so after consulting my chat ai. i decided fixing it myself would be a big problem for me so i am taking it to bish rv repair in bozeman montana . also having them make it easier for me to access the inline valve for bypassing the tank. I cant get my fingers on it to turn it on and off. very tight. also anther problem is the black tank shut off valve does not close all the way and the dump hose is always full so hope they can repair these issues. so thanks and I appreciate the help and advice
Skipster started following water system leak at hotwater heater
how do I access the fittings on tbe water heater. I can see a leak either the blue or red hose going into the insulated water heater. is there a utube video on how to get to those fittings. I have trouble turning the valve off for water going into water heater and now there is water spraying out of the blue hose connection.. how do I get to it to repair. my hands won't fit anywhere in there. do i take the styrofoam insulation off to get more room so I can repair the fitting. no idea. or should I take it to bish rv repair in bozeman,mt.. and let them repair it
I noticed that Oliver is getting active on X.
Lost Mine trail was our favorite!
I got the Oliver into a tight spot on a rough road in this one...
Problem solved! I took the Oliver to a highly-rated solar installer in our area and he solved our problem. Galway girl was correct, the internal fuses (there were two) in the Xantrex inverter were blown. The service tech had another identical inverter on hand (he had replaced it with a Victron) and used those fuses, since he didn’t have new replacements in stock. We also had him replace our AGM batteries with a Vatrer 12V 300AH Bluetooth LiFePO4 Self Heating battery (only $599) and a shut off switch, so I don’t repeat my reverse-polarity blunder when it goes in storage. Thank you all for your help. Heading up to northern MN for some mountain biking next week.
Haven't bought anything yet, just still in the beginning of the planning stage. And that King antenna was removed within days of buying #45... Ended up bringing it to @mossemiwho also lives here in Tampa. Have to get my son off to college and complete the move to our new place in Floral City Fl, but once that's done, upgrades will be priority #1!
The 3K model is enough, especially with your efficient Turbro inverter A/C (or your new Chill). I hope you bought one of the open box/used MP2s at half price! With the 4K model out, look for deals on the 3K models coming soon! I just looked again at the picture of your beautiful hull #45! Remove that king antenna and mount solar panels sideways. I'll bet today you can get near 800W up there! Install two drive motors so you can pitch the panels up on both left or righthand sides! Would be so cool. Consider my brain picked (just for now)! 😎
- Last week
Not that we need this much power, but a new Victron Energy MultiPlus-II 12/4k/160-50 120V just came out for $1,105 (no tax or shipping cost with this vendor). It's at a good price, having paid $997 for the 3K model July of 2024. Also, very good customer service with InvertersRUs. They serviced a warranty replacement for me on a small Victron MPPT SC. All I had to do was to email the pic of the Victron Connect app screen. They shipped a new one out immediately with return label. It provides 4KVA (3.4 KW) inverted power and can charge up to 160A. It's 2" longer, the same width and 3/4" taller, plus 7 LBS heavier than the 3K model that several of us have installed, so it will just fit in the streetside basement. With a whole lot of LiFePO4 Ahs, you could use this kind of power, if you're still running an ol' school single-speed compressor A/C and don't want to worry about what else you power up! No Soft/Easy Start needed with this bad-boy and you won't ever get stuck with a Multiplus failing for low voltage cutout. With required input as low as 9.5V your batteries may cutout before the MP2 ever will! Wow, checking my thread above on page 1, it was two years ago to the day, when I finished my installation. We are rarely plugged in and never turn it off, so our MP2 has run 24x7 for a full 2 years now, always providing service without issue. 😎 https://invertersrus.com/product/ve-multiplus-ii-12-4k/
Congrats
Made in USA leaf springs
thompsonkd replied to Mountainman198's topic in Mechanical & Technical Tips
We also recently had Alcan upgrade our leaf springs and axles. Having a 2018 trailer we had the old 3000 lb axles and of course the 4 pack leaf springs installed by Oliver. It took us a while to decide to have the work done, but it was becoming obvious that we were due for a broken leaf spring or two without an upgrade. Upgrading the axles was an easy decision since the new axles provide better brakes and (hopefully) less maintenance. It’s a relatively quick process to have Alcan do the work; it takes about 2 hours. Lew told us his wife had worried about people driving to town to purchase a torque wrench and socket pulling a trailer so he now sells a decent torque wrench and the necessary socket to perform the required torquing for $50 dollars. He also provides a sheet with all the torque specs and is available for any questions. Tucker the technician who performed the work for us was available as well to answer any questions that we had. We did notice that the new running gear is much stiffer. We aired down our tires, and have done the preliminary torques. We would definitely recommend Alcan. Seems easier to have them do the work but as has been detailed by others, Alcan will ship so folks can do the work themselves or have a shop close to them do the work.Lew told us he is doing about 1 Oliver a week now, plus providing gear for the new Oliver Apex. I guess 38 pages of forum information pays off, for anyone who has the patience to read it all! Alcan suggested we go to Randy’s South Side Diner in Grand Junction while the work was being done. Decent local restaurant for breakfast! -
taylor.coyote replied to Mountainman198's topic in Mechanical & Technical Tips
I think it was Mountain man that discovered Alcan Springs and made the first post in the forum. some 36 pages later in the forum, seems the has provided a great service to Oliver owners and a real bump in sales for Alcan. Thank you Mountain man, for your contribution to all of us that have broken springs and now running on Alcan. Additionally, I think the folks at Alcan might consider some recognition and maybe a modest commission for purchases made by Oliver owners. Best to you and happy torquing Mountain Man -
That is a good A/B test right there. I have not yet pulled the trigger on this, but if/when I do, the "short gutter" looks like the winner.
