Brian and Maria Posted May 27, 2021 Posted May 27, 2021 On our most recent outing one of our battery tray latches failed. The pin on the left/fore side of the battery tray was totally missing as was the rivet/pin on which the rear of the latch pawl pivots. Fortunately I found the latch pawl itself loose in the battery compartment. Our temporary fix to get us home included tie wraps and, of course, duct tape to secure the latch pawl in place. The right (aft) side battery tray latch was not affected. Until such time we can arrange a permanent repair, I'm confident that our semi-permanent solution pictured below will serve to keep the tray secure. It consists of a stainless steel anchor shackle holding the latch pawl in place so that it cannot be raised whatsoever, thereby preventing the battery tray from sliding out. I found that the 3/16" shackle fits perfectly, with the anchor shackle pin fitting snugly in the holes. For reference the particular shackle I used is made by National Hardware, #N100-347 and available at Lowe's. Hopefully this information is helpful to those who may experience the same failure. Be safe everyone. - Brian 1 2 Brian and Maria | and furbabies Lucas and Joie | Western NC 2020 Elite I | Hull 583 | February 6 Delivery 2018 F150 XLT 4x4 Supercrew | 3.5L V6 EB | Max Trailer Tow | Undercover Elite Tonneau
Moderators topgun2 Posted May 27, 2021 Moderators Posted May 27, 2021 Back in the day when these trays only came with one latch, there was discussion about what was to be done in the event that single latch failed. This led to simply drilling a hole in about the same place as your shackle is pictured and placing a stainless bolt through that hole. It works! Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted June 1, 2021 Posted June 1, 2021 Here is a pic of our battery tray in our 2020 LEll. No issues to date. It appears quite robust and solid. 1 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Brian and Maria Posted June 16, 2021 Author Posted June 16, 2021 On 5/27/2021 at 3:34 PM, Brian and Maria said: I found that the 3/16" shackle fits perfectly, with the anchor shackle pin fitting snugly in the holes. For reference the particular shackle I used is made by National Hardware, #N100-347 and available at Lowe's. Corrections: The shackle size that I used as pictured in my original post is 1/4" made by National Hardware #N100-278. I apologize for any confusion. - Brian 1 Brian and Maria | and furbabies Lucas and Joie | Western NC 2020 Elite I | Hull 583 | February 6 Delivery 2018 F150 XLT 4x4 Supercrew | 3.5L V6 EB | Max Trailer Tow | Undercover Elite Tonneau
Geronimo John Posted September 20, 2021 Posted September 20, 2021 I searched the University and Forum and did not find an answer. So am asking here as at least this topic in sort of on topic to this thread.... sort of. 🙂 What is size the inside dimensions of our OE2 battery tray, and what is the vertical clearance from tray to ceiling of the storage bay? I am laying out possible solar batteries and associated equipment and want to make sure they will fit. I thank you, Geronimo John MODERATORS: If there is a better place to post this, I would appreciate your moving this post as appropriate. Thanks. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted September 20, 2021 Posted September 20, 2021 On 6/1/2021 at 7:53 AM, Patriot said: Here is a pic of our battery tray in our 2020 LEll. No issues to date. It appears quite robust and solid. @ Patriot: If you don't mind, some questions from a soon to be Lithium owner: What batteries do you have? What are their dimensions and overhead clearance? Thank you Geronimo John TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderator+ ScubaRx Posted September 20, 2021 Moderator+ Posted September 20, 2021 1 hour ago, Geronimo John said: I searched the University and Forum and did not find an answer. So am asking here as at least this topic in sort of on topic to this thread.... sort of. 🙂 What is size the inside dimensions of our OE2 battery tray, and what is the vertical clearance from tray to ceiling of the storage bay? I am laying out possible solar batteries and associated equipment and want to make sure they will fit. I thank you, Geronimo John MODERATORS: If there is a better place to post this, I would appreciate your moving this post as appropriate. Thanks. You can easily fit three Battle Born's in the tray. There are a few owners out here that have done just that. Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Geronimo John Posted September 20, 2021 Posted September 20, 2021 @ ScubaRX: Is that three 270 Ah Battleborns? Or three smaller ones? Thanks JPR TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators topgun2 Posted September 20, 2021 Moderators Posted September 20, 2021 GJ - You might want to PM Patriot in that he jus might miss your request for info on his batteries. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted September 20, 2021 Moderators Posted September 20, 2021 11 hours ago, Geronimo John said: @ ScubaRX: Is that three 270 Ah Battleborns? Or three smaller ones? Thanks JPR I’m sure Steve has three 100aH batteries based on what he told me before I did my installation. I installed two Battle Born 100aH batteries and there is room for one more. I don’t think three of the larger batteries would fit. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Overland Posted September 20, 2021 Posted September 20, 2021 The tray that Oliver uses is the MorRyde SP60-042 Utility Tray, inside dimensions 14" x 21" x 2.75". There's 12.75" clear from the floor of the tray to the bottom of the aluminum catch for the lock. The Battleborn 270Ah batteries are 21.3" x 11.6" x 10", so I don't see how you'd fit even one without removing the tray. Three of their standard 100Ah batteries will fit easily, and four will fit tightly; i.e., it will take some work to wire them up. 1 2
Overland Posted September 20, 2021 Posted September 20, 2021 BTW, I see that Battleborn have their standard 100Ah battery on sale for $799 right now, which is the best price I've seen since I bought mine in '17. 2 1
Geronimo John Posted September 21, 2021 Posted September 21, 2021 10 hours ago, Overland said: The tray that Oliver uses is the MorRyde SP60-042 Utility Tray, inside dimensions 14" x 21" x 2.75". There's 12.75" clear from the floor of the tray to the bottom of the aluminum catch for the lock. The Battleborn 270Ah batteries are 21.3" x 11.6" x 10", so I don't see how you'd fit even one without removing the tray. Three of their standard 100Ah batteries will fit easily, and four will fit tightly; i.e., it will take some work to wire them up. Thank you SOOOOOO much for this data. Geronimo John Lives in Hi, Ollie in OK. Somewhat of a PITA for project planning. But it is what it is. 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rideandfly Posted September 21, 2021 Posted September 21, 2021 On 9/19/2021 at 7:57 PM, Geronimo John said: What is size the inside dimensions of our OE2 battery tray, and what is the vertical clearance from tray to ceiling of the storage bay? John, Replaced Ollie's battery tray with Oliver's latest tray about 6 months ago, took a few measurements of the old (2015) and new tray. New tray on right: Old 2015 tray: I only use one Battle Born 100AH lithium battery with a 100W solar suitcase with plenty of room for other stuff in the tray: 3 Bill 2015 LE2 #75 2024 F350 6.8L
Geronimo John Posted September 21, 2021 Posted September 21, 2021 On 5/27/2021 at 9:47 AM, topgun2 said: Back in the day when these trays only came with one latch, there was discussion about what was to be done in the event that single latch failed. This led to simply drilling a hole in about the same place as your shackle is pictured and placing a stainless bolt through that hole. It works! Bill @ Bill: LoL "Back in the Day". Those single latch trays were used on my 2018 Ollie. Hopefully that ancient time, just 3 years ago, does not qualify for us to be "Ole Timers"!!!! On a previous post you are correct about "bolting" the single latch and using a nut and bolt. This topic was addressed a couple of years ago, way back in 2019 I think, and I commented that instead of using a nut, to use a RivNut so that we are not having to fish the nut after we drop it. For those not acoustomed to RivNuts (AKA: Rivet Nuts, Blind Flange Nuts, etc.), below is a sample. If you are not familiar as to how they are installed, send me a PM. Mahalo! 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators SeaDawg Posted September 22, 2021 Moderators Posted September 22, 2021 6 hours ago, Geronimo John said: Hopefully that ancient time, just 3 years ago, does not qualify for us to be "Ole Timers"!! Some of us (sensitive to "age") prefer the term "experienced." I can live with "seasoned," as well. 🤣🤣🤣 Btw, which size rivnuts did you use in your installation? Did you use backer material, or, just the fiberglass sidewall? I ask, because I'm really only familiar with these in furniture/wood. Thank you. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators mossemi Posted September 22, 2021 Moderators Posted September 22, 2021 (edited) If I remember the original post correctly and that’s a 50/50 proposition, the RivNut was installed in the sidewall of the tray mount and a bolt threaded into the RivNut acted as a tray stop to prevent it from sliding. Mossey Edited September 22, 2021 by mossemi Clarification 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderators topgun2 Posted September 22, 2021 Moderators Posted September 22, 2021 9 hours ago, mossemi said: and that’s a 50/50 proposition, Always the optimist - 😂 aren't we? 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
