Teaney Hull 292 Posted July 21, 2025 Posted July 21, 2025 About to buy a 50 foot drinking hose and seeing some HORRIBLE Amazon reviews. What has worked for you? Thanks Gary Hull 292 Gary and Anita Teaney and Ranger 2017 Oliver Elite II Hull 292 2018 Nissan Armada Tampa, FL
Jim and Frances Posted July 21, 2025 Posted July 21, 2025 (edited) We've been using the Zero-G hoses for several years now. No issues to date. They are approved for drinking water and store easily. Also, since I am lazy and have a bad back, we use the stainless quick connect fittings on the trailer and all our hoses. Fast and easy! (The more expensive stainless fittings are much better than the brass ones - which tend to leak a bit.) Hope this helps! Edited July 21, 2025 by Jim and Frances Added comment 3 SE Texas | 2021 Elite II Twin Bed # 927 "Lucy" | 2019 F250 FX4 6.7
Moderators Mike and Carol Posted July 21, 2025 Moderators Posted July 21, 2025 (edited) We’ve also been using Zero-G for years. Both at home and while camping. Edited July 21, 2025 by Mike and Carol 3 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted July 21, 2025 Posted July 21, 2025 2 hours ago, Teaney Hull 292 said: What has worked for you? Keep in mind, flat hoses and other compact hoses recommended do not work for filling the fresh tank via the boondocking port. Something we do often, filling from our extra 35-gal fresh tank in the pickup bed. When pulling water by suction you need a rigid hose, one that will NOT shrink or flatten. We go with the standard Camco hose. 35 ft is what's needed to get from our truck to the boondocking inlet when hitched. I had a 25' hose so purchased a 10' hose which is great alone when we have water hookup at a campground. They are firm and many complain about rolling them up. I roll in big loops and it fits in the Oliver Trunk and unwinds nicely. Good reviews on this Amazon item: https://www.amazon.com/Camco-TastePURE-Heavy-Duty-Construction-22843/dp/B004VHXS20/?th=1 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
John Dorrer Posted July 21, 2025 Posted July 21, 2025 A number of us have purchased these hoses, and there have been no reports of issues using to fill fresh tank or for city water. Use the search and type the word: Hoses 1 2 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
mountainoliver Posted July 21, 2025 Posted July 21, 2025 I’ve been using the zero g hose for several years as well with no issues. Because they aren’t a flat shrinking type hose it fills the fresh tank quickly. I have four 25 foot hoses and typically only use one 25 foot hose but have used all four at times. 6 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Patriot Posted July 21, 2025 Posted July 21, 2025 Here is a link to the Gorilla hose - https://www.homedepot.com/p/Gorilla-1-2-in-x-25-ft-Marine-and-RV-Hose-GMAR0025/325990305 4 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
johnwen Posted July 21, 2025 Posted July 21, 2025 Ditto on the Zero G for us. Get the dark gray hose, not the blue ... we went through several blue ones because of leaks and finally tried the dark gray, the end fittings are much easier to screw onto a faucet. I'm not sure they still make the blue hoses but if you find one, do yourself a favor and don't buy it. We are very happy with Zero G. Best of luck, John 2 3 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
jd1923 Posted July 21, 2025 Posted July 21, 2025 2 hours ago, John Dorrer said: A number of us have purchased these hoses, and there have been no reports of issues using to fill fresh tank or for city water. Correct, but not for just a small few of us who need to pull water (vs. push) though the Boondocking inlet. When a hose shrinks or flattens it cannot be used as a suction line. We just had a thread on this subject. 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
johnwen Posted July 21, 2025 Posted July 21, 2025 11 minutes ago, jd1923 said: Correct, but not for just a small few of us who need to pull water (vs. push) though the Boondocking inlet. When a hose shrinks or flattens it cannot be used as a suction line. We just had a thread on this subject. Very true...we use a short non collapsible one for that :) https://www.amazon.com/dp/B0894GTNZN?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 2 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Rolind Posted July 22, 2025 Posted July 22, 2025 We are also big fans of the Gorilla Hose. We carry a short rigid hose for drawing water from an external container https://a.co/d/3D14tZS 3 Robert and Cheryl, Louisville, KY, Legacy Elite II 2023 Hull #1390 Oliphino, TV F250 Tremor
