Jps190 Posted May 22, 2023 Posted May 22, 2023 I am going to change out the grease zerks for 45 degree fittings. What size are the fittings and are they all the same size? thanks, John 1 John and Kim 2021 GMC Sierra 2500 AT4 6.6L Duramax 11350 GVWR 3048lb Payload 2021 Oliver Elite II. Hull #887. 600 Watt Solar Mod
Moderator+ ScubaRx Posted May 22, 2023 Moderator+ Posted May 22, 2023 The grease fitting ends are all the same but the thread sizes differ. Some are SAE, some are metric. Take one with you when you go to buy the new ones. 3 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Frank C Posted May 22, 2023 Posted May 22, 2023 Mine were all 1/4”-28 thread size (2019 Elite II with the Dexter EZ Flex suspension) and I switched them to the 45 degree angled type. But as Steve mentioned above, some Oliver trailers have metric thread fittings (an M6x1 thread size). 1 2
Jps190 Posted May 22, 2023 Author Posted May 22, 2023 OK, so on my 2021 the ones between the wheels were 6mm and the outside ones were 1/4. Sure would be nice if they lined up where you wanted when they bottomed out. 🤷♂️ 2 John and Kim 2021 GMC Sierra 2500 AT4 6.6L Duramax 11350 GVWR 3048lb Payload 2021 Oliver Elite II. Hull #887. 600 Watt Solar Mod
routlaw Posted May 22, 2023 Posted May 22, 2023 Speaking of zerks, just went through the process of lubing all of mine this past few days, well all but one. Both wheels were off the ground for that side but no amount of pressure from the grease gun would push grease into the zerk. Took the zerk out, cleaned it and made sure the pin was not frozen and able to recede but even this made no difference. Anyone ever run into this situation? If so how did you finally get it to take grease? Thought about shooting some Fastbreak into the seams of the bushing thinking the grease in that area had dried hard. Thanks Legacy Elite II #70
rideandfly Posted May 22, 2023 Posted May 22, 2023 John & Kim, A thin flat washer will probably change where the fitting points when it bottoms out. I pointed all of the pin straight zerks outward, the grease gun I have works OK with them. routlaw, Did the fitting take grease easily when the EZ Flex was installed? The single pin port should be pointing horizontal to pump grease in the bushing with weight on the wheel. If the port is pointing up or down, you may not be able to pump grease in with weight on or off the wheel, depends on which way the port is pointing. Try with weight on the wheel, too. 3 Bill 2015 LE2 #75
routlaw Posted May 22, 2023 Posted May 22, 2023 @rideandfly yeah I tried it both ways with weight initially off the wheel, then lowered and tried again all to no avail. The pin points out straight or horizontally though. To the best of my recollection it took grease when new and installed. Thanks. I suppose anther option would be to disassemble that joint, lube and reinstall. 1 Legacy Elite II #70
Tom and Doreen Posted May 22, 2023 Posted May 22, 2023 Just did mine yesterday: The issue that I have is that the grease doesn't seem to travel through the entire shackle link to the opposite end on a couple of the shackle links, it just oozes out of the first joint. I also found that one of the zerks behind the hanger on top of the equalizer on one side had never been touched by a grease gun, there was no evidence of any grease on the zerk at all. 1 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
Moderators topgun2 Posted May 23, 2023 Moderators Posted May 23, 2023 15 hours ago, Tom and Doreen said: The issue that I have is that the grease doesn't seem to travel through the entire shackle link to the opposite end on a couple of the shackle links, it just oozes out of the first joint. See the pic post by RideandFly above - given that the grease comes out via the hole in the bolt - it is very likely that even though your grease is only oozing out of the first joint, it is still doing its job. However, if it was me - I'd first make sure that the second joint was VERY clean and that there was no evidence of that bolt or area being bent or out of alignment. And, I'd put grease in there again. God luck! Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
ADKCamper Posted May 23, 2023 Posted May 23, 2023 If you can't get the 45-degree zerks to cooperate, something like the following 90-degree adapters on the end of your straight grease gun hose/fitting might work for you... https://locknlube.com/collections/greasing-accessories/products/locknlube-90-degree-grease-coupler-adapter# or https://locknlube.com/products/locknlube-simple-90-coupler?variant=8158561206327 Of course they're also available on Amazon 🙂 The width at the business end of the first adapter is about 1-3/16". The width of the 2nd "simple 90" adapter is about 2-1/16". The Locknlube site wants $16.99 for the first (left photo), and $10.99 for the second (right photo). 4 Tom & Holly 2018 Oliver Legacy Elite #409 - 320W rooftop solar, 300Ah Epoch LiFePO4, Victron Smart Solar MPPT 100/30 charge controller, Progressive Dynamics PD4060CVS 60Amp Lithium-capable Converter, Xantrex PROwatt SW 2000 inverter, Bulldog HD1213-0656 Shocks; Tow Vehicle: 2017 Silverado 1500, 5.3L Gas, 4x4 Z71, Dbl Cab, Std Bed.
Geronimo John Posted May 23, 2023 Posted May 23, 2023 Serrated bolt heads that have been torqued (vs. torquing the nut side) will often have stripped out their mounting hole allowing them to spin. Same problem solved for the EZ flex center bolt. Are you certain that the grease holes have remained horizontal? GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Imelda Posted June 11, 2023 Posted June 11, 2023 I am trying to replace mine with the 45 degree zerks. I am having a hard time getting first old ones out to replace them. The nut part looks like it may be getting stripped when I tried a channel lock on it to screw it out. I am assuming they are screwed in and not driven in and I have to screw them out. What size wrench should I be trying? 1/4 inch 1
rideandfly Posted June 11, 2023 Posted June 11, 2023 9MM wrench works on the zerk fitting with 1/4” threads. 3 Bill 2015 LE2 #75
