John Dorrer Posted October 29, 2025 Posted October 29, 2025 (edited) 19 hours ago, Steve Morris said: I've not acted on advice to switch to steel valve stems while using our TST tire pressure monitor. Yesterday, that procrastination bit me in the ass on my way home from the Hungry Mother Fiberglass Rally in Virginia. Rapid Pressure Loss" or similar wording was what the monitor said with a constant loud beeping. A quick look in my mirror showed the front left trailer tire was indeed low. Stopped to check, and with 28 PSI showing, I elected to slowly drive to the next exit, and found a flat spot in a gas station lot. The rubber valve stem was partially separated from the rubber base, and if flexed, dumped out pressurized air. No fixing that on the spot! Time to change tires. I have all the tools needed, and it was a cool sunny day, so that was a bit of luck. It had been raining a few hours earlier. I didn't have my impact driver with me, but I do have an 18" breaker bar, so I could loosen the lug nuts. Before jacking up and removing the tire, though, it was time to get the spare. Two heavy e-bikes made this a chore, but fortunately, that's when a large fellow stopped and offered to help. (Oddly enough, the local deputy sheriff who was using the facilities at the station never even checked to see if we needed anything on his way out of the parking lot.) With his help, we slid the rack and mount out far enough to get to the spare. His impact driver made for a faster swap than my breaker bar, and his torque wrench was easier to get to than mine buried in the trailer's basement. All in all, about an hour and a bit delay, and the kind gentleman who stopped to help refused any remuneration. - I usually only carry the impact driver with me on long trips. And while this was about an eight hour drive, I'd elected not to bring it with me. It will now be included in every trip. - I'll be removing the bike rack mount and cleaning those surfaces and applying a dry lube to make it easier to slide the rack in and out. After we were done, I was really re-thinking John Davies choice to not use the fiberglass tire cover while toting bicycles! - I will be changing to all steel valve stems before we leave on our next trip! I was lucky, we had a slow leak so we could fill and get home. We went to a truck tire place and they vacuumed out balance beads and installed metal valve stems. Edited October 29, 2025 by John Dorrer Typo 5 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Geronimo John Posted November 25, 2025 Posted November 25, 2025 (edited) On 9/28/2025 at 6:17 PM, ADKCamper said: My deep socket gets stuck as well… with both the closest sae and metric sizes. I suspect poor quality control on the chrome-covered lug nuts’ outer dimensions. This issue has been a long running one. Some time ago I copie Frank's post: OE2 LUG NUTS: Frank 😄 For anyone getting replacement lug nuts, make sure you get the proper type for aluminum wheels. The correct ones are the “bulge acorn” type which have a larger conical seating surface for use on aluminum wheels. Aluminum wheels are softer than steel wheels and require the larger seating surface. The ones installed by Oliver are the correct bulge acorn type so get the same style. “Acorn” type have a smaller conical face and are for steel rims. JPR: COMPARE SPECIFICATIONS! 24 required. I believe it was MaxBurner that turned me on th these chrome plated lug nuts from Summit Racing. My regular sockets work well with them and no interference with the wheel rims on our 2019. Edited November 25, 2025 by Geronimo John Edited finish per Steve & Ma. Thanks Steve! 5 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Steve and MA Posted November 25, 2025 Posted November 25, 2025 26 minutes ago, Geronimo John said: these stainless steel lug nuts from Summit Racing. My regular sockets work well with them and no interference with the wheel rims on our 2019. The Summit sourced lug nuts are chrome plated steel, not stainless steel. The OEM Lionshead Jaguar wheels on our 2022 LE2 have steel lug nut inserts. The contact between lug nut and wheel is steel against the lug nut, not lug nut directly against the aluminum. There are stainless steel lug nuts available, but none that are bulge acorn. Show me if you know otherwise. Bulge acorn vs. acorn is irrelevant due to the steel lug inserts on the Lionshead wheels. From what I can see, the contact between the insert and lug is the same whether the acorn nut is the bulge style or not. I don't know if the aluminum wheels on other year models had steel lug inserts. If not, then use the bulge acorn style. If you want to use stainless steel acorn (non -bulge) lug nuts, then keep in mind there's a risk of galling, which effectively welds the lug nut to the stud. Avoid use of impact tools to remove/replace the lug nuts to mitigate this risk. Steve 4 1 Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
