Snackchaser Posted January 18, 2025 Posted January 18, 2025 When doing hook-ups or departures from camp, I regularly find myself in need of water pump pliers to tighten and loosen water lines. . . which means digging out the tool box to find them. So I decided to mount a dedicated pair in the outdoor garage where they will be close at hand when needed.  After looking at various options for storing the pliers, I settled on a small leather tool pouch from Amazon. It was low profile, could be easily mounted on the wall, and it didnât take up precious garage floor space. The pouch also had pockets for a small flashlight and pen, which also can also be elusive items when signing in after dark. The tool pouch had a belt clip that was removed, and I stretched one of the pockets to fit my LED penlight. The leather is easily stretched by soaking it in water for about 60 seconds and using a dowel or other cylindrical object to expand the pocket. The leather is quickly dried in an oven at 130 degrees to hold the new shape. I chose a 7â Knipex Plier Wrench for my kit because of its high quality. They arenât cheap, but the Oliver is deserving, and they are a pleasure to use. There are many excellent choices available for pliers, flashlights and pens. I just used what I already had on hand. Some folks might also be interested in my handy tool for stashing and retrieving things from the unreachable depths of the garage. This is simply a sanded length of 1/2â x 3/4â moulding with an aluminum angle screwed onto one end as a hook to pull things out. Oh, and notice the spring to pull the garage door suspension cable out of the way so it doesnât get pinched in the seal like mine does. Hope you find this useful! Cheers! Geoff  8
Moderators topgun2 Posted January 18, 2025 Moderators Posted January 18, 2025 26 minutes ago, Snackchaser said: Some folks might also be interested in my handy tool for stashing and retrieving things from the unreachable depths of the garage. You mean that you simply can't craw in there to get what you want?đ 4 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted January 18, 2025 Posted January 18, 2025 (edited) 4 hours ago, Snackchaser said: When doing hook-ups or departures from camp, I regularly find myself in need of water pump pliers to tighten and loosen water lines. . Your working too hard đ. We have been using eley hose quick connects for several years and they have served us well and do not leak. A quick and simple way to hook up our water hose sans pliers. https://www.eleyhosereels.com/products/garden-hose-quick-connectors?srsltid=AfmBOorhl73lbWlG-pTRQ_aHjougxYv88x-aD4DfsGjJACCyuZjoAX0t More info here -  Edited January 18, 2025 by Patriot 11 2020 OLEII - Hull #634 aka-  âXPLORâ 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - âBeast of Burdenâ Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. âĄď¸âĄď¸11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.âĄď¸âĄď¸ North Carolina Â
jd1923 Posted January 18, 2025 Posted January 18, 2025 35 minutes ago, Patriot said: Your working too hard đ. We have been using eley hose quick connects for several years and they have served us well and do not leak. Thanks Patriot for this reminder. I read your original post over a year ago. Expensive but if truly no leaking in your years of experience, then worth it. Theyâre 10% off now and I like how you can order x number of male/female fittings. That will take some counting before ordering. On my upgrade list! 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steph and Dud B Posted January 18, 2025 Posted January 18, 2025 5 hours ago, topgun2 said: You mean that you simply can't craw in there to get what you want? Things have a bad habit of sliding to the front of our truck bed, under the hard tonneau cover and out of reach. This hook works great. scottchen PRO RV Awning Rod Opener Easy Reach Telescopic Puller 13-3/4" to 44-3/4" Stainless Steel Silver & Black - 1pack https://a.co/d/aQmHp1H 1 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Snackchaser Posted January 18, 2025 Author Posted January 18, 2025 Â 1 hour ago, Patriot said: Your working too hard đ. We have been using eley hose quick connects for several years and they have served us well and do not leak. A quick and simple way to hook up our water hose sans pliers. Nice! Â I think I'd need several sets! 1 2
jd1923 Posted January 18, 2025 Posted January 18, 2025 21 minutes ago, Steph and Dud B said: Things have a bad habit of sliding to the front of our truck bed, under the hard tonneau cover and out of reach. This hook works great. Geoffâs short homemade stick, not near enough tool! The awning opener, not a good enough hook. I use one of these and itâs never where I need it, so just bought another one, just for the TV and TT! Itâs 27â long or 40â when extended, it gets the job done! Iâve had mine well over 10 years and it has been a savior on many occasions. Not bad at $15. https://a.co/d/ci6xMqe 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steph and Dud B Posted January 19, 2025 Posted January 19, 2025 31 minutes ago, jd1923 said: I use one of these My wife won't let me get a hoe. 1 5 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Patriot Posted January 19, 2025 Posted January 19, 2025 (edited) 51 minutes ago, Snackchaser said: Nice!  I think I'd need several sets! I use a Y valve on the CG shore fresh water source for my extra hose âcamp hoseâ. The rear bumper makes a nice shelf to support my water hose. My Andersen levelers came in handy as the slab had a slight fall to the street side to allow water to run off. This was at Teton Valley Resort in Victor, Idaho last fall, we love the Tetons. And this was a really nice base camp. Edited January 19, 2025 by Patriot 4 2020 OLEII - Hull #634 aka-  âXPLORâ 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - âBeast of Burdenâ Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. âĄď¸âĄď¸11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.âĄď¸âĄď¸ North Carolina Â
