  • The title was changed to XPLOR Hull# 634 - (2) Epoch 300ah battery and complete Victron Install
David, great write up!  Looks like they did a great job.
We’ve stayed at Cumberland Mountain State Park a bunch of times, one of our favorites.  Mike
Thanks Mike,
We were due for the upgrade and this system gives us many more options. Cannot say enough about Inverter Services.
Cumberland Mountain SP is well kept, with level sites and it was super quiet which we like with only a handful of late fall campers.
David
Edited by Patriot
David,
Great looking installation, looks like you picked a quality company, too. Looking forward to seeing this installation learning more about it!
Very nice? How long did they have your trailer? We already have the lithium package, but at some point, I'd like to swap in the Victron inverter, Cerbo GX, and DC-DC system.
Did you bring along the Truma soft start for them to install? I'm assuming they don't stock these.
Steve - Northern Ohio, USA
Facebook - Instagram
Thanks! Plan on 1-2 weeks depending on what you’re having done. They had the SoftStartRV in stock  for our Truma.
They typically have a 6-7 month wait time for an appointment, they are that good and 💯worth the wait based on our experience.
I happened to a call and ask if they had a cancelation, they did. I was originally scheduled for March.
Edited by Patriot
31 minutes ago, rideandfly said:
David,
Thanks Bill,
We will set a time up for you to come by for sure! 👍🏻
Thank you!
David:
Where did you have the Inverter/Converter installed?
41 minutes ago, Geronimo John said:
David:
John,
Under the rear street side bed right where the former Xantrex 2000 was installed by Oliver. A custom platform was added to secure the longer a heavier Victron Inverter/charger.
Edited by Patriot
  • Love 2
1 hour ago, Steve Morris said:
Thank you!
Steve, glad to pass it forward. If you go with Inverter Services, I  think you will be happy with their work. Jim Posey whom I think you have seen on the Oliver FB page referred me to this company. He has had a lot of work done by them on different RVs over the years and believes they are one of the best. I agree.
Edited by Patriot
  • The title was changed to XPLOR Hull# 634 - (2) Epoch 300ah batteries and complete Victron System Install
SOLD on 11/21/25 on FB Market Place.
Edited by Patriot
@Patriot
I have a couple of questions about your Victron/Epoch installation.
Do you know what the black material is that they used for mounting the Victron equipment and Andersen connector?
I also noticed that you have both an Orion XS 1400 DC/DC charger and an Orion-Tr 12|12 - 9  DC to DC converter.  You mentioned that the Orion XS 1400 DC/DC charger was part of the lithium upgrade, so what is the purpose of the Orion-Tr 12|12 - 9  DC to DC converter?
Here are my thoughts:  edited-
We previously owned an Overland Trailer (which had a Max Air fan).  We experienced a voltage issue so I had the Orion-Tr 12/12-9 installed to stabilize and maintain 12v power to the fan. Now I do not have to be concerned about possible spikes or a malfunctioning control board. Max Air Fans operating above 13.8v can damage the fans control board. This will prevent damage to the sensitive control board.
The black plastic board material used to secure all components is called Starboard or Black HDPE and I can tell you it’s super tough and used in Marine grade applications. Inverter Services uses lots of this material during their installs. Here - https://www.amazon.com/gp/aw/d/B08M6DJNH4/?_
Open Source info on Max Air Fans-
*** MaxxAir fans are designed for a 12 Volt DC system, operating within a voltage range of approximately 10.6–13.6V, with an optimal test voltage of 12.8V. Operating above 13.8V can damage the fan's control board and void the warranty, especially if the system is charging. To prevent issues from voltage spikes, a DC/DC voltage regulator is recommended for stable power, especially when the vehicle's charging system is active.
Edited by Patriot
2 hours ago, Patriot said:
Let’s see, in my best kitchen english my thoughts as I am not an electrician or electronics wiz, but am learning - 😊
From previous experience from an Overland Trailer we owned which had Max Air fan and we had  a voltage issue with, I requested the Orion-Tr 12/12-9 install to stabilize and maintain 12v power to the Max Air Fan and not to be concerned about possible spikes and a fried or wonky control board. Max Air Fans operating above 13.8v can damage the fans control board. This will prevent damage or ward off the potential electrical gremlins to the sensitive control board.
I'm not familiar with factory solar/lithium systems installed from Oliver and like David, still learning about electrical/electronics.  We installed Battleborn Lithium battery with Renogy Solar controller that we use with up to two solar suitcases, and an onboard progressive Lithium charger.
We had issues with our MaxxAir fan. It started beeping and a green light on the unit started flashing. Checked internet and found Lithium batteries can cause high voltage issues with MaxxAir fans, when we had the issues we were on shore power, the Progressive lithium charger had our 12V system at 14.4V DC. Also gave MaxxAir/Airxcel technical support a call and they confirmed lithium battery higher voltage can cause the problem we were having with the MaxxAir fan.
This had me wondering if the  higher lithium voltage would cause issues with other 12V components, checked with Jensen and they said our TV was tested to 16 to 17V without issues. I don't know about other 12V components on Ollie, yet.
We installed a DC to DC converter (12.3V output) from Amazon, secured with Velcro. Also replaced the fan's circuit board with one from Amazon, probably unnecessary.  It's working OK now.
https://www.amazon.com/dp/B081RG8XP5?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Found this on YouTube:
Edited by rideandfly
Interesting!  Apparently fans manufactured after Jan 2022 have the new boards which are not impacted by higher voltages from lithium chargers.  Fans with a serial number starting with 22 should have the new board.
