Fritz Posted November 3, 2023 Posted November 3, 2023 It's a minor issue, but sitting at the dinette or lying in bed we found the touch lights can be glaringly bright. I discovered that a 4" PVC sewer-pipe connector has a flange that is the ideal diameter for slipping over the touch light to create a light shade. To create a shade I cut off the flange from a connector using the band saw. This is the cut end that slips over the light... This is the finished end that becomes the bottom of the shade: The shade slips over the light and stays in place with a friction fit, but a bit of 3M double stick tape provides insurance: Dinette touch light, without shade: Dinette light, with shade: Galley lights, with shades: Shade installation does not appear to have any effect on light operation--they still turn on and off by touch. I suppose that the flanges could be cut with a hand saw (hack saw, coping saw?), which would likely require some additional filing and sanding. Also, the shades could be painted white, but for now we've stuck with plain black. 1 10 2021 Oliver LE2 Ram 2500 diesel
Moderators topgun2 Posted November 3, 2023 Moderators Posted November 3, 2023 I do not have "touch lights" but I really do like both the idea and execution of these shades. Nice thinking and doing! 👌 Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Rivernerd Posted November 3, 2023 Posted November 3, 2023 2 hours ago, Fritz said: a 4" PVC sewer-pipe connector has a flange that is the ideal diameter for slipping over the touch light to create a light shade. Lest folks get confused when they go looking for "4" PVC," what you used is ABS. In the plumbing world, ABS is black, PVC is white. So, to replicate your clever mod, folks should buy a 4" ABS connector. 2 hours ago, Fritz said: Also, the shades could be painted white, but for now we've stuck with plain black. The same fitting might be available in PVC, which would come in white. Lots easier than painting. The fitting you used in PVC might be this 4" PVC Sewer and Drain Adapter: https://www.lowes.com/pd/PVC-4-in-x-4-in-dia-PVC-Adapter-Fitting/3455246?user=shopping&feed=yes&srsltid=AfmBOoqiQKecE5I94QDhmh3FLnYQEu_e183jcC9ZSiT_t9vAn5YMpw4bqvE If I were trying to implement this mod, I would buy one of those, see if it fits, then return it if it doesn't, and buy more if it does. 2 2 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Fritz Posted November 4, 2023 Author Posted November 4, 2023 5 hours ago, Rivernerd said: Lest folks get confused when they go looking for "4" PVC," what you used is ABS. In the plumbing world, ABS is black, PVC is white. So, to replicate your clever mod, folks should buy a 4" ABS connector. Thanks for the correction. I used a couple fittings that I had sitting around from a project I did 20 years ago. And I just checked the Home Depot website—these fittings have become expensive! So, if you have to go buy fittings to cut up for shades you will hopefully find a cheaper alternative to the ABS fittings that I used. 2021 Oliver LE2 Ram 2500 diesel
jd1923 Posted November 4, 2023 Posted November 4, 2023 Nice simple mod, good idea and crafty install. I cannot stand light hitting my eyes at the wrong angle too. We don't have the touch lights either, but if the size is right, that doesn't matter. Painting is not such a good idea. Get ABS if you want black and PVC for white. Adding this to my list! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted November 5, 2023 Posted November 5, 2023 Measured the lights in our Oliver today and they are 3 1/8" diameter (the older version, not touch-lights). These 4" adapters should be 4" ID so lots of room, was hoping they would fit closer. There are 12 interior lights (not counting 3 bathroom lights). Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Fritz Posted November 5, 2023 Author Posted November 5, 2023 Thanks. Newer trailers (at least our 2021 trailer) have five touch lights. The 4” pipe flanges form a tight friction fit around these touch lights. I did not try the concept with other lights (such as those on the ceiling or in the cabinets). Other sizes of pipe or associated fittings might work well for your lights. Good luck! 2 2021 Oliver LE2 Ram 2500 diesel
Patriot Posted November 5, 2023 Posted November 5, 2023 On 11/3/2023 at 3:01 PM, Fritz said: It's a minor issue, but sitting at the dinette or lying in bed we found the touch lights can be glaringly bright. I discovered that a 4" PVC sewer-pipe connector has a flange that is the ideal diameter for slipping over the touch light to create a light shade. To create a shade I cut off the flange from a connector using the band saw. This is the cut end that slips over the light... This is the finished end that becomes the bottom of the shade: The shade slips over the light and stays in place with a friction fit, but a bit of 3M double stick tape provides insurance: Dinette touch light, without shade: Dinette light, with shade: Galley lights, with shades: Shade installation does not appear to have any effect on light operation--they still turn on and off by touch. I suppose that the flanges could be cut with a hand saw (hack saw, coping saw?), which would likely require some additional filing and sanding. Also, the shades could be painted white, but for now we've stuck with plain black. The only challenge I see with the shade installation is when you need to replace the touch lights (and you will) you are likely going to have to remove the shade and re-tape and reinstall. Other than that it looks like a nice mod. I would go with white PVC. 👍🏻 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Fritz Posted November 5, 2023 Author Posted November 5, 2023 Actually, I did have to replace a touch light for which I had installed a shade. I sprayed a little bit of rubbing alcohol around the base of the shade where it was stuck to the fiberglass, wiggled it a bit, and the shade came right off. I replaced the touch light, and reinstalled the shade. 1 3 2021 Oliver LE2 Ram 2500 diesel
