It's a minor issue, but sitting at the dinette or lying in bed we found the touch lights can be glaringly bright.  I discovered that a 4" PVC sewer-pipe connector has a flange that is the ideal diameter for slipping over the touch light to create a light shade.  To create a shade I cut off the flange from a connector using the band saw.  This is the cut end that slips over the light...
This is the finished end that becomes the bottom of the shade:
The shade slips over the light and stays in place with a friction fit, but a bit of 3M double stick tape provides insurance:
Dinette touch light, without shade:
Dinette light, with shade:
Galley lights, with shades:
Shade installation does not appear to have any effect on light operation--they still turn on and off by touch.
I suppose that the flanges could be cut with a hand saw (hack saw, coping saw?), which would likely require some additional filing and sanding.  Also, the shades could be painted white, but for now we've stuck with plain black.
  • Like 10
2021 Oliver LE2
Ram 2500 diesel
I do not have "touch lights" but I really do like both the idea and execution of these shades.  Nice thinking and doing! 👌
Lest folks get confused when they go looking for "4" PVC,"  what you used is ABS.  In the plumbing world, ABS is black, PVC is white.  So, to replicate your clever mod, folks should buy a 4" ABS connector.
The same fitting might be available in PVC, which would come in white.  Lots easier than painting.
The fitting you used in PVC might be this 4" PVC Sewer and Drain Adapter:
https://www.lowes.com/pd/PVC-4-in-x-4-in-dia-PVC-Adapter-Fitting/3455246?user=shopping&feed=yes&srsltid=AfmBOoqiQKecE5I94QDhmh3FLnYQEu_e183jcC9ZSiT_t9vAn5YMpw4bqvE
If I were trying to implement this mod, I would buy one of those, see if it fits, then return it if it doesn't, and buy more if it does.
Thanks for the correction.
I used a couple fittings that I had sitting around from a project I did 20 years ago. And I just checked the Home Depot website—these fittings have become expensive!  So, if you have to go buy fittings to cut up for shades you will hopefully find a cheaper alternative to the ABS fittings that I used.
2021 Oliver LE2
Ram 2500 diesel
Nice simple mod, good idea and crafty install. I cannot stand light hitting my eyes at the wrong angle too. We don't have the touch lights either, but if the size is right, that doesn't matter. Painting is not such a good idea. Get ABS if you want black and PVC for white. Adding this to my list!
Measured the lights in our Oliver today and they are 3 1/8" diameter (the older version, not touch-lights). These 4" adapters should be 4" ID so lots of room, was hoping they would fit closer. There are 12 interior lights (not counting 3 bathroom lights).
Thanks. Newer trailers (at least our 2021 trailer) have five touch lights. The 4” pipe flanges form a tight friction fit around these touch lights. I did not try the concept with other lights (such as those on the ceiling or in the cabinets).  Other sizes of pipe or associated fittings might work well for your lights. Good luck!
2021 Oliver LE2
Ram 2500 diesel
The only challenge I see with the shade installation is when you need to replace the touch lights (and you will) you are likely going to have to remove the shade and re-tape and reinstall. Other than that it looks like a nice mod. I would go with white PVC. 👍🏻
Actually, I did have to replace a touch light for which I had installed a shade. I sprayed a little bit of rubbing alcohol around the base of the shade where it was stuck to the fiberglass, wiggled it a bit, and the shade came right off. I replaced the touch light, and reinstalled the shade.
2021 Oliver LE2
Ram 2500 diesel
  • 2 years later...
I've had this mod down at the bottom of my Oliver to-do list, and it's hard to imagine, but I'm down to the bottom! 🤣 We have the older glass LED lights that are 3 1/8"dia. The glare from the cabin lights is BRIGHT! And I certainly agree white PVC is the way to go, not black ABS for us and not something painted, extra work and would not age well.
Long search looking at all the 3-4" PVC parts at Lowes and Depot and I found these 4" drain covers (see pic). With a 3 1/2" hole saw I cut the center out of one (not easy to keep the drill centered, use patience with the drill clutch on). It looks to be a good fit and these were only $3.60 ea at The Home Depot. They are 1 3/4" deep (off the ceiling).
If you look at what @Fritz did above, he used VHB tape to mount his. I'm mounting at least 6 for Cabin and Dinette lights or a total of 12 to do all cabin lights. Getting 2-sided tape all around the perimeter of so many light shades would be a pain and if you don't seal the full perimeter light will come through the cracks. I wish 3M made a 1/4" round bead of VHB, but working flat tape around a perimeter is not fun. After cutting these parts, there is an 1/2" flat along the perimeter, a very good surface for sealing.
