3 hours ago, Galway Girl said:
those with the Xantrex Freedom XC2000 inverter…
Great post, Craig!
Battle Borns gone.  Epoch’s installed.  Hold down straps aren’t on yet.
46 minutes ago, Mike and Carol said:
Epoch’s installed.
Mike, very happy for you, on your 600 Ah upgrade!
It looks like you used the bolts that came with the Epochs on all 4 posts. I found when the 4/0 lugs were doubled up that the OEM bolts only had a few threads to hold on. Yours might be fine, depends on the thickness of the lugs, but on two I used M8 bolts 5mm longer (see pic).
John, thanks.  I’m using 2/0 cables.  I asked the Epoch guy and he said 2/0 or bigger.  I also have some longer M8 bolts that I ordered just in case.  The bolts that came with the batteries work fine.  I’m happy with the upgrade!