Moderator+ ScubaRx Posted July 22, 2025 Moderator+ Posted July 22, 2025 (edited) 9 hours ago, jd1923 said: Keep in mind, flat hoses and other compact hoses recommended do not work for filling the fresh tank via the boondocking port. Something we do often, filling from our extra 35-gal fresh tank in the pickup bed. When pulling water by suction you need a rigid hose, one that will NOT shrink or flatten. Because of so many recommendations, yesterday I bought a 25 foot marine and RV Gorilla hose from Home Depot. Like John, we do a lot of boondocking and often fill our tank from our Scepter Military water cans. I was unaware that they "...do not work for filling the fresh tank via the boondocking port..." This will not present a problem for us as I have a dedicated set-up for that purpose but I mention it here for the benefit of others that might not have known. On Home Depot's website, this is a buy one, get 20% off on the second one until 07-27-2025. I believe I'll get another for a dedicated black flush hose. They are so light and compact they'll take up only about 10% of the room as the old hoses presently do. Edited July 22, 2025 by ScubaRx 8 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
John and Debbie Posted July 22, 2025 Posted July 22, 2025 9 hours ago, ScubaRx said: Because of so many recommendations, yesterday I bought a 25 foot marine and RV Gorilla hose from Home Depot. Like John, we do a lot of boondocking and often fill our tank from our Scepter Military water cans. I was unaware that they "...do not work for filling the fresh tank via the boondocking port..." This will not present a problem for us as I have a dedicated set-up for that purpose but I mention it here for the benefit of others that might not have known. On Home Depot's website, this is a buy one, get 20% off on the second one until 07-27-2025. I believe I'll get another for a dedicated black flush hose. They are so light and compact they'll take up only about 10% of the room as the old hoses presently do. I did buy a Gorilla RV hose for the black tank flush a couple months ago. I found that at some dump stations, the hose they have isn't long enough. I have another one in case the Camco 25' hose won't reach the city water inlet. I have only used that once at a KOA that had the water faucet past the hitch! John 1 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Galway Girl Posted July 22, 2025 Posted July 22, 2025 We use US made Flexzilla hoses. They are drinking water safe and stay flexible in low temps. Here’s our complete list in our blog: https://4-ever-hitched.com/blog-articles/f/campsite-water-setup?blogcategory=Camping+Equipment 1 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Patriot Posted July 22, 2025 Posted July 22, 2025 (edited) 12 hours ago, ScubaRx said: On Home Depot's website, this is a buy one, get 20% off on the second one until 07-27-2025. Just beware that the 20% discount applies for on line orders only. I was informed by an HD associate that if you are in the actual store and naturally want the 20% discount, order and pay for it on your phone. Then go to customer service with the product in hand, then show your on line receipt and you’re good to go. I learned this lesson today. 🤷♂️ Edited July 22, 2025 by Patriot 1 4 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
DavePhelps Posted July 22, 2025 Posted July 22, 2025 As far as the more traditional RV hoses that won't collapse in a siphon scenario, the very best that I have found are the ones sold by The Water Filter Store. The fittings are excellent and the hose is also very high quality material. They will also custom make them to length as you require. https://www.rvwaterfilterstore.com/products/custom-built-hoses Dave 2 2015 Oliver Elite 1, Hull 107 2025 GMC Sierra HD 2500 AT4, 6.6 L8T (gas)
