Citrus breeze Posted June 6, 2022 Posted June 6, 2022 Hi, I just parked at my first boondocking site. Filled my fresh water tank, and turned on the water pump. Heard no sound. It’s not pressurizing the tank. No water flows from any faucet. What am I doing wrong? Or, Heaven forbid, is the pump broken? I’ve never used pump before. HELP! Charlie. Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
Moderators topgun2 Posted June 6, 2022 Moderators Posted June 6, 2022 Charlie - When you turn on the water pump switch does the little light on the switch glow green? How did you fill the fresh water tank? Have you looked under the curbside bed to make sure that your valves are in the correct position? What year and model Ollie do you own? Have you checked the water pump fuse? That's a start...... Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Citrus breeze Posted June 6, 2022 Author Posted June 6, 2022 I used the street side fresh water inlet. The green light is on. The first valve on left lower side is open. It seems that no water is being drawn from the tank. No sound. Is there a circuit breaker for the pump somewhere? citrusbreeze Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
Moderators mossemi Posted June 6, 2022 Moderators Posted June 6, 2022 19 minutes ago, Citrus breeze said: Is there a circuit breaker for the pump somewhere? My 2017 LE2 water pump has a circuit breaker in the attic. I do not know if that applies to your Ollie or not. Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderators mossemi Posted June 6, 2022 Moderators Posted June 6, 2022 https://support.olivertraveltrailers.com/portal/en/kb/articles/2021-model-water-pump-valves The link above will take you to a water pump guide for 2021 and 2022 LE2’s. The picture below is for earlier LE2’s. Mossey 1 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderators topgun2 Posted June 6, 2022 Moderators Posted June 6, 2022 No guarantee - but - if the green light is "on" at the switch then it is likely that there is power getting to the pump. Have you checked the wire connections at the pump? Have you tried the water pump switch in the bathroom/shower AND the one in the main cabin? 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted June 6, 2022 Moderators Posted June 6, 2022 Our water pump quit working once. When I checked it I noticed that there was a wire lose that goes to the pump. On mine, there are two red wires that connect to the pump. Make sure they are both still connected. They can work lose if you are on bumpy roads. Mike 1 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators SeaDawg Posted June 7, 2022 Moderators Posted June 7, 2022 It's really helpful if you complete year and hull number in your profile, and signature. Our 2008 has a couple switches to turn off the pump. One by the door. Your pump may need a prime. 5 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderator+ ScubaRx Posted June 7, 2022 Moderator+ Posted June 7, 2022 Have you tried just turning on a faucet? Even with the pump on, the water will not run if it doesn’t sense a change in water pressure. 5 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
John E Davies Posted June 7, 2022 Posted June 7, 2022 Pump failures are not uncommon, and if yours is defective from the factory, the failure could be right away. Mine quit unexpectedly but it took five years…. Do you have a volt meter (VOM tester) and do you know how to do very basic electrical troubleshooting? If not, maybe this would be a good starting point for you to learn how. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Citrus breeze Posted June 8, 2022 Author Posted June 8, 2022 Thanks Everyone! I called Jason at Oliver. He returned the call quite promptly, and talked me through various things to check. Turned out I had to go to the water pump itself under the curb side bed to check the wires. There are two little red wires that attach to the underside of the pump, near you as you look. One of them was not connected at all! Three screws had to be removed to be able to reattach the wire once attached…Everything worked. Surprise! Thanks for all the feedback. Citrusbreeze Charlie 7 Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
Patriot Posted June 8, 2022 Posted June 8, 2022 8 minutes ago, Citrus breeze said: Thanks Everyone! I called Jason at Oliver. He returned the call quite promptly, and talked me through various things to check. Turned out I had to go to the water pump itself under the curb side bed to check the wires. There are two little red wires that attach to the underside of the pump, near you as you look. One of them was not connected at all! Three screws had to be removed to be able to reattach the wire once attached…Everything worked. Surprise! Thanks for all the feedback. Citrusbreeze Charlie Glad Jason got you squared away. Happy Camping! 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators Mike and Carol Posted June 8, 2022 Moderators Posted June 8, 2022 On 6/6/2022 at 5:34 PM, Mike and Carol said: Our water pump quit working once. When I checked it I noticed that there was a wire lose that goes to the pump. On mine, there are two red wires that connect to the pump. Make sure they are both still connected. They can work lose if you are on bumpy roads. Mike 10 hours ago, Citrus breeze said: Thanks Everyone! I called Jason at Oliver. He returned the call quite promptly, and talked me through various things to check. Turned out I had to go to the water pump itself under the curb side bed to check the wires. There are two little red wires that attach to the underside of the pump, near you as you look. One of them was not connected at all! Three screws had to be removed to be able to reattach the wire once attached…Everything worked. Surprise! Thanks for all the feedback. Citrusbreeze Charlie The red wires do fall off. 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators topgun2 Posted June 8, 2022 Moderators Posted June 8, 2022 On 6/6/2022 at 5:59 PM, topgun2 said: Have you checked the wire connections at the pump? Indeed they do. Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
MAX Burner Posted May 8, 2023 Posted May 8, 2023 On 6/7/2022 at 3:47 PM, John E Davies said: Mine quit unexpectedly but it took five years We've had SureFlo's quit on us several times... IMHO, I'd take John's advise and get a VOM on the pump to learn what's going on electrically. Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