Boudicca908 Posted November 25, 2025 Posted November 25, 2025 10 hours ago, Steve and MA said: there's a risk of galling This has been one of the more informative threads I've read in some time. All kinds of lessons to be learned. Thanks to all. Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Geronimo John Posted November 25, 2025 Posted November 25, 2025 (edited) On 11/24/2025 at 7:08 PM, Steve and MA said: If not, then use the bulge acorn style. Steve: Thanks for the correction. I updated my post accordingly to "Chrome Plated" steel. Our 2018 OTT rims came with the “bulge acorn” style. Replaced them with the same style as recommended by Frank and by MaxBurner sold by Summit. They have worked very well and my standard sockets work with them. I do use a Dewalt 20V impact to remove and snug up. But for the final three tightening stages by torque wrench. (Retorque in three stages (60, 80 and 95/100 ft-#). GJ Edited November 26, 2025 by Geronimo John typo 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ollie-Haus Posted November 25, 2025 Posted November 25, 2025 (edited) My emergency tire service kit includes the following. The reason I carry these items is they take up little space and stow in an easy access location like under the back seat of the truck or in the front tongue box on the Oliver. The Milwaukee charger is mounted on the side wall of our truck bed for anytime access. With that out of the soft case, the impact socket set fits nicely inside the soft case with the light and impact wrench so everything is together. I like having a tire plug kit along because a screw or nail in the tire is the most common cause and as mentioned earlier is the easiest fix and can be done with wheel still mounted to trailer. All these items fit neatly in a small space and are invaluable for getting you safely back on the road in a tire emergency. The most important thing is to try if possible to do an emergency repair away from traffic on a hard level surface. There are other tools you can have along to do a more thorough repair, but this set of tools will get you back on the road and safely to the closest tire shop if needed. This wrench fully charged has enough charge to remove all four wheels on your truck or trailer. The batteries will stay charged for many months in storage. https://www.homedepot.com/p/Milwaukee-M12-FUEL-12V-Li-Ion-Brushless-Cordless-Stubby-1-2-in-Impact-Wrench-Kit-w-2-5-0Ah-1-2-5-Ah-High-Output-Batteries-2563-22-48-11-2450/337134504 The sockets are extra deep so you won't need an extension even with a torque wrench. If needed you can remove the protective sleeve on the socket to fit the lug nut in the wheel. Three sizes to fit most automotive lug nut sizes. https://www.amazon.com/dp/B0C98ZHKQX?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_7&th=1 12V Milwaukee work light is indispensable in many ways and uses the same battery as the impact wrench. https://www.amazon.com/dp/B0BRZ31ZFS?ref=ppx_yo2ov_dt_b_fed_asin_title Tire plug kits come in many types and sizes. I personally like the mushroom style plugs. https://www.amazon.com/dp/B0FK4SNRBG?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 Edited November 26, 2025 by Ollie-Haus 6 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23
Geronimo John Posted November 26, 2025 Posted November 26, 2025 (edited) I carry pretty much the same roadside kit. I also carry a Dewalt 20V air compressor. GJ Edited November 27, 2025 by Geronimo John Typo 20V air compressor. 5 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ollie-Haus Posted November 26, 2025 Posted November 26, 2025 (edited) 19 hours ago, Geronimo John said: I carry pretty much the same roadside kit. I also carry a Dewalt 12V air compressor. GJ I have a built in compressor on the truck but yes, absolutely need some type of built in or portable air compressor. I personally favor the Milwaukee M18 portable compressor, which happens to be nicely discounted for Black Friday at this time: https://www.homedepot.com/pep/Milwaukee-M18-18-Volt-Lithium-Ion-Cordless-Inflator-with-2-5-0Ah-Batteries-and-Charger-2848-20-48-59-1852B/326514175 Edited November 26, 2025 by Ollie-Haus 1 1 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23
Geronimo John Posted November 26, 2025 Posted November 26, 2025 Chris: I have to agree that likely the Milwaukee line isbetter quality than the DeWalt line for just about everything. At a cost penalty of course. But the 20V vs. 18V difference compensates a bit though. In 2018 I wanted to "lighten up" my industrial tools for use in our travel gear. I was replacing my ancient (Seriously WW2 vintage) drill, impact and masonary drill. My oldest son inherited these monsters. At the time I went with the DeWalt line. One of the deciding factors was a common 20V battery, as that's the real cost factor in all of the 18/20V class lines. Since then I have acquired Dewalt multi-tool and a grinder. Have not needed to buy any additional batteries. Knock on wood.... I love my Dewalts. But, if one were to offer a 1 for 1 trade to the Milwaukee line.... I would join you. So long as I didn't have to pay for the swap. 🙂 The only Dewalt 20 V that I don't recommend is their "skill saw" my son-in-law purchased. It is a battery eater 2X/day. All the others can generally work all day on a charge while doing carpentry work. 