On 9/12/2025 at 12:55 PM, jd1923 said:
We moved back to our AZ home seven years ago after living for 12 years back and forth between two homes, where my tools were spread between the two and my truck. On Craig's I found large stand-up Snap-on toolbox and was lucky to find a huge, well made workbench setup that Adam and I disassembled to move and rebuilt it to fit a custom L-shaped layout around 2 stalls of our 3-car garage, the center stall being my workspace. I also found a used Tuff Shed for storage, so my garage would be solely an auto workshop, not junked up with storage items.
I installed other standing toolboxes and cabinets, enough room for a major 45-year collection of hand tools and spare parts. Then I emptied every hand-carry toolbox into the larger stationery toolboxes. During a winter cold-spell I spent days sorting our every box and package I hade with nuts & bolts, auto parts, electrical and plumbing parts. , etc. I bought a case of blue plastic single-gang electrical boxes (cheap effective storage bins) to hold all the small screws, nuts & bolts, nails, crimp parts..., drawers full of them in mounted file cabinets.
For years now to the present, I know where every tool and most spare parts are located. I return all tools to where they belong daily, unless I'm in the middle of a job I will continue the very next day. Spending considerable time in organizing your tools is well worth it. I get repairs done now in half the time, not having to hunt for parts and tools!
In getting ready to work, climbing under truck or trailer, I think a hard 5-10 minutes and collect part & tools needed in flat plastic trays that I lay on the ground where I'm working. The other thing I bring, since I/we will always forget something is my phone. With Chris' office just inside our home from the garage entrance, she's nearby and often happy to help. 😂 She'll come out to hand me a tool or two, knowing its easier for her to do so vs. what it takes me to get off a hard garage floor, and then climb down again. I do mean the word 'climb' as the downs and ups are not as easy as they used to be! 🤣
We all prefer to work preventive maintenance at home vs. getting stuck on the road. I have enough extras that I've assembled a small dedicated toolbox and a plastic parts box for the Oliver. They sit in the bottom of my large truck toolbox along with a 3/4" breaker bar, cheater bar and other long items. Proud to be keeping our truck and trailer in good maintenance so that these tools just sit ready, and have not been yet needed, 124 overnights in two years with our Oliver!
Hope to never need them, but I have what we need to change tires, bearings, leaf springs or do a truck repair, like replacing an alternator or water pump on the road. Now that we've upgraded to Alcan Leaf Springs, I just removed the spare set of 1750 LB springs from the TV. The Alcans are not going to fail in my lifetime, though I do have tools with to replace wet bolts/bushings or most anything else!
John, would love to know what parts you keep in that tool box. I’m on a 4 week run in our trailer and odds are, I’ll wish I had something that is needed.
2017 Oliver Elite II Hull 292
2018 Nissan Armada
Tampa, FL
  • 4 months later...
On 9/19/2025 at 3:45 PM, Mike and Carol said:
We were at ALCAN this morning.  They do good work!
When getting the D52's does Alcan run the brake line in or along the outside of the axle?
Do they use "high dollar" water proof connections?
Do they check what wire gauge was used before connecting to the new 12" brakes?
My understanding is that the axles come prewired with the brakes.  Like the smaller axles I assume that the brake wires are run inside.  During my torque sessions underneath the trailer with the new springs I didn’t see any wires run along the outside.  Mike
  • Sad 1
I was trying to find specs on the brakes.  What I found is the it didn't matter if it was 12"  or 10"  brakes.  Dexter shows 12 gauge to run 2 or 4 brakes from the tongue of the trailer.  I do not think the dexter wires coming out of each of  10" brakes are 12 gauge the look more like 14 or 16 gauge.  Other places such as trailer shows 14 gauge to each brake.
One 12 gauge from the tongue could easily  be split into 4 separate 14 gauge wires.   I just do not know how and where Oliver did this.  If there are problems I would say it was Oliver design problems and not Alcan upgrade.
Edited by 2008RN
Dexter pre-wires the brake wires inside the axel. Oliver only connects their wiring to the Dexter wiring.
Thanks guys.  I sort of suspected as much.  But was wishing the other way.
I recall they are:
  • D35 Axles have 10 X 2.5" shoes.
  • D52 Axles have 12" X 2" shoe.
  • Both magnets sets pull a nominal 3 amps each drum = 12 amps for LE2.
  • Wiring per above is the same (Run thru the axle)
Edited by Geronimo John
When I replaced my factory D35 axles with D52's last year, the brake wiring was an option.  Based on other OTTO experience’s repairing the brake wiring inside the axles, I chose pigtails for each hub and used hose clamps to attach PVC conduit to the axle and ran the wiring through the conduit.  Was that the right thing to do?  Time will tell!
Was it done at Alcan or DIY?
