Wondering if any other owners are considering the new Dodge Ramcharger option for towing their Olivers? On paper sounds pretty good with towing capacity up to 14,000 pounds and 2600 lb cargo capacity. Range is over 100 miles on electric only almost 700 miles using gas, although surely less for both towing.
2025 Ram 1500 Ramcharger Hybrid: What We Know So Far
2022 Oliver Elite II Hull#1047 "Saunter"
Solar Pro 390 aH Lithionics
2022 Ram 1500 5.7L Hemi
ALAKAZCOILINIAKSMIMONENVNMNCOHSCTNTXUTWV
We had a 2019 Ram 1500 Longhorn Laramie with 5.7 Gas E-torque engine.  It had air suspension too.  It had all the bells and whistles although we didn't use them all.  The issue we had was payload with the 1/2 ton.  We knew that we wanted to make longer trips and wanted to have our Weber Grill, then a Q1200, and stand, plus a small griddle someone gave us, plus generator, Clam quickset, and assorted other gear, plus my golf clubs.  We wanted to have extra clothing for longer trips to be able to do seasonal changes.  We only had 400lbs of payload after, my wife, myself, a forty pound dog, and a couple of back packs after connecting the Oliver LEII which had a tongue weight of about 700lbs.  It really meant we had to keep too many items in the aisle that we had to transfer in and out of the Oliver before and after we traveled to the next campground.  The E-torque was sweet and allowed us to have increased low end torque for pull outs onto the highway and starts from red lights and stop signs.  We did love the Ram, so we eventually traded it for a 2021 Ram 2500 with 6.4L Gas engine.  We have air suspension on this truck too.  We have over 1300lbs of additional payload over and above what we had on the fully loaded Ram 1500.  We love our current truck, but the 1500 with E-torque got better mileage and the engine would completely cycle off at long stops if we weren't towing and just traveling in and about town.
Hull 509 "The Swallow"
Certain of these specs? These are far greater capacity than what David @GraniteStaters mentioned. They’re also better than our 2500!
Your sited article makes this vehicle sound as if it’s still in development. Is it currently on the market? I can’t imagine us ever owning something like this. I like our big ole honkin’ truck just like she is.
Beautiful truck will be here soon. Sounds awesome on paper but as you stated the range would be cut in half towing, from what I understand. Hybrid tech is enticing but personally will hold out for full electric with longer tow range. We will get there one day when there is a large enough battery bank on the TT for highway range assist. Power assist and brake regeneration if it has its own electric motors powering the wheels, as well. Then we can get out and park it with an app on the iPhone or better yet it will park itself using AI and cameras!
Awesome specs:
The Ramcharger has a 3.6L V6 engine and a 92-kilowatt-hour battery pack. Over 600 HP and torque. Tows 15k pounds!
It also has a 130-kilowatt generator on board.
The Ramcharger has a dual-motor, all-wheel-drive system.
The Ramcharger has a payload capacity of 2,625 pounds.
The Ramcharger has a 0-60 time of 4.4 seconds.
The Ramcharger has a four-corner active leveling air suspension system.
WOW!
The RAM hybrid is awesome. The future is interesting and the truck is very cool but the range limitations and cost will have me sitting on the sideline watching. I have a 2016 Tundra with 145K miles on it and after 9 years of towing with it, it is still running like a sewing machine. Now that is value to me. Hope for 145K more. Took me this long to do all the upgrade to it. Ha
Edited by rideadeuce
Here ya' go!
https://pebblelife.com/?gad_source=1&gclid=CjwKCAiAwaG9BhAREiwAdhv6Y1nfr4vhcwlGralq6abgET5Pw27r1LfENSEXaE_3xUXrZYcRA21KLhoChccQAvD_BwE
Thanks for posting this and sharing the link.  Interesting that the engine is not even connected to the drivetrain - it only functions as an on-board charger for the battery.  In tow-mode, it comes on earlier to keep the batteries at a higher charge to make sure there is sufficient power for a significant  incline.  I tow in Colorado, so performance up and down the steep mountain passes is essential.  From my reading, it’s designed to take full advantage of re-charging while on the long downhill runs.
