Patriot Posted November 11, 2024 Posted November 11, 2024 (edited) Our Beast of Burden gets a new tail hook ha! After doing a bit of a deep dive I decided to order up a new weigh safe aluminum 10” drop hitch with a 3” shank. I have been using 2 reducers and have never been a fan of them as they are a bit sloppy and noisy or simply too many moving parts. I have to say out of the box I am really impressed with how solid this hitch is engineered. Really well done. I opted to not go with the tongue hitch weight dial. According to quite a few user reviews, these dials use a rubber seal/oring and at times can fail and then require maintenance by replacing the seal. When the O ring fails you will notice fluid leaking from the hitch 👎🏻. Just not something I ever want to think about….ever especially on a long trip. I did opt in for the stainless steel 2” and 2 5/16 balls vs chrome plated hitch balls and locking hitch pic all keyed alike . B&W tow and stow is also a good hitch which I was also considering. My preference has always been aluminum as rust and corrosion will eventually take its toll on steel powder coats so I passed. There is very little play with the new Weigh Safe 180 3” shank. That said, I did order this 3” anti rattle hitch clamp to keep everything buttoned up with zero play. Edit- I ordered my hitch clamp directly their website. Quick shipping and excellent communication. https://www.hitchclamp.com/collections/3-clamps My reducers will no longer be used when towing XPLOR. Edited November 22, 2024 by Patriot Update the link for Hitch Clamp products. 6 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
jd1923 Posted November 12, 2024 Posted November 12, 2024 @Patriot questions… Link for hitch, weight rating? Also, what are the safety chain connectors we see in your last picture? Link! I need these. it’s difficult getting under there on our TV. Thank you, JD 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted November 12, 2024 Author Posted November 12, 2024 (edited) 47 minutes ago, jd1923 said: @Patriot questions… Link for hitch, weight rating? Also, what are the safety chain connectors we see in your last picture? Link! I need these. it’s difficult getting under there on our TV. Thank you, JD You bet JD, these are called 1/2” hammer locks and are rated for 12000 lbs ea. To your point they make it much easier to attach safety chains. My Weigh Safe hitch is rated for 21,000 lbs. link -https://www.weigh-safe.com/product/weigh-safe-drop-hitch/?srsltid=AfmBOoolgTCwKhll9w1HP7E1phPvIgecdRRK__EUlWP7DPInx6CUJx0T Edited November 12, 2024 by Patriot 1 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Geronimo John Posted November 12, 2024 Posted November 12, 2024 16 minutes ago, Patriot said: Also, what are the safety chain connectors we see in your last picture? Link! I need these. it’s difficult getting under there on our TV. Thank you, JD This was a JD discussion several years ago. Below are what was recommended for our OE2's. It is not likely, but should these bit the dust I would get the 12,000 pounders vs. the 7100's. It sure solved the getting under the TV on our F-150. 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderator+ ScubaRx Posted November 12, 2024 Moderator+ Posted November 12, 2024 7 hours ago, Patriot said: Our Beast of Burden gets a new tail hook ha! ...I opted to not go with the tongue hitch weight dial. According to quite a few user reviews, these dials use a rubber seal/oring and at times can fail and then require maintenance by replacing the seal. When the O ring fails you will notice fluid leaking from the hitch 👎🏻. Just not something I ever want to think about….ever especially on a long trip... https://www.amazon.com/dp/B081D8Z6LG?ref_=ppx_hzod_title_dt_b_fed_asin_title_0_0 You have chosen wisely to go with the Weigh Safe Hitch sans dial. I went through three of these (with the dial) and they all failed. I finally bought a Curt 45902 for our Silverado HD trucks. I moved the Weigh Safe Hitch to Tali's Canyon Diesel. All of our other trailers are pulled with that truck anyway and I don't have to swap from the Oliver's 2-5/16" ball to the 2" ball for the smaller trailers. In my opinion, the use of a Weigh Safe Hitch with the dial in towing an Oliver is a WOT after the first use. Unless you are constantly loading the Oliver in different configurations, it's going to register approximately the same weight every time. 2 5 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Patriot Posted November 12, 2024 Author Posted November 12, 2024 5 hours ago, ScubaRx said: In my opinion, the use of a Weigh Safe Hitch with the dial in towing an Oliver is a WOT after the first use. Unless you are constantly loading the Oliver in different configurations, it's going to register approximately the same weight every time. Agreed, and I had the same thoughts. 👍🏻 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Moderators topgun2 Posted November 12, 2024 Moderators Posted November 12, 2024 I'll chime in on the hammer locks: Patriot put me on to these a couple of years back and they are everything they are supposed to be as both Patriot and GJ state above. Perhaps the only downside I can think of with these is that they could be a bit of a problem to remove. But, why remove them? Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted November 12, 2024 Author Posted November 12, 2024 (edited) A vid in the event you need to remove the hammerlocks. (No plans to here).