I'm thinking of bringing to Alcan a pre-cut section of 1/2" CPV, and some zipties and a tube of clear silicone to seal it up.  And a clear sketch of where "on the back of the front axle" is.  🙂
For previous Alcaners, were they amenable to such an arrangement if they knew about it ahead?
Any better ideas would be appreciated.
Thanks
Just wire it as designed. I'm surprised to see issues with the OEM wiring internal to the axles. How many have rewired due to actual failure of the wiring vs. worry.
When I removed our 10-year-old D35 axles there was nothing wrong with the internal brake wiring. I have a old dual axle flat bed trailer that we used for hauling dirt bikes and our SxS. I restored it 8 years ago, all 100% new wiring and I added brakes on one axle since it did not have brakes. I ran the wire across inside the axle as designed. Anything exterior, especially something "wire-tied" can be easily torn of from road debris!
If my brand new D52 axles ever get shorted brake wiring, which is an extremely low likelihood, I will run new wire right down the axle where it belongs. Just my opinion. 😎
I rewired my D35 due to intermittent brake disconnects.  I know of one other owner who did the same (and first told me of the solution).  When I pulled the wires there were several spots where the insulation was gone.  There was about 3 or 4 feet of excess wire and my theory is that it was bunched up causing it to rub inside the axle.  Once a new wire was zip tied to the outside of the axle my intermittent disconnect disappeared.  It’s obviously not a common problem and I wouldn’t change anything or rerun the wires if there were no issues.  I’ve now got the D52 axles and they are wired however the factory wired them.  Mike
Edited by Mike and Carol
A local shop that Dexter recommended handled the installation for $400.  The axles were $883 each with 2200 pound springs and EZ Lube hubs and I supplied new lug nuts.
Do you recall the wire size Dexter used internally on your new D52 axles?  12 AWG?
I've got an old set of D52 axles and they have 14 AWG inside the axles. Fed with 10 AWG from the trailer connector, though.
I believe Chris is correct regarding these wire gauges. Certainly the hitch wiring on the BLUE wire is 10 AWG. Given each individual trailer brake pulls 3A, then 14 AWG is sufficient, too bad they do not run wire, internal to the axles, with heavy rubberized insulation!
You can see in my photo, the junction under the front dinette seat where the trailer wiring harness is split. It appears it connects 10 to 10 AWG on the Blue wire with a yellow/10 AWG butt connector. OTT also uses a yellow 3M ScotchLok connecting a green wire. I'm guessing the green wire powers the Oliver brake lights.
They must split the 10 AWG blue wire again just inside the streetside wheel-well where there are two wires to power the brakes of each axle. My guess is they would use 12 AWG there, then connecting to the 14 AWG Dexter axle wiring going to each of 4 wheels. 😎
Thanks Chris & John.   I plan to crawl under my Oliver soon and check the wiring.   I may pull it out of the D35 axles to inspect.   John Davies had significantly undersized brake wiring in his 2017 Oliver.
https://olivertraveltrailers.com/forums/topic/2685-how-to-brake-wiring-is-undersized-some-answers-and-partial-solution/
Edited by Hokieman
Typo
Yep, it was John D's post that caused me to "ask the question".  Thanks for crediting him as the first finder on this topic.
We are in Grand Junction at James Rob State Park. Appointment with Alcan in AM. This is the start of a 6 week trip and we have a refrigerator and freezer full of food. Wonder if it’s reasonable to ask to plug in during service. We have large cooler and can unpack.
 Hull#1047 "Saunter"
Solar Pro 390 aH Lithionics
2022 Ram 1500 5.7L Hemi
It certainly is! They are so customer oriented, my bet is their answer would be, "Yes Sir, no problem!" (You have a 30A to 15A dog-bone, right?)
We do have 15-30 amp dog one. I will ask them in morning and if it’s an issue we can unpack pretty quickly
 Hull#1047 "Saunter"
From all the posts about Alcan, I don't recall any of their installs taking more than two hours.  Likely your two additional food storage boxes will not warm up all that much if you just keep them in the shade.
Agree.  They are pretty quick.  I don’t know which fridge you have, we left ours on propane.  Probably should have switched to 12v, but the ALCAN guys didn’t seem to care.  It was an open bay and they were done in a couple of hours.  We drove over from James Robb State Park, dropped off at about 7:50, went to breakfast, walked around Bass Pro Shop and got a text just before 10:00 that they were done.  We then drove down to Ridgway State Park near Ouray for a relaxing stay before heading down Highway 550 to Durango.  Mike
SERVAL owners have done the same thing.  We also have the first appointment of the day and will follow the lead.  Where's breakfast there that seems to be a hit?
We went to Dream Cafe on Main Street in Grand Junction.  It was good.
Thanks Mike.  That's the one.
Sometimes it is nice to plant happy thoughts.  I sent this to June:
