Snackchaser Posted December 27, 2024 Posted December 27, 2024 I’ve awoken wifey more than a few times; noisily groping around in the dark looking for a tasty midnight snack. So it occurred to me, why not install automatic pantry lights. . . ones that won’t light up the whole trailer? In a previous post, “Lighting the Abyss automatically,” I similarly installed closet lights that turn on when the door is opened and wifey loved it. So here was a perfect opportunity to use the leftover LEDs and switches from the Amazon 4-packs. This is an easy modification, except that there wasn’t a hot wire in that location. Well actually there is a hot wire for the radio, but I wanted one that’s on the master switch that shuts all the lights off at once. So I’ve done the hard part by figuring out how to get a hot wire from the master switch to the lights. I’m not allowed to make any visible holes or have exposed wiring, so I fished the wires from the rear street-side overhead cabinet - behind the pantry - and into the space behind the radio. There are wire channels in the overhead cabinets under the mats and Oliver conveniently moulded a wire channel in the back of the pantry to join them together. It’s easy to snake a fish-rod through the channel to pull a new hot and ground wire through. I’ve found that a $12 Amazon fiberglass sectional fish rod works great for fishing wires in the Oliver because you can add sections as you push it through. It’s a good idea to pull a string through with the wires incase there’s a need to add more wires in the future. Once the wires are fished though, they can be spliced to the under cabinet touch light. The lights wiring is covered by black duct tape under the mat, and there is enough room to tuck a butt splice in the slot. However, I personally preferred splicing into the lighting circuit in the attic where there is more room. This requires a clamp-on amp probe to find the lighting circuit while turning the lights on and off. Be mindful that the master switch wire is there too and it will also show current, and don’t ask me how I know! 1/2 sheet metal screws work well to attach the LED light bars, or use good double stick tape. There is an air gap between the inside and outside walls of the pantry, and screw holes can be drilled through the inside wall in the same way as Oliver did for the shelf mounts. Just be careful not to drill all the way through the outside layer. I put two LED bars end-to-end on the right side of the pantry where they can’t be seen. A piece of 1” aluminum angle was screwed to the upper left corner to mount the cabinet light switch, and the wires were sheathed and secured with cable clamps behind the door frame. Bon Appetit! Cheers, Geoff 1 5
Ronbrink Posted December 27, 2024 Posted December 27, 2024 I went the easy route and installed LED closet lights; rechargeable, dimmable, motion sensor and wireless. Larger ones in the pantry and under the curbside bed, smaller in the battery bay and dinette seat hatches. Easy mount with a magnetic strip and long battery life. 3 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; pending transfer of DC-DC cable run and Mechman 320A high output alternator from former TV.
Jason Foster Posted January 5 Posted January 5 We typically don't eat anything past about 6 pm, but cool idea. 3 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Bill and Nancy Posted January 5 Posted January 5 Nice job! I was lazy and found some battery operated stick on LED lights that are motion sensitive. The seem to work great and you just stick them on for us lazy folks. We put one in the pantry, the closet and the basement next to the access between the beds. I also stuck one that you touch to turn on above the main switch panel. I always hated at night I cant see the black witches without a flash light. Now I just touch the light and it comes on so I can see the switches. So far it's been 2 seasons without needing new batteries. An inexpensive solution that takes no time to or skill to install, just peal and stick. Bill 3 Bill & Nancy Holland MA 2022 Elite II Hull #1265 2022 GMC Diesel Canyon
Patriot Posted January 5 Posted January 5 1 hour ago, Bill and Nancy said: Nice job! I was lazy and found some battery operated stick on LED lights that are motion sensitive. The seem to work great and you just stick them on for us lazy folks. We put one in the pantry, the closet and the basement next to the access between the beds. I also stuck one that you touch to turn on above the main switch panel. I always hated at night I cant see the black witches without a flash light. Now I just touch the light and it comes on so I can see the switches. So far it's been 2 seasons without needing new batteries. An inexpensive solution that takes no time to or skill to install, just peal and stick. Bill Bill, Care to post up a link to your peal & stick lights? 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
jd1923 Posted January 5 Posted January 5 17 hours ago, Jason Foster said: We typically don't eat anything past about 6 pm, but cool idea. Jason, that’s the healthy way to be! Wish I could do the same. Lucky for me when it’s not after 9 PM. I used to be a huge midnight snack guy in my younger years. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
dewdev Posted January 5 Posted January 5 @Bill and Nancy Where did you get the battery operated stick on LED lights that are motion sensitive? Thanks 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Bill and Nancy Posted January 5 Posted January 5 I'll check with Nancy she buys the stuff I just get the honey do list. I'll go out in the trailer now and get some pictures and find out where we got them and re post shortly Bill Bill & Nancy Holland MA 2022 Elite II Hull #1265 2022 GMC Diesel Canyon
