Moderators Mike and Carol Posted January 18 Moderators Posted January 18 This is an issue I have not seen before. While checking my trailer this morning I noticed that my battery box is separating from the hull. I don’t know when this started. When we replaced my AGM batteries in Dec ‘20 I did not notice this. Once the four AGM’s were out I did a lot of cleaning and work on the tray and I feel that I would have noticed it then if it was happening. I will submit a trouble ticket with Oliver to see what they think. Not sure how this would be repaired. If you have an older trailer that carried those heavy AGM batteries I would check for cracks or separation. Here are some pictures, what does everyone think? Here is the right side: Here are a couple of the top: Left side top: 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators topgun2 Posted January 18 Moderators Posted January 18 A thread on "cracks" at and/or near the battery box was posted a number of years ago. But, as I recall, these cracks were generally in the exterior hull right at the corners of the battery box. Have you looked at the "support post" that is between the hulls directly under the battery box (approximately in the bottom center of the box)? Bill 1 5 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted January 18 Author Moderators Posted January 18 9 minutes ago, topgun2 said: A thread on "cracks" at and/or near the battery box was posted a number of years ago. But, as I recall, these cracks were generally in the exterior hull right at the corners of the battery box. Have you looked at the "support post" that is between the hulls directly under the battery box (approximately in the bottom center of the box)? Bill No, I didn’t have time this morning. It’s in storage and I had turned on the furnace yesterday because mid-20’s was forecasted last night (first freeze this year). I’m going to bring it home sometime this week and get a closer look. Mike 1 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators Mike and Carol Posted January 18 Author Moderators Posted January 18 Just found this thread, similar issue. https://olivertraveltrailers.com/forums/topic/7089-battery-box-repair/#comment-109444 1 1 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators topgun2 Posted January 18 Moderators Posted January 18 Wow - good research! I forgot about that thread - it appears to be exactly the same problem. Maybe Galway Girl would be willing to do the repair for you?😉 Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Galway Girl Posted January 18 Posted January 18 Mike, Please turn a ticket in to Oliver Support as category of structural failure/battery box. My repair has held since 2022 when I turned in the ticket. I followed specific Oliver instructions on my repair as I was too far from the Factory for a repair. I've also had Oliver inspect each time I go back for service...and so far it's held in place. Craig 5 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Moderators Mike and Carol Posted January 18 Author Moderators Posted January 18 25 minutes ago, Galway Girl said: Mike, Please turn a ticket in to Oliver Support as category of structural failure/battery box. My repair has held since 2022 when I turned in the ticket. I followed specific Oliver instructions on my repair as I was too far from the Factory for a repair. I've also had Oliver inspect each time I go back for service...and so far it's held in place. Craig Craig, yes I turned in a ticket this morning. Reading through what you did I might be marginally able repair it. I’ll see what Oliver service says when they come in to work. I would like to talk with you when you have time. I saw your PM. Thanks. Mike 5 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Geronimo John Posted January 19 Posted January 19 8 hours ago, Mike and Carol said: I don’t know when this started. Crazy Horse asked if by chance you have Alcon's? I told him to mind his own business. GJ 3 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jd1923 Posted January 19 Posted January 19 (edited) 3 hours ago, Geronimo John said: Crazy Horse asked if by chance you have Alcon's? I told him to mind his own business. GJ "Alcan" Springs, somehow when reading this earlier today, I kind-a though this might come up... And, I remembered that Craig @Galway Girl wrote about this same issue and making the repair. From his post above, "My repair has held since 2022" (TG) which is two years prior to when our friend Lance installed Alcan Springs on his Oliver, the first. Keep an eye on your battery door and I will do the same. The question is, what causes the failure? Is the battery base secure? Edited January 19 by jd1923 1 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted January 19 Author Moderators Posted January 19 10 hours ago, Geronimo John said: Crazy Horse asked if by chance you have Alcon's? I told him to mind his own business. GJ Yes, I do have a recent install of ALCAN springs. Looking at the separation it appears to me that this is not new. I have also learned of other instances of this (Galway Girl being one of them) that predate any ALCAN spring installations. You gave good advice to Crazy Horse 🤪. 3 1 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Hokieman Posted January 19 Posted January 19 (edited) 22 hours ago, topgun2 said: Have you looked at the "support post" that is between the hulls directly under the battery box (approximately in the bottom center of the box)? This reminded me of an older thread (see link) that addressed battery box support bracket and bolts. Recommended reading for those that have not already addressed, it might help avoid a loose battery box. In my case, both nuts & bolts of the support were very loose when I checked them, and the holes were drilled poorly by the factory. I drilled a new “clean” hole and installed 3 stainless bolts, washers and nylon nuts. A quick and easy task. https://olivertraveltrailers.com/forums/topic/6112-battery-box-support-bolts-missing I recommend caution when sliding out the battery tray, be gentle and avoid leaning on the tray. It puts an excessive force on the rivets and support bracket, especially if you have AGM batteries. Edited January 19 by Hokieman 3 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250. Former owner of 2019 Oliver Legacy Elite #431. Blairsville, GA
