mountainoliver replied to John Dorrer's topic in General Discussion
Okay, thanks. I still can’t imagine the Bulldog popping off of a correctly sized ball. Mine is sort of close fitting. Anyway I hope you can figure out what actually happened. - Today
John Dorrer replied to John Dorrer's topic in General Discussion
B & W Stow and Go with marked 2" & 2-5/16" on the top of each ball -
John, if the hitch was closed and locked closed…..maybe a dumb question but are you sure that your hitch ball is in fact 2 inches and not 1 7/8? Accurately measure with calipers. -
Oliver no longer selling through dealers?
jd1923 replied to DanielBoondock's topic in General Discussion
high prices, over-charging, service calendars booked months out, shoddy work, all they care about is new RV sales! 🤣 Just hear-say though, since I have no real experience in this area. Years ago, with a Class-C, I called to make an appointment and I replied no-thank-you after hearing they were taking appointments 3+ months out and you'd have to leave it there for a few weeks! They'll "work you in." We have a new business that opened recently in town. It's a great concept! They do not sell RVs, but only service HD trucks and RVs. If you need service, look for a place like this in your neighborhood. Get your TV and TT serviced with one company at the same time! Southwest Truck and RV | Gas or Diesel vehicle repairs | RV Repair -
June 7th went by and our Oliver has been parked for a few weeks on the corner of our property. The A/C running, set at 80F on battery (😎) since it's getting hot again. We've had a most beautiful Spring that has literally lasted for months. Clear skies every day until some clouds blew in. Just heard some thunder, always hoping for rain. Maybe a monsoon or two will come early this year... I forgot all about her on our third anniversary! We're not traveling again until Labor Day which starts our new travel season and there's nothing big scheduled in mods like our last two summers. She looks and performs a whole lot better than she did 3 years ago! 🤣 The 7th is also Chris' birthday! I certainly did not forget that nor our 32nd wedding anniversary on the 1st! Charley turned 12 yesterday. He got a summer cut and a bone! He loves traveling in our tow vehicle and camping in the Oliver! (see pic above) Thankful to have our Oliver! It's improved our lifestyle, with the ability to leave on moment's notice and glamp (never really liked that word but how true it is). Looking forward to another great year with our Oliver. Even giving some thought to that Rally...
Nathan M joined the community
Steph and Dud B replied to DanielBoondock's topic in General Discussion
Yes, but... RV dealers are notorious for not wanting to service RVs they didn't sell. I imagine they'll still do warranty work but I'll bet they won't be interested in non-warranty service of a brand they no longer carry. Time will tell. -
HDRider replied to DanielBoondock's topic in General Discussion
Depends on how busy they are. We all got nervous when Oliver attempted to pull service. -
Dick Pahle joined the community
rideandfly started following Trailer Separation from Tow Vehicle
@John Dorrer glad you're OK! Reed used to post here. He made a video about operating a Bulldog hitch, for those that would like to learn more about the Bulldog:
We all do this and I'm sure you've done it correctly 100s of times. Don't we all also eyeball all hitch connections 2-3 times before we leave and every time we stop? If it was not connected correctly, it would have fallen off in the first few miles while still towing at low speed. Wondering how much OTT will quote? Pretty good price in the link I supplied above for the same Bulldog part. Here are my before & after pics! The only hard part with this installation is marking the correct positions for the drill holes on the new Bulldog. The larger ball helps and with the 12.5K rating you will have a 2x safety margin, given most Olivers loaded are a little over 6K LBS.
Steph and Dud B replied to John Dorrer's topic in General Discussion
Even if the collar did slide back somehow, how did the spring-loaded coupler gate manage to re-close so the collar could slide back into place? I can't see it. Either the ball doesn't fit the coupler properly (coupler socket or ball damaged or wrong size), one of the springs is broken, the ball was never in the coupler to start with, or the coupler wasn't latched. Now I'm wondering if Oliver taught us to use the Bulldog incorrectly when we took delivery. He had us lower the coupler onto the ball with the coupler latch handle in the *down* position, then use a foot or rubber mallet to close the coupler around the ball. At that point the collar snaps closed and we put the pin in. Now I see there's another (better?) way to do it. -
Don't be so hard on yourself. You have been dealt a bad hand and have done more on your own that most people are able or willing to do! This should not be the case on a 2022 Oliver and 2023 HD truck! Good thing you have a modern diesel truck. I imagine you are running the exhaust brake to compensate for the trailer brakes. Taking another look at this photo, I don't see the large black cable coming from the hitch, but I do see all the wire colors associated with a trailer wiring harness. You can have an issue there, but there is no movement there like at the hitch or at the wheels. Wago connectors covered with electrical tape, good work OTT! Wagos are not reliable. It makes sense the black is fused for the +12V (accessory or charge wire). This should be disconnected anyway. The blue is for brakes. If you have a butt connector and crimp tool where you can reach in there, I would replace the Wago connector. I'd replace them all but not while on the road. So all trailer lights, turn signal lights, etc work except the blue wire? Again low likelyhood. Intermittent loss is more likely either the electronics going bad