Truck bed slide out trays
Townesw
Who is using truck bed slide out trays/racks? What product are you using and what vehicle are you using it in? Please post pictures. Especially ScubaRx: tell me about your rig please.
Bill and Martha
2019 Chevrolet 2500HD Duramax
Don't have pics at the moment... But... We are using the Cargo Glide in a 2016 F-150.  We bought the TV and Oliver at about the same time and got the CG right away.  I was going to wait and see how NOT having the CG would work but Donna said that one crawl into the bed to get something and i would want to kick myself for that decision.  So, we got it and she was right.   We have a cap and I put some 2x3's across the lip and added 3 sheets of pegboard to create a shelf.
Steve has a much better option...   He made a shelf that is attached to the glide so they both slide in and out.  I would love that but not sure I have the skills.  (Unless Steve posts a detailed tutorial.... HINT HINT)      Worth the money.
Gregg & Donna Scott and Missy the Westie  -    The Flying Sea Turtle - Hull # 145     Western NC
This is a link to a recent video by an Oliver owner showing his new truck bed tray.
However, ain't nuttin like ScubaRx's double decker!
I just installed a system called Decked. It has two large slide out draws about 4’ long it has a composite deck that will hold 2000lbs in each corner there are small cubby storage.  Each unit conforms to your type of truck bed. Very easy to install about two hours. Cost about $1250. Free shipping.   Working very well so far I have a good amount of weight in the draws and they roll very easy and close nice.  Web site is Decked good video on the product.
There's a place in Iowa, Ainley Kennels, that will make custom aluminum drawers & slides.  I talked with them last year about making something for my truck, but never followed through.  But they were going to make one for me that had two 12" tall drawers, a 20 gallon water tank, and a full extension slide on top for around $2000, which I thought was pretty reasonable.  I think it was a few hundred more for a 6 ½' bed.  I should get back on that - it would sure simplify things.
Bill, I am using a Cargo Glide 1000.  It's been installed for about 3 years now and no issues.  Here is a pic of the slide and the "shelf" I build for cheap... just 2x3's and some peg board.  Works fairly well for what I need to store in the bed.
Scotty
Thank you Townesw for starting this post. My Chevy 2500 could stand one of these. I suppose they can be made in different lengths. I have a toolbox/60gal fuel tank in my bed. I also carry 50gal of fresh water with me so knowing that these drawers can support a load is very important to me. Additional storage is a plus.
Ray and Betty Jo Bayless
Our two pups Muffinz and Maddie
2018 Chevy Silverado 2500 Duramax 6.6 liter 4WD Crew
2018 Oliver LE2 Twin Bed, Hull #322, Our Igloo on Wheels
  • 4 weeks later...
I like the slides but don't like the fact that you need to drill new holes through the bed floors. Unless the install puts nautical bedding compound around the holes and fasteners the new holes will introduce the possibility of rusting around those points. Doing it correctly with the install is easy but unless you supervise the install it is likely to be substandard. Just my 2 cents. Thanks
2019 Legacy Elite #431;  2019. TV 2019 GMC Canyon Denali, crew cab, 4X4, Long bed, Duramax Diesel.
[postquote quote=175221][/postquote]
I agree about doing it yourself.
[postquote quote=175233][/postquote]
The video I watched on the CargoGlide install shows them drilling holes. Not something I’m looking forward to doing to a new Duramax, but I’d rather me do it than some installer.
Bill and Martha
I see that now.  I know there's at least one brand that doesn't require drilling (on a Ford, at least), but of course I can't find it now.  Looks like both Cargo Glide and Bed Slide want you to drill.  I might be O.K. with that on a steel bed truck, but not sure about an aluminum F150 bed being able to hold.  I'd want some serious washers underneath at a minimum.
This is the slide I bought 6 years ago. It has gone thru several iterations of build in the two different pickups I’ve mounted it in. It has two different levels (as I built it.)
You do have to drill to mount it. Both in the slide and the bed. If you are handy and doing it yourself this probably won’t bother you too badly.