Galileo Posted July 22, 2025 Posted July 22, 2025 23 hours ago, johnwen said: Ditto on the Zero G for us. Get the dark gray hose, not the blue ... we went through several blue ones because of leaks and finally tried the dark gray, the end fittings are much easier to screw onto a faucet. I'm not sure they still make the blue hoses but if you find one, do yourself a favor and don't buy it. We are very happy with Zero G. Best of luck, John Been using the blue Zero-G hose for two years and 4 long trips. No issues other than I don’t care for the fitting metal. I don’t imagine that hose will be very forgiving of manhandling the hose near the fitting, but I don’t, so it’s fine. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Galileo Posted July 22, 2025 Posted July 22, 2025 22 hours ago, johnwen said: Very true...we use a short non collapsible one for that 🙂 https://www.amazon.com/dp/B0894GTNZN?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 I just snapped up a male GHT “repair” hose end with a bard, and a 3’ piece of heavy vinyl tubing to fit from the local hardware store. Though I generally only need to use it for winterizing, I did have to press it into service to boondock 10 gallons into the tank at a campground with electric only hookup. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted July 23, 2025 Posted July 23, 2025 (edited) On 7/21/2025 at 3:08 PM, johnwen said: Very true...we use a short non collapsible one for that 🙂 We use a 35 ft rigid hose to get from our truck bed to the Boondocking inlet! (when hitched) Here I used only the 25’ hose since I had backed closer. Not carrying those little water jugs! We fill about 18 gallons at a time, every 3-5 days, half our 35-gal storage tank. Filled up this morning while breaking camp (in the rain) and dropped some gray which is allowed in our remote NF location. Ready for our next camp! Edited July 23, 2025 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
johnwen Posted July 23, 2025 Posted July 23, 2025 4 hours ago, Galileo said: Been using the blue Zero-G hose for two years and 4 long trips. No issues other than I don’t care for the fitting metal. I don’t imagine that hose will be very forgiving of manhandling the hose near the fitting, but I don’t, so it’s fine. We are full timers and use ours a lot these past 5 + years. 3 replacements of the "blues", because of leaks, had me looking for something else. No arguments here, just wanted a better fit for us. Just my opinion and do really like the easy way both the gray and blue wrap and store in our front basket :) 2 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Galileo Posted July 23, 2025 Posted July 23, 2025 Yes, I switched to the Zero-G (was on a prominent display at Camping World) after I got tired of the Camco white hoses. I’ve found those can’t take being hooked up to even regulated (30-35psi) water for extended periods. They swell and don’t inspire much confidence. They also kink pretty easily. I’ve never seen a grey Zero-G hose. I was just attracted to the light weight, smaller coiled size, and - so far - no leaks. Front basket? While you drive? I’ve never left anything in there while moving except between the registration booth and our camp site, and then the dump station. My cords and hoses get tucked in the “basement”. I’m eyeing the SeaBiscuit cover, but hesitating due to the $$$. Dunno what they bill the difference between the blue and the grey as being. Perhaps I got a later one that doesn’t have the issues you experienced. ’Course, now I’ve jinxed myself and I suppose the damn thing will explode on me tomorrow… 1 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Ronbrink Posted July 23, 2025 Posted July 23, 2025 (edited) 7 hours ago, Galileo said: Dunno what they bill the difference between the blue and the grey as being. The diameter of the hoses are different; gray is 5/8”, blue 1/2”. I have two dedicated gray hoses, one for freshwater hookups, the other for black tank rinse; and a blue hose for general washing and cleaning. The black tank rinse hose lives in the rear bumper compartment with the other dump equipment, the other two in the basement. Edited July 23, 2025 by Ronbrink 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted July 24, 2025 Posted July 24, 2025 (edited) 15 hours ago, Ronbrink said: The diameter of the hoses are different; gray is 5/8”, blue 1/2”. I have two dedicated gray hoses… I would not have an 1/2” ID hose. It’s like having a built in water restrictor! You want 5/8” with 3/4” fittings, min. Commercial hoses are 3/4” end-to-end. Per Ron, get the gray if you gotta have this brand! Edited July 24, 2025 by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted July 24, 2025 Posted July 24, 2025 On 7/22/2025 at 11:26 AM, DavePhelps said: Water Filter Store. The fittings are excellent and the hose is also very high quality material. Lotta money, why 1/2” ID? Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
