  1. Today
  2. Bill Thanks! Forgot to mention the Hungry Mother SP VA rally has a Facebook group, too.
  3. Sounds good. I’ll bring it along. Bob
  4. Be a bit careful with your reservations for the Hiawassee rally in that they really do get crowded. They do have an "overflow" area but I can not recommend it. Also, if you go be sure to get to the pot luck dinner early because all seats under cover will be gone quickly. Bill Hiawasee artwork-2017-1 - Copy-2.tif
  5. @Olive2Roam I am interested, we can touch base at the rally somehow. Mossey
  6. I recently had the new rec pro on-demand hot water heater installed in our Oliver. I have this heating unit from our trauma left over if anybody could use it. We will be at the rally. However, we are leaving tomorrow morning to start our road trip so if you get back to me quickly, I’ll throw it in and you can have it when we get to the rally. Bob
  7. We happened to be camping at Stone Mountain SP NC a few weeks ago when the Carolina Casitas were having a gathering, they invited us to join their Facebook group, so we did! Nice group of folks. Hope to attend Eggs on the Hiawassee River GA gathering held during June. They also have a Facebook group. We attended a couple of Hungry Mother SP VA Fiberglass gatherings attended by various fiberglass owners including Ollie owners. If I remember correctly one of the Oliver owners attending had a hand in making Peach and Cherry cobblers, too! 🙂
  8. Thanks to all who have provided valuable insights and photos. As we have had a busy travel schedule on the road, I have not yet had the opportunity to pull the drawers under the sink or to inspect the underside of the fresh water tank overflow tube in Hull #1291. For now, we are carefully filling the fresh water tank when we need to boondock, until our pre-planned schedule allows me time to try to "get to the bottom" of what caused our problem. We will be on the road until the end of October. I hope to be able to investigate once we get back home. I will then report my findings, if any.
  9. We have done the list the last three years. After talking to Scott Oliver and Matt last year, they were going to try to include that information with the welcome package. So no, I am not collecting details this year. Due to a scheduling conflict with a building project here at home, we have canceled our reservations. We’ll see you in Florida for Eggs n S’mores.
  10. Steve, was it you who put the attendee list together with Site Locations last year for The Lake Guntersville Rally? If so, please add me. Hull 292, site E38 in The Range Rover, From Tampa Florida.
  11. Is there a list of 2026 Lake Guntersville Rally Attendants? Wish I could remember who put the list together with Camp sites.
    Hope to see you there, from Gary, Anita, and Ranger, our Standard Poodle in Hull 292, The Range Rover
  12. Welcome from Gary, Anita, and Ranger, our Standard Poodle in Hull 292, The Range Rover. We will be at site E38 at the Rally. Hope to see you there
  13. I have been following along without anything to add, but I now have a few thoughts. The fresh water overflow discharge port is, in the words of Google: So it looks like a 2 piece fitting that requires access to the inside and outside of the hull to install, service or remove. So the next step requires a modification to the floor below the bottom drawer below the sink. This picture of the area below the sink without the drawers in place. The blue square surrounds a cutout in the rear wall that OTT provided for access to the refrigerator 120V outlet. The red square surrounds a cutout in the floor that I made with a router, using the walls as a guide. This access was needed for a prior plumbing modification. It may also provide access to the freshwater overflow port that would be needed for the installation, removal or repair. Both of the access ports are normally covered with a thin piece of plywood. My MOP for sanitizing the freshwater tank in hull 193, begins by mixing several ounce of chorine or a quart of hydrogen peroxide in a 5 gallon water jug and using the boondocking port to pump it into the freshwater tank. I then fill the tank using a hose at the freshwater fill bib. I am generally in the area of the Ollie while doing the sanitation job, but I do not monitor the amount of water going in, I just wait for it to overflow. And I do use a pressure regulator set to 40 lbs. whenever connecting a hose to the freshwater tank or city water bibs. Mossey
  14. Better go ahead with your retirement as planned😎. You have seen the future!
  15. In addition to the Oliver regional rallies, there are also fiberglass rallies with more and more Olivers in attendance. Here in Ohio, the Casitas of Ohio put on a spring kick-off fiberglass rally and a fall rally. This past spring there were five Oliver’s in attendance out of maybe 20-25 total trailers. The Florida Eggs n S’mores fiberglass rally in January had at least a dozen Oliver’s. Hungry Mother fiberglass rally in Western Virginia had five Olivers. And there are similar rallies all over the country.
