Moderators mossemi Posted December 19, 2025 Moderators Posted December 19, 2025 (edited) On 12/19/2025 at 9:21 AM, CRM said: And is it me, or is the bolt on the Battleborn battery that he says is too small and the equivalent of a 6 awg cable look to be the same size used on the Lithionics battery main connections? CRM gets a gold star for his observation, because I can confirm that the terminal bolts on my 3 100 amp hour BB's are 8mm or 5/16". My 320 amp hour Lithionic battery has the same 8mm or 5/16" terminal bolts. Mossey Edited February 12 by mossemi 1 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
jd1923 Posted December 19, 2025 Posted December 19, 2025 4 hours ago, mossemi said: CRM get a gold star for his observation, because I can confirm that the terminal bolts on my 3 100 amp hour BB's are 8mm or 5/16". My 320 amp hour Lithionic battery has the same 8mm or 5/16" terminal bolts. Mossey Mossey, you have both BB and Lithionic batteries? 8mm is pretty much standard, same on Epoch. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steve and MA Posted December 19, 2025 Posted December 19, 2025 (edited) It looks like the issue is the bolt inside the BB that conducts (and resists) all of the current. A plastic spacer separating the internal buss bar from the terminal prevents direct connection of the two. The external terminal connections on the BB as well as the Lithionics do not rely on the bolts as part of the circuit. For both designs, the battery cables are held directly against the battery terminals when properly connected. There's much more surface area contact between them than just an 8mm bolt. Edited December 19, 2025 by Steve and MA Added picture of BB internal terminal bolted to buss bar 2 2 Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
Moderators mossemi Posted December 19, 2025 Moderators Posted December 19, 2025 1 hour ago, jd1923 said: 5 hours ago, mossemi said: Mossey, you have both BB and Lithionic batteries? Yep! I bought the BB's in 2020. I won the Lithionics battery at the 2025 OTTO's Rally. I haven’t installed the Lithionics battery yet, because my onboard charger is not approved by Lithionics. A MP2 is a future project. Mossey 3 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
rideandfly Posted December 20, 2025 Posted December 20, 2025 (edited) Temperature tags or something similar may be a good idea for both batteries, too. Like the idea of being able to check battery temps with the smart phone. Here's my current plan to monitor the 100AH BB temperature connected to the load, subject to change, will see. We have two 100AH BB connected parallel in our Ollie. Since we have one Victron IP65 Bluetooth SmartShunt, going to connect the + BB battery terminal to the Shunt temperature sensor that the + load/charge cable is also connected to. We don't have an inverter or factory installed solar. Battery charge comes from a Progressive Dynamics 4045 converter/charger or our two 100W solar suitcases. The reason I installed a Victron IP65 SmartShunt in the battery compartment is because it's waterproof. Here's a Q&A on the Victron forum about connecting the IP65 SmartShunt to the Victron temperature sensor splicing to the correct IP65 wires: https://communityarchive.victronenergy.com/questions/213907/temp-sensor-with-smartshunt-500a-ip65.html Edited December 20, 2025 by rideandfly 2 Bill 2015 LE2 #75 2024 F350 6.8L
Geronimo John Posted December 20, 2025 Posted December 20, 2025 (edited) Steve great picture! GJ Edited December 20, 2025 by Geronimo John TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Patriot Posted December 21, 2025 Posted December 21, 2025 (edited) Another vid from Will on a new issue with BB’s.🤔 Edited December 21, 2025 by Patriot 1 2 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Cort Posted December 21, 2025 Posted December 21, 2025 16 hours ago, Patriot said: Another vid from Will on a new issue with BB’s.🤔 Good for Will for testing a new battery. I was getting a little down on him for posing that everyone should get rid of their BB's. I wonder if its an applicable test? Apparently BB should be able to handle this but when I looked this up on AI it said this is a very severe test of the batteries and they will heat up. Unless I have this wrong - under normal circumstances we would never draw nearly this much power from a battery (???) 2 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
