This has been bothering me for a while. When I connect the brake cable to the truck it hangs down to 2"-3" above the road.
Can you run it up through the hitch pin with the 7-pin cord?
What does everyone do?
I'm concerned it is matter of time before it is hit by road debris. Having the trailer brakes activate at 60+ mph is a scary thought.
Thanks,
Edited by John Dorrer
Typo
I find if I twist mine it makes it more taut and doesn't hang so low. Same for chains. I've always worried low hanging chains and brake cable could create a spark and possibly fire in dry conditions.
2022 Oliver Elite II Hull#1047 "Saunter"
Solar Pro 390 aH Lithionics
2022 Ram 1500 5.7L Hemi
ALAKAZCOILINIAKSMIMONENVNMNCOHSCTNTXUTWV
Get one of these John
https://a.co/d/iYv5OWt
**Sold😞**
I have what rich.dev showed above and has worked great. Otherwise zip ties as Mike and Carole suggested.
Twisting chains to adjust length is not recommended and can dramatically reduce their strength. Best to cut them to the required length with no twist!
Dave
2015 Oliver Elite 1, Hull 107
I hang my cable in the Sea Biscuit “Moose Rack”. It keeps it at the right height while under way. So far so good.
️Recent Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.
Thanks,
I route my cable over the whale tail of the Andersen. This keeps it far from the ground
2021 Elite II, Hull# 898
That's what came on ours in March 2023.
Steve - Northern Ohio, USA
Facebook - Instagram
Cut them down to the correct length if they hang too much but also make sure you cross them at least once, so if the trailer hitch comes off the ball, it drops onto the chain crossing.
My post was about the brake cable hanging too low, not the chains🙃👍
I plea the 5th.
7 hours ago, Jason Foster said:
I plea the 5th.
🤣 I did get a good chuckle.
I soon replaced the stock brake cable with the red coiled cable, like the one @rich.dev mentioned, after stepping over the trailer tonge when hitched and tripping myself; yep face forward fall, lesson learned. (It’s okay to laugh!)
Just got mine from Amazon. When I go to storage, I will swap it out and coil the old one and keep it as back-up.
Lucky this came up just as I was getting around to fixing it. On my way back from alaska this year I ended up having to hit an empty DEF box in the middle of the road. Didn't have a chance to avoid it but if I had thought more about it I would've at least gone over it off center instead of just straight on (initially figured itd be better for it to hit the part of my bumper that sticks down to protect the winch/diff in the center), ended up smashing the plastic loop that holds the cable to the "pin thing". Didn't even realize it was broken until a couple days later when I went to inspect everything to make sure it was still good.
  • Wow 2
2018 F150 FX4 5.0v8
2022 Oliver Elite Hull #1285
2023 Oliver Elite Hull #1434
Had a similar incident last trip on our way out of Houston, but a slow rolling tire was the ‘target’! Out of nowhere, said tire came rolling into my lane with little time to react and lane change not an option given the heavy traffic. Following some ‘flagrant language’, I immediately started to slow my speed to time for an impact at vehicle dead center. As I worked my way over to the first available exit, my thoughts were on potential damage to the Oliver, most likely to the fiberglass. Thankfully all was found good, but had the tire been on a rim this would have certainly been a dire situation.
Edited by Ronbrink
  • Wow 3