  16. Good photos yep, one flexible P-trap is straight, the other is certainly twisted. How do they twist this during installation? Sometimes a job is easier when doing it the right way! Wish I had looked that direction when I had all the waste valves out (was instead looking forward to run DC-DC wiring)! Can a person get an arm in there to loosen the two hose clamps? If so, all can be good. You could put the part in hot water to get it back to original shape which was a great suggestion! But first I would send picture to OTT asking them to replace the part ASAP no charge. Also it's so cool to see the 3" ducting to the bathroom! If it kills me, I've got to install semi-rigid ducting, a homerun from furnace to bath. OEM ducting, Why, why, why? When the bottom hull is open for a few extra dollar full RIGID ducting SHOULD be laid. Ours was full of holes across the bottoms, everywhere. I replaced all I could within reach.
  17. From the looks of those long tanks, and knowing that the level sensors are on the ends, just a few degrees off lengthwise level could result in significant tank level inaccuracies! Good picture! @Hokieman
  18. That's a Through-hull marine fitting. Oliver probably added the insect screen. I looked at mine with a mirror and it doesn't have that black stuff. Me thinks it's clogged! I'd try poking a piano wire through the mesh while slowly adding water to the tank to see if it flushes out. Catch it in a white container to see what it is.
  19. Me too, and thanks for the photo Mike! You can almost read the print on the overflow tube! Hard to be sure with photography, things closer looking larger and all, BUT the overflow tube sure looks considerably larger than the rest of the plumbing.
  20. Here’s another photo that shows how it is installed. Replacing that screen is now on my task list. Thanks to @Wayfinder for bringing the screen situation to our attention, I would probably have never noticed it. And thanks to @Rivernerd for alerting us to a potential problem. https://olivertraveltrailers.com/forums/topic/11495-fresh-water-tank-overflow-condition/#comment-126984
  21. TPMS are nice but the batteries do die and then it one more thing to replace. I have them on my tow vehicle and premptively replaced them because they are pain when they die. Been there with a different vehicle. Like you, a good, frequent visual check plus putting a pressure gage on once in awhile is my prefered method. Like Russell explained, having 4 pressures in your face all the time can be an unwelcome mental distraction for many of us.
  22. Yesterday
  23. Agreed, a screen insert makes sense to keep insects out. Filter material, why? It does look like a filter, but there's no need to filter waste water! The finer the screen or filter material, the quicker it will muck up, and eventually be closed shut. Thanks for the picture! I suggested the scope and now I need to get one! The screen/mesh looks somewhat clogged up. Who knows what has collected above it in your 5 years, our 11 years? Hull #1291 has at most 4 years of use! Could be one of those hole-saw plugs from the tank installation stuck along the path. It irks me how lazy "professional installers" can be. With the right tool it would take a few seconds to retrieve the plugs and a blast of compressed air to quickly clean out the new tank. Fill the tank more slowly? Filling up at Maverick on our last trip, It took over 10 minutes to fill the tank (28 gal on the counter) and the hose had a very good flow rate. Because it's so slow, I now start filling the fresh tank and dump tanks while it's taking its time filling. For me the 1/2" PEX plus the OEM restrictor makes the incoming water flow slow enough. I'll be checking and likely removing this "filter" instead. On my long list is also removing the Fresh and City Water line restrictors (they restrict flow vs. pressure). Everybody in every RV forever has run the hose until the tank overflows. Camping is supposed to be fun! 🤣 Is the "plastic flanged bulkhead fitting" removable, so serviceable? The screen is relatively close to the bottom, so there's hope. Given @Rivernerd's experience, I would certainly try to remove that fitting and see if the screen/filter is serviceable. If not, I would take long auger drill bit and turn it by hand slowly into the screen, trying to grab as much of it as possible for removal. Try to remove as much as possible with the bit, wider bits and other tools. Then use the scope again to see if it's clear all the way up and down into the tank. Finally, take a piece of stainless steel screening material, shape it into a cone and insert it at the very bottom. This screen insert could be removed later easily with a needle-nose pliers. It will be interesting to find out the end result here. I imagine a lot of us will be looking up that overflow tube soon enough!
