Ray and Susan Huff Posted June 12, 2020 Share Posted June 12, 2020 We are deciding which options we "need" on our Elite II. We want to keep it as simple as possible, but a keyless entry (but also with a key) entry would be handy. My husband and I sometimes go off in different directions from the campground. Unless each of us remembers to take a key, one of us is left "homeless". We do have a keypad entry on our pickup, so a simple solution would be to keep a key in the glove box. Before saying, "yah or nay" I want to investigate, further. I downloaded the manual from the Oliver site. It doesn't state, but I assume the key will override the electronic lock. Any problems with this? In the Keep it Simple category, the manuals suggest you remove the keypad batteries when not using the RV for longer periods of time. Probably a good idea, especially where it is outside and considering we live in a damp climate. Keyless entry would be handy - our pickup and SUV have it; our present RV doesn't, but it is another thing to maintain and possibly malfunction. Please share your experience with this option. Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold) Link to comment Share on other sites More sharing options...
BackofBeyond Posted June 12, 2020 Share Posted June 12, 2020 I love our keypad. Have not removed the batteries in 2 yeas, key unlocks anytime. never use keys, almost always the keypad - very good item. 2 Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible" Link to comment Share on other sites More sharing options...
John E Davies Posted June 12, 2020 Share Posted June 12, 2020 (edited) Do the numerals show wear and collect dirt (grease rings) after using them a lot? I don’t normally like keypad locks such as an outside garage door opener access pad or a security system panel, since the numbers you use for your code become very obvious unless you change them often. How many digits are needed to operate it? How easy is it to reset the code? Can you clean the buttons so they all look the same? John Davies Spokane WA Edited June 12, 2020 by John E Davies 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Galway Girl Posted June 12, 2020 Share Posted June 12, 2020 I've only had our Hull 505 now for 10 months. I had one situation last fall where the keypad cracked over one of the numbers. I called for a warranty and the RVlock company sent me a replacement front pad that showed up in 3 days. I installed it in about <5 minutes. Pull old pad off, stick new pad on. They also said that cracked pads don't necessarily stop the system from working as the unit is sealed behind the mylar pad. The system has worked well ever since, no cracks, no major signs of wear yet. The lock come with keys, and a battery powered keyfob for opening from your keychain remotely. 95% of the time...we open with the keypad. CS 1 3 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Link to comment Share on other sites More sharing options...
GraniteStaters Posted June 12, 2020 Share Posted June 12, 2020 Our keypad also cracked over one of the numbers. The company is sending us a new pad. The one thing that I don't like is the noise it makes after you press your code, then press lock or unlock. It is quite loud. I do like the convenience of not having to remember to carry the keys all the time. Paula 1 David Caswell and Paula Saltmarsh Hull 509 "The Swallow" Link to comment Share on other sites More sharing options...
Mattnan Posted June 13, 2020 Share Posted June 13, 2020 We have the key pad and use it 100% of the time. We had one issue where the pad was loose. I just glued it on. For a few days we used it without the numeric pad. I wanted dry day for the glue. I am glad we have it and like it. I imagine if the numbers show signs of ware we could just replace the numeric pad. Yes you can change the 4 digit acess and instructions are in the accessory manual. We like it. Link to comment Share on other sites More sharing options...
Nancy K. Posted June 13, 2020 Share Posted June 13, 2020 Regarding the noise, I have heard from several sources that this is true (we don't yet have our Ollie so maybe someone can confirm.): All you have to do is press and hold the 1 key for 3 seconds. You will hear a beep and then be able to use the keyless entry on your RV without the annoying beeping. 1 "Creativity is the fun of putting together unexpected ideas." Hazel Edwards Link to comment Share on other sites More sharing options...
NomadLife Posted June 4 Share Posted June 4 June 4, 2024 Hello everyone! I am looking for front door electronic keypad that also has key access (as a backup) recommendations along with the associated Pro's and Con's to this specific lock. Providing the website link you purchased this from as well would be gratefully appreciated. Thank you! - KJ Hull # 600 (2020 E2) Link to comment Share on other sites More sharing options...
