Guest TxMN2020 Posted September 16, 2024 Posted September 16, 2024 Was told by sales rep at recent RV show that this type leveler system did not work well with all twin axle trailers due to clearance or angle, was not familiar with this type leveler at that time, we have a Legacy Elite II 2025 on order hopefully early December delivery. Thinking we may pick it up at manufacturer instead of them shipping to our dealer, and would give us an opportunity to take factory tour, many have said it was worth the time. excited to get it and trying to put together the essential item now. ve
rich.dev Posted September 16, 2024 Posted September 16, 2024 We have the Anderson levelers and they work great! 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Moderators mossemi Posted September 16, 2024 Moderators Posted September 16, 2024 7 minutes ago, TxMN2020 said: this type leveler system did not work well with all twin axle trailers due to clearance or angle, I think the issue is with the Dexter E-Z Flex Tandem Axle Equalizer Suspension which allows one axle/tire to stay in contact with the road surface when the other axle/tire is on another level, such as driving over a curb. The solution is to use a leveler under each axle/tire on the same side. I have rarely ever needed this type of leveler on both sides of the trailer before using the stabilizer jacks and it is wise practice to always have all 4 tires in contact with the ground or a levered or the square plastic pads. You want to avoid the tires being unsupported. Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Guest TxMN2020 Posted September 16, 2024 Posted September 16, 2024 Thanks, I need to educate myself on that suspension system, if I understand correctly, the 3 jacks on our model are indeed levelers and not stabilizers. Airstream clearly has the opposite and specify they are only to stabilize. One of many reasons why I am trading up to an Oliver from an Airstream.
Moderators topgun2 Posted September 17, 2024 Moderators Posted September 17, 2024 39 minutes ago, TxMN2020 said: if I understand correctly, the 3 jacks on our model are indeed levelers and not stabilizers. Airstream clearly has the opposite and specify they are only to stabilize. sorry to "pop" the bubble, but while many of us indeed DO use our three jacks to level (or even jack up one side to get the tires off the ground), Oliver advises against using them for anything other than stabilizing. Therefore, if you want to level the trailer you can use products like Beech or Andersen levelers (there are several very similar systems on the market, or a product affectionally know as "legos" stacking blocks or even assorted thicknesses of wood that (similar to the "legos") are simply placed under each tire on the side you are trying to raise until you get the trailer level. For the purposes of leveling the trailer (side to side) there is no need to really understand the suspension system. Just make sure that whatever you do to one tire on the side you are trying to level, you do the same to the other tire. Bill p.s. if you travel alone a reasonable amount of the time, levelers like the Andersens or Beech are well worth the price. 1 5 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted September 17, 2024 Posted September 17, 2024 (edited) 2 hours ago, TxMN2020 said: Was told by sales rep at recent RV show that this type leveler system did not work well with all twin axle trailers due to clearance or angle, was not familiar with this type leveler at that time, we have a Legacy Elite II 2025 on order hopefully early December delivery. Thinking we may pick it up at manufacturer instead of them shipping to our dealer, and would give us an opportunity to take factory tour, many have said it was worth the time. excited to get it and trying to put together the essential item now. ve I just installed the Beech Lane Leveling system on our OLEll and it really works well and actually has exceeded my expectations. Having used it each time on this western loop we are on, it has been spot on every time. Not bad for $80 and about a 10 minute install. Just my field experience so far. A big Congrats on your 2025 order! I would highly recommend the factory tour. Edited September 17, 2024 by Patriot 4 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
jd1923 Posted September 17, 2024 Posted September 17, 2024 Sitting on our deck, having’ a drink before dinner, our Oliver some 60 ft away, and “Honey she’s still level!” 🤣 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderator+ ScubaRx Posted September 17, 2024 Moderator+ Posted September 17, 2024 4 hours ago, TxMN2020 said: Thanks, I need to educate myself on that suspension system, if I understand correctly, the 3 jacks on our model are indeed levelers and not stabilizers. Airstream clearly has the opposite and specify they are only to stabilize. One of many reasons why I am trading up to an Oliver from an Airstream. True, been doing it for 17 years. But like Topgun said, Oliver now advises against it. Look me up sometime and I'll play Paul Harvey and tell you.... 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
