We are looking forward to our new arrival in February, and are starting to put together a list of things to take to delivery.  The Oliver FAQs say that they provide a potable water hose, waste hose, lug wrench, water pressure regulator, etc.  I think there are a lot more goodies in the "etc" that are provided by Oliver.  Is there a complete list somewhere of all the included items?  We wouldn't want to buy some gizmo and then find that it is already included with the trailer.
2024 F-250 King Ranch 6.7L Diesel | 2022 Oliver Elite II - Hull#1034 'Hullabaloo'
Most of the other truly necessary gizmos are available at Hohenwald walmart, or tractor supply.
What you want to buy ahead are locks, leveling system, and whatever you like to outfit the interior.
My Advice: Don't go crazy. A lot of stuff is available anywhere, and people buy a lot of unnecessary,  never used stuff, ahead of time.
Try out minimalist camping. Then add.
8 minutes ago, SeaDawg said:
...Try out minimalist camping...
What is this "minimalist camping" of which you speak?
  • Care 1
  • Haha 4
So I picked up in May.  Oliver provided sewer hose, drinking water hose, water pressure regulator, sewer elbow to connect to sewer at campsite,  lug wrench and power cord.   You need a torque wrench for tires and that is not provided.  I bought my own water regulator so I can see the pressure and use Oliver one as backup.   You will also want chocks and levelers.
I’d highly recommend a tire monitoring system.
2021 Legacy Elite II Hull #807 - 2021 F150 w/ 3.5L EB and max tow package
The best person to answer this question is your sales rep at Oliver (in the event that there have been any recent changes).
Yes, those of us who know you realize that's not part of the camping vocabulary for you...
We also know how much you've helped others with the parts and gear you carry.
Just want to confirm that we got the same stuff as TexasGuy so that you're hearing from another person that took delivery recently.  Also, please remember to consider adjusting your tire pressure before you leave Oliver.  It is set at 80lbs and the advice given on this site to reduce pressure to 60lbs is prudent in my opinion.  Consistent with my last sentence make sure you have a tire pressure gauge with you that has an appropriate range for this type of tire.
I go for that Minimalist Camping, we came from a Casita so we were prepared for what we needed. All being said, yes there will be some items that you will want to have, but I have found that miss it once you may not need it, but miss it twice you might consider it. My last purchase was a "Honey Pot" having to unhook and go to the dump station is not that much fun. I can say that our RAM 4x4 truck was packed full of stuff when we went to pickup our new trailer, I was wondering a smaller vehicle might be a problem for some.
trainman
Great info!  We watched the Oliver E2 YouTube Delivery walkthrough video recorded two weeks ago and decided we are going to purchase a torque wrench in advance of pick up. Will this torque wrench work?  The video doesn’t say the size (1/2”, 1/4” etc) needed? Do you recommend a particular one?
Thanks Much, M&K
1/2-inch Drive Click Torque Wrench, 10~150 ft./lb
Hawaii / 2021RAM 2500 Power Wagon 6.4L / Elite II ~Delivery May 2022
OTT says they're setting them at 55 for delivery now.
That’s reasonable.  I used 55 for a couple of years and have settled on 50 now for the last year or so.
Looks good to me.
Since I always carry mine with me while towing I chose an inexpensive one so that I would not be terribly disappointed when/if it broke.  I check it a couple time a year to make sure that it is still within a reasonable zone of calibration.  The one I bought for the Ollie is THIS.  Is it the best - no.  Is it precise - probably not but it is good enough for the job at hand (lug nuts).
I run 60 psi., but when we received our trailer they were it 80 psi. I also let the helium out and put air back in, just don't want to deal with it down the road. I personally think it's just a selling gimmick for auto dealership to make money, I know I spent 35 years at one. If it's your thing them do it, it's neither a good, or bad thing for me.
trainman
It's N2, nitrogen. Helium would make the trailer lighter 🙂 And there is no need to get rid of it, just top up with regular air (which is 78% N2) as needed. I used to use nitrogen all the time, on airplanes. I agree it is a gimmick for normal cars.
6 hours ago, topgun2 said:
Looks good to me.
Bill,
Thank you very much!  M&K
TI carry a 1/2 inch allen wrench. Both water connection for hose hookups (city water and fresh water connections) work loose and leak fairly regularly. Fitting that I tighten is inside fitting where water enters trailer.