Patriot Posted June 4 Share Posted June 4 (edited) @NomadLife Hey KJ, Here you go. We have had this installed 4 years and are very happy with it. It has a manual key lock for both the handle and dead bolt. Absolutely no issues and very handy if you just want to use the key pad while camped. Naturally you will need to change batteries out once a year. It will let you know that through a lower beeping tone that your bats are getting low. We have never had a problem with our RV lock and the install took about 15 minutes tops taking my time. Pro tip - We also replaced our key pad with the silicone pad. They run sales often. https://www.rvlock.com/?utm_source=google&utm_medium=paid&utm_campaign=1748190371&utm_content=69572607838&utm_term=rvlock compact&gadid=392517272318&gad_source=1&gclid=Cj0KCQjw9vqyBhCKARIsAIIcLMGRkbWSRFcRLVHYMe9o6_qj19LLEKcw6kNk9rEErXwBIBWwKcBZSOAaAuDZEALw_wcB We purchased this one - I would still double check with RV lock to ensure your ordering the correct lock for fitment. https://www.rvlock.com/products/rvlock-v4-0-w-integrated-keypad-for-rvs Edited June 4 by Patriot 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor North Carolina 🇺🇸 Link to comment Share on other sites More sharing options...
NomadLife Posted June 4 Share Posted June 4 1 hour ago, Patriot said: @NomadLife Hey KJ, Here you go. We have had this installed 4 years and are very happy with it. It has a manual key lock for both the handle and dead bolt. Absolutely no issues and very handy if you just want to use the key pad while camped. Naturally you will need to change batteries out once a year. It will let you know that through a lower beeping tone that your bats are getting low. We have never had a problem with our RV lock and the install took about 15 minutes tops taking my time. Pro tip - We also replaced our key pad with the silicone pad. They run sales often. https://www.rvlock.com/?utm_source=google&utm_medium=paid&utm_campaign=1748190371&utm_content=69572607838&utm_term=rvlock compact&gadid=392517272318&gad_source=1&gclid=Cj0KCQjw9vqyBhCKARIsAIIcLMGRkbWSRFcRLVHYMe9o6_qj19LLEKcw6kNk9rEErXwBIBWwKcBZSOAaAuDZEALw_wcB We purchased this one - I would still double check with RV lock to ensure your ordering the correct lock for fitment. https://www.rvlock.com/products/rvlock-v4-0-w-integrated-keypad-for-rvs Thank you brother! 1 Link to comment Share on other sites More sharing options...
ThomB87 Posted June 4 Share Posted June 4 Agree with Patriot. The keypad works well. Order the silicon cover. The original will show wear on the numbers you use. It will eventually crack. Not sure why they do not just come with the silicone. If you do have issues RVlock has good customer service. They come with a fob but we never use it. Carry the key with you just in case as a backup. Change or test the batteries yearly. This did not happen to me. But passing on a story. Lock quit working. The trailer key was in the glove box of the tow vehicle. Tow vehicle was locked. Fob for the TV was in the trailer! They were able to get into the trailer by crawling in through the basement. It was not easy because you have to push up on the basement cover which has a heavy mattress and bedding on top of it while laying on your back. Apparently a very good workout testing both strength and flexibility. Two lessons were passed on to me. Carry your truck key with you even if you are just walking around the campground. And if you work on the lock, like replacing the key pad, double check the connector. There is a plastic connector between the keypad and lock mechanism. Make sure it clicks in securely. 3 Bill Thomas 2019 Elite II Hull # 534 2020 Chevrolet Silverado HD 2500 Link to comment Share on other sites More sharing options...
Steph and Dud B Posted June 4 Share Posted June 4 (edited) We had OTT install the RV Lock on Eggcelsior. It's ok, but the first one failed after water got into it due to an install error by OTT. Before our Oliver we had this lock on two trailers: LATCH.IT Keyless Door Lock for RV Sealed Electricals Unlike Competitors! | Fits 2.75"x3.75" Lock Hole https://a.co/d/1lhYkU0 I think the LATCH.IT lock was superior to the RV Lock installed by Oliver, with a better build quality. Both are easy installs. Edited June 4 by Steph and Dud B Typo 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