Seems there would be a number of potential advantages of this approach, not the least would be huge battery capacity available to supply the trailer if needed.
Not sure I would be one of the early-adopters for a first model-year — but definitely of interest to watch!
Our 2019 Tundra takes less maintenance than my wife's sewing machines!
  • Haha 2
A manufacturers max payload number is theoretical for a very specific version of that truck.  After all is said and done, options added, axle ratios, etc.  You often find that the payload numbers are far less than the maximum stated for the truck.  Don't believe it until you see the sticker on the door.  And, maybe then until you've put it on the scales.  Then you will run into what every other half ton truck tower runs into.  Payload limits.
I like my stinky diesel WAY too much for this.  It's also loud and obnoxious, just the way a truck should be.
I am considering a Ford F-150 with the Coyote as a backup.
  • 3 weeks later...
And likely even less if you are a mountain kind of camper.  But you will LOVE it on the highway.
Maybe we should try to move these comments over here to this discussion?
Scroll down. Page 4 on my phone.
Awesome specs:
WOW!
Does that 130,000 watt generator not take up the entire bed of the truck? 😊
I believe it's in the engine compartment.  We'll soon see.
It's pretty unique.  If you want to stop and charge, it's a phev. (Plug in hybrid).
But, if you want to make tracks, and the distance, the pentastar solely charges the battery.
Contractors can use the battety on-site,  vs bring in generator.
The battery isn't huge. So, daily driver, purely electric. Towing over distance,  definitely need the big gasser pentastar to charge the battery.
I'd say for now, possibly best of both worlds. Still reliant on fossil fuel for long distance,  but at least only one drive train to maintain. The reliable pentastar is pretty much tried and true, though not as an onboard generator.
The power of rhe electric motors is impressive.  It's a compromise,  but, probably a good one in today's world.
Edited by SeaDawg
  • 3 months later...
I stopped at a RAM dealer last week to get the latest on the truck.
What’s posted above is everything the dealer knew. “Probably available 1Q26” was about all they could add.
I’m liking the looks of the 2026 Ramcharger 1500 “extended range EV” (series hybrid) I’d be a bit shy about ordering one now and getting in on the bleeding edge of technology with one of the first ones off the line - but I’m already thinking it will be our next TV.
Will the range be less when towing? Of course - just as my 700 mile range TV would be pushing it to get 400 miles when I hook up the Oliver. I don’t really care to drive even 300 miles in a day if possible. I’m used to refueling before hooking il the trailer again, so again - no loss of utility there.
I know the “if a little is good, a lot is better” mentality is too deeply entrenched to ever be put to bed, but I’ve done pretty well with the “minimalist” approach to tow vehicles. So since the specs on this vehicle are considerably higher than my current or past truck - I think it will do just fine. The regenerative braking will put it hard and shoulders above except perhaps a big diesel with exhaust braking. The small diesels in our current and previous TVs (2.8 and 3.0 liter) have more than enough guts to pull the Ollie up and over the continental divide multiple times - and the get phenomenal mileage with and without the trailer.
I don’t need 0-60 in 4.4 seconds (nor would anything in the trailer be where you left it!) but that power means this thing has serious chops both going and stopping.
Before the Oliver, my driver was a 2017 Prius. I thought the way they worked the hybrid was overly complicated - but I was pleasantly surprised to find the transmission was actually quite simple. Much less complicated than a typical ICE transmission. Still, I like the series hybrid even more.
King Bed Floorplan
electronics package
Truma Aqua-Go
LOUD Dometic Penguin A/C
LevelMate Pro+
RealTruck hard tonneau cover
Rove R2-4K DashCams
I'm looking forward to a test drive, sometime next year.
We've loved our 2008 Dodge Ram. But, It's getting a bit long in the tooth, approaching 300k miles.
The simplicity of the new hybrid design is indeed intriguing.
Same here.
Will be interesting to see how the system runs the ICE. I’m wondering if a V6 is really more engine than needed. I would think an L4 would be enough. Maybe even a diesel…
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