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted November 26, 2025 Posted November 26, 2025 On 9/24/2025 at 6:47 PM, Steve and MA said: As already mentioned, the electric jacks can be used for tire changing as long as you're still hitched and the TV parking brake is set. Very EXCELLENT! Please add: ON LEVEL GROUND and tie a ribbon on the steering wheel to indicate "No Move". I also use the OEM jacks for all my maintenance efforts. When on level ground. Why? The jack forces are compressive down the jack leg. On a slope the forces are compressive and sheer. These jacks are not designed for sheer forces. For that you would need a "floor jack". Not something to carry cross country. Safety John 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ollie-Haus Posted November 27, 2025 Posted November 27, 2025 3 hours ago, Geronimo John said: Chris: I have to agree that likely the Milwaukee line isbetter quality than the DeWalt line for just about everything. At a cost penalty of course. But the 20V vs. 18V difference compensates a bit though. In 2018 I wanted to "lighten up" my industrial tools for use in our travel gear. I was replacing my ancient (Seriously WW2 vintage) drill, impact and masonary drill. My oldest son inherited these monsters. At the time I went with the DeWalt line. One of the deciding factors was a common 20V battery, as that's the real cost factor in all of the 18/20V class lines. Since then I have acquired Dewalt multi-tool and a grinder. Have not needed to buy any additional batteries. Knock on wood.... I love my Dewalts. But, if one were to offer a 1 for 1 trade to the Milwaukee line.... I would join you. So long as I didn't have to pay for the swap. 🙂 The only Dewalt 20 V that I don't recommend is their "skill saw" my son-in-law purchased. It is a battery eater 2X/day. All the others can generally work all day on a charge while doing carpentry work. Totally agree, you stick with the brand and size of battery system you start with. I chose Milwaukee because that's what I used for years at work and was able through work to get significant discounts at the time. Not to start over in retirement, I've continued with the brand. One thing we can do now when replacing an old tool is to buy the new brushless version of tools when available by most companies that offer more powerful and much more efficient motors in the tools that make the batteries last much longer. I have had Dewalt tools a few years ago and loved them and actually still have a drill that still works fine. Regardless of brand, having the right tools on board when out on the road can make for quick and easy repairs and less downtime in an unexpected emergency.👍 PS: If you shop at Home Depot and compare the two brands, you actually get a much better price with the Milwaukee if you are buying the whole kit with batteries. The Milwaukee comes with two larger batteries and charger for a considerably lower price than the similar DeWalt kit which only includes one smaller battery at a higher price. Home Depot is definitely the source for deep discounts on Milwaukee tools. 1 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23
Geronimo John Posted November 27, 2025 Posted November 27, 2025 For sure on getting the kits. Also having a smaller (2AH) and a larger (5AH) battery packs. I generally use the 5AH in the air compressor and the 2AH in everything else. I guess we should unhijack this thread. Sorry John and Jodi! John and Jodi: What tires were on your trailer? Having two tires to fail sounds like a thread we posted earlier this year. 🙂 GJ DIY - Two Flat Tires On An OE2.docx 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted November 27, 2025 Posted November 27, 2025 (edited) Last week at Galveston Island SP, used my tire plug kit to repair where a screw was causing a slow leak. Tried doing it with the tire still mounted, but those Load Range E tires are really stout and ended up having to remove to get more leverage. The Bottle Jack/Jack Stand, VIAIR, DeWalt impact wrench, assorted lug nut sockets and torque limiting impact extension bars all came into play! Upon return home I ordered a heftier tire plug kit and will put the former in the wife’s SUV. Bottom line, BE PREPARED! Edited November 27, 2025 by Ronbrink 4 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Steve Morris Posted November 27, 2025 Posted November 27, 2025 Be careful with inexpensive tire repair kits. Over the years I have read several reports of the plastic handles failing, impaling the drill in the operators hand. If you've never done a repair, I would suggest practicing on a junk tire. It is a lot harder than it looks to push the drill through an E-rated tire! A battery drill makes it much easier. I've had this set from ARB for about 10 years, and fortunately have only had to use it once: https://ok4wd.com/arb-speedy-seal-tire-repair-kit-arb10000011/ 5 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Ronbrink Posted November 27, 2025 Posted November 27, 2025 5 hours ago, Steve Morris said: Over the years I have read several reports of the plastic handles failing, impaling the drill in the operators hand. So true. The former are solid plastic and better suited for the passenger tires on the SUV. The new tools are solid aluminum and a much better fit for the intended purpose. Definitely shy away from the cheap plastic ones that can’t withstand the excessive forces needed for our trailer tires! 