Patriot Posted January 19, 2025 Posted January 19, 2025 1 hour ago, jd1923 said: Thanks Patriot for this reminder. I read your original post over a year ago. Expensive but if truly no leaking in your years of experience, then worth it. Theyâre 10% off now and I like how you can order x number of male/female fittings. That will take some counting before ordering. On my upgrade list! Yes spendy for sure JD. Itâs one of those buy once, cry once purchases. Ha! 2 2020 OLEII - Hull #634 aka-  âXPLORâ 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - âBeast of Burdenâ Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. âĄď¸âĄď¸11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.âĄď¸âĄď¸ North Carolina Â
jd1923 Posted January 19, 2025 Posted January 19, 2025 1 hour ago, Patriot said: I use a Y valve on the CG shore fresh water source for my extra hose âcamp hoseâ. The rear bumper makes a nice shelf to support my water hose. That's another good idea... What is that on the back of XPLOR?!? And how many LBS? Please let me know! I've always see the front of your Oliver, parked in your storage shed. WOW! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted January 19, 2025 Posted January 19, 2025 5 hours ago, jd1923 said: What is that on the back of XPLOR?!? And how many LBS? We typically carry both of our bicycles on a 1UP USA Super Duty bike rack. My wife and I are avid cyclist and enjoy rails to trails or just riding around in our CG. The total weight of our rack and bikes is appprox 110#. The bikes are locked down and covered with an XXL Yardstash cover I bought on Amazon. 3 2020 OLEII - Hull #634 aka-  âXPLORâ 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - âBeast of Burdenâ Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. âĄď¸âĄď¸11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.âĄď¸âĄď¸ North Carolina Â
Ronbrink Posted January 19, 2025 Posted January 19, 2025 14 hours ago, Patriot said: I use a Y valve on the CG shore fresh water source for my extra hose âcamp hoseâ. The rear bumper makes a nice shelf to support my water hose. Same here, the Y valve with Eleys for an extra âcamp hoseâ is a very handy addition with many uses. There are times when I prefer not to use the rear bumper as a support for the blue water filter, so I carry a short section of PVC pipe as a ground standoff, works great. Also, the bumper protrusion on either side can be used to hang coiled excess water hose and even propane hose at the rear port, if equipped. Some pics for you and others: 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2â receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted January 19, 2025 Posted January 19, 2025 (edited) 12 hours ago, Patriot said: We typically carry both of our bicycles on a 1UP USA Super Duty bike rack. My wife and I are avid cyclist and enjoy rails to trails or just riding around in our CG. The total weight of our rack and bikes is approx 110#. The bikes are locked down and covered with an XXL Yardstash cover I bought on Amazon. Your picture makes it look like a good size motorcycle. I used to love cycling, when we lived in Texas and Florida. Thousands of road bikes all around Austin and the Hill Country. Here the steep climbs are too tough and the drops too dangerous. I see young guys coming down our road, coasting on bikes at well over 40 MPH! They'd have to ride their brakes all the way down to get any slower. At some point, I want to figure out how to bring my Honda CRF230 dirt bike (240 LBS). It's likely too heavy for the rear of the Oliver. Maybe front of the TV with a special mount or in the truck bed. I just ordered this device to measure tongue weight which I need for the Oliver and a flatbed trailer that carries our side-by-side, so I know the best position for it on the trailer). https://www.amazon.com/dp/B007REK28M?ref=fed_asin_title Edited January 19, 2025 by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted January 19, 2025 Posted January 19, 2025 23 hours ago, Snackchaser said: Nice!  I think I'd need several sets! I really like the idea of having the hose connection "T" before the filter idea. I often need a hose sprayer, but generally have little control over flow when using one of the camp ground taps directly. I have a spare connector in my basement as shown below. Having both the lines out with their own valve would allow use of the hand hose without putting pressure or flow into Ollie. Thanks for waking up the idea! GJ      2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker    OLLIE: 2018 OE2 Hull 342, Twin Bed.   OLLIE DIYâs: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf.  TV DIYâs: 2 5/16" Anderson System, Nitto reconâs, Firestone Rear Air Bags, Bilstein 5100âs, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).  Â
