We have several  first aid kits. One in the truck. One in the trailer, front of the shelf of the closet. Another bigger bag, more extensive,  that moves from the boat to the hall closet, or can move to the truck, for longer trips. I  also carry a very few items in my purse, and tuck a few in the glove box.
One of the routine checklist items at the beginning of the season is to  empty each kit and check the contents for missing or damaged/expired items. The general rule is also to replace items if they've been used at the next drug store or Walmart stop.
Last trip, I  spent an hour replacing the last of the g4 halogen bulbs in little used fixtures with LEDs. On the very last one, at the foot of the bed, I  took off my glasses to see the tiny holes for the g4 prongs, as I see better close up without the glasses. Big mistake #1.
I got a sharp pain in my eye when a piece of something  fell into my unprotected eye. The slot for eye drops and eye wash was empty in the first aid kit. I'd neglected to replace it last time...
Fortunately,  I was able to hold my lid aside and cry it  out. But, it could have been  serious.
I discovered a few other empty slots... antacid, and topical benadryl for bug bites. Filled them all when we went into town.
Don't neglect your kit like I did....
Keep it up to date.
Sherry
Tourniquet, hemostatic guaze, lots of 4X4s for packing ( GSW—welcome to NRA America ), 325 mg aspirin, usual first aid kit stuff.
Tow with 2018 Chevy Colorado baby Duramax, plug-in solar--dual awnings.
Before our last trip, I started to reorganize our first aid stuff.  I bought two of these pouches from Blue Ridge Overland and filled them each with the stuff from the list below.  That way my wife and I will always have an individual kit with us when hiking, and since there's always at least one pack in the truck, we'll always have a kit with us there.
Within each pouch, I have individual 'kits' in zip lock bags so that it's easier to get to what you need and also to keep things dry.  Pretty amazing what you can stuff into a small kit.
Backpack First Aid Kit
Wound Kit:
Band Aids:
2 ea. S/M/L
2 ea. Knuckle and Butterfly
Bandages:
(2) 2x3
(2) 3x4
(2) 8 x3
(4) 3x3 Gauze Pads
Gauze Roll
Wound Closure Strips
Waterproof Tape
Duct Tape
(6) Alcohol Pads
Neosporin
Scissors
Blister and Bite Kit
Moleskin
Glacier Gel, Lg & Sm
(4) Oval Blister Bandages
(6) Benadryl
EpiPen
Afterbite
IvyX
Mini Tweezers
Misc
(2) Tylenol
Sunscreen
(4) Bug Wipes
(5) Eyedrop Vials
SOL
SAM Splint
Life Straw
(2) Trioral Salts
(2) Rescue Blankets
Thermometer
Signal Mirror
Besides stocking up on the "materials" needed for first aid it is good to get a reminder every few years on how to use these things and improvise if you don't have the "proper" materials available.  The American Red Cross  conducts both regular first aid and wilderness first aid courses in many communities around the country.  While you're at it, the winter just might be a great time to also refresh ones self on AED's and CPR.
Good suggestion. Some red cross classes can even be completed online, at home.
Here's a link to finding classes from the red cross near you.
https://www.redcross.org/take-a-class
Temporary tooth repair kit in mine... break a tooth, loose a filling, you’ll be glad you have it.
GrayGhost
2015 Legacy Elite II Hull # 98
2020 F150 3.5 EcoBoost
Great ideas! I also recently started keeping a product called “Blood Stop” which is used for major bleeding issues. Not necessarily for large areas though. I have used this on a deep cut recently and it seemed to stop the bleeding quickly. There are similar products the military uses for major wounds that would be handy as well.
2017 Elite II, Hull #208
2019 Chevy HD 2500 Duramax
That might be handy if you were to accidentally bite a big ole chunk out of your tongue while taking warfarin.
Really? I've read some good reviews on bleed stop powders and bandages. I've incorporated them  into our big kit.
Would you not recommend them for a reason,  Steve?
Sherry
Really? I’ve read some good reviews on bleed stop powders and bandages. I’ve incorporated them into our big kit.
Sherry
No, I think they are a very good thing.  My previous response was a inside joke to Ken.  Ken and Mary Kay were at our house the night before we all left for Quartzsite this past January. While eating dinner, I did the very thing I mentioned (bit my tongue).  It bleed copiously for two hours.  I thought I was gonna die!
I've read that ERs don't care much for the bleed stop stuff since it's so difficult to get out of wounds later.  Certainly in a life or death situation it would be worth it though.
Yes, you are exactly correct. Some products are rather nasty and I think may cause burns to ER folks. Hoping that someone with medical experience will jump in here. The product that I have is a plant based gauze that actually disintegrates over time. The one time (thankfully) that I had to use it I put a piece on the cut then a regular band aid over that. The next day the gauze was gone. As moisture contacts the material the material dissolves and in so doing, it thickens the moisture (blood) causing the blood to clot quicker. At least that’s my take on it. Another item we seldom think about today is a Styptic pencil. That can be used to stop some persistent bleeding as well. Comments doctor?
I discovered that you can’t hold pressure on your tongue. 90% of the problem that night was the warfarin. Oral vitamin K reversed the warfarin and finally helped staunch the blood.
One thing I would try on your kits...the scissors. Some of the scissors I have seen will not cut the tape. A good pair of bandage scissors are cheap. Even Harbor Freight has a pair of EMT scissors for $1. The next thing I would, and do, carry would be a roll of 'Kling'. It is a non adhesive wrap that will secure a gauze pad or wet bandage in an emergency. It would also hold a splint or act as an ace bandage...
Steve, I offered the soldering iron fix but nooo you had to do it your way. I could mostly guarantee that would have worked. I also had a wire tie tourniquet worked out, again you didn’t want to try that either. What can I say.
Thanks Ken, friends like you are rare indeed.
