Has anyone perhaps used suction cups and tarps (e.g., lightweight nylon) to create occasional streeetside shade in lieu of an awning?  If so, how has it worked?  Similarly, has anyone tried smaller, window-size awnings for shade or as a rain shield?  In advance, thanks for your insights.
2021 Oliver LE2
Ram 2500 diesel
That is an interesting idea, I personally have no love for the awning and rarely deploy it due to wind concerns. I have thought of replacing it with a 270 degree Foxwing canopy, on the right side only, to allow some shade for the back of the trailer. The radius is just over 8 feet.
A few owners have installed window awnings from Little House Customs.  Like so...
We have the full side awning and use it all the time.  For us, it's a regular part of setting up camp to set both awnings like in the photo below (with or without the arms down).  That's far enough to keep an unexpected rain out of any open windows while not being extended so far that the wind can catch them.  And of course it takes just a few seconds to roll them further out to block the sun.
Edited by Overland
Sorry to everyone for referring back to the Airstream again. They have it as an option pkg. you can have a separate awning for each window. They  withstand high winds easy to open just pull down the strap and attach it to the hooked bracket. It  provided much cooling  with all the windows. I preferred these  awnings over the large 16’ awning I never had to worry about these window awnings when I was away from camp,  If Oliver offered individual awnings for the windows  I’d prefer that over the full-size awning.
I think that would be a good addition to the Oliver options list, honestly.
We use our manual awning all the time. But window awnings on the street side would be very nice.
Years ago, one owner played with the idea of making streetside awnings from solar panels, kind of dual function. He never did it, but youtube rver Tito did. It attaches with suction cups.
Karen Luekens and her husband added an awning to the dinette window, a modified Carefree awning from Little House. At that time, Little House still did installs. I think they only ship parts to you now, and you install yourself, or hire someone.
Here's a photo of the Luekens' Casita, and their Oliver.
Edited by SeaDawg
The Little House ones are nice, does anyone know, can they be deployed part way? Here is a screen cap of that page Overland posted.
I’m interested in reading the installation instructions. I would be quite concerned about the lack of reinforcing plates under the fiberglass. Link?
EDIT, I emailed Little House asking for the instructions and any comments about installing on an Ollie.
Thanks -- your first photo came through, but not the second one...
2021 Oliver LE2
Ram 2500 diesel
I agree - partial deployment, and maybe a solid fabric to help shield rain, would be good.   If they are light, perhaps they could be held on with suction cups (and removed for travel)...
2021 Oliver LE2
Ram 2500 diesel
15 minutes ago, John E Davies said:
I would be interested in reading the installation instructions. I would be concerned about the lack of reinforcing plates under the fiberglass. Link?
http://thehandycamper.com/window-awnings-2/
18 minutes ago, SeaDawg said:
Thanks, that was informative. I personally do NOT believe  that blind pop rivets going into only fiberglass is a good design, in any way! With aluminum plates behind, they are fine. I would replace the rivets with self tapping screws and a full layer of 3M VHB tape. Even then I would worry about somebody walking into the deployed arm and ripping it off the hull. Crunch! “Oh, sorry!”
But I guess I should ask, is there a backing plate for each of the Oliver factory installed awning lower support brackets?
I agree. Zipdee, who (I think) makes the airstream window awnings, uses a similar method. Rivets.
I'm thinking there might be access in the cupboards over the windows for proper backing and fasteners, in the Oliver.
http://www.awningsbyzipdee.com/instructional-videos.html
As far as partial deployment, I  didn't find anything in the Carefree owners manual. You could pm KarenLuekens. They'd certainly know.
Edited by SeaDawg
10 minutes ago, mtkadan said:
shade cloth interested me....a 12x20 piece is 100bucks...would cover the whole side of the trailer and me light.
see link:Shade Cloth, 70% Black (greenhousemegastore.com)
only need 3 hard points on top and poles/anchors at the bottom...????
That looks nice. The thing that bothers me about the shade cloth, or a tarp, are all those grommets , and the possibility of them scratching the hull in the wind.