John Dorrer Posted September 17, 2024 Posted September 17, 2024 The Andersen Levelers have been great. Used them for 10 years. 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Ronbrink Posted September 17, 2024 Posted September 17, 2024 (edited) The Beech Lane and Anderson brands of levelers look to be the same in appearance and design other than in color, black and red, respectively. Although there is a diverse selection of levelers available, this tear drop ramp-type leveler pairs well with OTTs, especially when used in conjunction with a cell phone app leveling systems as @Patriot and @jd1923 refer. Reason being these systems will indicate if leveling adjustment needs to occur side-to-side, then the leveling ramp(s) can be positioned on the side to be raised and vehicle driven onto them until level according to the app. Set the TV emergency brake, position the wedge(s) of these setups, detach trailer, complete front-to-back leveling per the app utilizing the forward stabilizing jack. Edited September 17, 2024 by Ronbrink 5 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Rivernerd Posted September 17, 2024 Posted September 17, 2024 I concur with Ronbrink's advice. We use the Rophor system, which has worked well for us for the past two years, and is less expensive than some competitive products: https://www.amazon.com/Rophor-Leveler-Version-Leveling-Non-Slip/dp/B09NJSXRRB/ref=asc_df_B09NJSXRRB/?tag=hyprod-20&linkCode=df0&hvadid=693330410595&hvpos=&hvnetw=g&hvrand=15739391212809512128&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9029558&hvtargid=pla-1637492471943&psc=1&mcid=8b6eff5b433a3cedbac02e4e81b209a9 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Moderators topgun2 Posted September 20, 2024 Moderators Posted September 20, 2024 Even though I've used the Andersen levelers for 9 years and have had absolutely no issues with them, I saw THIS short video from Long, Long, Honeymoon this morning. While the Andersens are guaranteed for life, they should not break.😒 Bill 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Rivernerd Posted September 20, 2024 Posted September 20, 2024 For what it's worth, the Rophor levelers are ribbed (not smooth like the Andersens), and come with the rubber mats for placement underneath the levelers on hard surfaces. We have used them for almost two years now with no slippage or other issues. 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
jd1923 Posted September 20, 2024 Posted September 20, 2024 3 hours ago, topgun2 said: While the Andersens are guaranteed for life, they should not break.😒 Bill There's always a complainer! Ours don't slip on any surface and adding a rubber mat would be a pain. What in the world would you have to do to break one, OMG! I get them on and watch the LevelMatePRO as I'm climbing up to level. They work great by me. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
ScottRicki Posted September 20, 2024 Posted September 20, 2024 I have had two of the Anderson levelers break. One after five years and one after two years. They do warranty for life and no issues getting one replaced but you must pay “shipping “ cost of $13.75 1 1 Scott&Ricki 2017 Legacy Elite II Twin, Hull 225, The Bus 2007 Tundra Prev: 2003 Casita, 2009 Weekend Warrior
Jason Foster Posted September 21, 2024 Posted September 21, 2024 I have used my "stabilizers" to level my trailer since I have owned it. They work great and get the job done. However, they are not built for it. If you are in a fairly level place, they will be fine, but once you start hanging the suspension with tires off the ground, you lose stability. In most scenarios, those won't hurt anything. Where it becomes an issue is with lateral trailer movement. At full extension, the stabilizers create tons of leverage which can damage the frame, mounts and even the tubes. I use two types of wheel levelers when I plan on extended stays. Both have their advantages and disadvantages, mostly as inconvenient. The first set are easy to lay down and include a lock wedge to keep your wheels in place but they are big. The second set stack when not in used and assemble to whatever height you want. Once I get leveled, I drop the stabilizers onto a hard block with rubber pad. 3 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
jd1923 Posted September 21, 2024 Posted September 21, 2024 2 hours ago, Jason Foster said: If you are in a fairly level place, they will be fine, but once you start hanging the suspension with tires off the ground, you lose stability. Yes, tires off the ground are anything but stable and yes, you need to get close to level first. I have a set of the yellow ramps you have, but not for the Oliver since they do not work well for dual axle. I only use them for when I need the rear wheels on the TV higher. I used the awkward orange squares to level before I decided to spend the $90 on the Andersons! Glad I did. Often Chris quickly places the two Anderson levelers on one side while I'm still parking the truck and when ready I pull up or back up in a quick minute to level. I got a pair of the Anderson 8" tall round platforms for the rear stabilizers and now only use our old orange squares for the front trailer jack. It's so much easier. Looks like the newer Anderson levelers have a ribbed bottom for better traction: Camper leveler - Andersen Hitches Trailer Jack Block - Andersen Hitches 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Jason Foster Posted September 22, 2024 Posted September 22, 2024 6 hours ago, jd1923 said: Yes, tires off the ground are anything but stable and yes, you need to get close to level first. I have a set of the yellow ramps you have, but not for the Oliver since they do not work well for dual axle. I only use them for when I need the rear wheels on the TV higher. I used the awkward orange squares to level before I decided to spend the $90 on the Andersons! Glad I did. Often Chris quickly places the two Anderson levelers on one side while I'm still parking the truck and when ready I pull up or back up in a quick minute to level. I got a pair of the Anderson 8" tall round platforms for the rear stabilizers and now only use our old orange squares for the front trailer jack. It's so much easier. Looks like the newer Anderson levelers have a ribbed bottom for better traction: Camper leveler - Andersen Hitches Trailer Jack Block - Andersen Hitches I didn't consider the Andersen's because of the price. I felt $50 for one was a bit inflated, and then I would likely just drive off the big end anyway. The Rophors are similar but half the price and include a bag. I wonder if they compare. 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