I put a Rat Pack in the beed of my truck.  Here's the link: https://www.amazon.com/Weather-Guard-3343-PACK-Drawer/dp/B00279RCHG/ref=asc_df_B00279RCHG/?tag=hyprod-20&linkCode=df0&hvadid=312061963574&hvpos=1o1&hvnetw=g&hvrand=10705243785031862010&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1013690&hvtargid=pla-569311574600&psc=1
I bought s a couple of these over 20 years ago and used then in two commercial trucks.  Then, when I retired, I installed one of them in my Ram.  They last forever and roll very easily.  But they are expensive.
Mine is about 22" wide, 48" long and about 12"-14" high.  Pushed forward it allows a lot of area between it and the tailgate, and full length and height of the bed beside it.  The biles can still roll in next to it under that camper shell.  Mine is full of gear I seldom use, but must have along.  Like the Viar compressor, floor jack, jumper cables, extra draw bars, tow ropes, etc.  I'm thinking about sliding it rearward a ways to allow two jerry cans to sit in front of it.  I don't want them in the trailer.
  • 4 weeks later...
We were traveling from Grand Marais MN to Baileys Harbor WI today and made a detour to Antigo WI where Slide Masters are made. This is the company that made ScubaRx’s slide out tray. Looked at a display at a store there and also a Slide Master in the bed of the truck that belongs to the fellow that runs the company. All of their slide outs are custom made to your dimensions. Based on what I saw today I think I’ll go with the Slide Master.
Traveling through Antigo I saw a sign “SQUIRREL TAILS WANTED”. Turns out Mepps Spinners (fishing lures) are made here.
https://www.mepps.com/
Bill and Martha
We too, are headed thru Antigo Wisconsin sometime in the next week or so. I’m contemplating building a new system for the back of my truck.
If I do, my existing slide system will be for sale. I know it will perfectly fit in the bed of any 2014 to 2019 General Motors pickup, short or standard bed.
Interested?
PM me with any questions for more information.
Steve, thanks but I’m not interested in yours but it would be a nice unit for someone else. I’m interested in an AH3 with some additional features built in.
Be sure to take all your squirrel tails and drop them off at the Mepps factory in Antigo. They’ll pay you cash money for them. Or double the cash value in Mepps merchandise. Can’t beat that.
Bill and Martha
Yesterday, I upgraded from my 2015 Toyota Tundra to a new <span style="margin: 0px; line-height: 107%; font-family: 'Calibri',sans-serif; font-size: 11pt;"><span style="color: #000000;">2019 GMC Sierra 2500HD Denali, crew cab 4WD Duramax 6.6L Diesel with Allison 6-speed transmission, 445hp, 910 ft-lb torque, 3.73 rear axle, 20-inch Goodyear wranglers, GVWR 10,000 lbs. (payload 2500lbs).  Plan to install ARE truck cap.  Looked at the Slide Master web site and very interested.  Please keep me posted on your thinking and progress with Slide Master since we now have similar trucks. Curious as to your decision on the Slide Master model, steel or aluminum, tray, etc. I did call Slide Master and install does require drilling into that brand new, Denali-liner truck bed (ouch).  Not being a skilled person, I likely will outsource the Slide Master install to a capable craftsperson (maybe Cap World since they will install my truck cap).  Exciting stuff (all it takes is money). Quite sad about drilling holes, but, seems to be the way to leverage that 100% slide out.    </span></span>
KWR
Steve, would it fit in a 2015 Tundra? Thanks
Quite nicely methinks. Measure the width between the wheel wells inside the truck bed. Then measure the length of the truck bed.
Steve
On behalf of Nan, the 2015 Tundra bed measures 49 inches between the wheel wells and 78 inches bed length
KWR
Steve
It will fit perfectly in that space.
Steve,
Ken said it would fit, so that ends that.  Please let me know if you want to sell it and then I will have to figure out how I am going to get it.  Thanks to both you and Ken.
Steve,
Nan, send me a PM with all your home info and we’ll work something out. I’ll be happy to mount it for you.