I'm looking for suggestions for a proper sealant. It should bond to PVC to fiberglass, but not permanently! Something that could be removed with a solvent if necessary, and something that would not damage fiberglass. I know I don't want a silicone-based product (wish silicone caulk was never used on our fiberglass). Besides sealants that come in caulk tubes, or brush on, are there any thin bead sealants packaged like butyl tape? Would some brand of butyl hold these light shades? Any ideas? Thank you.
Probably depends on the weight of the new shade and amount of contact area but do you think rubber cement would work? Easy to apply, easy to remove and inexpensive.
New to us 2017 Legacy Elite II Hull #251 (with updates)
TV:  2023 Tundra Double Cab 4x4 TRD Sport (still with original engine)
Each shade weighs about 3 oz. and there is over 3 square inches of total contact area, 1/2" around the perimeter, 4 1/2" diameter. I was hoping for something I could apply and press on without a support stand and there is no way to use a clamp. Rubber cement can drip and get messy and would need to be held in place for some time to get tacky. But thanks for helping! VHB tape would be overkill and wasteful to trim around the circular shades. Where are all you guys who glue on mounting boards for your electronics? There must be a good product for this!
You could try Gorilla Clear Grip.   It’s a clear, flexible,  fast drying adhesive, nothing like original Gorilla Glue, or RTV silicone.   It works like a contact cement.   You put a thin layer on both surfaces, let dry for a few minutes, then stick it on.  No need to clamp or hold it for more than a few seconds.   I buy it at Home Depot, use it around the house for special projects.
.https://gorillatough.com/product/gorilla-clear-grip
Edited by Hokieman
Added some content
I haven't examined these shades in this regard. However, I believe this would be a good job for a 3-D printer.  A glued or snap-on shade could be drawn in free CAD software, such as Tinkercad.  The drawing can be saved as an STL file (for 3D printer) and shared in any of the free design sites such as Thingiverse where anyone can download it.   If you don't know someone with a 3D printer, there are plenty of local and on-line services that would print them for a small fee.   Shades could be printed in any of the numerous available colors and materials.  Basic PLA (plant based plastic) or ABS would be perfect.  You could make it more stylish than a pipe fitting, and refine the shade thickness to diffuse the light without glare.
This would require experimentation to get it right.  I'm not overly keen on the idea, but if you want to sketch something up to get started, I'd be willing to collaborate with you to design a decent shade.  I have plenty of white PLA and white ABS on hand for prototypes.
Cheers!  Geoff
Thanks, Geoff. This would be a good Forum project if a number of members are interested. I'm going to see how the PVC drain cover pictured above will look. I already have the parts and I ordered some Gorilla Clear Grip that @Hokieman suggested, arriving here on Monday.
  • 1 month later...
On 3/7/2026 at 10:57 AM, jd1923 said:
We have the older glass LED lights that are 3 1/8"dia. The glare from the cabin lights is BRIGHT! Long search looking at all the 3-4" PVC parts at Lowes and Depot and I found these 4" drain covers (see pic). With a 3 1/2" hole saw I cut the center out of one (not easy to keep the drill centered, use patience with the drill clutch on). It looks to be a good fit and these were only $3.60 ea at The Home Depot. They are 1 3/4" deep (off the ceiling).
Six weeks later, after a lot of local camping this spring, I got the lamp shade installation done! 😎
Drilling 5 more of these, I found the large hole saw was binding hard. So I put the drill in reverse and it cut clean through the soft PVC in seconds, nice! I installed them over the Main Cabin and Dinette lights. I didn't want lamp shades over the beds, or the kitchen, since they are low enough and want the light to spread horizontally.
So, we went with 6 shades total. I used the Gorilla Clear Grip that @Hokieman suggested above. The instructions state to apply glue to both surfaces, wait 2 minutes and connect, but it would be very difficult to apply glue to the Oliver ceiling! In a PM from Mike, he suggested putting glue on the shade part, placing it up on the ceiling to get a circle of glue up there, then remove it for 2 minutes and reapply. Great idea!
I tested the glue first with two random PVC parts. The next day they held strongly together and after I broke the seal, the glue residue came off easily, cleaned up nicely, way easier than removing spent VHB tape. This will be a new sealant in my Oliver toolbox and I cannot believe I got a 3-pack on Amazon for $9!
