Townesw Posted July 10, 2021 Posted July 10, 2021 I posted this back in 2018 but was reminded of this again this morning. While disconnecting my hose I noticed my city water female hose connection fitting was loose. The picture below shows the fitting after I removed the strainer/ washer. You need to carry a 1/2 inch hex key (Allen wrench) or you’ll have to use a bolt with a head that fits a 1/2 inch wrench. Just snug this fitting up after removing the strainer/washer. Be sure to replace the strainer/washer after tightening the fitting. Here is the post that I made about this back in 2018. Just disregard the threadjacking in the middle of the original thread. 6 2 1 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
Galway Girl Posted July 10, 2021 Posted July 10, 2021 Adding a link to the article with the SPEC's of those water fittings...Craig 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Mcb Posted July 10, 2021 Posted July 10, 2021 I figured out one of mine was loose because it was spraying water when I hooked the hose to it… didn’t have a 1/2” Allen wrench at the time, but I do now.. any project requiring a new tool is a good one as far as I’m concerned. 🙂 1 2 Mark & Deb..2020 Elite II..Dearie..Hull #685..2016 Tundra
Boudicca908 Posted July 31, 2023 Posted July 31, 2023 On 7/10/2021 at 11:46 AM, Townesw said: You need to carry a 1/2 inch hex key (Allen wrench) or you’ll have to use a bolt with a head that fits a 1/2 inch wrench. Just snug this fitting up after removing the strainer/washer. My City Water connection started leaking A LOT and my neighbor took a look and said I was missing the check valve -- but after reading the forum posts related to this subject, I learned that my check valve is moved inboard, and I was able to fix my City Water connection with borrowed hex key and plumber's tape. Now to buy my own hex key. Also -- I don't have fingernails long enough to grab that outer red rubber strainer, so I used a sewing needle to gently pull it out. I plan to buy spare strainers and O-rings that go on the other side, especially since there are 3 of these connections (City Water, Fresh Water and the Boon Docking inlet) -- can anyone tell me what size the O-ring is? I'm not sure how it's measured. Thanks for all the help, Forum family! 2 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
rich.dev Posted July 31, 2023 Posted July 31, 2023 55 minutes ago, Boudicca908 said: there are 3 of these connections Actually 4 including the black tank flush 3 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Patriot Posted July 31, 2023 Posted July 31, 2023 @Boudicca908 I purchased these Ely quick connects and really like them. https://www.eleyhosereels.com/search?q=Quick+connects They make connecting to water inlets sooooo much easier and quicker and are solid brass. Patriot🇺🇸 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Boudicca908 Posted July 31, 2023 Posted July 31, 2023 3 minutes ago, Patriot said: I purchased these Ely quick connects Thanks for the reminder! I have at least one quick connect and a friend took it off, thinking he was going to solve my leak problem. I'll reinstall it now. 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
jd1923 Posted August 1, 2023 Posted August 1, 2023 I went with 6" extensions, since I really dislike craning my neck to reach under! They connect easy, hand-tight without leaking. The 4-pack is perfect for an Oliver. Amazon.com: Hourleey Garden Hose Protector, Hose Extension Adapter with Coil Spring (4 PCS) : Patio, Lawn & Garden 3 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators SeaDawg Posted August 1, 2023 Moderators Posted August 1, 2023 I like the spring guard. Let us know how it works out for you. I also see that you have plugs in the openings. 👍👍👍 good plan. Where do you keep the plugs when connected to city water or filling tank? 3 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators SeaDawg Posted August 1, 2023 Moderators Posted August 1, 2023 3 hours ago, Boudicca908 said: Thanks for all the help, Forum family! It is, indeed. A family. 1 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
jd1923 Posted August 1, 2023 Posted August 1, 2023 1 hour ago, SeaDawg said: I like the spring guard. Let us know how it works out for you. I also see that you have plugs in the openings. 👍👍👍 good plan. Where do you keep the plugs when connected to city water or filling tank? They're flexible too, so if you hit something, np. I've used these before, had them on a class-c, decent quality and inexpensive, not much to go wrong. Good eye! I was going to remount those funny little chains, but didn't want to take the time, at the time. I removed the bottom screw to remove them and replaced the screw in the hose bib. Last time I just placed the cap inside the rear storage bin where we keep the hoses. Thanks for asking! 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
SNY SD UP Posted August 1, 2023 Posted August 1, 2023 Every time I buy a (blue) Camco in-line hose water filter, I save the old short white spring hose. And each year, I put one on the Ollie. The rear port is fairly accessible/exposed and this hose “attached” may not be best between (in-route) uses. I like the white hoses, as it provides a bit of a shock absorber to the connection on the OTT side, if someone who is 75 y-o and pretty much all legs, catches a foot on one of those hoses. Just get a beaded chain extension and attach to the existing black screw plugs already there and put them in the end of the white hoses while underway. B~Out 5 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
MAX Burner Posted August 1, 2023 Posted August 1, 2023 15 hours ago, jd1923 said: I went with 6" extensions, since I really dislike craning my neck to reach under! Great mod, thanks for sharing! Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
