Katjo Posted August 9, 2022 Posted August 9, 2022 I really don’t like that I can’t see out the door window when the door is shut. Does anyone that has changed their frosted window to clear have a recommendation/link to the specific clear glass/frame that fits the Oliver door? 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
NCeagle Posted August 9, 2022 Posted August 9, 2022 @Katjo, check this site out: https://www.zarcor.com/rv_products/rv-door-window-kit/ There are several options from tinted to clear glass. Several owners have made this modification, so if you search the forum for "zarcor" you should find lots of good info. Cheers! 1 1 2020 Elite II, Hull 688 --- 2021 Silverado 2500HD, 6.6L Duramax Diesel
Townesw Posted August 9, 2022 Posted August 9, 2022 I put a clear tinted window from Lippert in our Oliver entry door made by Lippert. I called Lippert and talked to a real person (Sandra Berg) and told her what I wanted to do. She asked for some numbers off of the door to make sure I ordered the correct parts. Be sure to order the “snap in window release clips”. They are supposed to expand the tabs that secure the inside frame to the outside frame but I still had to break several tabs to get them to release, so you’ll also need a new inside and outside frame. You will want to use new frames anyway so that you have good seals Parts I ended up using for hull 313 706073 GLASS; DARK TINT - G20; 13.25 X 22.24 TEMPERED 429436 SNAP-IN WINDOW CLIPS; 16 PCS KIT 716156 WINDOW FRAME; LOW PROFILE W /SEAL; 15 X 24 OUTER - WHT 716157 WINDOW FRAME; LOW PROFILE; 15 X 24 INNER - WHT 2 4 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
Moderators Mike and Carol Posted August 9, 2022 Moderators Posted August 9, 2022 We swapped out our frosted glass for a clear several years ago and installed the Zarcor window shade. Do a search, I posted a bunch of photos as did others. We’ve been very happy with it. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Katjo Posted August 9, 2022 Author Posted August 9, 2022 2 hours ago, Townesw said: I put a clear tinted window from Lippert in our Oliver entry door made by Lippert. I called Lippert and talked to a real person (Sandra Berg) and told her what I wanted to do. She asked for some numbers off of the door to make sure I ordered the correct parts. Be sure to order the “snap in window release clips”. They are supposed to expand the tabs that secure the inside frame to the outside frame but I still had to break several tabs to get them to release, so you’ll also need a new inside and outside frame. You will want to use new frames anyway so that you have good seals Parts I ended up using for hull 313 706073 GLASS; DARK TINT - G20; 13.25 X 22.24 TEMPERED 429436 SNAP-IN WINDOW CLIPS; 16 PCS KIT 716156 WINDOW FRAME; LOW PROFILE W /SEAL; 15 X 24 OUTER - WHT 716157 WINDOW FRAME; LOW PROFILE; 15 X 24 INNER - WHT @Townesw Oh my goodness this is so helpful! Thank you so much for taking the time to post all the photos and the exact information I was looking for.❤️ 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Katjo Posted August 9, 2022 Author Posted August 9, 2022 4 hours ago, NCeagle said: @Katjo, check this site out: https://www.zarcor.com/rv_products/rv-door-window-kit/ There are several options from tinted to clear glass. Several owners have made this modification, so if you search the forum for "zarcor" you should find lots of good info. Cheers! @NCeagle Thank you👍🏼 1 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Katjo Posted August 9, 2022 Author Posted August 9, 2022 3 minutes ago, Katjo said: @Townesw Oh my goodness this is so helpful! Thank you so much for taking the time to post all the photos and the exact information I was looking for.❤️ 4 minutes ago, Katjo said: @Townesw Oh my goodness this is so helpful! Thank you so much for taking the time to post all the photos and the exact information I was looking for.❤️ @JVAJAMS 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Katjo Posted August 9, 2022 Author Posted August 9, 2022 1 hour ago, Mike and Carol said: We swapped out our frosted glass for a clear several years ago and installed the Zarcor window shade. Do a search, I posted a bunch of photos as did others. We’ve been very happy with it. Mike 1 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Katjo Posted August 9, 2022 Author Posted August 9, 2022 @Mike and Carol Thank you! Love it and the shade.😍 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Patriot Posted August 9, 2022 Posted August 9, 2022 @Katjo Here is my Zarcor window shade write up for anyone interested - we reeeeeally like this mod. 😊 I highly recommend if your going to the trouble to change out the glass, take it to the next level and add the blind it’s a good safety mod allowing you to see who is knocking. 👍🏻 1 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Katjo Posted August 9, 2022 Author Posted August 9, 2022 This is great, thank you! 1 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Fritz Posted August 9, 2022 Posted August 9, 2022 I too installed a clear (tinted) window from Zarcor in the door last week. Window installation went smoothly. Love being able to see outside. I have not yet installed the window shade, as there was a part missing (which Zarcor promptly sent). John at Zarcor mentioned that he would like to make an installation video specific to Oliver trailers. If anyone in or around Dallas would like a clear or tinted window with windowshade, he will install one for free as long as he can make the video. Just give him a call (Zarcor website with contact info was listed above). Feel free to mention that Christian (aka Fritz) from Idaho posted this on the forum. 2 2021 Oliver LE2 Ram 2500 diesel
Guest Posted August 9, 2022 Posted August 9, 2022 I am surprised OTT uses frosted glass on their entry door. Are there people that prefer not ever being able to see through the glass? Why would they not offer glass to match the other windows. If they wanted to add blinds/shades to them that would be nice. However, the frosted glass would not be preferred by Carrie and I. We are usually in the wilderness and privacy is not an issue. I guess we will be preforming this modification after we pick up our trailer in December. Thanks for all the information. Kirk
Moderators Mike and Carol Posted August 9, 2022 Moderators Posted August 9, 2022 40 minutes ago, Kirk Peterson said: I am surprised OTT uses frosted glass on their entry door. Are there people that prefer not ever being able to see through the glass? Why would they not offer glass to match the other windows. If they wanted to add blinds/shades to them that would be nice. However, the frosted glass would not be preferred by Carrie and I. We are usually in the wilderness and privacy is not an issue. I guess we will be preforming this modification after we pick up our trailer in December. I think for most people privacy is an issue. With no shade, it might be uncomfortable for some to have a clear window that folks at a campground could see through, especially at night. Mike 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators SeaDawg Posted August 9, 2022 Moderators Posted August 9, 2022 We hang a shirt or jacket over the head bump cushion, in our 2008. I made a curtain, used it a few times, and went back to the shirt. 3 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Guest Posted August 9, 2022 Posted August 9, 2022 26 minutes ago, SeaDawg said: We hang a shirt or jacket over the head bump cushion, That’s similar to what we always did in our past trailer. Works great. Easy and blocks light for trying to sleep in. Might be in our future again, after modification.