jd1923 Posted December 21, 2025 Posted December 21, 2025 22 minutes ago, Cort said: Unless I have this wrong - under normal circumstances we would never draw nearly this much power from a battery (???) It depends on your total Ah and usage... I certainly agree with Will on two points (his snarky way makes me 🤣, although if you own BBs it's certainly not funny). First, these are truly OVERPRICED in today's market and he ran a valid test. Second as he stated, I wonder if BB the company has reprogrammed these to produce less output which of course results in less heat produced. Of course units sold years ago would not be programmed as such unless you can/have updated firmware. More on your question... Running a 1100W coffee machine is drawing 90A (1100/12 for 12VDC). Running a blow-dryer or A/C could pull 1800W or 150A . So any 1100W appliance is very close to his 99A test which I would call normal use. If you were running on a single 100 Ah, I'd say you'd be screwed! HOWEVER, not to worry as most of you have two or three 100 Ah BB batteries. Say you have 3 batteries the amperage is split, so the 1100W appliance that pulls 90A will pull 30A from each battery (more "normal circumstances"). This is why most of you have not had heat issues. The fact that the Gold Standard, premium priced battery can only produce half of their spec!!! If you bought BB new recently, I'd strongly suggest asking for your money back. In contrast, the 300 Ah Epoch Essential can draw 100A recommended and 200A maximum (400A peak for 10s). 300 Ah at $1200 list price is $4/Ah rating ($3.40/Ah when on sale 15% off). The BB at the $800 current sale price is more than double the cost at $8/Ah. If the 100 Ah BB could truly produce 100A discharge, 3 BBs would be far superior to one 300 Ah Epoch (only) in its ability to produce discharge output. But If actual numbers are 50% less, then the output capacity is about the same. Most Oliver Owners who upgraded to Epoch have installed two 300 Ah batteries (600 Ah for 85% the cost of 3 100 Ah BBs today, when both are on sale). Two have a discharge capacity of 200A, maximum 400A which means you can run that noisy Dometic P2 A/C (150A+) all day, under spec/no heat issues, or until you get low on SOC! 😎 5 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
John Dorrer Posted December 22, 2025 Author Posted December 22, 2025 Mike Sokol posted another email newsletter on Battleborn. It is too long to screen shot, so you will need to get on the newsletter mailing. John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
John Dorrer Posted December 22, 2025 Author Posted December 22, 2025 Here is the whole article 2 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Geronimo John Posted December 28, 2025 Posted December 28, 2025 On 12/19/2025 at 7:09 AM, mossemi said: CRM get a gold star for his observation, because I can confirm that the terminal bolts on my 3 100 amp hour BB's are 8mm or 5/16". My 320 amp hour Lithionic battery has the same 8mm or 5/16" terminal bolts. Yes, the single bolt on the BB must carry the load. On the Lithionics I believe they use the same bolt, but the buss bars have several bolts that appear to share the load. I recall this from one of the videos. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Cort Posted December 28, 2025 Posted December 28, 2025 On 12/21/2025 at 10:03 AM, jd1923 said: It depends on your total Ah and usage... I certainly agree with Will on two points (his snarky way makes me 🤣, although if you own BBs it's certainly not funny). First, these are truly OVERPRICED in today's market and he ran a valid test. Second as he stated, I wonder if BB the company has reprogrammed these to produce less output which of course results in less heat produced. Of course units sold years ago would not be programmed as such unless you can/have updated firmware. More on your question... Running a 1100W coffee machine is drawing 90A (1100/12 for 12VDC). Running a blow-dryer or A/C could pull 1800W or 150A . So any 1100W appliance is very close to his 99A test which I would call normal use. If you were running on a single 100 Ah, I'd say you'd be screwed! HOWEVER, not to worry as most of you have two or three 100 Ah BB batteries. Say you have 3 batteries the amperage is split, so the 1100W appliance that pulls 90A will pull 30A from each battery (more "normal circumstances"). This is why most of you have not had heat issues. The fact that the Gold Standard, premium priced battery can only produce half of their spec!!! If you bought BB new recently, I'd strongly suggest asking for your money back. In contrast, the 300 Ah Epoch Essential can draw 100A recommended and 200A maximum (400A peak for 10s). 300 Ah at $1200 list price is $4/Ah rating ($3.40/Ah when on sale 15% off). The BB at the $800 current sale price is more than double the cost at $8/Ah. If the 100 Ah BB could truly produce 100A discharge, 3 BBs would be far superior to one 300 Ah Epoch (only) in its ability to produce discharge output. But If actual numbers are 50% less, then the output capacity is about the same. Most Oliver Owners who upgraded to Epoch have installed two 300 Ah batteries (600 Ah for 85% the cost of 3 100 Ah BBs today, when both are on sale). Two have a discharge capacity of 200A, maximum 400A which means you can run that noisy Dometic P2 A/C (150A+) all day, under spec/no heat issues, or until you get low on SOC! 😎 Thanks for clearing that up. 🙂 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
CRM Posted January 9 Posted January 9 Ouch! Things get worse... Battleborn Battery MELTED?! 🔥🔥New Problem! 5 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