jd1923 Posted March 7 Posted March 7 On 11/3/2023 at 2:33 PM, Rivernerd said: The same fitting might be available in PVC, which would come in white. Lots easier than painting. The fitting you used in PVC might be this 4" PVC Sewer and Drain Adapter: I've had this mod down at the bottom of my Oliver to-do list, and it's hard to imagine, but I'm down to the bottom! 🤣 We have the older glass LED lights that are 3 1/8"dia. The glare from the cabin lights is BRIGHT! And I certainly agree white PVC is the way to go, not black ABS for us and not something painted, extra work and would not age well. Long search looking at all the 3-4" PVC parts at Lowes and Depot and I found these 4" drain covers (see pic). With a 3 1/2" hole saw I cut the center out of one (not easy to keep the drill centered, use patience with the drill clutch on). It looks to be a good fit and these were only $3.60 ea at The Home Depot. They are 1 3/4" deep (off the ceiling). If you look at what @Fritz did above, he used VHB tape to mount his. I'm mounting at least 6 for Cabin and Dinette lights or a total of 12 to do all cabin lights. Getting 2-sided tape all around the perimeter of so many light shades would be a pain and if you don't seal the full perimeter light will come through the cracks. I wish 3M made a 1/4" round bead of VHB, but working flat tape around a perimeter is not fun. After cutting these parts, there is an 1/2" flat along the perimeter, a very good surface for sealing. I'm looking for suggestions for a proper sealant. It should bond to PVC to fiberglass, but not permanently! Something that could be removed with a solvent if necessary, and something that would not damage fiberglass. I know I don't want a silicone-based product (wish silicone caulk was never used on our fiberglass). Besides sealants that come in caulk tubes, or brush on, are there any thin bead sealants packaged like butyl tape? Would some brand of butyl hold these light shades? Any ideas? Thank you. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Tony and Rhonda Posted March 8 Posted March 8 Probably depends on the weight of the new shade and amount of contact area but do you think rubber cement would work? Easy to apply, easy to remove and inexpensive. 1 New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (still with original engine) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
jd1923 Posted Monday at 10:00 PM Posted Monday at 10:00 PM On 3/8/2026 at 7:23 AM, Tony and Rhonda said: Probably depends on the weight of the new shade and amount of contact area but do you think rubber cement would work? Easy to apply, easy to remove and inexpensive. Each shade weighs about 3 oz. and there is over 3 square inches of total contact area, 1/2" around the perimeter, 4 1/2" diameter. I was hoping for something I could apply and press on without a support stand and there is no way to use a clamp. Rubber cement can drip and get messy and would need to be held in place for some time to get tacky. But thanks for helping! VHB tape would be overkill and wasteful to trim around the circular shades. Where are all you guys who glue on mounting boards for your electronics? There must be a good product for this! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Hokieman Posted Tuesday at 02:16 AM Posted Tuesday at 02:16 AM (edited) You could try Gorilla Clear Grip. It’s a clear, flexible, fast drying adhesive, nothing like original Gorilla Glue, or RTV silicone. It works like a contact cement. You put a thin layer on both surfaces, let dry for a few minutes, then stick it on. No need to clamp or hold it for more than a few seconds. I buy it at Home Depot, use it around the house for special projects. .https://gorillatough.com/product/gorilla-clear-grip Edited Tuesday at 02:35 AM by Hokieman Added some content 1 1 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250. Former owner of 2019 Oliver Legacy Elite #431. Blairsville, GA
Snackchaser Posted Tuesday at 05:34 PM Posted Tuesday at 05:34 PM 18 hours ago, jd1923 said: Each shade weighs about 3 oz. and there is over 3 square inches of total contact area, 1/2" around the perimeter, 4 1/2" diameter. I was hoping for something I could apply and press on without a support stand and there is no way to use a clamp. Rubber cement can drip and get messy and would need to be held in place for some time to get tacky. But thanks for helping! VHB tape would be overkill and wasteful to trim around the circular shades. Where are all you guys who glue on mounting boards for your electronics? There must be a good product for this! I haven't examined these shades in this regard. However, I believe this would be a good job for a 3-D printer. A glued or snap-on shade could be drawn in free CAD software, such as Tinkercad. The drawing can be saved as an STL file (for 3D printer) and shared in any of the free design sites such as Thingiverse where anyone can download it. If you don't know someone with a 3D printer, there are plenty of local and on-line services that would print them for a small fee. Shades could be printed in any of the numerous available colors and materials. Basic PLA (plant based plastic) or ABS would be perfect. You could make it more stylish than a pipe fitting, and refine the shade thickness to diffuse the light without glare. This would require experimentation to get it right. I'm not overly keen on the idea, but if you want to sketch something up to get started, I'd be willing to collaborate with you to design a decent shade. I have plenty of white PLA and white ABS on hand for prototypes. Cheers! Geoff 1 1
jd1923 Posted 1 hour ago Posted 1 hour ago On 3/10/2026 at 10:34 AM, Snackchaser said: You could make it more stylish than a pipe fitting, and refine the shade thickness to diffuse the light without glare. This would require experimentation to get it right. I'm not overly keen on the idea, but if you want to sketch something up to get started, I'd be willing to collaborate with you to design a decent shade. Thanks, Geoff. This would be a good Forum project if a number of members are interested. I'm going to see how the PVC drain cover pictured above will look. I already have the parts and I ordered some Gorilla Clear Grip that @Hokieman suggested, arriving here on Monday. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