Moderators SeaDawg Posted August 9, 2022 Moderators Posted August 9, 2022 9 minutes ago, Kirk Peterson said: That’s similar to what we always did in our past trailer. Works great. Easy and blocks light for trying to sleep in. Might be in our future again, after modification. If I were going to go to the work to change our for clear glass, I'd "probably " go for the interior shade upgrade above. I do like your thinking. Has anyone installed the Zarcor " upside down," so that you could pull down the shade from the top? Or, how does that work? If I went to the trouble of changing the window, I'd like to be able to just look out the top inch or so. Does it operate with the screen door closed and locked, with the door locked? 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Fritz Posted August 9, 2022 Posted August 9, 2022 The Zarcor shade does not slide up-down like the other Oliver shades. The Zarcor shade consists of 2 sheets of flexible plastic with vertical stripes about 1/2” wide alternating with clear material. One sheet is fixed in place on the window, the other slides side to side. When the stripes are aligned (on top of one another), you can see through the clear portions (about half of the window area). When the blind is is in the closed position, the stripes collectively block the view through the window. Quite clever, really. However, I may devise a small removable curtain on the inside of the screen door so that when the window is open it is completely open. 1 2021 Oliver LE2 Ram 2500 diesel
Patriot Posted August 9, 2022 Posted August 9, 2022 1 hour ago, SeaDawg said: If I were going to go to the work to change our for clear glass, I'd "probably " go for the interior shade upgrade above. I do like your thinking. Has anyone installed the Zarcor " upside down," so that you could pull down the shade from the top? Or, how does that work? If I went to the trouble of changing the window, I'd like to be able to just look out the top inch or so. Does it operate with the screen door closed and locked, with the door locked? The Zarcor blind has a little tiny lever at the bottom of the windows edge on the inside which you push left or right and it flips the mini blinds from open to closed. It’s nice to close for privacy or if you need to block out unwanted CG lights. The blinds are vertical so the all open when you slide the little lever. It will operate with the screen door and door locked by just sliding the plastic access panel open to the main door. Our screen door has no lock. “Every picture tells a story” a famous song by a British singer you guess who? Ha ..so here goes- Blind now closed. You can see the off white access handle with the little knob. You slide this left to right to open and close the blind. The access door to the main door is open. Blind open and handle pushed to the left. Access door closed. 1 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators SeaDawg Posted August 9, 2022 Moderators Posted August 9, 2022 Thank you, @Patriot. Those photos really help. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Patriot Posted August 9, 2022 Posted August 9, 2022 1 minute ago, SeaDawg said: Thank you, @Patriot. Those photos really help. You are welcome! I like photos and I think we all do! 😊 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators SeaDawg Posted August 9, 2022 Moderators Posted August 9, 2022 35 minutes ago, Patriot said: You are welcome! I like photos and I think we all do! 😊 Yes, we do! So helpful! The other brand that folks installed couldn't be operated from the closed screen door. Useless, imo. Who wants to open the door, to operate the blind? Thank you, very much. I could see operating your blind from the side, and squinting out. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Patriot Posted August 10, 2022 Posted August 10, 2022 44 minutes ago, SeaDawg said: Yes, we do! So helpful! The other brand that folks installed couldn't be operated from the closed screen door. Useless, imo. Who wants to open the door, to operate the blind? Thank you, very much. I could see operating your blind from the side, and squinting out. You are welcome. Having our Ollie here at home I can usually get a photo to help out of someone needs one. It certainly provides solid privacy when using the shower, blocking out the hot sun, sleeping, or having a little quiet dinner at the dinette. It’s a pretty easy straight forward install. Unfortunately my original glass was really glued in solid and did not just pop out of the frame. So I replaced the frame and glass. It’s all Topgun2’s fault, he turned us onto this mod. 😄 1 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
AndrewK Posted August 10, 2022 Posted August 10, 2022 Here is another option from Zarcor. It is an OceanAir roller shade, like you would find in an Airstream. We wanted to make sure we had a full, unobstructed view from the window, when the shade was open. It also works as a grab handle, when closing the screen. Here is the part information if anyone is intersted. CSH-3-W - OceanAir CABINshade, White - 21 5/8" x 23 5/8" x 24 1/8. It is a custom size. Andrew 1 6 Andrew 2019 Legacy Elite II 2018 BMW x5 35d
Moderators mossemi Posted August 10, 2022 Moderators Posted August 10, 2022 @AndrewK, and it still looks great! Mossey 3 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
