GRP Posted February 14, 2023 Posted February 14, 2023 Can someone share what high quality water proof storage container they are using that fits in the basket? I am looking to basically fill up the full footprint of the basket and would like it to be at least 20" high. Thanks, GRP LE II Hull #1049 2022 Tundra Limited 4X4
Moderators topgun2 Posted February 14, 2023 Moderators Posted February 14, 2023 There have been a number of these "containers" shown here on the Forum over the years. "High quality" and "waterproof" can be a bit subjective though. I'd start by looking through the "Mods" section of the Forum and/or doing a search for storage basket. Good luck! Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John and Debbie Posted February 14, 2023 Posted February 14, 2023 29 minutes ago, G. Patterson said: Can someone share what high quality water proof storage container they are using that fits in the basket? I am looking to basically fill up the full footprint of the basket and would like it to be at least 20" high. Thanks, GRP The Costco black with yellow top storage bin fits in the basket. Because of the shape of the basket there's a little gap in the front. It seems water tight, but I just put chocks, jack stands and things in there that don't require absolute water tightness. That's not answering your question, but my two cents worth. John 1 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
GRP Posted February 14, 2023 Author Posted February 14, 2023 Thanks John, I was hoping that with all members someone has a slick container with gasket and latches that would be at least close to water tight. I did not find anything using the site search function that was helpful. As particular as some Ollie owners are, I thought for sure someone would have good step up that would beat my present home depot semi water tight solution. I suppose my question was not worthy to be on the front page for very long. Oh well, back to searching. Cheers, Glen LE II Hull #1049 2022 Tundra Limited 4X4
dewdev Posted February 14, 2023 Posted February 14, 2023 4 hours ago, G. Patterson said: Thanks John, I was hoping that with all members someone has a slick container with gasket and latches that would be at least close to water tight. I did not find anything using the site search function that was helpful. As particular as some Ollie owners are, I thought for sure someone would have good step up that would beat my present home depot semi water tight solution. I suppose my question was not worthy to be on the front page for very long. Oh well, back to searching. Cheers, Glen GRP: I am one of a number of Oliver Owner's that are using this Rubbermaid container in the front basket. It has gone through many rain storms without taking in any water. It is a Rubbermaid Action Packer 24 gallon container and I bought it on Amazon. 2 5 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators mossemi Posted February 14, 2023 Moderators Posted February 14, 2023 22 hours ago, dewdev said: GRP: I am one of a number of Oliver Owner's that are using this Rubbermaid container in the front basket. It has gone through many rain storms without taking in any water. It is a Rubbermaid Action Packer 24 gallon container and I bought it on Amazon. I use the same Rubbermaid container to carry my Honda generator in the back of our SUV. I have never used it in the front basket because I don’t carry anything of value there. I have never tested it in the rain, but it does keep the gasoline fumes contained. You could always put some silicone or rubber edge trim around the top lip of the tub to create a gasket. Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
GRP Posted February 15, 2023 Author Posted February 15, 2023 Thanks Dewdev and Mossemi for the Rubbermaid suggestion. That looks like the ticket for me. Cheers, Glen 2 LE II Hull #1049 2022 Tundra Limited 4X4
BBL Posted February 15, 2023 Posted February 15, 2023 23 hours ago, dewdev said: GRP: I am one of a number of Oliver Owner's that are using this Rubbermaid container in the front basket. It has gone through many rain storms without taking in any water. It is a Rubbermaid Action Packer 24 gallon container and I bought it on Amazon. DewDev - Nice setup, I see your Ford backup stickers on your tongue and tray. Do they work there? I was told that vertical would not work and to avoid a straight line on the tongue if possible. My trailer will not have the basket so I will have more room for the decal but just wondering how yours works. Thanks, Brian
Patriot Posted February 15, 2023 Posted February 15, 2023 On 2/14/2023 at 3:47 PM, dewdev said: GRP: I am one of a number of Oliver Owner's that are using this Rubbermaid container in the front basket. It has gone through many rain storms without taking in any water. It is a Rubbermaid Action Packer 24 gallon container and I bought it on Amazon. I have this same Rubbermaid container and unfortunately mine is not water proof at all. I even attempted using a foam seal on the lid with no success. It only holds my Andersen plastic chocks and blocks so it’s not a show stopper. I drilled small water drain holes in the bottom rear corners to allow water to drain out. It works for what I need it to do. 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
