I'm looking at the EPOCH 300 AH lithium batteries. The Eco series (w/out electrical heating) are on sale for a cool $499. The Essentials with self heating cost $1199 (no sales right now). Buying the Eco-series would save quite a bit of money on an already quite expensive upgrade...But would I miss those Essentials?
Essentials
https://www.epochbatteries.com/products/12v-300ah-heated-bluetooth-lifepo4-battery-epoch-essentials
Eco Series
https://www.epochbatteries.com/products/12v-314ah-eco-series-lifepo4-battery
I spend the winters in the Southwest and spring./summer/ and fall in the mountains. At times temps drop into the 20's or very, very rately teens.  I never stay in a spot where the daytime temps don't reach into the upper 40's at least.
So do I really need to be able to charge when temps are below 32? And - if the Oliver is heated - as it would be - would it be able to keep the battery box warm enough in cooler temperatures. Perhaps not I didn't see vent holes...
Edited by Cort
2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
The Pro Series is a dual purpose Starter/Deep Cycle battery. Useful life of the battery might be short-term. Check warranty. Essentials have 4000 duty cycles.
Edited by jd1923
Whoops! Thanks for catching that - I meant Eco Series
I expect the challenge is ensuring your batteries and your charging system are turned off every time temps drop down to freezing.  The easier solution is what we have:  a switched external warming mat placed under the batteries and wired to our Oliver 12V system.
Ours was installed by Oliver with our 390 Ah Lithionics battery package.  One similar option now available is from Lion Energy:
https://shopsolarkits.com/products/lion-energy-battery-warmer?srsltid=AfmBOoo5_6ceyboAQUUVw1CNe_jCPeADkLbtop6B-CC3Z-THhq2OC5zhaDI
FWIW, we have the self-heating Lithionics and they've been great. Don't have to worry about them much. Don't have to remember to turn a heating pad on. But we live, and mostly camp, in the Northeast.
Essentials
Eco Series
Batteries with internal heaters are a nice option to have. I like options. 😊 This week it’s going to be in the 20’s and 30’s here in beautiful Western NC.
XPLORs (2) Epoch 300AH batts will be just fine.
Edited by Patriot
Thanks for the warmer idea!
For sure if your Litho's are going to freeze, then Isolate them!
Our Litho's are in a semi-sealed box.  That box prevents wind chilling and provides some insulation from the outside situtation.  it also gets some heat tranfer from the cabin thru it's inside walls.  So when does the battery actually freeze?  It would be have to be really cold for a long duration.   If I were in your shoes, I would not get the heaters.  But I would give myself some "Options".  As I have stated many times, "I Like Having Options".  Some suggestions for your situtation:
Determine the brand/model Extreme Weather info:
  • What is their recommendation for long term storage of the battery in extremely cold conditions with no supervision by the owner.  This will give you a worst case process for that battery.   For the Battleborns:  Charge to 50 - 60% and isolate with master switch until thawed.  Then recharge at a reasonable rate to 100% SOC.  Remember that is for their battery only.  Other MFG's have their process.  This would be a consideration in which ones to buy.
In your situtation I would consider these (In priority order):
  • Park with the sun on your street side if expecting temps may be an issue.  When it warms up, open the battery box door.  Close it before it starts cooling down for the afternoon/night.
  • Insulate the door of the battery box.
  • Installed a master cut-off switch if you don't already have one.  Just in case your situtation gets really bad.
  • Create cabin air circulation into and out of the battery compartment.  A couple of vents (High and Low) and a small 12v fan exhausting the top vent, with a coin style switch to come on when the box is getting near freezing. This would afford significant protection.
For less than $200 you could do all four of the above.
But, if you really want to go overboard, you could get some bluetooth temperature sensors to monitor the box temperature.  Severall greats posts about this topic here in the forum.  Hopefully their authors will comment back with their link.
Good luck, and enjoy your Ollie!
Edited by Geronimo John
Typo
As always GJ - thanks for your sage advice. Leaning towards the self-heaters if just because its easier (lol)
Thanks for the flowers.
Self heaters for long term storage are good only if you have plug-in shore power.
They are great for boondocking short term in extreme conditions.  But are a bit expensive.
Enjoy your great trailer and BRAVO for being a four season camper!
Will Prowse (a lithium battery guru) has a YouTube video on just this subject. He basically says no, in most cases not needed.
2021 Legacy Elite I , Hull #765
2021 Chevrolet Silverado 3.0 Diesel
Navarre, Fl
Thanks! It got down to 12 degrees when I got stuck in Mammoth. Luckily the lead acid batteries hung in there. I guess I have some extra insurance, now.
He's probably correct....:)
He’s just a young man, not the battery-god! 🤣
I think making a LiFePO4 investment is important and without internal heaters you’ll be doing work-arounds for as long as you use them, disconnecting them, heat blankets or something. Do it once, do it right!