I should be in the clear. . . darn!  Thought I had a new project there for a moment!
  • Haha 4
@Patriot
Thank you for answering my first 2 questions!  The Victron Orion 12|12 - 9 installation location confused me, the converter I installed for the MAXXAIR fan voltage issue is in the attic area.
I am familiar with Starboard products, as they are produced in Florida and I have used some around the house.  I am always looking for different ways to do things and was wondering how Inverter Services attached the Starboard to the Oliver’s fiberglass?
They use a really strong industrial strength glue which I do not recall the name of. I do know that they use this adhesive in ALL their RV and Marine fiberglass installs. The next time I speak to the good folks at Inverter Services, I will try and remember to ask him about the adhesive they use. 👍🏻
“We previously owned an Overland Trailer (which had a Max Air fan).  We experienced a voltage issue so I had the Orion-Tr 12/12-9 installed to stabilize and maintain 12v power to the fan. Now I do not have to be concerned about possible spikes or a malfunctioning control board. Max Air Fans operating above 13.8v can damage the fans control board. This will prevent damage to the sensitive control board.”
 I also had read about this issue with the Maxxfan control board around the time I changed my batteries to lithium about four years ago. I added the Drok buck/boost circuit to run both the bath fan and the Maxxfan and suggested using the Drok circuit for anyone with lithium batteries as a safety precaution. To my knowledge all other “12 volt” appliances are designed to withstand over the typical lithium battery voltage without any issues.IMG_1468.thumb.jpeg.91f11ca31b8d3c0dd7c645ab8e8e894a.jpegIMG_1467.thumb.jpeg.7b35034836322c786c392918edac1b26.jpeg
2017 Elite II, Hull #208
2019 Chevy HD 2500 Duramax
Appreciate info on the other 12V components!
Epoch Lithium Battery Storage Info-
I reached out to Epoch Battery Lithium battery customer service (Stockbridge, Georgia) regarding our recent install of (2) of Epoch 300ah (self heating) batteries in our OLE2 and correct SOC during short term winter storage. They responded quickly and this is the guidance they provided.
This information is for anyone that now owns or is considering a swap at some point from aging AGMs over to Epoch 300ah batteries. Epoch recommends 1-6 months in storage a 50-70% SOC.
Epoch does not recommend leaving the batteries plugged in 24x7 via 30amp power and maintaining the batteries at 100% SOC during storage months.
⚡️⚡️Just passing it forward! ⚡️⚡️
A little more detailed info on battery storage I received from Epoch.
 If You Must Leave the Battery Installed
Cold climates:
 Keep the battery connected to a powered LiFePO₄ charger or maintainer so the internal heater can operate.
o The heater only runs when the battery is plugged into an active power source.
o Solar panels alone usually can’t provide enough energy at night or during long cloudy stretches.
 Do not attempt to charge the battery below 32 °F (0 °C) unless the heater is operating.
Temperate or warm climates:
 A small solar maintainer can work if days are sunny and parasitic draws are very low.
 If possible, connect to shore power or plug in occasionally to ensure a full top-up.
 Avoid long periods at 100% charge — this shortens battery life.
🔌 Before Storage
1. Charge to about 50% SOC (roughly 13.1–13.2 V for 12 V systems).
2. Turn off or disconnect all non-essential loads. Even a tiny 50 mA draw can drain 36 Ah per month!
3. Use a battery disconnect switch or pull the main fuse if possible.
4. Confirm heater power if you plan to leave the battery in a freezing location.
🧯 Step 3 – Understand heater and charger operation
 Epoch batteries with internal heaters must be connected to an active charger for the heater to receive power.
 The heater automatically turns on when the internal temperature drops near freezing and turns off when warm enough to charge.
 If no power source is available, the heater cannot run, and charging below freezing must be avoided.
⚠️ Never try to “force charge” a cold battery. Doing so can cause permanent damage.
🧭 Step 4 – Check occasionally
 Installed batteries: check voltage or Bluetooth app monthly.
 Stored indoors: check every 1–3 months.
If voltage falls below about 13.0 V (12 V system) or 26.0 V (24 V system), recharge briefly to about 50% SOC.
🌡️ Summary Table
Storage Location
Climate
Recommended SOC
Charger Needed?
Heater Power
Notes
Indoors (best)
Any
40–60%
No
N/A
Check every 2 mo.
Installed + Shore Power
Cold/Temperate
40–60%
Yes – active
Yes
Ideal if removal not practical
Installed + Solar Only
Temperate
40–60%
Possibly
Maybe
Risky in long cloudy/cold spells
Installed + No Charger
Any
50%
No
No
Disconnect all loads; check monthly
⚠️ Quick Reminders
 Do not charge below 32 °F (0 °C) unless the internal heater is powered.
 Avoid storing at 100% charge for more than a few weeks.
 Avoid high heat (above 86 °F / 30 °C) during long storage.
 Use only LiFePO₄-compatible chargers (Victron, Epoch, or similar).
 Always follow Epoch’s voltage and temperature specifications for your model.
🏁 Spring Startup
1. Inspect cables and terminals.
2. Reconnect any disconnect switches or fuses.
3. Bring the battery to full charge before first use.
4. Verify normal operation in the Epoch App or Victron monitor.
Questions or Support
If you’re unsure which option is right for your climate or setup, contact your authorized Epoch dealer or support team.
They can help you confirm heater operation and charger compatibility.
Edited by Patriot