ScottyGS Posted January 20, 2025 Posted January 20, 2025 I threw a fireplace tool with a 90 degree bend on the end in the basement years ago. Hooks the milk crates I store stuff in pretty good and use it for the campfires too. Won't go without it and am paranoid about leaving it at a campsite. 3 Gregg & Donna Scott and Missy the Westie  -   The Flying Sea Turtle - 2016 Hull # 145  2024 Nissan Titan XD -  Western NC  Â
Ronbrink Posted January 20, 2025 Posted January 20, 2025 14 hours ago, Geronimo John said: I really like the idea of having the hose connection "T" before the filter idea. Conversely, I like my Y at the spigot for max pressure to the auxiliary hose, not on the pressure regulated side. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2â receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
dewdev Posted January 20, 2025 Posted January 20, 2025 @Snackchaser Nice install Geoff: Can you tell us what the devices are next to your leather plyer holder? Did you install them there or are they new locations in your 2022 Ollie?  Also, I see two toggle witches in the upper left of your pictures. What are they for and did OTT install them? Thanks Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine Â
Snackchaser Posted January 20, 2025 Author Posted January 20, 2025 1 hour ago, dewdev said: Nice install Geoff: Can you tell us what the devices are next to your leather plyer holder? Did you install them there or are they new locations in your 2022 Ollie?  Also, I see two toggle witches in the upper left of your pictures. What are they for and did OTT install them? Thanks!  And I see how that poor quality photo could raise questions from observant folks.  Only the spirit level was installed by Oliver. The bottom item is a 12vDC outlet for a macerator pump. Next is a rotary switch for electric valves that are used for freshwater tank drain, boondocking and winterizing line-ups. Itâs described in the post âElectric valve control⌠with a twist.â   Then there is a third water-pump switch for the outdoor shower, or when filling the freshwater tank from the boondocking port. This is described in the post â4-way pump switch for the outdoor shower.â Above that, are labeled LED indicators for the aforementioned pump and valves. Lastly a Levelmate with lengthened thumb screws for easy battery changing. They do look like toggle switches! Then my trusty pliers. . . they actually replaced quick disconnects that I found were too bulky and inflexible for my needs. Cheers! Geoff 3
dewdev Posted January 20, 2025 Posted January 20, 2025 @Snackchaser Did you install them yourself? Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine Â
MAX Burner Posted February 7, 2025 Posted February 7, 2025 On 1/18/2025 at 7:53 PM, jd1923 said: I use one of these and itâs never where I need it, so just bought another one, just for the TV and TT! Itâs 27â long or 40â when extended, it gets the job done! I find myself stepping up on the top of the rear wheels to grab stuff from the front of the truck bed -- I'm getting a wee bit "long in the tooth" for those operations, and may need to get a hoe, I'll check with D and see what she thinks.... HA! 4 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD)Â 2017 LEÂ II;Â Hull #226 "Casablanca" HAM call-sign: Â W0ABX
jd1923 Posted February 7, 2025 Posted February 7, 2025 5 hours ago, MAX Burner said: I find myself stepping up on the top of the rear wheels to grab stuff from the front of the truck bed -- I'm getting a wee bit "long in the tooth" for those operations, and may need to get a hoe, I'll check with D and see what she thinks.... HA! That won't help you to get the the back of the Oliver trunk (rear basement)! Three weeks ago I took a fall, and on the way down I cracked a rib, hitting my lower back on the arm of a chair. I was so hurt and stiff, I used this "hoe" to lift the toilet seat and about anything else I needed to reach below waist height! 𤣠Five days later, I did very slowly install LCAs on my '92 SC400, but my injury did delay my DC-DC charger installation! Nothing like crawling under a truck with a bruised rib, ouch! 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steph and Dud B Posted February 8, 2025 Posted February 8, 2025 On 2/7/2025 at 7:26 AM, MAX Burner said: I find myself stepping up on the top of the rear wheels to grab stuff from the front of the truck bed Bought something like this when we had a fifth wheel, to help me reach into the bed while hooking up: Heavy Duty Tire Step https://a.co/d/5vK6ftR. 3 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
jd1923 Posted February 9, 2025 Posted February 9, 2025 9 hours ago, Steph and Dud B said: Bought something like this when we had a fifth wheel, to help me reach into the bed while hooking up: Heavy Duty Tire Step https://a.co/d/5vK6ftR. Done what Art @MAX Burner suggested, for decades, stepping on the tire to get up in the bed. Taller tires and getting older makes this not quite as easy as it used to be! I always have a metal milk crate in my truck bed to assist. But thank you Step & Dud! I should get one of these for working in the engine bay of a truck! The milk crate can slip when leaning forward and this looks to be taller, a better height. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
dewdev Posted February 9, 2025 Posted February 9, 2025 (edited) I use a milk crate all the time to get into the bed of my RAM. Edited February 10, 2025 by dewdev Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine Â