We live in a moderate climate, but over the last few nights with lows to 20F, at 8AM the Ruuvi in our basement at the rear wall measured 27F and the Epoch BMS kept all out battery cells right at 36F. I prefer knowing we can travel any day, at any temp, and use and charge our batteries! 😎
$500 vs. $1200 per 300 Ah is a huge difference though. When we bought our “Essentials” I don’t believe there was an Eco Series available. We purchased Essentails since they were lower cost vs. the Elite Series.
👏👏👏👏 Well Stated
Sorry if this is a stupid question.
Situation:  You live in Cooler/colder climates  below 30 degrees and go camping every 1-2 months.  When in storage you have the Oli plugged in to shore power.
When in storage for 1-2 months at a time, how do you keep the 12V supply working to keep the intern/external battery heater and lights in camper running  if you disconnect the power to the batteries?   If  you have the batteries connect to keep the heaters working, how do you keep the SOC at 50%-60%.
Thanks
Good questions.  Answer?  You don't.  If below-freezing temps are possible when in storage, you must have power connected to ensure the 12V battery heaters can protect the batteries.  And, when power is connected, you don't need to keep SOC at 50-60%, just when no power is connected.  Dropping SOC to 50-60% applies when storing the batteries for long periods in a temperature-controlled environment, like when the batteries are removed from the trailer and stored inside a home.
Edited by Rivernerd
I thought that if you kept the batteries SOC at 100% over long periods even in warmer weather that it shortens its life of the batteries.   I don't own Lithium's yet, but there will be a time to Upgrade from AGMs.  Just wanting to understand all of the perimeters for the care and feeding.
Thanks for your input.
Although there are varied recommendations among LFP makers, in general it is not good to maintain 100% SOC for extended periods of time in storage; extended meaning three months + with no demand. In this instance, isolating the batteries and storing at 50% SOC seems an acceptable practice. Personally, I continually maintain 100% SOC year-round given the fact that I routinely go to the Cow Barn to check on things and make it a practice to exercise the LFPs. During summer visits the air conditioner is ran off the batteries and likewise that unit’s heat pump during cooler weather; cycling the battery bank in this manner is good ‘care and feeding’! I’m fortunate to have enclosed storage with electricity, which is adventitious in this battery management scheme. That said, my COW is turned out often and thus, rarely sees ‘extended’ periods of nonuse; always ready to search greener pastures!
Edited by Ronbrink
@RonbrinkI have a 3 sided RV port with 120 electricity.  To rephase what you said, If I had LFP with some type of internal/external heater for the winter, I could go out monthly and unhook the shore power and then run a high electric load for a while and  that will cycle the batteries enough to keep them in good shape.  At what SOC do you drain the batteries to before reconnecting the shore power?
@2008RNApprox 50% if storing for the winter months.
Edited by dewdev
Good questions.
We have the Lithium Pro package installed by Oliver in 2022.  It includes three 130Ah Lithionics batteries.  This 390 Ah battery bank is protected from freezing by an external, switched, battery warming mat, installed by Oliver as part of the package.
When storing our Hull #1291 during the cold Idaho mountain winters, I follow Lithionics Storage Procedure Rev. 7.1, a copy of which is attached.  As I read it, that procedure recommends:  (1) leaving shore power connected, with the warmer switch on, to keep the battery warmer operating, but (2) doing a drawdown/recharge cycle every 6 months when in storage.  I am now in the middle of the fourth winter following this protocol.
If I didn't have shore power in the detached garage where I store our Elite II, I would remove the batteries in the fall, reduce State of Charge (SOC) to 50% and store them in my temperature-controlled attached garage, per the attached protocol.  Leaving the trailer connected to shore power, but with periodic discharge/recharge, is easier, so that is what I do.
As Lithium Iron Phosphate (LiFePO4) batteries usually have at least a 10-year life when properly used and maintained, I may not know how effective my winter storage battery practices have been for another 6 years.  But, so far, so good.
As a footnote, if we had chosen AGM batteries when ordering our Elite II, now is when those lead acid-based AGMs could be nearing the end of their useful life.  Years of working with Sealed Lead Acid (SLA) AGM batteries to power my CPAP machine on wilderness river trips persuaded me to pay the substantial premium for the Lithionics LiFPo4 battery package.  No regrets.
Lithionics Storage Procedure Rev.7-1.pdf
Edited by Rivernerd
Yes, that would be golden IMO; just be sure to confirm the heater is working in winter conditions (LFP truly above freezing temp). I like to discharge the battery bank to 50% SOC if time allows, otherwise at least slightly below 75% SOC. Reason being that I have two chargers, the Xantrex 2000W inverter/charger and a dedicated Victron Blue Smart charger; 80A and 30A charge rates, respectively; 110A combined charge output. The Victron charger is triggered by a Victron Cerbo set to activate it when 75% SOC occurs. Incidental discharges above the 75% SOC threshold are serviced solely by the Xantrex charging component to maintain 100% SOC.
Wow, thanks guys for all of the input.  I really appreciate it.   Those were questions that kept bugging me about Lithium batteries..  I feel much more comfortable when the time comes to upgrade,
