection failed us last year. Art and I replaced it with one that has LED indicators for each of the wires heading back. Worth the extra few $ in my opinion. We check the trailer brakes with the manual trailer actuator every time we start out our day. A good idea to know if you have trailer brakes before leaving the camp site. Twice in 7 seasons we circled back to our camp site and worked the issue. Sort of like a "Don't Leave Home" without brakes idea. GJ 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jamesgang Posted February 13, 2025 Posted February 13, 2025 On 10/12/2024 at 4:36 AM, Patriot said: @Kraig My wife and I just completed one of our bucket list 7400 mile, 48 day trips out west camping and touring through CO, UT, ID, WY, MT, NB. I can say without any hesitation we were so glad to have the comfort, safety and cargo capacity of our 1 ton diesel F350. Ford nailed it with their diesel engine brake on the 10 speed 6.7 liter power plant. It sure came in handy on steep mountain passes like Wolf Creek and Teton Pass just to name a few. Good on you for checking your brake controller and identifying the issue. Thanks for passing this info forward. Safe Travels! i switched from an ecoboost F150 to a 6.7D F250 for the mountain pass reason - F150 could pull, but it didn't have the comfortable braking (including engine braking) the F250 has 2 2017 F250 Platinum D6.7L 2016 LE2 #157 with all options // Upgrades: Truma CP Plus and A/C, D52 Axles, Windows, Bath Fan, 4xTrojan AGM AES (-40F)
Patriot Posted February 13, 2025 Posted February 13, 2025 1 hour ago, jamesgang said: i switched from an ecoboost F150 to a 6.7D F250 for the mountain pass reason - F150 could pull, but it didn't have the comfortable braking (including engine braking) the F250 has It’s a night and day difference, wise choice and welcome to the forum! I also see you have added a bunch of nice upgrades to your Oliver, well done! 👍🏻 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators topgun2 Posted February 13, 2025 Moderators Posted February 13, 2025 1 hour ago, jamesgang said: F150 could pull, but it didn't have the comfortable braking (including engine braking) the F250 has 2 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Jason Foster Posted February 16, 2025 Posted February 16, 2025 On 10/12/2024 at 7:40 PM, jd1923 said: If our trailer brakes did not test working positive when leaving a campsite, I would certainly fix the issue prior to any highway travel. Hope you were not in western Montana! Yes, the big F350 can stop itself and a 7K LB trailer, but not the issue. If the road gets slippery or some gravel, or an odd angle on a downhill slope, the trailer can easily jackknife w/o brakes. Then there are legal issues in you knowingly driving on US highways with faulty equipment required by law. Trailer brakes are required by law for 7K+ trailers. This. We should all be checking our trailer brakes. It is the very first thing I do when pulling out of the campsite and I also drive a big diesel powered truck. Like @Rivernerd mentioned, liability is separate from personal safety. You might be fine with your big truck but if you run over a kid chasing a soccer ball and you stopped just fine but your trailer brakes aren't working, you and/or the manufacturer will be in trouble. ALWAYS check those brakes and fix them before going anywhere. 3 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