  24. Finally a proud owner of an Oliver. Let the adventurers begin. Cheers!
    1. topgun2
      topgun2
      Douglas -
      What an exciting road (or lack thereof) lay out before you.  Enjoy the heck out of that new APEX.
    2. Douglas Rink
      Douglas Rink
      Thank you sir! I am sure going to give it my all to do.
  25. I have been making my way east towards the rally, and visiting a few lakeside and riverside campgrounds. West Rolling Hills campground on Milford Lake, view from my campsite in Loop A West Rolling Hills is an Army Corp of Engineers cg located alongside Milford Lake, Milford SP, Milford Wildlife Area, Fish Hatchery, Nature Center.... https://www.recreation.gov/camping/campgrounds/233608 Milford Lake is huge (I think over 15,000 acres) fed by the Republican River. Lots of fishermen, and I saw photo evidence from the camp host of a massive 54 pound catfish he caught the day I arrived. I didn't use any services there, but will attest to the friendliness of the host and other campers, and the clean conditions everywhere around the lake. A beautiful campsite. Sunset from the Prairie Meadow campground in Elk City State Park Elk City SP is west of Independence Kansas. This was a late arrival and early departure for me, but I enjoyed this sunset when I went walking after setting up. The campground overlooks Elk City Lake. There were lots of birds, including Barred Owls and Screech Owls near the campsite! The Current River is lined with vegetation, but walking trails provide direct access from some campsites in Big Spring cg Big Spring Campground in Ozark National Wild & Scenic River is also very pleasant. I've camped there a couple of times. It's a bit of a thrill (rollercoaster) driving to the campground along a narrow winding rolling road, but the campground and the river are beautiful. They have separate buildings for hot and cold showers, and offer other amenities. sunset from my campsite in Eureka Campground, Kuttawa KY Eureka Campground in Kuttawa KY is along the Cumberland River, overlooking The Land Between The Lakes. This is another ACOE campground, and another great location for fishing. The sites are mostly spacious with picnic tables and separate fish-cleaning tables at the site, fire pits and direct lake access from the campsite. There are tons of things to see and do near Land Between the Lakes. I plan to come back to this area. Oh! And about that 54 pound fish.... here's the camp host Tony with his catch at West Rolling Hills cg in Junction City KS
  26. I've met with another couple of Olivers on the road! One on my way to Elk Mountain Campground at Wind Cave, south of Hot Springs SD (Terry & Terri Hand, Hull #143) And then last week I met Kathy & Nancy who were locals from Abilene Kansas camping at West Rolling Hills Campground, on Milford Lake. Kathy couldn't quite remember her hull number; she thought it was 17xx but it was a 2022. It's always great to meet another Oliver on the road.
  27. Well I just crawled under there to get a better understanding of the drain port. Ours is in the form of a plastic flanged bulkhead fitting that appears to extend about four inches up through the bottom hull just off the aft corner of the fridge compartment. It’s ID is about 3/4 inch and upon shining a light up inside, there is a fine mesh screen at the upper end and it appears to have a black fiberish filter material on top of the screen. There’s board dividing the fridge compartment from the galley drawer space, so no access to the drain from the outside fridge access panel. My guess is the mesh and what appears to be a filter material are there to prevent anything from getting into the freshwater tank through the drain. But this also would restrict the flow of water during the filling process. Sounds like there’s a few questions for Oliver service to better understand the principle of design and of course what to do if this filter/mesh becomes clogged over time.