Moderators topgun2 Posted January 5 Moderators Posted January 5 THIS looks like it is the puppy. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted January 5 Moderators Posted January 5 18 hours ago, Jason Foster said: We typically don't eat anything past about 6 pm, but cool idea. That’s us, usually done with evening meal by 5 and don’t eat again until 10ish the next morning. 3 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Bill and Nancy Posted January 5 Posted January 5 21 minutes ago, dewdev said: @Bill and Nancy Where did you get the battery operated stick on LED lights that are motion sensitive? Thanks This should be the link for the motion sensitive strip lights. Im not sure where I got the puck light but they have them on amazon but they come in packages of 3 or more. I think I may have got it at Lowes or Home depot. I think I attached the link and the photo file correctly I wanted to put titles on them but I cant seem to do it. The motion lights have a metal strip that sticks with sticky tape to the trailer. Then the light stick with magnets to the strip with rare earth magnets. So it makes it easy to take them down to put in batteries. Hope this helps Bill IMG_0029.HEICIMG_0029.HEICIMG_0029.HEICIMG_0030.HEICIMG_0031.HEICIMG_0032.HEIC https://www.amazon.com/dp/B0C9Q3DVH3 ref_=icdp_ba_mweb_mb_pd_bap_m_grid_rp_0_20_pr_gf&clientRefMarker=pd_bap_m_grid_rp_0_20_pr_gf&heartsTeamIdentifier=buyagain&heartsViewId=FAVORITE_REORDERS&psc=1 1 Bill & Nancy Holland MA 2022 Elite II Hull #1265 2022 GMC Diesel Canyon
Bill and Nancy Posted January 5 Posted January 5 I did something wrong because the photos dont show unless you click on them. Bill & Nancy Holland MA 2022 Elite II Hull #1265 2022 GMC Diesel Canyon
Jason Foster Posted January 10 Posted January 10 On 1/5/2025 at 4:31 PM, jd1923 said: I used to be a huge midnight snack guy in my younger years. Same. But the things I did when I was young don't like me as much as they used to. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Jason Foster Posted January 10 Posted January 10 On 1/5/2025 at 5:30 PM, Mike and Carol said: That’s us, usually done with evening meal by 5 and don’t eat again until 10ish the next morning. About 8 the next morning for us but close enough. 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Jason Foster Posted January 10 Posted January 10 On 12/26/2024 at 9:39 PM, Snackchaser said: I’ve awoken wifey more than a few times; noisily groping around in the dark looking for a tasty midnight snack. So it occurred to me, why not install automatic pantry lights. . . ones that won’t light up the whole trailer? In a previous post, “Lighting the Abyss automatically,” I similarly installed closet lights that turn on when the door is opened and wifey loved it. So here was a perfect opportunity to use the leftover LEDs and switches from the Amazon 4-packs. This is an easy modification, except that there wasn’t a hot wire in that location. Well actually there is a hot wire for the radio, but I wanted one that’s on the master switch that shuts all the lights off at once. So I’ve done the hard part by figuring out how to get a hot wire from the master switch to the lights. I’m not allowed to make any visible holes or have exposed wiring, so I fished the wires from the rear street-side overhead cabinet - behind the pantry - and into the space behind the radio. There are wire channels in the overhead cabinets under the mats and Oliver conveniently moulded a wire channel in the back of the pantry to join them together. It’s easy to snake a fish-rod through the channel to pull a new hot and ground wire through. I’ve found that a $12 Amazon fiberglass sectional fish rod works great for fishing wires in the Oliver because you can add sections as you push it through. It’s a good idea to pull a string through with the wires incase there’s a need to add more wires in the future. Once the wires are fished though, they can be spliced to the under cabinet touch light. The lights wiring is covered by black duct tape under the mat, and there is enough room to tuck a butt splice in the slot. However, I personally preferred splicing into the lighting circuit in the attic where there is more room. This requires a clamp-on amp probe to find the lighting circuit while turning the lights on and off. Be mindful that the master switch wire is there too and it will also show current, and don’t ask me how I know! 1/2 sheet metal screws work well to attach the LED light bars, or use good double stick tape. There is an air gap between the inside and outside walls of the pantry, and screw holes can be drilled through the inside wall in the same way as Oliver did for the shelf mounts. Just be careful not to drill all the way through the outside layer. I put two LED bars end-to-end on the right side of the pantry where they can’t be seen. A piece of 1” aluminum angle was screwed to the upper left corner to mount the cabinet light switch, and the wires were sheathed and secured with cable clamps behind the door frame. Bon Appetit! Cheers, Geoff By the way, for a person who goes by the nickname Snackchaser, your cabinets are curiously devoid of snacks.... 1 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Snackchaser Posted January 10 Author Posted January 10 16 minutes ago, Jason Foster said: By the way, for a person who goes by the nickname Snackchaser, your cabinets are curiously devoid of snacks.... Yes, the snacks are missing!!! Wifey has been notified and I can neither confirm or deny any involvement in their disappearance! 3
