Just made the plunge to move from a small motor home to an Ollie.  We took a plant tour a week ago and were impressed.  Primary motivation was for our Alaska trip next year.  I don't trust either the Mercedes chassis nor the (unnamed) coach on the Alaska highway.  I completely trust my Toyota Tundra and from what we saw, the Ollie is more than capable.
We did see "Pura Vida" and several other almost completed trailers on the line during our tour.
Probably not the place for a question - but here goes. What are folks using for bed linens, etc. for the small twin/cot mattresses that are used on the twin bed configuration?
Looking forward to joining in the "family" in May.  We signed up for a February production slot that became available.
The Ellis Family from Locust Grove (Atlanta suburb)
2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx install in progress...
TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
Welcome!  I don't have much to offer in the way of Oliver experience, as we are waiting for our late March delivery.  Let us know how your delivery goes.
Jason and Sonja are located in western Wyoming near Pinedale, WY.
Oliver Elite II #609 (2020)
TV: 2017 Ram 3500
Mainiac's idea is a good one - I use a sleeping bag.  However, I also have a fitted sheet under the sleeping bag and even a mattress pad under that.  There are a number of "posts" here on the Forum that discuss various sources for sheets that fit.  However, mine was just a plain old twin mattress sheet that was altered slightly to fit the slightly smaller size of the Oliver mattress.  With the mattress pad I use four ( one on each corner) of those elastic sheet tighteners to take up the slack.
https://www.amazon.com/Suspenders-Adjustable-Fasteners-Grippers-Mattress/dp/B07BLPWKDS/ref=sr_1_9?crid=NJ12MPTHLHXQ&keywords=elastic+sheet+corner+fasteners&qid=1579357449&sprefix=elastic+sheet%2Caps%2C149&sr=8-9
We used regular twin sheets for a couple of years. Just tucked them in good and used the elastic fasteners Bill mentions above. For the past couple of years we’ve been using custom sheets from AB Lifestyle. We got mattress pads, fitted and top sheets. They are a perfect fit for the twin beds. You can do a search on this forum for ablifesyles and you’ll see a number of threads.  Or go to their web site and look at what they have available for the Oliver. Welcome!  Mike
Welcome from the Savannah area.  I bought sheets, pads and blankets from ABlifestyles and they fit the Oliver perfectly.  I talked to "Janice" and her number is:  1-800-825-4533.  She was extremely helpful and I received them in just a few days.
These mattresses are falsely advertised by Oliver as “twin sized”. They are in fact bunk sized (30 inches wide) and a set of generic fitted bunk linens work fine, you just have to deal with some extra material at the outside rear curve. This works way better than using a twin set, which has extra material everywhere.
I bought a bunch of twin sized linens before delivery and discovered the first night that it was the wrong size. I still get a little unsettled when I think about it, especially since Oliver has done nothing to correct the description.
I keep a thick mattress protector and a pretty cover on both our beds. I sleep on top in a sleeping bag with thin liner, my wife prefers sleeping between sheets and an additional blanket. My side always looks neater. 😉
Edited by John E Davies
I personally found that the custom sized sheets from AB Lifestyles were too narrow and so the sheets tended to twist up at night.  So we had better luck with regular twin sheets, just tucked in more at the back.  Of course they may have changed their sizing since then.
But like the others who posted above, it wasn't long before we switched to just a bottom sheet and sleeping bags, and then later we ditched the mattresses all together in favor of cushions.  We just didn't have the patience to make beds every morning, and the cushions seem just as comfortable to us.  So in the morning now we just stuff the sleeping bags in the closet and that's it.
Edited by Overland
Thanks for all the replies.
Congrats on placing your new Ollie order.
North Carolina 🇺🇸
It looks to me like you two (Patriot and Katanapilot) will be coming down the production line together.  Congrates!
Excellent and thanks!  Looking forward to having a well built travel trailer. We like our Sprinter based motorhome, but the travel trailer will suit us better for our Alaska trip.
  • 4 months later...
We just did the same . . . . put down a deposit to secure a build date . . . . . chose a later slot as we didn't want to travel from PNW, cross country in Dec/Jan.
Our situation mirrors yours.  Have had a high-quality 25' Class B+.  No reliability issues with the coach . . . . but the MB chassis is too unreliable for us to confidently take long road trips.  Twice we have had issues with wheel-speed sensors; very inconvenient when the Mercedes brain says, "nope . . . . the engine isn't going to continue to run under these conditions".   Still under warranty, but MB service centers are few and far between when you get away from highly populated areas.  We trust our 2013 F350 to get us where we want to go.
As for linens (assuming you plan to get regular mattresses and not use the standard pads) I made fitted sheets to fit the non-standard twin mattresses on our current RV.  Easy to do, using flat top sheets.  You can find many blogs and Youtube videos with step-by-step instructions.  We also purchased bunk size mattress protectors from AB Lifestyles.
Ray and Susan Huff
1UP-USA Heavy-duty bike rack
