Dennis and Melissa Posted February 23, 2024 Author Posted February 23, 2024 On 2/12/2024 at 1:03 PM, topgun2 said: WE need - demand - pictures. If you can't prove it - did it ever actually happen?🤔 Does this count??? 4 1 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
MAX Burner Posted February 23, 2024 Posted February 23, 2024 On 2/17/2024 at 9:51 AM, Mike and Carol said: We always use a pressure regulator. I carry the simple brass non-adjustable as a back up, but use an adjustable regulator. Why a backup? The easy answer: Because 1 is none, and 2 is ONE! 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
dewdev Posted February 23, 2024 Posted February 23, 2024 I agree with Rivernerd. I bought a 30A female to 15 amp male adaptor. Have not used it in 3 years but good to have it and not need it. I also bought a 30 foot RV 30 amp cord so I can extend the Oliver provided cord for long distance to the power pedestal. You will need a adaptor in that case to plug both cords together. I use the extra cord at home because the distance from my OTT to the 30 amp plug at the house is a little longer than the Oliver provide cord will reach. Have not needed it yet at a campground but I take it camping just in case I need it. 2 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
MobileJoy Posted February 23, 2024 Posted February 23, 2024 I have a 30A male to 15A female connector along with a home outlet circuit tester. These testers are much cheaper than the 30A tester, and I already had one. This allows me to check proper wiring at the 30A outlet in the pedestal before plugging in the trailer. In theory the inboard EMS does these tests, but why plug in if you already know the pole is incorrectly wired? I do not use an external EMS/protector. 3 2021 Elite II Twin #850 "Mojo", 2020 F250 Lariat 7.3L FX4 3.55
Dennis and Melissa Posted March 14, 2024 Author Posted March 14, 2024 Newbies now owners 9 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
Moderators topgun2 Posted March 14, 2024 Moderators Posted March 14, 2024 Nice day, nice truck and gorgeous Oliver! Congrats and a big welcome to a real part of the family! Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
MAX Burner Posted March 15, 2024 Posted March 15, 2024 Great looking rig, @Dennis and Melissa: You're looking like us! ...but where's your puppy? HA! 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted March 17, 2024 Posted March 17, 2024 (edited) Blocks or boards are an important and necessary to reduce wear, damage or destruction of your jacks. The wear part has two components. First, is you don't use them as much every time you change camp sites. Less use = less wear. Secondly having the jacks on some sort of blocking reduces the lever arm of the jack to resist lateral movement and the trailer as a result will feel more steady. But MOST importantly is what happens during an OOPs (Driving off with a jack down). On multiple occasions I have seen owners of all experience levels execute the death of a jack by OOPs. If on concrete, it will kill the jack. On softer ground, the jack plate likely will dig in and kill the jack. Either way the odds are you will have a deceased jack. This can be a real PITA. But, with something between the jack and the ground, preferable at least 5" or more high, another engineering concept comes to the rescue. And that concept is called slip. In engineering, slip is a sliding displacement along a plane of one part of a system relative to the rest of the system under the action of shearing forces—that is, forces acting parallel to that plane. To greatly reduce OOPs damage to our jacks we need to add something between them and the ground to take advantage of the slip plane concept. I call thick ones blocks. Thin ones made of sections of lumber I call boards. Blocks can be purchased in lots of different sizes and materials. If I were going to go with a single block for each jack, I personally like TopGuns! Cheap, strong, and not hard to replace. Not as pretty as the Anderson's, but they are way less expensive. Blocks are also most optimal if all of your camp sites are RV Park level. But, alas we are generally boondockers and our camp sites come in all forms of not level. This is one reason why we carry a milk crate full of 2" X 6" X 11" sections of treated boards for our OE2. Here are some of the operational advantages of boards: Comparatively they are real inexpensive. Lose one and you carry on. Should long term storage bring termite damage to the bottom board of the stack, I toss a single board. The others are still useable. I can toss them around with zero worries. I can use more of less of my board sections as needed to offset unlevel camp sites. For