in the truck brake controller, a loose connection at the 7-blade connector or a wire shorting on-n-off at the wheels. The U-Haul rental is a pain but will give you a truck vs. trailer diagnosis. You may do this and find no error and then think you wasted more time, already thinking it was something wrong in the Oliver. If you are able to test for amperage on the brake lines and found an error this would be easier with tool and testing knowledge. Problem with this option is it can test good when sitting/testing and then a bad wire can touch when moving, hence your intermittent issue. Nothing worse than intermittent issues. I bought a truck NEW once in my life, the other 10 were all purchased USED. It had a bad trans, the torque converter would slip intermittently when hot. I took it to 3 different Dodge dealers for warranty repair. It always worked fine when at the dealer, at least that's what they said! Sound familiar to your experience? It lasted until it was out of warranty and then it failed on an AZ to TX trip. I was lucky to limp along on the final stretch, just barely getting to our Georgetown home. You could stop at Harbor Freight in Little Rock and purchase a clamp-on ammeter. Test for amperage like in the picture I shared above. I've got another idea. Forget about it for a while, use your exhaust brake and enjoy your trip. After you get to New Mexico drive another day to Prescott Arizona. I have an Oliver parking spot with a 30A hookup, good mountain water, free dump station down the street. I have the next 3 weeks off work and would work a couple days on your Oliver! We can tow my Oliver with your truck to see if we get the same error message. I will wire a new 7-blade connecter, new brake wiring at the axles or whatever is needed. I'm not kidding! I enjoy repair work and it's a genuine offer to help you. PM me if you want. If your issue is with the Oliver, I can and will fix it. Best wishes, JD
Made in USA leaf springs
It's good that you got that taken care of. New or used the factory springs on these trailers are a significant worry. We have a 2023 trailer and one of our springs snapped on our last trip. -
topgun2 replied to DanielBoondock's topic in General Discussion
I seem to recall that in the video Jason says that they will continue to act as service for Oliver's. Bill -
I wonder how interested the ex-dealers will be in continuing to service Olivers they sold. -
Probably stock ordered before the decision was made.
mossemi started following Floor support under the refrigerator?
The first picture is a different view from topgun2's. The second picture is of the aluminum support tubes I installed for my Nova Kool refrigerator. The aluminum tubes span the trough noted in the first picture. And if you really have a need to know in order to proceed with your installation, you can follow @jd1923's suggestion above. Or you can remove the drawers below the sink and cut a hole in the cabinet floor and have a look around, like I did. Mossey
Since you had the latch pinned, I would assume that the issue was caused by the wire part that connected from the latch to the collar. I don't see how that collar can slide back allowing the coupler to open without some type of deformation to, or disconnection of, that wire. Let us know what Bulldog tells you.
Yes it is! Great fishing if you are so inclined. And not far away there are some sights to see. https://www.visitutah.com/articles/dinosaur-national-monument-flaming-gorge
Reset 2.0 (Hull 1364) just spent its first night (with us) in Utah. The Flaming Gorge area is absolutely beautiful. This trips pass list so far includes: Raton Pass (NM) 7,834 ft Monarch Pass (CO) 11,312 ft Douglas Pass (CO) 8,205 ft
Tom and Doreen replied to John Dorrer's topic in General Discussion
John, the 2-5/16 sounds like a safe bet. I doubt you'll have to worry after that. -
Apparently, the snow is in WY this June.... https://cowboystatedaily.com/2026/06/09/merry-christmas-yellowstone-to-get-june-snowstorm-as-cold-front-dips-into-wyoming/
No pictures. Trailer is back in storage. After a day processing, we are sure the trailer was secure on the ball. My wife directs me back and when we have the ball where we want it under the hitch, I lower the hitch. Once I know it is seated, I squeeze the lever and slide the slide closed. With it closed, I turn to my wife and we give each other Knucks and she hands me the pin to insert. After the incident and getting the front raised, I pulled the pin and opened the hitch. The bridge joint was a hard impact. It must have shut our dash cam off, or leaving it on when I went to the store and left it on overnight may have errased it. I wonder if this was a combination of bad bridge joint, new Alcan 5-leaf springs, and wear or issue with the 2" Bulldog. I'm not willing to go through that again. Requested pricing from Oliver so I can have them ship the 2-5/16". When I pick up the trailer, I will be taking roads less traveled straight to my Truck Service place to get it replaced. I may ship to Bulldog to have them determine what may have caused the failure. -
DunnYet started following Made in USA leaf springs
Reset 2.0 (Hull 1364 ‘23) has new Alcan springs! Even though I got mixed up on the drop off time and was late, the team at Alcan did a great job. Had an incredible breakfast at the Dream Cafe per several suggestions in this thread, then Rebecca and I went up through the Colorado National Monument with Reset 2.0 safely in the hands the Alcan team. Can’t imagine going over that Rim Road with the Ollie 😀 Adding to my list of “designations I never wanted to achieve,” they told me my springs were among the worst they had seen. Bushings completely shot and in terrible shape. That’s the joy of purchasing a used Ollie. At least we have solid records from the day we purchased forward. Now doing the enforced rest breaks under the trailer, a.k.a tightening the shackles and u-bolts.
