FloraFauna Posted October 13, 2024 Posted October 13, 2024 Before you think I am crazy, please hear me out. I am wondering about skipping winterization this year so that the trailer is ready to go for winter trips south or colder weather camping when we get an occasional cold weather breaks. When I winterize, I find myself not considering trailer travel until Spring - 5 months of no camping and no trailer use. Nobody wants to winterize and dewinterize several times per winter. Would be nice to head south especially in February or there are times midwinter where we get relative warms spells with brilliant sunshine with or without snow. Winterization seems like surrendering. Pertinent information: I live in southern Wisconsin so cold weather happens. Sometimes we get to 0 F or below but not often and not for long - maybe once or twice per winter for a few days. Obviously I don't intend to head out in the coldest weather but such conditions in storage would present a risk. The Ollie is in unheated, dry storage with electricity about 200 ft from my house so I see the trailer and monitor it everyday. Solar gain to the building will often have the storage space at 10 to 20 degrees above the outside temp. I would leave the Truma furnace on and set at like 40 or 45 F. Obviously I would burn through some propane but I am amazed how efficient the Truma furnace is and since the interior of the building is ventilated I don't see a CO risk. I see some others have put electric space heaters in their trailer but I would worry about air/heat movement and cold corners with a small electric heater where the furnace fan with the blower is more likely to distribute the heat. Maybe combine the space heater with a fan? I drain my tanks after every trip so tanks would be empty. Does anyone have experience (or more experience than I with my Ollie) in this regard with advice to share? 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
Moderators SeaDawg Posted October 13, 2024 Moderators Posted October 13, 2024 (edited) Winterize. It's not that hard to dewinterize when you get south. We had a freak winter storm in late October in nc. I hadn't winterized. We lost the outdoor shower. Even if you just drain and blow out the plumbing, you're better than nothing. I buy rv antifreeze as soon as it's on rhe shelf, and keep a few gallons extra through summer. If nothing else, makes a great door stop. Where you live (and I grew up near there), I'd winterize after last fall trip. That's what we did in "tropical" southern Minnesota. (You know, the pineapple belt....:) You don't have to "de-winter" to do a weekend trip. Just carry water in jugs, and a portapotty, or use a wag bag in the toilet, if you don't want to de-winter. Edited October 13, 2024 by SeaDawg 1 3 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Geronimo John Posted October 13, 2024 Posted October 13, 2024 Having any water in the trailer lines with a hard freeze can cause extensive damage. Strongly suggest the above sage recommendation....it's just not worth the risk. Using the trailer dry can easily be done. For the toilet use one of those bags in the toilet or "go" elsewhere. GJ 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
dewdev Posted October 13, 2024 Posted October 13, 2024 (edited) @FloraFauna I strongly agree with the above comments. I live in Maine and we have some cold snaps in the witner, like you. With the tanks empty, the worry is really freezing of the water lines, particularily the plastic fittings and backflow preventors. That type of damage is a real pain to fix. The backflow preventors and some of the water lines are difficult to access. Play it safe and winterize. You do not have to have water in the lines to camp in the winter; just bring bottle water to drink. If going south, then dewinterize when you get below the freezing zone. Edited October 13, 2024 by dewdev 6 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
FloraFauna Posted October 13, 2024 Author Posted October 13, 2024 hmmm. So far three for three on winterize from those who have been doing this longer than I. Thank you for your sound advice. I kind of knew my idea was wishful thinking and not practical given my location. We have a composting toilet so that's not an issue in any case. I also already have the RV antifreeze as well. Definitely don't want to trash my water lines and valves. 2 2 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