real soft ground, I can stack two flat on the ground (side to side) and another on top 90 degrees perpendicular to them to create a double size footprint. They make great axle spacers should you have two flats or break a spring! For reasonably level camp sites, I stack three of them on top of each other to maximize height and (MOST IMPORTANTLY) to create more slip planes of safety for our jacks from an OOPs. Yes, I am also a member of the OTT Jack Drop Club. Good news is when OOPsing, you hear it thud and stop, With three jack drops in six years I have had no jack damage. So whether you use blocks or board sections either way: Slip Planes Saves Jacks! GJ Edited March 18, 2024 by Geronimo John typo 3 4 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators topgun2 Posted March 17, 2024 Moderators Posted March 17, 2024 3 minutes ago, Geronimo John said: So whether you use blocks or lumber sections either way: Slip Planes Saves Jacks! Or - do as I do - I use both if possible.😉 Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Geronimo John Posted March 17, 2024 Posted March 17, 2024 (edited) 23 hours ago, topgun2 said: Or - do as I do - I use both if possible.😉 So long as you use at least one (Preferably more) boards on top of wood blocks sort of works. Sort of due to the rough surface of the jack skid plate on the softer board. For other blocks with anti-ski surfaces it is not a reliable slip plane. Here's how I believe the slip interfaces react: (Top To Bottom) The rough jack steel base on top of a board on your block is not reliablek as stated above. Your one really good slip plane is the board bottom surface to the block top surface if it is smooth. If not, it is a gamble. The block to dirt slip plane is also not reliable. In softer grounds it gets pushed into the dirt a bit. On paving, the hard bumps of the paving resist the block from moving. So, as above, this one also is not a reliable slip plane.. So with a block on a single board setup, you have one slip plane of variable reliability. However with three or more boards you have at least 2 reliable slip planes: The jack steel base to the top of board. As above this one does not count. Next you have at least two really good slip planes between the three smooth boards. As above, the board to dirt slip plane is not reliable and does not count. Having at least two good slip planes is very effective. However, if I had already purchased the blocks, I would at least carry three boards to get one effective slip plane. More if I wanted two slip planes per jack...belts and suspenders. GJ Edited March 18, 2024 by Geronimo John Typo & clarity 1 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Boudicca908 Posted March 18, 2024 Posted March 18, 2024 Belts and suspenders. I like that. Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Dennis and Melissa Posted March 18, 2024 Author Posted March 18, 2024 (edited) 5 nights in the camper so far. 1 @ mothership 2 @ Falls river - major storm No leaks! But the campground threatened to flood. So back to the mothership. 3 @ mothership 4-5…babbler State Park outside of St. Louis. Just electric. Subfreezing nighttime temps. All systems working as designed comfy, cozy. 😀 only two issues to speak of. 1 we seriously overpacked clothes. Whatever 😂 2 hooking up the Anderson to a ram 1500 with airbags suspension that keeps changing levels. Rereading the owners manual on how to do this. not fun. might lead to a different truck. This is day five of what we hope to be 60-ish for our first trip. Thanks to everyone who help us prepare so thoroughly. Your advice was very valuable. Hope to see you all at the rally. Edited March 18, 2024 by Dennis and Melissa 7 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
Dennis and Melissa Posted March 18, 2024 Author Posted March 18, 2024 And now I have a question. I dispute between my wife and me. Do we get to color in states just because we towed the trailer through them or do we have to actually spend the night there? 😜 1 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
Boudicca908 Posted March 18, 2024 Posted March 18, 2024 3 minutes ago, Dennis and Melissa said: Do we get to color in states just because we towed the trailer through them or do we have to actually spend the night there? My rule is only if my Oliver spent the night! 5 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Moderators topgun2 Posted March 18, 2024 Moderators Posted March 18, 2024 40 minutes ago, Dennis and Melissa said: 2 hooking up the Anderson to a ram 1500 with airbags suspension that keeps changing levels. Rereading the honors manual on how to do this not fun might lead to a different truck. Make sure that you contact Andersen before taking drastic measures. I'd bet that they have heard of the issue you are experiencing and have a solution for you. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Dennis and Melissa Posted March 18, 2024 Author Posted March 18, 2024 20 minutes ago, Boudicca908 said: My rule is only if my Oliver spent the night! SO BE IT!! I am declaring victory. Kentucky and Illinois will have to wait. 1 3 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