😎 While attached to the receiver as @topgun2 said it could be a little bit of a challenge. Edited November 13, 2024 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Geronimo John Posted November 13, 2024 Posted November 13, 2024 (edited) On 11/12/2024 at 3:52 AM, topgun2 said: Perhaps the only downside I can think of with these is that they could be a bit of a problem to remove. But, why remove them? Bill: You hit the nail square on the head. I found it a PITA to install, and will find a cutting torch or cut-off grinder to remove them if I ever need to. Problem is getting the shackle on something under the truck, in a way to allow for pounding a moving target to install the pin, especially if doing this solo. Would be a PITA for sure. Like you, mine stay on our TV 24/7. Edited November 14, 2024 by Geronimo John typo 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted November 13, 2024 Posted November 13, 2024 11 hours ago, Geronimo John said: I found it a PITA to install, and will find a cutting torch or cut-off grinder to remove the if I ever need to. Found a brand that uses a cotter pin to secure the connecting rod, any thoughts? 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted November 13, 2024 Posted November 13, 2024 2 hours ago, Ronbrink said: Found a brand that uses a cotter pin to secure the connecting rod, any thoughts? The cotter pin just keeps the connecting rod in place. This model should work fine. Also wondering on these. Most are rated at 2500#. This one at 11,000# wondering how? Stronger steel. Others are stainless steel which is certainly a weaker steel. https://a.co/d/aeiJN3k Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Ronbrink Posted November 13, 2024 Posted November 13, 2024 39 minutes ago, jd1923 said: The cotter pin just keeps the connecting rod in place. This model should work fine. Also wondering on these. Most are rated at 2500#. This one at 11,000# wondering how? Stronger steel. Others are stainless steel which is certainly a weaker steel. https://a.co/d/aeiJN3k 12,000# working capacity, 46,000# breaking capacity per Amazon’s description. Good enough for me! 2 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
rideandfly Posted November 13, 2024 Posted November 13, 2024 When Patriot told me about how he was connecting Ollie's chains, I did not use them at the time because Ollie's chains were easy to connect/disconnect on the Tundra hitch. When I purchased the F-150, first thing I noticed the chain hooks were not as easy to connect/disconnect as they were on the Tundra, then I remembered what Patriot had said before. I thought Patriot was using lifting shackles (my mistake), so started using screw-pin lifting shackles (using blue Loctite on the threads) that also exceed federal guidance that makes it easy to connect/disconnect Ollie's chains. Thanks David! Hammer Locks: https://www.mcmaster.com/products/hammer-locks/ Screw-Pin Lifting Shackles: https://www.mcmaster.com/products/lifting-shackles/ Federal Guidance: "If the ultimate combined breaking strength of the two chains is equal to the gross weight of the towed vehicle(s), the requirements of § 393.70(d) are satisfied. It should be noted that some States may have more stringent requirements for safety chains". https://www.fmcsa.dot.gov/safety/when-two-safety-chains-are-used-must-ultimate-combined-breaking-strength-each-chain-be-equal 3 Bill 2015 LE2 #75 2024 F350 6.8L
John Dorrer Posted November 17, 2024 Posted November 17, 2024 1/2", 12,000 lb Hammer Locks installed. Great addition. Thanks Patriot. 1 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Moderators topgun2 Posted November 17, 2024 Moderators Posted November 17, 2024 Great addition, John. Now, grab a can of Krylon semi-gloss black spray paint and give that hitch a shot. All will look new again. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted November 17, 2024 Author Posted November 17, 2024 (edited) 7 hours ago, John Dorrer said: 1/2", 12,000 lb Hammer Locks installed. Great addition. Thanks Patriot. Awesome! I prefer the black color over the red. Looking great John! 🤩👍🏻🇺🇸 Edited November 17, 2024 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Patriot Posted November 22, 2024 Author Posted November 22, 2024 (edited) My 3” hitch clamp arrived today. I decided to cancel my order with Amazon and order directly from Hitch Clamp for a much quicker delivery. Very impressed with the fit and finish of this product. Zero play or movement with this robust clamp. They also gave me a Veterans discount. 🇺🇸👍🏻 https://www.hitchclamp.com/collections/3-clamps Edited November 22, 2024 by Patriot 3 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Moderator+ ScubaRx Posted November 22, 2024 Moderator+ Posted November 22, 2024 Very nice. I could never decide which way was the correct installation orientation. 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Patriot Posted November 22, 2024 Author Posted November 22, 2024 (edited) 13 hours ago, ScubaRx said: Very nice. I could never decide which way was the correct installation orientation. Thank you. I had the same question when I called HC before placing my order. I spoke to a fella named Gabe. I asked him about proper fitment? He said it is designed to put the downward pressure on the shank vs the clamp lifting the down pressure/tongue weight up. https://www.hitchclamp.com/pages/videos Edited November 23, 2024 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Dave and Kimberly Posted April 4 Posted April 4 Patriot- I did a search and your post was exactly what I was looking for! I'm upgrading my truck to an F-250 Super duty Lariat 6.7L Diesel...and I was considering exactly the hitch you bought. Because I don't have the truck yet... I can't measure it up to determine which "drop" to get and ensure our Ollie rides nice and flat. Did you need the 10" drop to make that happen... or do you just have multiple trailers that require it? I see that the hitch comes in several drops... 6", 8" and 10" drops also. 3 2022 Elite II, Hull #1097 Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries. Our tow vehicle is a 2019 Ford Lariat F-150 4wd, 3.5L Eco-boost, 3.55 rear end, with the Max tow package. Elli Rose also has the street side awning and several walnut and cherry mods on the inside.
