For those times when I leave the trailer but want to keep some ventilation flowing.
I thought about a piece of round steel bar lying in the window track, but the end of the slot curves up and I think a hard push on the window would launch it clean out of there. Any ideas? I prefer No Drill, but that would be an option. I think most residential add-on window locks are a joke, but maybe there is one I haven!t seen that would work here....
Thanks,
I think the existing window stop would prevent anything you put in the track from reaching the curved corner.
True, but it is not a very strong anchor point. It is intended to stop a slow lightweight window under normal operation, not one that is being forced open hard by an intruder. It might work, but I would worry about it.... maybe you could beef it up by screwing a section of aluminum bar into the track behind the stop, with two or three extra screws.
Go longer, measure the rod from bottom corner of window to top corner, so it sits at an angle, this way it only slides down when the window is closed. The rod doesn't need to be so large it won't fit within the track to be effective.
Randy
One Life Live It Enjoyably
2017 F350 6.7L SRW CC LB
2015 Oliver Elite II Hull #69
If I want more ventilation,  I prop the bathroom door open, open the bath window and vent, and open the main cabin vent. Leave the fantastic fan on low and auto...
This actually  draws a lot of air through our little trailer. Pretty tiny thief to fit thru the bath window... lol.
But, you've probably already done that...
Clamp a Vise-Grip on the middle rib of that aluminum extrusion where you want the window to stop. Use needle nose Vise-Grips and slip a short piece of rubber tubing on each jaw.
Bill and Martha
2019 Chevrolet 2500HD Duramax
Or you could just not worry about it.  If someone wants into your trailer bad enough their gonna get in and tear up a lot of stuff in doing so.  If you ever lock yourself out, you'll wish you'd left a window unlocked.  We generally leave the windows unlocked and open.  Sometimes the door also.  Of course, Reacher might be in there.  For those of you who've met him, you know what I mean.
  • Thanks 4
Or you could just not worry about it. If someone wants into your trailer bad enough their gonna get in and tear up a lot of stuff in doing so. If you ever lock yourself out, you’ll wish you’d left a window unlocked. We generally leave the windows unlocked and open. Sometimes the door also. Of course, Reacher might be in there. For those of you who’ve met him, you know what I mean.
Will your insurance cover property losses from theft if you intentionally leave your stuff unsecured? I bet there would be big problems with the claim. What about firearms? And personal valuables, credit cards and IDs? Leaving unrestricted access into the cabin is just not on the table. Regardless of any killer Australian Killadoodles that might be inside.
If you are worried about getting locked out, hide a spare under the frame. Or just carry a second one at all times, as I do.
If your post was a joke, I did not get it....
I've met him (Mr. Reacher) and would keep me out, as would my Chessie.   I also  lean towards less worry about theft and such, not because the threat isn't there, but prevention is too often just a smoke screen. Breaking into an Ollie is a simple task, (not unlike most RV's), therefore I prefer to leave little of any worth inside. Few thieves are going to take "normal" RV camping stuff. I don't leave valuables, wallets, and such in the RV, put $$ electronics in the truck, and don't worry about it.  Out of site - out of mind, don't flaunt it.
I tend to rely more on observation and common sense, sometimes just paying attention reaps big rewards. I must admit, I carry a firearm much more than I once did, not around camp, or hiking (non bear area), but I have one handy - if it became necessary.  Yes, I'm probably too trusting,  - 30 years of camping from here to there and back, not really had an issue.
If your post was a joke, I did not get it….
After reading this I was trying to think of what of value we kept in the trailer while gone. I suppose someone could disconnect the TV and my old Apple TV. We have a coffee maker and a toaster. Clothes and bedding. A cheap guitar. We always lock the door but routinely leave a window cracked or open. I carry a couple of credit cards and drivers license and military ID but never leave them in the trailer when gone. If someone wants my television I would rather they gently slide the window open, climb in and take it out the door rather than break a window or jimmy the door. We leave chairs, small camp table, Weber gas grill all out when we go hiking or run to the store. I guess we are either naive or too trusting. Mike
I've met Reacher and am indeed glad he did not reach me.
Of course, we have our own canine security.
Onward through the Fog!
EarthPicks of Cochise County
Since we we are taking about window security , my issues are the opposite.  I need to keep the girls inside, even if they spot a bird or a squirrel.  They are Setters and always on the hunt.
2013 Toyota Land Cruiser 200
2018 Twin Bed Elite II #351
I ended up with 16 inch sections of a gray 48 inch fiberglass driveway marker pole. Three windows, three pieces from a single pole. It’s fiberglass and 3/8 “ diameter and after filing the cut ends it looks nice enough. The stop does actually keep the rod in place pretty well. I got the pole at a local ranch supply for about $2. I use them along my walk and drive in winter.