Moderators Mike and Carol Posted March 18, 2024 Moderators Posted March 18, 2024 We only color in states after we’ve spent the night in our Oliver there. Have fun! Mike 1 3 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Dennis and Melissa Posted March 18, 2024 Author Posted March 18, 2024 (edited) 37 minutes ago, topgun2 said: Make sure that you contact Andersen before taking drastic measures. I'd bet that they have heard of the issue you are experiencing and have a solution for you. Bill The boys at the mothership struggled when hooking up the Anderson to my Ram. It kept bouncing up and down on them. Next day, When I tried to do it myself I failed. We were still at their campground, so three or four of them came out and 30 minutes later we had it hooked up again. I was so afraid the next morning when it was my turn to do it by myself, but it worked perfectly first try. my confidence was through the roof. The next day we were leaving Hohenwald for St. Louis. It was a Saturday morning so no one else was around from the staff. Took me an hour, including loosening the chains and retightening by hand. I am very concerned where this leads. On the plus side, the truck and trailer handled wonderfully for the 350 mile trip. I hope to figure out the procedure that makes this trivial. But if not, I may detach the chains and see how the truck handles without them. I like the idea about contacting Anderson. I’ll reach out to them in the next couple of days. Thanks. Edited March 18, 2024 by Dennis and Melissa 1 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
Patriot Posted March 18, 2024 Posted March 18, 2024 We only color in the states we camped overnight in.😊 1 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Rivernerd Posted March 18, 2024 Posted March 18, 2024 15 minutes ago, Dennis and Melissa said: I hope to figure out the procedure that makes this trivial. You might consider replacing some of the extra chain links required to connect the Andersen WD hitch to your Oliver with turnbuckles. If the truck changes height on you, you may be able to simply adjust the turnbuckles to compensate. Although I tow with a Tundra that does not have an airbag suspension, I find it easier to attach the Andersen with the turnbuckles loose, then tighten the turnbuckles to make the chain assembly taut. See this thread: 2 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
hgreen Posted March 18, 2024 Posted March 18, 2024 On our Grand Cherokee with the auto leveling system, the manual wants it turned off until you are hooked up and then turned back on. We don’t tow the Oliver EII with it but have towed other trailers with it. Maybe look in your manual to see if it talks about hooking up the trailer with auto leveling. Just a thought. Congrats on your new trailer. 2 3 2022 Elite II, Hull #1271 Picked up 10/12/22 2024 F250 King Ranch FX4, 7.3 gas, 3:73. 2021 FX4 Expedition, Heavy tow package, 3:73, Anderson Hitch.
MAX Burner Posted March 18, 2024 Posted March 18, 2024 5 hours ago, Boudicca908 said: My rule is only if my Oliver spent the night! Same here! 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
John Dorrer Posted March 19, 2024 Posted March 19, 2024 7 hours ago, Dennis and Melissa said: And now I have a question. I dispute between my wife and me. Do we get to color in states just because we towed the trailer through them or do we have to actually spend the night there? 😜 Spending the night😊 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Rivernerd Posted March 19, 2024 Posted March 19, 2024 6 hours ago, Rivernerd said: I find it easier to attach the Andersen with the turnbuckles loose, then tighten the turnbuckles to make the chain assembly taut. I carry a pair of Robogrips in the bed of my Tundra for this purpose. 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Dennis and Melissa Posted March 19, 2024 Author Posted March 19, 2024 we are settling in to the point of decorating 🙂 We love these little suction cups. And it holds up this cute little sign outside the door. Question: I know I have to remove the sign before traveling. Do I have to remove the suction cup? I think not. But I thought it better to ask than end up an idiot. 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