jd1923 Posted October 14, 2024 Posted October 14, 2024 (edited) 11 hours ago, FloraFauna said: I am wondering about skipping winterization this year so that the trailer is ready to go for winter trips south or colder weather camping when we get an occasional cold weather breaks. @FloraFauna I’ve been doing this for years, though Wisconsin is not Arizona. However, I learned this procedure from an engineer who winterized his Bigfoot Class-C using only compressed air at his home in Calgary. We travel Oct through May, not summers. I do this when we get home between winter trips, Not using the pink stuff 2-3 times per winter, or ever. Some say “I would never use compressed air.” I say, I’d never use pink chemical antifreeze. OTT does not recommend using compressed air. https://olivertraveltrailers.com/forums/topic/9849-winterizing-without-rv-antifreeze/?_rid=8971/ Edited October 14, 2024 by jd1923 Fix link 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted October 14, 2024 Posted October 14, 2024 (edited) 11 hours ago, FloraFauna said: I live in southern Wisconsin so cold weather happens. Your northern location tells me all I need to know. I would really think about winterizing based on where you live. A few minutes of effort can forgo hours of locating and repairing a leak. Our Truma makes winterizing super easy. Edited October 14, 2024 by Patriot 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
John Dorrer Posted October 15, 2024 Posted October 15, 2024 On 10/13/2024 at 2:06 PM, FloraFauna said: Before you think I am crazy, please hear me out. I am wondering about skipping winterization this year so that the trailer is ready to go for winter trips south or colder weather camping when we get an occasional cold weather breaks. When I winterize, I find myself not considering trailer travel until Spring - 5 months of no camping and no trailer use. Nobody wants to winterize and dewinterize several times per winter. Would be nice to head south especially in February or there are times midwinter where we get relative warms spells with brilliant sunshine with or without snow. Winterization seems like surrendering. Pertinent information: I live in southern Wisconsin so cold weather happens. Sometimes we get to 0 F or below but not often and not for long - maybe once or twice per winter for a few days. Obviously I don't intend to head out in the coldest weather but such conditions in storage would present a risk. The Ollie is in unheated, dry storage with electricity about 200 ft from my house so I see the trailer and monitor it everyday. Solar gain to the building will often have the storage space at 10 to 20 degrees above the outside temp. I would leave the Truma furnace on and set at like 40 or 45 F. Obviously I would burn through some propane but I am amazed how efficient the Truma furnace is and since the interior of the building is ventilated I don't see a CO risk. I see some others have put electric space heaters in their trailer but I would worry about air/heat movement and cold corners with a small electric heater where the furnace fan with the blower is more likely to distribute the heat. Maybe combine the space heater with a fan? I drain my tanks after every trip so tanks would be empty. Does anyone have experience (or more experience than I with my Ollie) in this regard with advice to share? High Risk Low Reward. It takes 10-15 to winterize and maybe 10 minutes to dewinterize. You can carry a couple of small jugs of water and RV Anti-freeze to use in the toilet. We live in Indianapolis and can expect 0° - 20° for extended periods. We get South where it might get to 35° at night and dewinterize. We keep our Truma Aqua-Go closed and the filter stored until we are in wark weather My question is why would you even risk doing what you have posted. When pipes in your Oliver freeze and crack, many times it is in hard to get to places, resulting in added expense and major stress. It simply isn't worth the risk, when it only takes 10 minutes to dewinterize. 4 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Patriot Posted October 15, 2024 Posted October 15, 2024 38 minutes ago, John Dorrer said: High Risk Low Reward. It takes 10-15 to winterize and maybe 10 minutes to dewinterize. You can carry a couple of small jugs of water and RV Anti-freeze to use in the toilet. We live in Indianapolis and can expect 0° - 20° for extended periods. We get South where it might get to 35° at night and dewinterize. We keep our Truma Aqua-Go closed and the filter stored until we are in wark weather My question is why would you even risk doing what you have posted. When pipes in your Oliver freeze and crack, many times it is in hard to get to places, resulting in added expense and major stress. It simply isn't worth the risk, when it only takes 10 minutes to dewinterize. After a good wash and detail inside and out we winterized and covered up XPLOR today. We used approx 2.5 gal of RV antifreeze. Agree with @John Dorrer super easy to dewinterize should we decide to head to the coast of somewhere beautiful. 👍🏻🇺🇸😎 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
