John E Davies Posted January 16, 2021 Share Posted January 16, 2021 (edited) Please, I need some education and suggestions. I already have a pole and mount, .... https://polesandholders.com/PNH-22-Deluxe-**NEW**-and-MOST-Popular-Flag-Pole-p206298627 .... and am hoping to find a lightweight OMNIdirectional antenna that I can plug directly into the Jetpack via a bulkhead through-fitting in the back of the hull and then through a short extension, to the rear center table. Something like this... Wilson Electronics 4G Omni Plus Building Antenna 700-2700 MHz, 75 Ohm (304423) I need to know if that would be suitable, if I can extend the cable, and how far, and what kind of through hull fitting to use. I am next to clueless about this. “Mouse” has the factory installed WeBoost amplifier, it works but pretty marginally.... Here is my pole and mount. ... https://olivertraveltrailers.com/forums/topic/3371-flag-pole-and-mount/ I could mount the antenna at the top and still fly wind art below it. Would the pole’s flexing be a problem for the cellular signal stability? I could keep it only half way extended if needed when it is really breezy. Thanks for any suggestions and guidance. John Davies Spokane WA Edited January 16, 2021 by John E Davies SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Overland Posted January 16, 2021 Share Posted January 16, 2021 (edited) That’s the one I was looking at when I was thinking about doing the same. Or the squarish version of it I think. I believe we had a thread about this a few years ago discussing options for both antennas and masts 🤔. I ran into a campground host at Glacier who had an antenna setup, and said that it did the job. Edited January 16, 2021 by Overland 1 Link to comment Share on other sites More sharing options...
AndrewK Posted January 16, 2021 Share Posted January 16, 2021 John, here is link to the Internet Resource Center's YouTube video, on a simple antenna you can just put in your window. If I needed an MIMO antenna, I would try this first. Netgear MIMO 6000450 Antenna for JetPacks & MiFis - Affordable Cellular Signal Enhancing - YouTube Keeping is simple! Andrew 2 Andrew 2019 Legacy Elite II 2018 BMW x5 35d Link to comment Share on other sites More sharing options...
Frank C Posted January 16, 2021 Share Posted January 16, 2021 (edited) I’m considering the same setup for an external cellular antenna on a mast. Found this one on Amazon that has a U-clamp setup to attach to a round pole. I haven’t figured out the thru-hull connection yet though. It comes with a 5 meter long cable so that should be plenty long enough. High Gain 10-12dBi External SMA Male/Dual TS9 3G 4G LTE Bracket Mount Signal Booster Antenna for Netgear Nighthawk M1 MR1100 Verizon Jetpack 8800L Mobile Hotpots Router MiFi Mobile Hotspot Router https://www.amazon.com/dp/B088FBV6HF/ref=cm_sw_r_cp_api_glc_fabc_2z3aGb6DGB749?_encoding=UTF8&psc=1 Edited January 17, 2021 by FrankC Link to comment Share on other sites More sharing options...
BackofBeyond Posted January 16, 2021 Share Posted January 16, 2021 1 hour ago, John E Davies said: Please, I need some education and suggestions. I already have a pole and mount, .... https://polesandholders.com/PNH-22-Deluxe-**NEW**-and-MOST-Popular-Flag-Pole-p206298627 .... and am hoping to find a lightweight OMNIdirectional antenna that I can plug directly into the Jetpack via a bulkhead through-fitting in the back of the hull and then through a short extension, to the rear center table. Something like this... Wilson Electronics 4G Omni Plus Building Antenna 700-2700 MHz, 75 Ohm (304423) I need to know if that would be suitable, if I can extend the cable, and how far, and what kind of through hull fitting to use. I am next to clueless about this. “Mouse” has the factory installed WeBoost amplifier, it works but pretty marginally.... Here is my pole and mount. ... https://olivertraveltrailers.com/forums/topic/3371-flag-pole-and-mount/ I could mount the antenna at the top and still fly wind art below it. Would the pole’s flexing be a problem for the cellular signal stability? I could keep it only half way extended if needed when it is really breezy. Thanks for any suggestions and guidance. John Davies Spokane WA Really like the pic - for what the antenna costs - try it out - not satisfied - send it back. RB Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible" Link to comment Share on other sites More sharing options...
Jairon Posted January 17, 2021 Share Posted January 17, 2021 (edited) 52 minutes ago, AndrewK said: If I needed an MIMO antenna, I would try this first. I agree with Andrew. If you can't get a signal with the Netgear antenna, you'd probably need a directional antenna to pole mount. It gets clunky (wind, signal search, gain/loss, additional coax, etc) so I'd opt for the Netgear solution whenever possible. If you do opt for a directional, here is some info about the setup. Edited January 17, 2021 by Jairon 1 2019 Toyota Land Cruiser 2021 Oliver Elite II, Hull #748 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted January 17, 2021 Moderators Share Posted January 17, 2021 If you're not camping in an area with a lot of gnats or mosquitoes, you could just run the wire through the sliding screen and window to try it out. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Moderators mossemi Posted January 17, 2021 Moderators Share Posted January 17, 2021 (edited) On 1/16/2021 at 4:59 PM, John E Davies said: I could mount the antenna at the top and still fly wind art below it. Would the pole’s flexing be a problem for the cellular signal stability? I could keep it only half way extended if needed when it is really breezy. I would suggest that you never fly wind art or a flag of any kind while having an antenna deployed on your mast. The antenna itself will create enough deflection in the mast to affect the cellular performance. MiMo technology would certainly help, but why add to your problem with a moving antenna. And if you are in a cellular signal challenged area, you may not have the benefit of the latest cellular base station equipment suppling your signal. Mossey Edited January 18, 2021 by mossemi 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
JRK Posted January 18, 2021 Share Posted January 18, 2021 A moving mast will not work well with a directional antenna. Think of a flashlight - the radio signal is focused. The width of the radio beam depends upon the design of the antenna. An omnidirectional antenna is less problematic on a moving mast, and will probably work fine. The radio wave pattern is dependent upon the installation and antenna design, also. An omnidirectional antenna sends the signal out in a 360 degree pattern, or at least that's the theory, but again dependent upon installation factors. The radio signal won't be as "intense" as with a directional antenna, but with a directional antenna you need to know where the cell tower/weefee antenna is located. If you know that, then the window mount mimo directional antenna might be adequate. Still, it depends upon so much more, such as is the physical terrain open, trees, campsite in a valley, boondocking, in a park with a known internet connection and cell tower, etc. I play ham radio, at the frequency ranges of weefee and cell phone at times. I regularly put up 20' antenna masts for a few hours. I use both directional and omnidirectional antennas, depending upon what i want to do. Even directional antennas have a variety of radio wave pattern, which controls the effective gain of the antenna. 1 1 2014 Toyota Tacoma 4x4 2021 Elite I #758 Link to comment Share on other sites More sharing options...
Galway Girl Posted January 18, 2021 Share Posted January 18, 2021 I think this thread from the Mobile Internet resource center may lead you to some ideas: 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Link to comment Share on other sites More sharing options...