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted November 27, 2025 Posted November 27, 2025 7 hours ago, Steve Morris said: It is a lot harder than it looks to push the drill through an E-rated tire! A battery drill makes it much easier. Good point, and it’s even harder pushing the plug in as far as recommended. I ended up using liquid dish soap to lubricate, did the trick! Some kits come with either a lubricant or a sealant, which serves as the lubricant. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted November 29, 2025 Posted November 29, 2025 On 11/27/2025 at 1:53 PM, Ronbrink said: Good point, and it’s even harder pushing the plug in as far as recommended. I ended up using liquid dish soap to lubricate, did the trick! Some kits come with either a lubricant or a sealant, which serves as the lubricant. Once I had to get out a drill and make a hole so I could get the plut into the leak. Wasted an hour trying to do so before the light bulb came on. I also have had leaks in the main tread area that took three plugs to slow them down. Even with three, it still leaked, but slow enough that I could get off the mountain by re-airing up twice. Good idea to have an air compressor of some sort! GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Jamie Peghiny Posted November 30, 2025 Posted November 30, 2025 (edited) This thread has been a real eye opener and very helpful. I’ve been a travel trailer owner since 1995 and have had two tire problems that were easily resolved because we were near tire dealers. I always travel with a pile of tools but have never been prepared with impact wrenches, deep sockets, torque wrenches or tire repair kits. I will be soon though. Hopefully I’ll never have to use any of this stuff. I will take the advice given here to practice jacking, removing and replacing a tire here at home so we’ll both know what to do. The Word DIY document is very good and I will print two copies and store them as recommended. My brother in law blew out two tires on the highway last summer on the first and second days of a month long trip and ended up buying 4 new tires. Those tires were less than 3 years old (not an Oliver, a big 5th wheel). Thank you for this. I hope to contribute to this knowledge base sometime. Jamie Edited November 30, 2025 by Jamie Peghiny 1 2 1 Jamie and Sandi New Harbor, Pemaquid Point, Maine 2021 LEII Hull #802
Geronimo John Posted November 30, 2025 Posted November 30, 2025 As a new member of the forum, welcome aboard! Lots of great owners out here with a many tons of knowledge that's way over my head as well. Especially in electronic gizmology. So please don't be shy in asking questions and then follow-up's when necessary. I can guarantee one, if not several, of the owners is an absolute expert on the topic du jour. Travel safe and enjoy every day, Geronimo John 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted November 30, 2025 Posted November 30, 2025 Jon and Jodi: What manufacturer and model of tires did you have trouble with? GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Tideline77 Posted November 30, 2025 Posted November 30, 2025 in case the OP doesn’t reply I will chime in his Signature shows 2022 year model hull pretty sure that the 2022 year models got Coopers My foggy memory thinks that Michelin tires were the Oliver spec but Coopers were substituted due to supply chain issues ………Covid our 2022 has Coopers as many others have 2 Robert E 2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
Moderators topgun2 Posted December 1, 2025 Moderators Posted December 1, 2025 14 hours ago, Tideline77 said: My foggy memory thinks that Michelin tires were the Oliver spec but Coopers were substituted due to supply chain issues ………Covid And the fact that Michelin stopped making a tire in the size needed for the Oliver. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Geronimo John Posted December 2, 2025 Posted December 2, 2025 On 9/25/2025 at 12:11 PM, jd1923 said: If you have rubber, make sure to install high-quality STEEL valve stems first. Buy from Summit or local auto parts store, NOT Amazon China-made. Tire companies do not carry them. JD: Which one do you recommend at Summit? GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted December 2, 2025 Posted December 2, 2025 Lots of good reminders and recommendations in this thread. There are two more: First, a good TPMS is essential for our trailers. Consider it SAFTEY Required. Secondly, if it hollers at you, immediately turn on the flashers and slow down to buy time. Find a flat spot to address whatever is amiss. Slowing down may likely turn a steel reinforcement wire nightmare into just a wobbling tire event. Great thread! GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted December 2, 2025 Posted December 2, 2025 (edited) 9 hours ago, Geronimo John said: JD: Which one do you recommend at Summit? GJ Regardless of where you buy, be sure the valve stems are compatible with the internal tire pressure sensors on your TV to ensure proper fitment. I purchased mine at tpmsdirect.com. Took them to Discount Tire and they installed them free, probably since I’ve done business with them for years. Edited December 2, 2025 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