FloraFauna Posted October 15, 2024 Author Posted October 15, 2024 There is another way to frame the question I posed (in an admittedly reaction inducing way). How cold can you camp (all systems on, heating and plumbing) before the risk of water lines freezing becomes a concern? Oliver advertises this as 4-seasons trailer but that obviously has limits. What is that limit? Your responses suggest that limit is between 0 and 20 degrees. Certainly you can use this 4 seasons trailer with temps in the upper 20's, right? I am camping right now and the nightly low is forecast at 27 degrees. Or is the limit 30 degrees? 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
Moderators SeaDawg Posted October 16, 2024 Moderators Posted October 16, 2024 Depends. Keep the belly warm. In our older ollie, we were good to teens, if it warmed above freezing daytime. 2008 doesn't have your insulation. We open accesses to the belly, and run heat. Me, if i know temps will be freezing/cold, I winterize, to avoid stress. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Rivernerd Posted October 16, 2024 Posted October 16, 2024 5 hours ago, FloraFauna said: I am camping right now and the nightly low is forecast at 27 degrees. Or is the limit 30 degrees? We have camped in ambient temps as low as 9 degrees F with the furnace running on propane (nearly full time to keep up). We pulled the outside shower head inside the hull by twisting it off, then putting it back on inside. Our remote thermometers in the belly of Hull #1291 reported temps down to 33 degrees F, but not below. No freeze damage. Whew! That said, I do not recommend camping in an Elite II in temps below 15 degrees F, to be safe. With lows in the 20s F, you should be o.k. with the furnace running. Towing an Elite II in sub-freezing temps is a different issue, as it is potentially dangerous to run the furnace on propane while on the road. And, your water heater is at risk unless you have a Truma with the antifreeze adapter. On the trip mentioned above, we did our travel mid-day, when temps were above 32 F, because we choose not to run the propane furnace unless we are parked. 1 4 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Moderators Mike and Carol Posted October 16, 2024 Moderators Posted October 16, 2024 17 hours ago, FloraFauna said: There is another way to frame the question I posed (in an admittedly reaction inducing way). How cold can you camp (all systems on, heating and plumbing) before the risk of water lines freezing becomes a concern? Oliver advertises this as 4-seasons trailer but that obviously has limits. What is that limit? Your responses suggest that limit is between 0 and 20 degrees. Certainly you can use this 4 seasons trailer with temps in the upper 20's, right? I am camping right now and the nightly low is forecast at 27 degrees. Or is the limit 30 degrees? We’ve camped with overnight temps in the teens and had no problems. We also camped when the temperature never got above freezing for several days and had no issues. Especially if the daytime weather warms to above freezing the Oliver does great. We don’t enjoy very cold camping just like we don’t enjoy endless rain days. Even though the fire pit can warm up the Clam pretty quickly we try to avoid very cold weather. Mike 1 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
FloraFauna Posted May 1, 2025 Author Posted May 1, 2025 On 10/14/2024 at 2:27 AM, Patriot said: Your northern location tells me all I need to know. I would really think about winterizing based on where you live. A few minutes of effort can forgo hours of locating and repairing a leak. Our Truma makes winterizing super easy. As a follow-up to this post last fall. Glad I took your advice and buried my wishful thinking. I winterized as suggested and we had a cold, cold winter and spring. Have now dewinterized and all is good in the Oliver. In the fall in Wisconsin, us older folks get wishful and hope it won't be too cold, too long. Nine out of ten times we are wrong. But there's always hope, just don't bet your Oliver plumbing on it. 3 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
Patriot Posted May 1, 2025 Posted May 1, 2025 1 hour ago, FloraFauna said: Glad I took your advice and buried my wishful thinking. So glad it all worked out and you are good to go! Now enjoy and wishing you safe travels! 🇺🇸 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators topgun2 Posted May 1, 2025 Moderators Posted May 1, 2025 As Patriot implied - winterizing an Oliver is easy and really doesn't take that much time nor cost. Certainly this is true when compared to the time and cost of repairs due to freezing. Glad you did what you did and (I assume) even slept better at night knowing that you had protected your baby. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Jason Foster Posted May 2, 2025 Posted May 2, 2025 I haven't given much thought to winterizing here in Texas. I leave the gas heater on 52 during the winter and the Aquago in Eco. It did fine down to 20 degrees on some nights. This is when it is not in use. I keep it around 68 when we use it. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
