I posted this back in 2018 but was reminded of this again this morning. While disconnecting my hose I noticed my city water female hose connection fitting was loose.  The picture below shows the fitting after I removed the strainer/ washer.
You need to carry a 1/2 inch hex key (Allen wrench) or you’ll have to use a bolt with a head that fits a 1/2 inch wrench. Just snug this fitting up after removing the strainer/washer.
Be sure to replace the strainer/washer after tightening the fitting.
Here is the post that I made about this back in 2018. Just disregard the threadjacking in the middle of the original thread.
  • Thanks 7
Bill and Martha
2019 Chevrolet 2500HD Duramax
Adding a link to the article with the SPEC's of those water fittings...Craig
I figured out one of mine was loose because it was spraying water when I hooked the hose to it…  didn’t have a 1/2” Allen wrench at the time, but I do now..
any project requiring a new tool is a good one as far as I’m concerned. 🙂
  • Haha 2
  • 2 years later...
My City Water connection started leaking A LOT and my neighbor took a look and said I was missing the check valve -- but after reading the forum posts related to this subject, I learned that my check valve is moved inboard, and I was able to fix my City Water connection with borrowed hex key and plumber's tape.
Now to buy my own hex key. Also -- I don't have fingernails long enough to grab that outer red rubber strainer, so I used a sewing needle to gently pull it out. I plan to buy spare strainers and O-rings that go on the other side, especially since there are 3 of these connections (City Water, Fresh Water and the Boon Docking inlet) -- can anyone tell me what size the O-ring is? I'm not sure how it's measured.
Thanks for all the help, Forum family!
my Oliver has camped here
Actually 4 including the black tank flush
**Sold😞**
@Boudicca908
I purchased these Ely quick connects and really like them. https://www.eleyhosereels.com/search?q=Quick+connects
They make connecting to water inlets sooooo much easier and quicker and are solid brass.
Patriot🇺🇸
Thanks for the reminder! I have at least one quick connect and a friend took it off, thinking he was going to solve my leak problem. I'll reinstall it now.
I like the spring guard. Let us know how it works out for you.
I also see that you have plugs in the openings. 👍👍👍 good plan.
Where do you keep the plugs when connected to city water or filling tank?
It is, indeed. A family.
They're flexible too, so if you hit something, np. I've used these before, had them on a class-c, decent quality and inexpensive, not much to go wrong.
Good eye! I was going to remount those funny little chains, but didn't want to take the time, at the time. I removed the bottom screw to remove them and replaced the screw in the hose bib. Last time I just placed the cap inside the rear storage bin where we keep the hoses. Thanks for asking!
Every time I buy a (blue) Camco in-line hose water filter, I save the old short white spring hose.  And each year, I put one on the Ollie.
The rear port is fairly accessible/exposed and this hose “attached” may not be best between (in-route) uses.
I like the white hoses, as it provides a bit of a shock absorber to the connection on the OTT side, if someone who is 75 y-o and pretty much all legs, catches a foot on one of those hoses.
Just get a beaded chain extension and attach to the existing black screw plugs already there and put them in the end of the white hoses while underway.
B~Out
My Visited North America Map
15 hours ago, jd1923 said:
I went with 6" extensions, since I really dislike craning my neck to reach under!
Great mod, thanks for sharing!
  • (SOLD) 2022 TUNDRA
