dewdev Posted May 24, 2023 Posted May 24, 2023 As an update to my previous post, after a email discussion with Frank C, we noted that the existing wall was too thick to accept the specified barrel nuts and let the thumb screws go in straight. I contacted McMaster and they did not really have any good option with a barrel nut that had a larger gap, I took the vanity cover apart and removed the barrel nuts. I then used a grinder on the inside of the wall to make the area where the barrel nuts touched thinner. Using new barrel nuts, the installation was a lot better with the thumb screws going in straight so that the washer set correctly to seal off the opening. Hope this helps anyone that will be making this modification. 2 3 2018 Oliver Elite II, Twin Bed, Hull #354, new 3- 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Geronimo John Posted January 1, 2024 Posted January 1, 2024 Would Rivet Nuts worked as well? GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rich.dev Posted January 1, 2024 Posted January 1, 2024 1 hour ago, Geronimo John said: Would Rivet Nuts worked as well Should work, plusnut is another option. The flange on a rivnut is fairly small, a pre-bulb plusnut expands significantly more than a rivnut when compressed. And plusnuts are not as critical with the hole diameter as rivnuts, so a great option for fibreglass I think. 3 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
KenB Posted January 2, 2024 Posted January 2, 2024 8 hours ago, Geronimo John said: Would Rivet Nuts worked as well? I've installed several dozen rivnuts and would not consider installing them in a fiberglass hole. They take too much effort to expand and I think they would at a minimum bulge the surrounding fiberglass. 7 hours ago, rich.dev said: Should work, plusnut is another option. The flange on a rivnut is fairly small, a pre-bulb plusnut expands significantly more than a rivnut when compressed. And plusnuts are not as critical with the hole diameter as rivnuts, so a great option for fibreglass I think. I wasn't familiar with these, but looked them up. I especially agree that the aluminum version would be great solution. The literature specifically mentions use in fiberglass as an application. If you have a Rivnut installation tool I bet it would work with these too. 4 2013 Toyota Land Cruiser 200 2018 Twin Bed Elite II #351
Steve Morris Posted January 2, 2024 Posted January 2, 2024 Here is a rivet specifically designed for plastic. Grip range is .02" to .32", but you'd have to step up to a #10 fastener. I don't know if the vanity wall fits into that range. I have no idea if/how these would work for fiberglass, but since they are designed for plastic, I'm assuming that it would put a lot less radial load on the material. https://www.mcmaster.com/products/rivet-nuts/for-use-in~plastic-2/ 2 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Geronimo John Posted January 2, 2024 Posted January 2, 2024 I like either the suggested plusnut or Rivet Nuts for Plastic and Composites solutions better than a rivet nut for your project. I have used rivet nuts in fiberglass, but always put a washer on the back side before crushing. The washer spreads the load and greatly reduces the potential for pullout indued cracking from the back side. The use of a washer with either of these two other methods would also be suggested if any significant loads are anticipated as required by a specific application. For this project of course not needed. GJ 4 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rich.dev Posted January 16, 2024 Posted January 16, 2024 These should also work well for this application. https://www.facebook.com/share/v/QTPdcUrjpg3mfQu2/?mibextid=I6gGtw **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
MAX Burner Posted February 2, 2024 Posted February 2, 2024 After routing wires and an Ethernet cable under the vanity into the closet for the Starlink system, it was time to finish up the “Cubby Mod”. Used some available 3/16” plywood from another project to fashion a shelf and bulkhead to help organize storage. Rattle-canned a white enamel coating and - poof! One and done: Added 2 extra layers of insulation while in there. Cheers! 1 12 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
shhQuiet Posted February 2, 2024 Posted February 2, 2024 I love the extra faucet and dedicated shower, that definitely has me thinking... 🤔 1 2023 Oliver Legacy Elite II, Hull #1405, "Rocinante" TV: 2022 F-150 5.0 V8 4x4 YouTube: StevesRoadTripChronicles