I placed the parts, eyeballing center with about 1/4" free-play, rotated the shade to spread the glue, spun off to remove and replaced each in two minutes, again rotating the shade until it felt firm. I did the next 3 Cabin Lights in series, 5 minutes for the entire job given the parts were prepped. On the first one, a little glue squeezed out. It was easy to remove excess glue merely rubbing with a paper towel while it was still pliable. The PVC parts have embossed model # lettering on the glued surface. I used a razor blade to remove the lettering to level the mating surface, but you can still see a hair of light coming through since the glue is clear. White glue would eliminate this but it's not bad at all.
It's hard to take pictures of the shades on Main Cabin lights! The beautiful Oliver ceiling, still shiny at 10 years old, reflects like a mirror (see pics). In three years, we've only used the Main Cabin lights when cleaning or I'm working mods inside the Oliver. Now, we should use them often. And it will also be nice to sit down to dinner and not see that bright lamp glaring in front of Chris across the table. Basically the same amount of light is present, it's just not hitting us in the eyes anymore! 😎
Nifty solution. Lighting is everything, I'll post my Hue light solution here when I can get some pictures (the trailer is a mess as I reorganize)
Not clear but did you put a cover on the end? Ideal solution would be to have a phosphor coated glass or plastic. Hue does this I believe, the LED's activate the phosphor which than readmits a broad spectrum soft light. But I'm not finding such a thing, probably has to be in a vacuum.
However there are other solutions like this
LightDims White Dims Self Adhesive Dimming/Softening Sheets for Harsh LED Lights
Probably just an etched screen but something like that might help soften it
Edited by DanielBoondock
Sierra EV AT4 2026 (max range 500 mile pack)
Of course - another way of reducing these bright lights is to install a dimmer - 😁
Didn't want a different hue, nor less light, just not direct light (but also good comments/ideas)!
This solution allows for full light without direct exposure to your eyes. I've been asking our Pickleball center to shade their lighting in a similar way. We want all the light, just not staring in our eyes. You can lose the ball when your opponent hits a lob, like your playing outdoors in the sun!
At home we have dimmers, but instead of dimming a 100W bulb, generally I'd rather replace it with a 75W or 40W bulb. I bought a cabinet full of GE Reveal incandescent lights before harsh LED lights is all you can find on the market (thanks climate nuts)! Adding a dimmer? Would there be a convenient location for the switch?
This upgrade is the best cosmetic upgrade I've done for only $24, plus the cost of glue! 😎
Edited by jd1923
Addressing brightness and color temperature:
I've had issues with the original touch lights flickering and in one case completely failing so last week I replaced all of the touch lights with these, which a few people on this forum had recommended; (as always, thanks folks!).  I haven't used them for very long so I can't speak to their longevity but so far I like them for the following reasons:
  • You can select their color temperature when you purchase them
  • They have a  mechanical power switch
  • They are dimmable via the switch
  • They have a blue nightlight feature
  • Most importantly: They remember their last mode / state / brightness selected even when the trailer master switch had been turned off for travel. The one feature of the original touch lights that I didn't like was that when I powered the trailer master switch on all the touch lights would come on and I'd have to turn them off individually as desired
  • The hole pattern is close enough to the original lights to make installation easy. I did use screws rather than rivets though
In terms of the build quality they leave a bit to be desired, they're similar to the originals although they have a plastic base, probably not so great in terms of heat dissipation so time will tell. I bought a 4-pack and a 2-pack so I have one spare.
Edited by Tom and Doreen
Glad our older hull has switched (not touch) lights with solid glass covers, never a one has failed or gone dead in 10 years (knock on wood)! The shades I installed are great for our lights. The touch lights are of larger diameter. @Fritz who started this post used 4" ABS. I like the simple ON/OFF switches OTT installed on switch panels in two locations. Didn't want to change that or mess with settings. We are going to like these shades! (KISS) 😎
  • 1 month later...
These look pretty awesome, thanks for the tip!
The '26's don't have touch lights, but plain jane bright white which cheesy little switches. Olivers have a huge amount of lighting for a small trailer but I use them all.
Getting to choose your temp is amazing! How good is it, which one did you choose?
Otherwise the remembering the state is a huge feature too. Choosing blue for a nightlight is absolutely brain dead though, it should have been deep dark red to preserve night vision and not wake you up. Blue is a morning light and is the clue to your brain that its time to wake up. Oh well ...
I chose the 4000K color temp. It seems fairly close to the stock light. I changed all of the under cabinet light out so the light is consistent.  I did not change the ceiling or the inside cabinet lights.
In terms of the blue night light feature I doubt that I'll use that very much.
Your welcome!
