jd1923 Posted February 26 Posted February 26 3 hours ago, Galway Girl said: those with the Xantrex Freedom XC2000 inverter… Great post, Craig! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted March 1 Moderators Posted March 1 Battle Borns gone. Epoch’s installed. Hold down straps aren’t on yet. 7 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted March 1 Posted March 1 46 minutes ago, Mike and Carol said: Epoch’s installed. Mike, very happy for you, on your 600 Ah upgrade! It looks like you used the bolts that came with the Epochs on all 4 posts. I found when the 4/0 lugs were doubled up that the OEM bolts only had a few threads to hold on. Yours might be fine, depends on the thickness of the lugs, but on two I used M8 bolts 5mm longer (see pic). 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted March 1 Moderators Posted March 1 56 minutes ago, jd1923 said: Mike, very happy for you, on your 600 Ah upgrade! It looks like you used the bolts that came with the Epochs on all 4 posts. I found when the 4/0 lugs were doubled up that the OEM bolts only had a few threads to hold on. Yours might be fine, depends on the thickness of the lugs, but on two I used M8 bolts 5mm longer (see pic). John, thanks. I’m using 2/0 cables. I asked the Epoch guy and he said 2/0 or bigger. I also have some longer M8 bolts that I ordered just in case. The bolts that came with the batteries work fine. I’m happy with the upgrade! 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted March 1 Posted March 1 (edited) 13 hours ago, Mike and Carol said: John, thanks. I’m using 2/0 cables. I asked the Epoch guy and he said 2/0 or bigger. I also have some longer M8 bolts that I ordered just in case. The bolts that came with the batteries work fine. I’m happy with the upgrade! Excellent Mike! hard to determine cable size in a picture. It’s more the load to spec wire gauge and fuse amperage vs. battery type or Ah. If you have a 2KW inverter, 2/0 wire and 250A fuse are fine. 4/0 wire and higher fuse amperage are required to run a 3KW inverter at full capacity. 😎 Edited March 1 by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
rich.dev Posted March 16 Posted March 16 Ouch for BB…yet another video from Will Prowse, he’s not holding back in this one! 😀 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
John Dorrer Posted March 16 Author Posted March 16 17 minutes ago, rich.dev said: Ouch for BB…yet another video from Will Prowse, he’s not holding back in this one! 😀 You beat me to it. Unbelievable. 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Moderators Wayfinder Posted March 17 Moderators Posted March 17 If it's as bad as it appears, I hope they (BB) don't wait for someone to get hurt or worse, die, from a battery fire. What a shame. Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Geronimo John Posted 19 hours ago Posted 19 hours ago On 3/16/2026 at 2:22 PM, Wayfinder said: If it's as bad as it appears, I hope they (BB) don't wait for someone to get hurt or worse, die, from a battery fire. What a shame. The average vintage of RV owner's is such that Dragon Fly should be worried about just such a tragedy. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators Wayfinder Posted 5 hours ago Moderators Posted 5 hours ago Here are recommended products by Will. He loves EPOCH and Victron. 2 Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
rideandfly Posted 1 hour ago Posted 1 hour ago We had two newer BB 100AH batteries in Ollie, but recently installed two 105 AH Epoch batteries in parallel. I like the physically smaller/lighter Epoch batteries for our application compared to BB along with Epoch's customer support and Epoch's app to monitor Epoch Bluetooth Smart battery condition. Really like the built in Epoch carry handles on the 105AH batteries making it easy to install & remove these 22lb batteries. We don't have factory solar or an inverter like many folks here. We have a Progressive Dynamics 45 amp charger and also charge with up to two Renogy 100W Portable Suitcase Solar Panels and Renogy Solar controller when away from shore power. Looking forward to seeing how fast the Epoch batteries will charge with 100W Portable Suitcase Solar Panels during the 2026 camping season. 1 Bill 2015 LE2 #75 2024 F350 6.8L
mountainoliver Posted 14 minutes ago Posted 14 minutes ago 5 hours ago, Wayfinder said: Here are recommended products by Will. He loves EPOCH and Victron. Not at all getting on your case because part of my lithium battery research 6 years ago was Will’s channel and still is part of my solar/battery research. I purchased three BB batteries then along with several Oliver friends. Back then BB batteries were the gold standard. Back then Will did all sorts of testing, he went to the BB “factory”, and interviewed the owner. He was as excited about BB batteries as a little kid at Christmas. They could do no wrong back then. Fast forward to today, something changed. Anyway we do the best we can with our research and still…..🤞🤪 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
rich.dev Posted 4 minutes ago Posted 4 minutes ago 6 minutes ago, mountainoliver said: Fast forward to today, something changed. Anyway we do the best we can with our research and still…..🤞🤪 Will obviously now has more and better equipment than he did a few years back, and what really changed is that he discovered some significant problems with BB batteries. **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