Patriot Posted April 4 Author Posted April 4 (edited) 2 hours ago, Dave and Kimberly said: Patriot- I did a search and your post was exactly what I was looking for! I'm upgrading my truck to an F-250 Super duty Lariat 6.7L Diesel...and I was considering exactly the hitch you bought. Because I don't have the truck yet... I can't measure it up to determine which "drop" to get and ensure our Ollie rides nice and flat. Did you need the 10" drop to make that happen... or do you just have multiple trailers that require it? I see that the hitch comes in several drops... 6", 8" and 10" drops also. Hey Dave, Great choice on TVs, I really like the 10 speed and of course the engine brake especially on roads like the Teton Pass with 10% grade. Ford nailed it with the engine brake and 10 speed transmission. My particular Super Duty has the Tremor factory lift which if I recall is approx 1.5-2” depending on your tire size. I also run Nitto Ridge Grapplers. My recommendation is that you order the 8” drop and you should be fine since the standard SD does not have the factory lift. I do have another Aluma trailer that I use for various utilities. So the 10” drop with my trucks lift serves me well. I highly recommend this to keep things quiet when towing. - https://www.hitchclamp.com/pages/videos It works great. Are you gong to be at the Rally? If so let’s get together and talk Super Duties! 👍🏻 If you have any other questions shoot me a PM, glad to help. -David Edited April 4 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Dave and Kimberly Posted April 5 Posted April 5 Thanks for the quick response and information! Yes... we are going to be at the rally this year (site E-03) and only the second time we've been able to make it since we were there in 2022 right after buying our Oliver. We are almost as excited to get this new truck as we were to get the Oliver! We won't have it at the rally though... delivery isn't until late May... but trying to line up all our truck bling so that we can have it all ready! Also getting a Smartcap Adventure to keep our gear a bit more protected back there. Lets be sure to hook up because I have lots of questions... and you can tell me all about your Alcan springs also! (I have to say this carefully so as not to get another 20+pages started on the subject 🤣) We CAN NOT WAIT to see everyone at the rally again!! 3 2022 Elite II, Hull #1097 Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries. Our tow vehicle is a 2019 Ford Lariat F-150 4wd, 3.5L Eco-boost, 3.55 rear end, with the Max tow package. Elli Rose also has the street side awning and several walnut and cherry mods on the inside.
Moderator+ ScubaRx Posted April 6 Moderator+ Posted April 6 16 hours ago, Dave and Kimberly said: Thanks for the quick response and information! Yes... we are going to be at the rally this year (site E-03) and only the second time we've been able to make it since we were there in 2022 right after buying our Oliver. We are almost as excited to get this new truck as we were to get the Oliver! We won't have it at the rally though... delivery isn't until late May... but trying to line up all our truck bling so that we can have it all ready! Also getting a Smartcap Adventure to keep our gear a bit more protected back there. Lets be sure to hook up because I have lots of questions... and you can tell me all about your Alcan springs also! (I have to say this carefully so as not to get another 20+pages started on the subject 🤣) We CAN NOT WAIT to see everyone at the rally again!! We'll be right down the road from you in E-05. Drop by and set a spell with us. 3 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
BigTexas Posted April 6 Posted April 6 I purchased the same hitch when I switched to a 2500. In addition to looking good it also allows you to reverse the balls under the truck when not in use to save your shins. 2 Big Texas – 2018 Elite II, Twin Bed, Hull #306 2024 RAM 2500 6.7L Cummins, Weigh Safe hitch
John Dorrer Posted April 6 Posted April 6 Had to remove my hammer locks. What a PIA. My Oliver installed chain hooks wouldn't fit. Not sure what happened as I ordered what others purchased. 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
