Carl Hansen Posted April 23, 2025 Posted April 23, 2025 Greetings! Has anyone ever tried using "quick connects" on your city and fresh water inlets? It seems it would make things a bit easier if you are moving campsites regularly. I think it would be straight forward on the city water inlet but there might be a problem on the fresh water inlet. I have noticed that after filling the fresh water there seems to be water that flows out after I disconnect the hose. Is that water that from the fill tube into the holding tank. Would that cause any siphoning effect of the fresh water if the rubber plug was not re-inserted? I use stainless steel quick connections from McKillans on my power washer. They make an amazing product. I was wondering if their garden hose quick connects might work on the Oliver water inlets. Thoughts? Carl 2021 Legacy Elite I | "Lil' Tow" | Hull #924 Tow Vehicle: 2020 Jeep Gladiator
Moderators topgun2 Posted April 23, 2025 Moderators Posted April 23, 2025 Do you mean like - THIS or THIS or THIS or ???????? Simply type in the "Search" box at the top of the page the words "quick connect" and start looking. Bill 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted April 23, 2025 Moderators Posted April 23, 2025 Yes, we use quick connects on our fresh and city water connections. There are a bunch on Amazon, we’ve had ours for years. As far as water draining after you disconnect your hose, the backflow valve is at the back of the basement, a few feet from the connection, so the water that has not passed through the valve is probably what you are seeing drain. I have that too. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Carl Hansen Posted April 24, 2025 Author Posted April 24, 2025 I did the search before posting and did not come up with any of those threads you shared. Thanks for the help. This how the stainless steel McKillans look on the Oliver. Carl 3 2021 Legacy Elite I | "Lil' Tow" | Hull #924 Tow Vehicle: 2020 Jeep Gladiator
Patriot Posted April 24, 2025 Posted April 24, 2025 As @topgun2 linked above..these are high quality. https://www.eleyhosereels.com/products/garden-hose-quick-connectors?srsltid=AfmBOorhl73lbWlG-pTRQ_aHjougxYv88x-aD4DfsGjJACCyuZjoAX0t 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Steve and MA Posted April 24, 2025 Posted April 24, 2025 We use quick connects on our freshwater fill without issues. We seldom connect directly to city water. There are two good quality quick connects that we've used. One is the design from McKillans (typically stainless steel) and the other more common one was from Camco (typically brass). We haven't used the Eley brand mentioned above. None of these have backflow check valves, so there's some leakage upon disconnect. The Camco and McKillans types are similar but not compatible with one another. We used the Camco connectors until we added a Blue Technologies water softener and hose reels. Blue Tech has McKillans style connectors and a mix of NPT 1/2 inch and garden hose threaded connections. The Blue Tech softener and reels, along with a Clearsource water filter system, are mounted in our TV and are used to fill our fresh tank. Steve 1 Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
BigTexas Posted April 24, 2025 Posted April 24, 2025 We use quick connects. I also use a Y adaptor with individual gate valves at the park spigot to depressurize the line before disconnecting. Seems obvious but if you ever forget things get exciting quickly, especially if you use one of the expandable hoses. Also, the search function on this site sometimes is not very helpful. Others have posted a web format to use to make Google search the site more effectively. 1 Big Texas – 2018 Elite II, Twin Bed, Hull #306 2024 RAM 2500 6.7L Cummins, Weigh Safe hitch
2008RN Posted April 24, 2025 Posted April 24, 2025 (edited) I have 2 of the Eley hose reels with every thing has the Eley quick connects for the house. I have the male quick connect that I take off and on the 2 stage water filter for filling the fresh water at home. Never thought of fitting the Oliver and changing every thing to quick connects. so all I need is a pigtail to use at the camp site. The Eley products are pricey, but quality is top notch. I have almost 2 acres to water by hand in the summer, and have tried other reels, the Eley has out lasted the others, The hoses also have lasted longer than the big box stores. I dislike having to reach down under the edge of the trailer to hook the water up, especially when it is raining and the ground is filthy, and I have to work to get a nice tight connection. I think I will put a parts list together to upgrade filter/pressure regulator/hoses to Eley. i like the looks of the McKillans better than the Eleys but since I'm already intrenched with Eley at home, I will stay with Eley. Edited April 24, 2025 by 2008RN Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
Carl Hansen Posted April 24, 2025 Author Posted April 24, 2025 Let’s seem to be a great product. Multiple people here seem to be using that brand. 2021 Legacy Elite I | "Lil' Tow" | Hull #924 Tow Vehicle: 2020 Jeep Gladiator
dewdev Posted April 24, 2025 Posted April 24, 2025 (edited) @2008RN I have a small piece of plexiglass that I keep in the cellar to use to kneel down on when connecting my hoses. Edited April 27, 2025 by dewdev 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
2008RN Posted April 25, 2025 Posted April 25, 2025 thanks great idea Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
Moderators topgun2 Posted April 25, 2025 Moderators Posted April 25, 2025 18 hours ago, dewdev said: I have a small piece of plexiglass that I keep in the cellar to use to kneel down on when connecting my houses. 11 hours ago, 2008RN said: thanks great idea A couple of members (like Patriot) have used a small foam kneeling pad like THIS. Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Carl Hansen Posted April 25, 2025 Author Posted April 25, 2025 Those are great. That is what I use. Saves the knees! 2021 Legacy Elite I | "Lil' Tow" | Hull #924 Tow Vehicle: 2020 Jeep Gladiator
Patriot Posted April 25, 2025 Posted April 25, 2025 (edited) 1 hour ago, Carl Hansen said: Those are great. That is what I use. Saves the knees! Your knees will thank you! My foam kneeling pad lives in the Oliver’s basement. 👍🏻 Edited April 25, 2025 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted April 26, 2025 Posted April 26, 2025 On 4/24/2025 at 2:30 PM, dewdev said: I have a small piece of plexiglass that I keep in the cellar to use to kneel down on when connecting my houses. On your knees to connect a hose! 🤣 Sorry, not on my knees. I'm only getting on my knees for necessary repairs under truck or trailer. These make it easier and thanks to @Patriot the Eley connections can be put on and taken off one-handed (off pressure released). 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
John Dorrer Posted April 26, 2025 Posted April 26, 2025 I can still bend over and screw the quick connect on. No kneeling🤣. I must say, it can be a pain. However, I prefer to do as I do rather than having something sticking out there that is a target of road debris. To risky for me. 3 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
jd1923 Posted April 26, 2025 Posted April 26, 2025 4 hours ago, John Dorrer said: I can still bend over and screw the quick connect on. No kneeling🤣. I must say, it can be a pain. However, I prefer to do as I do rather than having something sticking out there that is a target of road debris. To risky for me. I was bending over too, never on knees, but now with these shorty extensions I do not have to crane my neck. Not truly risky. Check out the picture for perspective. The trailers tires are much further out and so is the rear bumper. They are also flexible so if something was to hit them they would just fold back. If something was to het them it would also hit the rear bumper which would be a big owie! I've loved them ever since adding them. Lead-free brass, good for drinking water (not that we drink water from the Oliver). https://www.amazon.com/Fevone-Extension-Flexible-Protector-Drinking/dp/B0BFWPFTFH/ Then I got these simple 1" chair leg caps for the Eley male ends which are inexpensive and fit nicely snug. https://www.amazon.com/gp/product/B000SKXR0C/?th=1 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