dewdev Posted February 15, 2023 Posted February 15, 2023 58 minutes ago, Brian and Brandelyne said: DewDev - Nice setup, I see your Ford backup stickers on your tongue and tray. Do they work there? I was told that vertical would not work and to avoid a straight line on the tongue if possible. My trailer will not have the basket so I will have more room for the decal but just wondering how yours works. Thanks, Brian Brian: That is actually not a picture of my Oliver, it is a picture of someone else's rig that gave me the idea to buy the Rubbermaid box. I painting the tip of my receiver with a yellow paint and it shows up great in my rear view camera in my TV. 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Geronimo John Posted February 15, 2023 Posted February 15, 2023 On 2/14/2023 at 11:45 AM, mossemi said: I use the same Rubbermaid container to carry my Honda generator in the back of our SUV. Mossey: Is your Honda the EU2000 or their larger EU2200? If it will fit my EU2200, Amazon has a good price for two of these boxes. Thanks GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Jstone Posted February 15, 2023 Posted February 15, 2023 I have 4 Rubbermaid Action packers that were purchased new, and first put into service in 2018 with our Sylvan Sport Go. They have never been water proof, and I did not buy them with that as a goal. I use one with my Elite II storage box for items that can wet. I would also like to know of a waterproof option, since none of mine seal enough to be considered even water resistant. 2 2022 Elite II Twin “Katie” Hull 997 2010 Toyota Sequoia
Guest Posted February 15, 2023 Posted February 15, 2023 I I am going to try an AluBox 124L. It weighs 16.5 pounds and measures as follows: external: 27L x 16W x 20.5H internal: 25.5L x 14.5W x 19H I am planning on mounting it in the tray with carriage bolts and it is lockable. However, this is a more expensive option. Kirk
Steve Morris Posted February 15, 2023 Posted February 15, 2023 7 minutes ago, snakeriveridaho said: I am going to try an AluBox Im eager to see if this fit! I was thinking how nice it would be to use one of these or the Zarges boxes. Keep us updated! 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Moderators mossemi Posted February 15, 2023 Moderators Posted February 15, 2023 1 hour ago, Geronimo John said: Is your Honda the EU2000 or their larger EU2200? I have a 2004 EU2000i I am not sure if the EU2200i would fit or not. My generator has to be sitting in the correct position so that the handle fits between the ribs of the inside top which run length wise. The pictures usually show the the outside of the top and those ribs run width wise. And I would say the price below is better than what I saw on Amazon. Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
AZ Wonderer Posted February 15, 2023 Posted February 15, 2023 I picked one of these Craftsman containers up at Lowe's. They come in a variety of sizes. I may eventually upgrade to something nicer, like Kirk above @snakeriveridaho is planning to use, but for now, it works. CRAFTSMAN Medium 10-Gallons (40-Quart) Black Heavy Duty Tote with Latching Lid in the Plastic Storage Containers department at Lowes.com 1 Southern Arizona | 2021 Ford F-150 | 2023 Oliver Elite II | Hull # 1319 | Delivery 3 Jan 2023
Geronimo John Posted February 15, 2023 Posted February 15, 2023 15 minutes ago, mossemi said: I would say the price below is better than what I saw on Amazon. Thanks. For SURE on the price beating Amazon... by about 50%! TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators topgun2 Posted February 15, 2023 Moderators Posted February 15, 2023 1 hour ago, Jstone said: Sylvan Sport Go Made right here in western North Carolina! 49 minutes ago, snakeriveridaho said: I am going to try an AluBox 124L. It weighs 16.5 pounds and measures as follows: Nice looking box! 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Hokieman Posted February 16, 2023 Posted February 16, 2023 Another good option is to remove storage basket and install a box like Mike & Carol. Storage Tray 1 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250. Former owner of 2019 Oliver Legacy Elite #431.
Moderators Mike and Carol Posted February 16, 2023 Moderators Posted February 16, 2023 9 hours ago, Hokieman said: Another good option is to remove storage basket and install a box like Mike & Carol. Storage Tray It’s been a very cost effective addition, tough and waterproof. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Geronimo John Posted February 16, 2023 Posted February 16, 2023 20 hours ago, snakeriveridaho said: I am going to try an AluBox 124L That's the perfect box in every way except one.... The cost at Overland Kitted (Arizona) is $580. A bit out of my budget at that number. Even if they had a RoF (Retired Ole Fart) and a military discount. However if they had a scratch and dent one ...... Sure is a fine looking box. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Guest Posted February 16, 2023 Posted February 16, 2023 12 minutes ago, Geronimo John said: That's the perfect box in every way except one.... I agree, it seems overpriced. I looked for a used one and couldn’t find one on eBay. I decided to pay that exorbitant price. I’ll let everyone know how it goes. Kirk
Geronimo John Posted February 16, 2023 Posted February 16, 2023 In theory both would accommodate a Honda EU 2200I. BOX SIZE Outside Dimensions Inches Inside Dimensions Inches L W H L W H HONDA EU2200I N/A See Right 20 11.4 16.7 R.M. Action Packer 24 Gallons 26 18.5 17 20 14.5 15 AluBox (124 Liters) 32.7 Gallons 27 16 20.5 25.5 14.5 19 However, I would carry in my generator to Walmart and test fit the Action Packer before buying. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
dewdev Posted February 16, 2023 Posted February 16, 2023 23 hours ago, Steve Morris said: Im eager to see if this fit! I was thinking how nice it would be to use one of these or the Zarges boxes. Keep us updated! Steve: If you contact Oliver they can send you a diagram (with dimensions) of their front generator basket I used to have it but must have deleted that file. 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Guest Posted February 17, 2023 Posted February 17, 2023 On 2/15/2023 at 4:17 PM, Steve Morris said: Im eager to see if this fit! Fits with room to spare! I’m getting an 18x15x5 inch waterproof plastic case to slide it front to keep my tool kit in. Kirk