You could cut and hem that end, and insert heavy webbing loops, instead of the brass grommets.
I looked up the weights on the carefree website. A 3.5 to 4 ft awning is quoted at 32 to 50 lbs. Probably too heavy for suction cups.
 I remembered airstream uses Zip DEE for the window awnings. If someone would be able to post the link I can’t.
Thanks for the confirmation,  Landrover, on the vendor. I wasn't sure if correct..
I  posted zipdee's installation and setup videos a few posts up.
I'll look up a link to dealer sales.
https://inlandrv.com/product/zip-dee-rear-window-awning/
http://www.awningsbyzipdee.com/rv-awning-products.html
Probably six of one, half dozen of the other, but I  honestly prefer the look of the Carefree. Probably a personal choice .
Edited by SeaDawg
Add links
Bruce & Cheryl (Forum name Cheryl) -  long time Oliver Elite II owners designed and made window shades for their Ollie some time ago.  Perhaps one of them will chime in and/or a PM to them might get info on how they did theirs.
The  large awning i did not like  they worked great but had a cheep feel to them. The window awnings less bulky strong feel worked great.
Thanks for that comment. I know Zipdee offers a lot more fabrics than the typical airstream choices. I "think" I prefer the white arms of the Carefree window awnings, though they're a little  chunky looking.
There are other window awning manufacturers,  as well. They're not the only two around.
The zipdee, and the little house carefree version, are manufactured (or modified) for our more rounded profiles, I think.
4 hours ago, SeaDawg said:
...I'm thinking there might be access in the cupboards over the windows for proper backing and fasteners, in the Oliver...
On all the units manufactured post 2009, there are inner liners on all the cabinets (except the bathroom and center rear). This will prevent you from (easily) being able to access the inside of the outer hull to mount any kind of backing plate.
This curved piece is the inside liner for the cabinets. It is made of fiberglass.
This photo is of Hull # 050 taken in 2013 during construction.
Edited by ScubaRx
I forgot about your nice cabinet liners in the newer models. Good thought, Steve.
So, the "liner" is actually molded fiberglass?
I need to take a look at the cabinet construction next time I'm in Hohenwald.  Thanks, Steve.
Edited by SeaDawg
This picture shows one of the awnings that Bruce and Cheryl made for LE2 136 that Bill is referring to.  As you may be able to see, the were made from PVC pipe and fittings.  The head rail and feet, picture below, are marine products.  Cheryl traveled with a sewing machine, so of course she made the shades.  As I remember, they removed everything except the head rail and feet for travel.  They were/are full timers from North Carolina and wintered in Florida.  The last time I saw them was at the 2018 Rally where Bruce received an award from Oliver for his contributions to helping solve the fresh water tank capacity issues.
9FD1ED72-1DF0-4A9C-91FE-999302018165.jpeg.6aab5d0e32d98bef91ac95a76f2ddcab.jpegEE191E4A-BAF0-4267-B47F-C4AD89F83D65.jpeg.5e7fba0919881e5ab8c9db56eeb8952a.jpeg
Edited by mossemi
Add link
I've seen this type of awning used on pickup campers.  One (don't recall the make) was even powered - or at least mechanical.
Edited by Ray and Susan Huff
Ray and Susan Huff
1UP-USA Heavy-duty bike rack
There are a lot of interesting options posted here, but for yet to be ordered Olivers I think it would be easier to simply order the street side awning.  But that's just my opinion.
We have yet to experience camping in our Oliver during weather warm enough to worry about shade.  My expectation is that the Oliver will be much cooler inside than our Leisure Travel Van which was not insulated and did not have double pane windows (though they were tinted).   The challenge with summertime heat and camping with solar panels is finding the sweet spot between optimum solar charging and keeping the interior cool.
We camp probably 85% of the time with some available shade.  Finding the site with the best orientation is part of the fun of camping.
Ray and Susan Huff
Thank you for finding and posting this. Do you know the purpose of the small rail above the exterior light?  Perhaps shield the window from some of the rainwater coming off of the roof?
2021 Oliver LE2
Ram 2500 diesel