John Dorrer Posted January 9 Author Posted January 9 2 hours ago, CRM said: Ouch! Things get worse... Battleborn Battery MELTED?! 🔥🔥New Problem! In a Big Way 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Moderators Mike and Carol Posted January 9 Moderators Posted January 9 16 hours ago, CRM said: Ouch! Things get worse... Battleborn Battery MELTED?! 🔥🔥New Problem! Concerning, for sure. My BB’s are 4 years old this month. I checked them last week and they look like they did when they were new. Nothing loose or discolored. We’ve done a lot of camping the last 4 years. From the videos it looks like there are design issues. I wonder if there is also a manufacturing QA issue. Why aren’t there widespread issues being reported from the many installed BB owners? Could there be a recent decline in manufacturing quality? Why hasn’t BB notified us of potential danger of using their batteries? I know there are quite a few Olivers with BB batteries, so this is quite troubling. Something about this whole thing feels a little off. Mike 3 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted January 9 Posted January 9 57 minutes ago, Mike and Carol said: From the videos it looks like there are design issues. I wonder if there is also a manufacturing QA issue. Why aren’t there widespread issues being reported from the many installed BB owners? Could there be a recent decline in manufacturing quality? I'm with you on this line of thinking. Years of use without issues reported. Now there is an instance, one reported issue, only in test of a brand new battery. What we don't know is if BB changed their build process, or did a supplier in China change/cheapen the process in one one or more battery components? 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted January 11 Posted January 11 (edited) Heads Up!! A 2 day old vid. Yet another new issue with Battleborn. 🧐 Not good. Edited January 11 by Patriot 2 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators Mike and Carol Posted January 11 Moderators Posted January 11 56 minutes ago, Patriot said: Heads Up!! A 2 day old vid. Yet another new issue with Battleborn. 🧐 Not good. This is the same video posted above on Thursday by CRM. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted January 11 Posted January 11 15 minutes ago, Mike and Carol said: This is the same video posted above on Thursday by CRM. Yeah, and has anybody read a report from a true BB customer vs. Will Prowse who makes his living on YouTube clicks?! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted January 11 Posted January 11 (edited) 11 hours ago, Mike and Carol said: This is the same video posted above on Thursday by CRM. Hey Mike, Please feel free to delete my repeat post on Will’s vid. I missed that link where CRM had posted it already. 😊 You make great points about the possible QC, obvious design flaws, over all manufacturing quality being a culprit. It will be very interesting to see how BB moves forward. As for BB admitting to any potential danger to its customers or that there is a problem even with a specific batch of batteries, I don’t see that happening. Sounds like you have had great service out of your BB’s and will likely never have an issue. 👍🏻 Edited January 11 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators Mike and Carol Posted January 11 Moderators Posted January 11 (edited) 3 hours ago, Patriot said: Hey Mike, Please feel free to delete my repeat post on Will’s vid. I missed that link where CRM had posted it already. 😊 David, it’s not a big deal, hard to tell that they were both the same video without clicking on both. I was just trying to save folks from an extra click. I’m sure there will be more videos as this issue develops. I’m just going to keep an eye on my 3 BB’s, which should be done anyway. They’ve been fine over many miles and 4 years. Mike Edited January 11 by Mike and Carol 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
CRM Posted January 11 Posted January 11 3 minutes ago, Mike and Carol said: David, it’s not a big deal, hard to tell that they were both the same video with clicking on both. I was just trying to save folks from an extra click. Mostly my fault since I don't know how to post a playable YouTube link. Easy to miss a text link. 2 3 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
John Dorrer Posted January 11 Author Posted January 11 38 minutes ago, CRM said: Mostly my fault since I don't know how to post a playable YouTube link. Easy to miss a text link. All things electric and all things internet are beyond me. I can update my signature map, and then after the next trip can't figure how to do it🙃 1 4 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Moderators Mike and Carol Posted January 11 Moderators Posted January 11 1 hour ago, John Dorrer said: All things electric and all things internet are beyond me. I can update my signature map, and then after the next trip can't figure how to do it🙃 It’s a good thing we have grandkids to help us through these technical challenges!! 3 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