Congrats on the new running gear. Best money we ever spent on labor was having Alcan professionally do the work on our Oliver. Good for you. The torquing is the easy part. Safe Travels!
Oliver Rally Registration Ends in Just 10 Days! Our Oliver Rally is coming up October 21–25 at Lake Guntersville, and we only have a few spots remaining! If you’d like to join us, be sure to register for the Oliver Rally here: https://olivertraveltrailers.com/events/oliver-owners-rally/registration/ You’ll also need to reserve your campsite directly with Lake Guntersville Campground. Registration closes Thursday, August 20. After that, we’ll be finalizing T-shirts, giveaways, activities, dinner plans, and all the fun details for the rally. Don’t miss your chance to camp, connect, and spend time with all of us. We’d love to see you there! ❤️ #OliverTravelTrailers #OliverRally #LakeGuntersville #OliverFamily
ChillerPhilippe joined the community
The campground at Colorado National Monument is really nice albeit without a lot of services. As best as I recall there are no full hookups but still a nice campground. We also camped in Rabbit Valley area but don't recall the name of the site however it was just off I-70. It's a good 25 or so miles out to that area from Grand Junction.
UPDATE on August 9, 2026: It has now been 1,800 miles of towing since the wiring work, and NO warning messages have been appearing on my Tow Vehicle .... I believe @ScubaRx is correct that we had the right avenue for my particular fix. I will update again, if it comes back. Thanks again to @jd1923 and @ScubaRx for all of their help, and to @jd1923's family for their gracious hospitality in Prescott.
I will make one more addendum to this thread: If you are going to Grand Junction CO for Alcan Spring installation (or just going because it's beautiful), take note that this year only the US Park Service has lifted the "timed entry" requirements for Arches NP in Utah -- and it's definitely a doable day drive from the James Robb campground in Fruita. They still have reservation requirements for the "hike with a ranger" but otherwise, you don't have to make a timed entry reservation this year -- in celebration of our 250th.
Boudicca908 replied to Mountainman198's topic in Mechanical & Technical Tips
I recently had the pleasure of working with Alcan Spring in Grand Junction CO for a set of new 5-leaf springs for my Oliver. Alcan is fantastic to work with. My mechanic's name was Tucker, and he was kind enough to take time before and after the install to be sure I understood what is needed in terms of torquing all the various nuts -- there are quite a few to be done, at 50 miles, 100 miles and then at 500 miles post-installation. The torquing isn't difficult, though doing the nuts on the springs is much easier with two people. Note that the requirements vary from the fixed end of the springs to the flex ends, so pay attention. About a week after my install, I spoke to Lew on the phone and he noted that yet another Oliver had just pulled through for new springs. Someone there said that they have installed new springs on at least 250 Olivers. Imagine that! While I was there, Alcan also installed a new set of Dexter Brakes for my Oliver. Thanks to @jd1923 for looking at my brakes and also to @ScubaRx for encouraging me to follow through with a Warranty Claim (I had 25,000 miles so I was within the 5 year, 100,000 mile warranty window.) Dexter was dynamite with their turn-around on the Warranty and shipping the brakes to Alcan, where I was already scheduled for new springs. I truly appreciate both of these businesses -- Dexter and Alcan Spring -- for their efficiency and excellent service. -
2015 Oliver Legacy Elite I air conditioner replacement recommendation
DBL-R replied to DBL-R's topic in Ollie Modifications
Yes it has the electric heat strip and the gas furnace both controlled by the thermostat. The difficulty is the interior shroud size and extending too far to the rear where the light is. Thermostat.heic -
We primarily use Google Maps and it works well most of the time. I like that you can search along your planned route to add fuel stops, rest areas, etc., and save the entire plan on your phone until you need to use it. However, you do need to do a sanity check on the route it plans to make sure it's not doing something crazy. When it puts me on secondary roads I use satellite view to scope them out, making sure they're not farm tracks or something.
carpenter started following Western wondering
I spent the last week traveling my home state of wyoming looking at properties to potentially buy. I spent the evenings comfortably in my Ollie and got to spend time in some of my favorite places here. I thought I would share photos.
- 4
Golfnut replied to DBL-R's topic in Ollie Modifications
I have a E1, I have the DPII Penguin(noise machine).. You want to look into Houghton units, Recpro has them and only 9 inchs high.. you might to check out the other threads about them.. im looking to maybe getting the 9500btu unit.in the near future?.. good luck with your search. P.S. dont know if your year has a separate thermostat for the furnace.. Stay safe out there..