jd1923 Posted September 22, 2024 Posted September 22, 2024 10 minutes ago, Jason Foster said: I didn't consider the Andersen's because of the price. I felt $50 for one was a bit inflated, and then I would likely just drive off the big end anyway. The Rophors are similar but half the price and include a bag. I wonder if they compare. They are expensive! Got to admit, found an eBay seller with a one-off pair for $60 (looked hard and long)! A better set would be as strong yet maybe taller. The Andersons are 4” tall, and they just fit between the wheels. I can see the required height on the LevelMatePRO before using. If > 4” move and try again! Then drive up ‘til level and you shouldn’t drive past the top. However, I have done so when I have gone in reverse when should have gone forward, or vice versa. What a mess, just drive forward, right over the dang things and try again! I haven’t broken one yet (rated to 30K LBS). 🤣 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Jason Foster Posted September 22, 2024 Posted September 22, 2024 16 minutes ago, jd1923 said: They are expensive! Got to admit, found an eBay seller with a one-off pair for $60 (looked hard and long)! A better set would be as strong yet maybe taller. The Andersons are 4” tall, and they just fit between the wheels. I can see the required height on the LevelMatePRO before using. If > 4” move and try again! Then drive up ‘til level and you shouldn’t drive past the top. However, I have done so when I have gone in reverse when should have gone forward, or vice versa. What a mess, just drive forward, right over the dang things and try again! I haven’t broken one yet (rated to 30K LBS). 🤣 I see that the Andersen Rapid Jack goes to 5 3/4 but it doesn't have the stop wedges. Might be something to try when 4 inches just isn't enough. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Ronbrink Posted September 22, 2024 Posted September 22, 2024 14 hours ago, jd1923 said: I got a pair of the Anderson 8" tall round platforms for the rear stabilizers and now only use our old orange squares for the front trailer jack. The Anderson Jack Blocks are great, like that they have magnets to ease attachment and centering. As for the front stabilizer, I use a Rapid Jack on its’ side. I have used it as intended to change a tire, despite claims it won’t work on an Oliver. It stows alongside its’ cousins in the garage! 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted September 22, 2024 Posted September 22, 2024 7 hours ago, Jason Foster said: I see that the Andersen Rapid Jack goes to 5 3/4 but it doesn't have the stop wedges. Might be something to try when 4 inches just isn't enough. I have topped these ramps a couple of times, that’s where the stabilizer jacks really shine to lift the body a tad more for level without lifting the tires anymore. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted September 22, 2024 Posted September 22, 2024 14 hours ago, Jason Foster said: I see that the Andersen Rapid Jack goes to 5 3/4 but it doesn't have the stop wedges. Might be something to try when 4 inches just isn't enough. These are designed for lifting the good wheel on a dual axle trailer to mount the spare on the other. I don't believe if you have a pair of these that one would fit between the two tires as needed to level one side, as the Oliver dual axles are spaced closely to each other. Amazon.com: ANDERSEN HITCHES | RV Accessories | Single Rapid Jack | 3620 : Automotive I've had an old aluminum version of this since the 90s. I used it to change a spare tire or two on the road since. Not sure why I've been carrying this, as the Oliver has power stabilizer jacks that can be used to mount the spare. I should just keep it on our flatbed trailer. Amazon.com: EZ-Jack Combination Jack and Wheel Chock for Dual Axllee Trailers - 20,000 Lb Cap. EZ-Jack EZJACK : Automotive 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
csevel Posted September 22, 2024 Posted September 22, 2024 20 hours ago, Jason Foster said: I see that the Andersen Rapid Jack goes to 5 3/4 but it doesn't have the stop wedges. Might be something to try when 4 inches just isn't enough. I have the Rapid Jack and a regular Andersen leveler. I purchased an extra chock directly from Andersen. I tend to find the best campsites that are always unlevel! 1 2 2020 Toyota Tundra TRD Sport 5.7L V8 2017 Oliver Legacy Elite II Hull #184 ~ "ILOVHER"
Jason Foster Posted September 23, 2024 Posted September 23, 2024 1 hour ago, csevel said: I tend to find the best campsites that are always unlevel! You and me both and I live in Texas, home of tumbleweeds and flatlanders. 1 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