taylor.coyote Posted January 19 Posted January 19 We are repairing our battery box separation as we speak per the old string from Galway Girl. The combination 250lbs of AMG batteries, off the grid travel and aluminum rivets proves to have been a bad marriage. Now have 300AH lithiuim batteries weighing in at 80lbs and steel rivets. 3 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca
Moderators Mike and Carol Posted January 20 Author Moderators Posted January 20 6 hours ago, taylor.coyote said: We are repairing our battery box separation as we speak per the old string from Galway Girl. The combination 250lbs of AMG batteries, off the grid travel and aluminum rivets proves to have been a bad marriage. Now have 300AH lithiuim batteries weighing in at 80lbs and steel rivets. You used stainless steel rivets? Any adhesive? I need to gather the materials I’m going to need for this repair. Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Geronimo John Posted January 20 Posted January 20 9 hours ago, Hokieman said: I recommend caution when sliding out the battery tray, be gentle and avoid leaning on the tray. Reallly good idea! 6 hours ago, taylor.coyote said: The combination 250lbs of AMG batteries, off the grid travel and aluminum rivets proves to have been a bad marriage. Yep weight and G-forces will tend to find weak parts. At least your Litho weight is way under what the OEM's were. We now have seen frame fractures and battery boxes being damaged by trailers likelly exceeding their design limits in one way or another. Just a reminder that stiff Frames/Springs/Shocks and high tire pressures are things to avoid or at least mitigate where we can. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators Mike and Carol Posted January 20 Author Moderators Posted January 20 (edited) 12 hours ago, Geronimo John said: We now have seen frame fractures and battery boxes being damaged by trailers likelly exceeding their design limits in one way or another. Just a reminder that stiff Frames/Springs/Shocks and high tire pressures are things to avoid or at least mitigate where we can. We only recently upgraded our springs and we’ve been at 50psi in our tires for many years. I think the heavy AGMs and many miles is at the root of this issue. There are a number of rivets all around the box that were all popped/damaged/pulled out. It doesn’t seem that that could happen all at once, but probably happened over time and miles. Our lithium batteries, installed 4 years ago, are 1/3 to 1/4 the weight of the AGMs. The Oliver response to my trouble ticket was to check and send pictures of the brace inside the trailer. I did and the response was that I could probably use a good adhesive to repair it since the brace holding up the box looked good. I didn’t like that answer so I asked to be sent over to service for some advice. Mike S in service said they use rivets to repair and also inspect the support bracket. I’m debating whether to try this myself or just make a trip to TN. Unlike Galway Girl, my bracket only has one bolt and it is in an adjustable slot. Other side: It’s interesting that the box is leaning out from the trailer and the bolt is at the bottom of the slot. When I pull the battery tray out, the box moves out more but every so slightly, less than 1/16”. I would think that the sag would be the other way around, leaning into the trailer since the weight is over the support more than 99% of the time. Edited January 20 by Mike and Carol Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Geronimo John Posted January 20 Posted January 20 (edited) 6 hours ago, Mike and Carol said: It’s interesting that the box is leaning out from the trailer and the bolt is at the bottom of the slot. When I pull the battery tray out, the box moves out more but every so slightly, less than 1/16”. I would think that the sag would be the other way around, leaning into the trailer since the weight is over the support more than 99% of the time. I SUSPECT that the lean out is to facilitate water drainage should a seal fail. I support your thought that the advantagee of a slight lean in would out-weigh potential negatives of a seal failure. The amount of the lean out could for sure facilitate the failure of the rivets. The support member as you have: with just one bolt (as pictured) could easily allow the top of the "stiff leg" to move out there by increasing lean and failure. Suggest adding a second bolt above the shown one to better fix (Lock in) the angle of tilt once properly adjusted. GJ Edited January 20 by Geronimo John adderd "Lock In" 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
taylor.coyote Posted January 20 Posted January 20 GJ, thanks for the tips on suspension and tire pressure. I'm running Alcan springs and 50psi in the tires. Hopefully this combination with lightweight batteries and steel rivets will be a good solution after my repair 2 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca
jd1923 Posted January 20 Posted January 20 Sorry this happened to you Mike! Maybe you could source a local tech if you don’t want to get into this yourself. At least you’re home for a while. Wish I had looked further into this last month when I added a 3rd battery! I can be so dumb, took this pic at that time. The bolt and nut where fine but question is, did the mount sag, should the bolt be tightened higher up in the slot? The main bolt, coming down from the bay was tight which I removed and replaced with a 1/2” eye bolt to hold battery straps and cable lock. It felt firm as I yanked on the battery straps several times. All our rivets look good after we towed 3 hours down the mountain yesterday with the new setup, battery straps were still tight. Two years ago we had 4 LA batteries filling the 30 LB tray. We must be 100 LBS lighter now, no tray and 3 li batteries! Heading back home for the weekend and I’ll have to pull the streetside bed and see if that mount should be raised. Bummer is to do it right I should remove the batteries AGAIN, to get the weight off the shelf to be able to see any movement. I’ll add a second bolt too, seen in other installations. There should always be two bolts and OTT should learn to have a QC specialist check WIP after EVERY installation on the factory floor! 😎 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