Geronimo John Posted February 18, 2024 Posted February 18, 2024 On 1/1/2024 at 9:34 AM, rich.dev said: Should work, plusnut is another option. The flange on a rivnut is fairly small, a pre-bulb plusnut expands significantly more than a rivnut when compressed. And plusnuts are not as critical with the hole diameter as rivnuts, so a great option for fibreglass I think. I've looked into the PlusNuts and agree they will be a better choice for our Ollie Fiberglass needs. Were you using steel or aluminum ones? What size? source? Thanks for the idea and for posting. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rich.dev Posted February 18, 2024 Posted February 18, 2024 8 minutes ago, Geronimo John said: Were you using steel or aluminum ones? What size? source? I used SS ones, but if I had to do it over I would use aluminum or THESE in size M5x25. I found the SS ones were tough to bulge/seat propery, but I think it was because of the homemade tool I used! 1 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Geronimo John Posted February 19, 2024 Posted February 19, 2024 Per your reference, I checked Splendiday.com and order out a set of them. Their design uses four "Petals" vs. most others that have just three. I like that. I've used rivet (Blind Flush Nuts as my GrandPa called them) nuts for many decades and they can be a PITA for fiberglass just as you stated. Also for plastic IMHO. Thanks for the suggestion. GJ 2 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
AlbertNTerri Posted February 19, 2024 Posted February 19, 2024 Wow, what a great use of space, very elegantly done, you've set quite a high bar for me to duplicate. I hope mine looks a nice as that when I get around to doing it. I'm thinking I'll add some shelving as well. That will really help tidy up the bathroom stuff/ cleaning supplies, a whole bunch of potential things can be stored in there. Thanks for sharing the mod!! albert 1 Albert & Terri Sterns Paonia, Colorado Elite II Hull #1125 Standard Floorplan / 2017 Ford F250 gas
dewdev Posted February 19, 2024 Posted February 19, 2024 On 2/19/2024 at 8:32 AM, AlbertNTerri said: Wow, what a great use of space, very elegantly done, you've set quite a high bar for me to duplicate. I hope mine looks a nice as that when I get around to doing it. I'm thinking I'll add some shelving as well. That will really help tidy up the bathroom stuff/ cleaning supplies, a whole bunch of potential things can be stored in there. Thanks for sharing the mod!! albert Hopefull the added insulation board is not a problem in keeping the area under the sink warm enough so the piping does not freeze. 1 2018 Oliver Elite II, Twin Bed, Hull #354, new 3- 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators mossemi Posted February 19, 2024 Moderators Posted February 19, 2024 13 hours ago, Geronimo John said: Per your reference, I checked Splendiday.com and order out a set of them. Their design uses four "Petals" vs. most others that have just three. I like that. I experimented with these on a scrape of OTT fiberglass for a mod I had in mind. I used a long bolt a couple of nuts and a pair of wrenches to crush them. I believe they are a worthy product for an anchor/mounting point in or outside of an Ollie. I still haven’t completed it, but it’s still on the list Mossey 4 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
rich.dev Posted February 19, 2024 Posted February 19, 2024 17 hours ago, Geronimo John said: Per your reference, I checked Splendiday.com and order out a set of them. Their design uses four "Petals" vs. most others that have just three. I like that. And replace those screws with knurled m5x25 thumb screws and these o-rings, I used these SS knurled thumb screws, but you also get white plastic knurled head thumb screws. 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Geronimo John Posted February 19, 2024 Posted February 19, 2024 GI NOTE: For the Bathroom Cubby install, the below does not apply to this install. For the anchor point install it would apply. For applications where you can somehow get to the back side here are two considerations: For high load applications, or ones that will be subject to strong vibrations, insert the Petal nut, then place a fender washer on the uncrushed nut. Then crush it. Doing so will greatly reduce fiberglass cracking and strength of the attachment. If you will be needing to unbolt the attachment, add a dab of adhesive to the crush zones of the Petal nut. Once crushed and cured, the bolt can be removed and you'll not lose the Petal Nut in the back space. GI Edit: The pedal nut will not fall out so edited the use of adhesive. Obvious brain fart! 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators mossemi Posted February 20, 2024 Moderators Posted February 20, 2024 2 hours ago, Geronimo John said: The below does not apply to this install. I thought you and rich.dev were discussing plusnuts installed in fiberglass. Mossemi 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Ronbrink Posted February 20, 2024 Posted February 20, 2024 18 hours ago, mossemi said: I believe they are a worthy product for an anchor/mounting point in or outside of an Ollie. An alternative, especially for inside use, would be this self-adhesive hook cleat. The adhesive pad is clear and very strong; placed one on each side of my LifeSaver Jerrycan. 