I'm interested in weather or not they kept the John Deer Truma water heater. Would be nice not to require a certified tech work work on the dang thing.  Tankless uses more water anyways... so I've heard via comparisons.
Edited by Wayfinder
Chris
2020 RAM 1500 Limited 5.7L
Augusta, Georgia
I read somewhere recently that they're not using *any* Truma products in the new models.
I always thought it was not a great sign when a vendor would spend an entire week at a rally having to fix their product.
Chris
Augusta, Georgia
But wait there is more….😊
https://www.facebook.com/reel/1641011913683764
I'd like to hear more about the integrated generator.
Me too...
I'm also interested in the price of that solar awning as well.
On 5/3/2026 at 8:41 AM, Steph and Dud B said:
From what I can see, it's a dolled up LE2 hull aiming to attract the overlander crowd. The 48V electrical system is interesting but would make finding accessories, etc. more difficult and more expensive. Will there be a DC to DC converter and 12V circuits for things like lights, USB ports, and 12V outlets?
Everything that runs on 12 volt still works just like it always did. To achieve this, the 48 volt system has been infused with magic, elves and possibly Elvis.
Edited by ScubaRx
  • Haha 5
That is correct...
The 960 watt Girard awning is $8224.15, but that is a 5% saving over its MRSP of $8657.00. I'd get two just to have enough.
  • Haha 4
Truma did not do any work. All the work was preformed by Oliver guys. And they were able to have one fixed and up and running in under 30 minutes.
There is no "integrated generator" as such that comes with the trailer. Jason is referring to an owner supplied generator that has been modified so as to be able to be integrated into the control system of their new EcoFlow control panel. Everything in the coach can be controlled from the touch screen as I understand it.
Edited by ScubaRx
And -
ALL of the expense in doing this work came out of the pocket of Oliver - not Truma.
  • Wow 2
Of course, one on each side so you can generate power from sunup to sundown.  Expensive power. I can't imagine that such a device will be trouble free over the years but maybe I am not up to date on the film technology.
I only deploy my regular Girard awning when I am at the trailer on calm days.  I certainly wouldn’t leave the awning deployed all day while the trailer is unattended, especially at the cost of the solar awning. I see this as the biggest limitation to the usefulness of the solar awning.
Robert and Cheryl, Louisville, KY, Legacy Elite II 2023 Hull #1390 Oliphino, TV F250 Tremor
I hope you all recognize this was tongue-in-cheek.
Yes, you'd have a DC-DC 48/12 converter!
Add one of these for every 30A required in 12VDC circuits! 😎
https://www.invertersupply.com/index.php?main_page=product_info&products_id=24883&msclkid=43c410b584c71378f430794e07bd6059&utm_source=bing&utm_medium=cpc&utm_campaign=invertersupply - shopping&utm_term=4584894771909782/
Edited by jd1923
53 minutes ago, jd1923 said:
The way I understood it, the inverter all the 12 volt stuff was built into the battery itself. Like a giant Jackery.
Start with three each for the jacks.  Or make every owner sign a waiver that they will not operate more than one jack at a time.... LOL
One for all the electronic outlets
No thank you. Never wanted a Jackery, like independent parts to replace if/when needed. They only running the A/C on 48V?
That's what fuses are for. 🤣 I power only one jack fuse at a time, a best practice.
Yep, but come to think of it... How nice it would be to have 2300A of solar available! Plus, you'd have have redundancy if (when?) one of them failed. Now we need a gray water storage carpet to put under the solar awning. And camp chairs that also hold fresh water. We could boondock forever!
  • Haha 3
Looks that way from what I can tell, and those 48V Houghton's on paper don't look very efficient either. I think the 120v inverter units that we each have would use less power even after the loss of running through an inverter.
I think it’s a myth. I had tankless on my first house - loved it. Instant hot water and as much as you want. Very popular in Japan, they don’t have the room for a big tank (neither did I). In my ‘26 it’s great. One time I got in the shower, all ready and realized I had forgotten to turn it on the night before. No problem, hit a switch and was in business. If that’s not convincing Truma has a Comfort mode that keeps the water sitting in the tank preheated.
I like the Truma combo control system for AC, heat and water. German engineering (yes I know about the recall, it happens) … I worked in Germany once upon a time on an engineering project. They’re very proud of their engineering culture (country wise). A crazy level of attention to detail. Not so great for software but physical engineering? Yeah … this was down by the Dark Forest, Stuttgart area. Lots of automotive and cuckoo clocks. I heard a cuckoo in the forest once, the Germans were mad because they never heard it 😅 (I digress)
Jackery is a relative newcomer I think. I bet they use cylindrical in those batteries, I’ll take the prismatic of Lithionics any day. Watch one of the factory tours.
Anyhow solar awnings sound great (but not at 8k! That is seriously expensive solar). Problem is getting to use them, OK haven’t had this too long but have been camping pretty continuously. Rarely had a chance to use them for any length of time. JMHO
Edited by DanielBoondock
Sierra EV AT4 2026 (max range 500 mile pack)
23 hours ago, ScubaRx said:
That is correct...
(Regarding no Truma anymore)
Yeah with Truma integration you either use it all or use nothing. What are they using for the PP model heat/water/AC? Yeah it’s not Truma, I don’t recognize it
They are using a Dometic FreshJet A/C.
OK from the image looks like the Freshjet 5 series. Headline features is low profile, it's a direct "Penguin II" replacement, but advertised as 'up to 9 dB quieter'.
For ceiling register there's two options, from the interior image looks like maybe this one with the front vents, just a basic mechanical
I'd get excited if somebody came out with something truly quiet, like what you get with a ducted mini-split. I don't understand why they keep making hard start AC's, put an inverter on there (PWM type control) with a truly variable fan speed.