2 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Steve Morris Posted February 20, 2024 Posted February 20, 2024 3 hours ago, Ronbrink said: An alternative, especially for inside use, would be this self-adhesive hook cleat. Handy little item, there! I just ordered four. We keep the Jerrycan in the passenger footwell of the truck when at camp, and in the bathroom next to the toilet when travelling. This looks like a better option. Have you travelled with the Jerrycan full, or do you empty it? That's a lot of weight if full. I'll put the second pair on the wall under the dinette table to secure things that we stick under there while on the road. (The last trip was a box of wine and booze. I wedged it in with an empty duffle and towels. Gotta protect that precious cargo!) 4 1 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Geronimo John Posted February 20, 2024 Posted February 20, 2024 15 hours ago, mossemi said: I thought you and rich.dev were discussing plusnuts installed in fiberglass. Mossemi You are correct as Mossemi appears to be using them as an anchor point! And it would apply. For the Bathroom cubby it would be a waste of fender washers as they are not high load or vibration applications. 1 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted February 20, 2024 Posted February 20, 2024 57 minutes ago, Steve Morris said: Have you travelled with the Jerrycan full, or do you empty it? That's a lot of weight if full. Yes, that is where staged when full whether in storage, traveling or camping; does not hamper ingress or egress, and hugs the wall under a waste bin. I have the optional shower accessory connected for convenience in filling water bottles, measured water for coffee, ice trays while sitting on the counter below the microwave, and even a quick outside rinse, as necessary. The shower handle holder is a similar adhesive product. I suggest using the blue painter’s tape to mark exactly where to adhere for proper positioning and levelness; it will save you some frustration! 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators mossemi Posted February 20, 2024 Moderators Posted February 20, 2024 56 minutes ago, Geronimo John said: For the Bathroom cubby it would be a waste of fender washers as they are not high load or vibration applications. I replaced the vanity towel bar/access cover with a marine hatch as several others have done. I used screws and nylon insert lock nuts to mount my hatch. If you follow @Frank C's installation and reuse the original vanity towel bar/access cover, I don't think you can beat his use of U nuts. I wish he had completed his version before I did mine, because I prefer his method! Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Steve Morris Posted February 20, 2024 Posted February 20, 2024 28 minutes ago, Ronbrink said: Yes, that is where staged when full whether in storage, traveling or camping Thanks! From previous posts I knew that's where you kept it for everyday use. I was mostly concerned if the attachments held the 45 pounds snugly while travelling. That's where I'll mount ours for travelling, then! That will be a lot more convenient getting it in and out than in the head. For actual use, we don't use the Jerrycan daily. We leave the house with four square plastic 1-gallon jugs of filtered water (from our home Berkey) and then refill them from the Jerrycan on the road as needed. These in turn are stored in the closet and get dumped into a pitcher we keep on the counter for everyday use. This is a carryover from how we used it in our Hiker square back trailer, with its extremely limited storage. 1 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Ronbrink Posted February 20, 2024 Posted February 20, 2024 6 minutes ago, Steve Morris said: For actual use, ………. I fill the LifeSaver Jerrycan and the Oliver’s freshwater tank with ‘home’ water prior to a trip departure; LSJ for consumption, freshwater tank for everything else. When the LSJ runs low it is refilled from the freshwater tank. This current system replaced having to bring a 3-gallon spout container of filtered water for initial countertop use, and the Travel Berkey for refilling, which is time consuming and cumbersome! In doing so, the footprint/stowage of the water management system is greatly reduced with an increase in onboard water supply. I too do not like change, unless for the betterment, all part of my Oliver Evolution! 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
